    4. [Vorlage] Spotify Skript
      crunchip Forum Testing Most Active @dos1973 last edited by
      @dos1973 ich hatte das damals so, muss aber angepasst werden
       * HTML-Playlist:
       * Quelle: https://github.com/twonky4/ioBroker.spotify-premium/wiki/Html-Playlist
       * https://forum.iobroker.net/viewtopic.php?f=21&t=8173&hilit=spotify&start=440#p183687
       * Setup
      const STATE_PATH = 'javascript.'+ instance + '.' + 'spotify.spotify-support.';
      createState(STATE_PATH + 'playListHtml', '', false);
      function refreshPlayList() {
      	var current = getState('spotify-premium.0.playlists.playlistList').val;
      	var ids = getState('spotify-premium.0.playlists.playlistListIds').val.split(";");
      	var strings = getState('spotify-premium.0.playlists.playlistListString').val.split(";");
      	var html = '<table class="playlistList">';
           * Sort Arrays
          var arrTemp = [];
          for (let j = 0; j < strings.length; j++) {
              arrTemp.push(strings[j] + ";" + ids[j]);
          arrTemp.sort();
          idsFinal = [];
          sourceFinal = [];
          for (let k = 0; k < arrTemp.length; k++) {
              let arrLine = arrTemp[k].split(';');
              sourceFinal.push(arrLine[0]);
              idsFinal.push(arrLine[1]);
           * Build Playlist
      	for (var i = 0; i < idsFinal.length; i++) {
      	    var playList = sourceFinal[i].split("–");
      	    var currentList = (current == idsFinal[i]) ? ' id="currentList"' : '';
      		html += '<tr onclick="vis.setValue(\'spotify-premium.0.playlists.playlistList\', ' + '\'' + idsFinal[i] + '\');">';
          		html += '<td class="spotify-playlist-title"' + currentList + '>';
          		    if(current == idsFinal[i]) html += '<div style="position:absolute;right:10px;width:30px;height:30px;"><img style="width:150%;" src="/vis.0/main/audio_volume_current.png"></div>';
                  	html += '<div>' + playList[0] + '</div>';
                  	if(playList[1] !== undefined) html += '<div class="albumName">Album: ' + playList[1] + '</div>';
          		html += '</td>';
      		html += '</tr>';
      	html += '</table>';
      	 * Script für automatisches Scrollen des aktuellen Titels
      	 * https://forum.iobroker.net/viewtopic.php?f=30&t=18222&p=190991&hilit=javascript+experten#p190365
          html += '<script>';
      	    html += 'var el = document.getElementById("currentList");'; // ID von dem aktuellen DIV in der TABLE oben
      	    html += "el.scrollIntoView(true);"; //true = Position oben / false = Position unten (Achtung hier Id:currentArtist angeben)
      	html += '</script>';
      	setState(STATE_PATH + 'playListHtml', html, true);
      on('spotify-premium.0.playlists.playlistList', refreshPlayList);
      on('spotify-premium.0.playlists.playlistListIds', refreshPlayList);
      on('spotify-premium.0.playlists.playlistListString', refreshPlayList);
      refreshPlayList();
       * HTML-Tracklist:
       * Quelle: https://github.com/twonky4/ioBroker.spotify-premium/wiki/Html-Tracklist
       * https://forum.iobroker.net/viewtopic.php?p=151165#p151165
      createState(STATE_PATH + 'trackListHtml', '', false);
      function refreshTrackList() {
      	var current = getState('spotify-premium.0.playbackInfo.playlist.trackList').val;
      	var source = getState('spotify-premium.0.playbackInfo.playlist.trackListArray').val;
      	var html = '<table class="tracklistList">';
          	for (var i = 0; i < source.length; i++) {
          		html += '<tr onclick="vis.setValue(\'spotify-premium.0.player.playlist.trackNo\', ' + i +');">';
              		html += '<td>';
              			 * Hier muss man dem aktuellen Track und/oder Artist eine ID vergeben
                  		var currentSong = (current == i) ? ' id="currentSong"' : '';
                  		var currentArtist = (current == i) ? ' id="currentArtist"' : '';
                  		if(current == i) html += '<div style="position:absolute;left:0px;width:40px;height:40px;"><img style="width:100%;" src="/vis.0/main/audio_volume_current.png"></div>';
                  		html += '<div class="spotify-tracklist-title"' + currentSong + '>' + source[i].title + '</div>';
                          html += '<div class="spotify-tracklist-artist"' + currentArtist + '>' + source[i].artist + '</div>';
                          //log(source[i].artist); // (sollten alle Artisten auflisten in der Log-Ausgabe)
              		html += '</td>';
          		html += '</tr>';
      	html += '</table>';
          html += '<script>';
      	    html += 'var el = document.getElementById("currentSong");'; // ID von dem aktuellen DIV in der TABLE oben
      	setState(STATE_PATH + 'trackListHtml', html, true);
      on('spotify-premium.0.playbackInfo.playlist.trackList', refreshTrackList);
      on('spotify-premium.0.playbackInfo.playlist.trackListArray', refreshTrackList);
      refreshTrackList();
      css
      .fixScroll > .vis-widget-body {
          position: absolute; /*Wichtig, muss absolute sein */
          width: 430px; /* hier deine Breite von deinem Widget */
          height: 470px; /* hier deine Höhe von deinem Widget */
          overflow-y: scroll; /* hier wird der Container zu einem scrollbaren Bereich */
      .fixScroll1 > .vis-widget-body {
          width: 410px; /* hier deine Breite von deinem Widget */
      .playlistList {
          width: 100%;
          padding-left:20px;
      .playlistList tr td {
          padding: 3px 0;
      #currentList {
          color: rgba(108,255,82,1);
      .spotify-playlist-title {
          padding: 0px 10px;
          color: rgba(255,255,255,1);
      .spotify-playlist-title > .albumName {
          font-size: 0.9em;
          color: rgba(255,255,255,0.8);
      .tracklistList {
          width: 100%;
          padding-left: 35px;
      .tracklistList tr td {
          padding: 3px 0;
      .spotify-tracklist-title {
          padding: 0px 5px;
      .spotify-tracklist-artist {
          padding: 0px 5px;
          font-size: 0.8em;
      #currentSong  {
      #currentArtist {
      	color: rgba(108,255,82,0.6);
        Leute, Vielen Dank -
        sobald ich zH teste ich das...
          Hi, das sieht bisher gut aus, muss noch etwas basteln ... aber die Darstellung passt. Ganz toll 🙂
            Coffeelover last edited by
            @dos1973 Hältst du uns nach deinem Basteln auf Stand? Würde das gerne weiter verwenden...
              Ja, ich habe angefangen, bin aber leider nicht zu Hause, d.h frühestens WE gehts weiter...
                Coffeelover @dos1973 last edited by
                @dos1973 Keine Eile - bei mir wird es vor dem nächstem Wochenende sicher auch nichts.
                  skokarl @wendy2702 last edited by skokarl
                  @wendy2702 sagte in [Vorlage] Spotify Skript:
                  @dos1973 sagte in [Vorlage] Spotify Skript:
                  HI Leute,
                  ich suche mir inzwischen einen Wolf. Habt ihr den Adapter laufen, oder das anfängliche Script.
                  Ich suche eine einfach Trackliste, so wie Sie hier x-mal gezeigt wird, aber finde nicht funktionierendes. Ich kann nur die aus dem Adapter nutzen, aber diese is mit zu "vollgepackt"
                  Kann sich bitte einer erbarmen. Danke
                  Ich weiß nicht genau worauf du hinaus willst. Mein View sieht aktuell so aus:
                  Da läuft kein zusätzliches Script im Hintergrund.
                  wendy2702,
                  stellst Du mir mal die View zur Verfügung ?, oder ist das die von weiter oben ?
                  • wendy2702
                    Glaube es ist die von weiter oben....
                    Hast du mal nen link zu dem Beitrag ?
                      der Post 583.
                      Da Du ja so fit bist, 😬 , mit Sonos One Boxen geht Spotify nicht, oder ?
                      Ich würde nämlich lieber die nehmen als die originalen Alexa Boxen, schon alleine wegen der Optik. Und Vattenfall hat mir ein paar geschenkt 😎
                      • wendy2702
                        wendy2702 @skokarl last edited by wendy2702
                        @skokarl sagte in [Vorlage] Spotify Skript:
                        Danke für die Blumen aber da verwechselst du mich.
                        Bin aktuell am Tablet zu dumm den Post zu finden ☺
                        EDIT: Spotify View neuer Upload spotify_view.txt
                        Soweit ich weiß geht Spotify mit Sonos nicht. Ich nutze Yamaha MusicCast ... die funktionieren zum Glück.
                          Spotify_View.txt
                          geht leider nicht.
                          • wendy2702
                            Hm...
                            Habe ich am Ipad gemacht. Vielleicht liegt es daran.
                            Bin erst morgen wieder am PC. Schreibe mir doch bitte einen Erinnerungs Ping per Chat 😎
                              so schaut jetzt bei mir aus...
                              abhängig vom Cover kommt etas Farbe rein 🙂
                              Playlisten:
                              Device Auswahl
                              ich habe nur ein Problem, bei der Playlist.
                              wenn ich einen Titel antippe, dann wird der oben drüber abgespielt?!
                              Es wird immer der Titel über dem Titel, der eingentlich gewählt wurde, abgespielt.
                              Hat hierzu jemand vielleicht eine Idee.
                              sigi234 Shakall74 2 Replies Last reply Reply Quote 1
                              • wendy2702
                                @skokarl Sorry hat wegen Krankheit bisschen gedauert bis ich wieder an den PC gekommen bin.
                                Habe meinen View jetzt hier https://forum.iobroker.net/post/245417 nochmal neu hochgeladen.
                                  Danke Wendy2702, gute Besserung. Hat sich aber für mich erledigt, mit dem Fully Browser und dem Fully Adapter kann man direkt die Spotify App auf dem Tablet von der View aus starten......ein Traum 🤗😁👍
                                    sigi234 Forum Testing Most Active @dos1973 last edited by
                                    @dos1973
                                    Cool, hast du ev. die View für mich?
                                      Herzog97944 @skokarl last edited by
                                      @skokarl Hallo, kannst Du mal erklären wie man das im Fully Browser einstellt. Damit man die Spotify App direkt aus der VIS starten kann. Über eine RücKmeldung freue ich mich.
                                      MIchael
                                      • wendy2702
                                        wendy2702 @Herzog97944 last edited by
                                        @Herzog97944 sagte in [Vorlage] Spotify Skript:
                                        MIchael
                                        Schau mal hier: https://forum.iobroker.net/topic/21266/fully-launcher-und-spotify/17
                                        • Hiltex
                                          Hiltex @xbeejayxhotmail.com last edited by Hiltex
                                          @xbeejayxhotmail-com sagte in [Vorlage] Spotify Skript:
                                          Ich habe mir erlaubt die Dateien einmal auf einem github repo abzulegen.
                                          https://github.com/SBajonczak/ioBroker.SpotifyUi
                                          Eventuell hilft es ja weiter?
                                          Sieht irgendwie komisch aus, wenn man das importiert...
                                          Es sieht so aus, als würde da einiges an CSS-Code fehlen. Ein Beispiel, das ich gerade gefunden habe, ist mdui-float. Woher kommt das denn?
                                            Herzog97944 @wendy2702 last edited by
                                            @wendy2702 Danke!
                                            1.0k
                                            javascript
                                            95
                                            745
                                            262346
