    4. [Aufruf] ZigBee CC253x Adapter Version 0.10.x
    • MyzerAT
      MyzerAT last edited by
      @Asgothian sagte in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
      //github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
      ich bekomme dies wenn ich deinen link ausführe
      admin.0	2019-03-24 20:55:38.201	info	successful connection to socket.io from ::ffff:192.168.0.2
      host.RDJL_Home	2019-03-24 20:55:27.101	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      iobroker	2019-03-24 20:55:26.987	info	exit 0
      iobroker	2019-03-24 20:55:26.902	info	npm ERR! /root/.npm/_logs/2019-03-24T19_55_26_881Z-debug.log
      iobroker	2019-03-24 20:55:26.902	info	npm ERR! A complete log of this run can be found in:
      iobroker	2019-03-24 20:55:26.879	info	ERR! code ENOLOCALnpm ERR! Could not install from "../github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes" as it does not contain a package.json file.
      iobroker	2019-03-24 20:55:26.876	info	npm
      iobroker	2019-03-24 20:55:18.549	info	npm install //github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes --production --save --prefix "/opt/iobroker" (System call)
      iobroker	2019-03-24 20:55:17.975	info	install //github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
      iobroker	2019-03-24 20:55:17.472	info	url "//github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes"
      • Asgothian
        Asgothian Developer @MyzerAT last edited by Asgothian
        @MyzerAT
        Hmm.. gerade geschaut.. bei mir gehts.
        • MyzerAT
          https://github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
          was meint er damit ?
          iobroker	2019-03-24 21:48:16.058	info	bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
          iobroker	2019-03-24 21:48:16.057	info	WARN
          iobroker	2019-03-24 21:48:16.057	info	npm
          • Asgothian
            @MyzerAT Da wird ueber eine nicht erfüllte abhängigkeit berichtet. Ist aber kein Problem.
            A.
            • MyzerAT
              @Asgothian
              ist es das ?
              zigbee.0	2019-03-24 22:06:28.438	info	Attempting to configure device 0x00158d000192d13d
              zigbee.0	2019-03-24 22:06:03.797	info	Attempting to configure device 0x00158d000192d13d
              zigbee.0	2019-03-24 22:05:54.685	info	Configure on Message active for 300 sekunden
              • Asgothian
                @MyzerAT ist was das ?
                • MyzerAT
                  deine änderung , diese log kenne ich nicht von den Eurotronic Thermostaten
                  • Asgothian
                    @MyzerAT Das ist teil der Änderung.Allerdings sollten nicht so viele Nachrichten kommen
                    • MyzerAT
                      nicht viele ist ein wenig untertrieben ^^
                      zigbee.1	2019-03-24 22:42:47.831	info	new dev 0x00158d000201a358 38941 lumi.sensor_switch
                      info.0	2019-03-24 22:42:26.308	info	Popup-News readed...
                      zigbee.1	2019-03-24 22:41:17.032	info	Zigbee: allowing new devices to join.
                      admin.0	2019-03-24 22:41:15.092	info	successful connection to socket.io from ::ffff:192.168.0.2
                      zigbee.0	2019-03-24 22:39:47.271	info	Zigbee: allowing new devices to join.
                      sonoff.0	2019-03-24 22:37:28.731	info	Client [DVES_3E4B4242] connected with secret 1553463448730_4384
                      sonoff.0	2019-03-24 22:37:28.219	info	Client [DVES_3E4B4242] connection closed: closed
                      javascript.0	2019-03-24 22:37:20.996	info	script.js.common.Heizung.Zigbee_Badezimmer_Heizung: **** Fenster Badezimmer geschlossen
                      javascript.0	2019-03-24 22:37:20.995	info	script.js.common.Klima.Aussen_5_Grad_unter_Innentemperatur: ********* stop intervall
                      sonoff.0	2019-03-24 22:35:15.514	info	Client [DVES_3E4B4242] connected with secret 1553463315514_4830
                      sonoff.0	2019-03-24 22:35:14.598	info	Client [DVES_3E4B4242] connection closed: closed
                      zigbee.0	2019-03-24 22:34:59.674	info	configure on Message closed
                      zigbee.0	2019-03-24 22:34:42.611	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:34:40.392	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:34:40.372	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:34:28.583	info	Zigbee: allowing new devices to join.
                      zigbee.0	2019-03-24 22:34:21.836	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:34:20.023	info	new dev 0x0017880104101f75 63604 LWB010
                      zigbee.0	2019-03-24 22:34:19.702	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:34:19.688	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:34:12.491	info	new dev 0x000d6ffffebb1e78 49023 TRADFRI signal repeater
                      zigbee.0	2019-03-24 22:33:59.449	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:33:58.961	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:33:58.911	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:33:39.872	info	new dev 0x000d6ffffe9f8c0d 48832 TRADFRI signal repeater
                      zigbee.0	2019-03-24 22:33:38.664	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:33:38.253	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:33:38.159	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:33:17.942	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:33:17.617	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:33:17.471	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:33:12.878	info	Successfully configured 0x00158d000192d13d SPZB0001
                      zigbee.0	2019-03-24 22:33:10.026	error	Zigbee publish to '0x00158d000192d13d', hvacThermostat - write - [{"attrId":16387,"dataType":41,"attrData":1800}] - 1 failed with error Error: AF data request fails, status code: 205. No network rout
                      zigbee.0	2019-03-24 22:33:09.123	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:33:06.973	info	new dev 0x000d6ffffe9f907c 33053 TRADFRI signal repeater
                      zigbee.0	2019-03-24 22:32:57.099	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:32:56.849	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:32:56.703	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:32:48.425	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:32:36.336	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:32:36.158	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:32:36.042	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:32:35.113	info	new dev 0x000d6ffffe9cc0e8 16053 TRADFRI signal repeater
                      zigbee.0	2019-03-24 22:32:27.711	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:32:15.519	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:32:15.425	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:32:15.233	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:32:07.016	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:32:02.751	info	new dev 0xd0cf5efffeea2f74 33127 TRADFRI signal repeater
                      zigbee.0	2019-03-24 22:31:54.771	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:31:54.734	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:31:54.476	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:31:46.308	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:31:34.033	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:31:33.954	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:31:33.724	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:31:31.271	info	new dev 0x000d6ffffe9c27d9 46341 TRADFRI signal repeater
                      zigbee.0	2019-03-24 22:31:25.626	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:31:13.347	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:31:13.240	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:31:12.976	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:31:04.926	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:30:52.642	info	Attempting to configure device 0x00158d000192d1ae
                      zigbee.0	2019-03-24 22:30:52.377	info	Attempting to configure device 0x00158d0001922cdf
                      zigbee.0	2019-03-24 22:30:52.209	info	Attempting to configure device 0x00158d0001922dcd
                      zigbee.0	2019-03-24 22:30:44.206	info	Attempting to configure device 0x00158d000192d13d
                      zigbee.0	2019-03-24 22:30:19.556	info	Attempting to configure device 0x00158d000192d13d
                      • Asgothian
                        @MyzerAT
                        In der Objektansicht - hat der Thermostat nen orangen oder blauen tag ?
                        A
                        • MyzerAT
                          gar keinen
                          • Asgothian
                            @MyzerAT dann hast du keinen Upload gemacht
                            A
                            • MyzerAT
                              wusste ich nicht das ich den auch machen muss, aber jetzt
                              ist das statt der FM die früher immer kam?
                              • Asgothian
                                Asgothian Developer last edited by
                                ja.. die andere Meldung kommt auch noch weg.
                                A.
                                • MyzerAT
                                  also nach ein paar mal drauf drücken auf das orange Symbol , sind nun alle Thermostate "Successfully configured " SUPER, thx @Asgothian
                                  • Asgothian
                                    @MyzerAT
                                    Der Trick sollte sein:
                                    1mal drücken, an jedem Thermostat z.bsp. Die solltemperatur verstellen, dann ist es sauber configured.
                                    • MyzerAT
                                      ich werde es beobachten, eine Verbesserung ist es jedenfalls! thx für deine Tolle Arbeit!!!
                                        Wildbill @Asgothian last edited by Wildbill
                                        Installation von hier:
                                        Hi, erstmal Danke für die neue Version. Ich habe eben die Möglichkeit gefunden, sie zu installieren. Parallel habe ich dem Stick eine neue Firmware gegönnt von hier:
                                        https://github.com/Koenkk/Z-Stack-firmware/blob/dev/coordinator/max_stability/CC2531/CC2531_MAX_STABILITY_20190315.zip
                                        Die max_stable soll dafür sorgen, dass das Netz möglichst stabil läuft und der Stick nur mit 5 Routern redet und der Rest dann mit denen.
                                        Aktuell habe ich nun 17 Lampen, 5 Bewegungsmelder (die habe ich wieder manuell eingefügt), 2 Remotes und einen Dimmer angelernt. Alles Tradfri bis auf eine Innr E14.
                                        Es scheint alles zu laufen und die Fehlermeldungen beim Start waren die Üblichen bis alles stabil ist. Im Adapter sind nun alle End devices als konfiguriert angezeigt. Nun schauen wir mal, ob, und wie lange das so läuft.
                                        BTW, ich habe heute nach einigem Lesen, auch bei Koenkk mal das Queuing ausgeschaltet, da sich hier die Geister streiten. Hat da jemand hier schon Erfahrungen im Vergleich mit/ohne gemacht?
                                        Gruss, Jürgen
                                        Kleines EDIT: Interessanterweise sehe ich nun zum ersten Mal die End devices jeweils mit der Lampe (Router) verbunden, die ihnen funktechnisch am nächsten sind. Wenn auch mit Status 255 (OFF) aber das ist ja normal. Das war bislang auch nicht immer so gegeben.
                                          Matdos last edited by
                                          Also habe es drauf gemacht und bei mir wurden die orangen Fenster von selber blau mit dem Haken ohne das ich was machen musste.
                                          Bin jetzt überall durch und habe alles ausprobiert, soweit geht alles was noch nicht gut geht ist der Türsensor bei Selina hier musste ich 4 mal die Türe auf und zu machen bis er mal den richtigen Zustand hatte nach Betätigen vom Anlern Knopf hat der Aqara Sensor 4 mal geblinkt (so solls sein wenn er ein Netz erkannt hat) danach habe ich mind 15 mal hintereinander auf und zu gemacht ohne Fehler mal schauen ob das so bleibt.
                                          Hier glaube ich aber langsam das die HW kacke ist da der schon irgendwie von Anfang an Probleme macht🤔
                                          Was ich noch habe das er beim setzen vom Wert 32 immer ne Fehlermeldung bringt, das hat jetzt aber nix mit dem Update zu tun das war vorher schon.
                                            Matdos last edited by Matdos
                                            Habt ihr noch mehr verändert? Soll ich die 2 Steckdosen und 2 Temp Sensoren auch wieder anlernen und schauen ob Probleme auftreten oder erst mal nen Tag so beobachten ob alles sauber läuft?
                                            31.7k
                                            79.8k
                                            0.10.x adapter zigbee
                                            27
                                            373
                                            53430
