    4. [Aufruf] ZigBee CC253x Adapter Version 0.10.x
    • Asgothian
      Asgothian Developer @MyzerAT last edited by
      @MyzerAT ist was das ?
      • MyzerAT
        deine änderung , diese log kenne ich nicht von den Eurotronic Thermostaten
        • Asgothian
          @MyzerAT Das ist teil der Änderung.Allerdings sollten nicht so viele Nachrichten kommen
          • MyzerAT
            nicht viele ist ein wenig untertrieben ^^
            zigbee.1	2019-03-24 22:42:47.831	info	new dev 0x00158d000201a358 38941 lumi.sensor_switch
            info.0	2019-03-24 22:42:26.308	info	Popup-News readed...
            zigbee.1	2019-03-24 22:41:17.032	info	Zigbee: allowing new devices to join.
            admin.0	2019-03-24 22:41:15.092	info	successful connection to socket.io from ::ffff:192.168.0.2
            zigbee.0	2019-03-24 22:39:47.271	info	Zigbee: allowing new devices to join.
            sonoff.0	2019-03-24 22:37:28.731	info	Client [DVES_3E4B4242] connected with secret 1553463448730_4384
            sonoff.0	2019-03-24 22:37:28.219	info	Client [DVES_3E4B4242] connection closed: closed
            javascript.0	2019-03-24 22:37:20.996	info	script.js.common.Heizung.Zigbee_Badezimmer_Heizung: **** Fenster Badezimmer geschlossen
            javascript.0	2019-03-24 22:37:20.995	info	script.js.common.Klima.Aussen_5_Grad_unter_Innentemperatur: ********* stop intervall
            sonoff.0	2019-03-24 22:35:15.514	info	Client [DVES_3E4B4242] connected with secret 1553463315514_4830
            sonoff.0	2019-03-24 22:35:14.598	info	Client [DVES_3E4B4242] connection closed: closed
            zigbee.0	2019-03-24 22:34:59.674	info	configure on Message closed
            zigbee.0	2019-03-24 22:34:42.611	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:34:40.392	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:34:40.372	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:34:28.583	info	Zigbee: allowing new devices to join.
            zigbee.0	2019-03-24 22:34:21.836	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:34:20.023	info	new dev 0x0017880104101f75 63604 LWB010
            zigbee.0	2019-03-24 22:34:19.702	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:34:19.688	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:34:12.491	info	new dev 0x000d6ffffebb1e78 49023 TRADFRI signal repeater
            zigbee.0	2019-03-24 22:33:59.449	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:33:58.961	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:33:58.911	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:33:39.872	info	new dev 0x000d6ffffe9f8c0d 48832 TRADFRI signal repeater
            zigbee.0	2019-03-24 22:33:38.664	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:33:38.253	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:33:38.159	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:33:17.942	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:33:17.617	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:33:17.471	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:33:12.878	info	Successfully configured 0x00158d000192d13d SPZB0001
            zigbee.0	2019-03-24 22:33:10.026	error	Zigbee publish to '0x00158d000192d13d', hvacThermostat - write - [{"attrId":16387,"dataType":41,"attrData":1800}] - 1 failed with error Error: AF data request fails, status code: 205. No network rout
            zigbee.0	2019-03-24 22:33:09.123	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:33:06.973	info	new dev 0x000d6ffffe9f907c 33053 TRADFRI signal repeater
            zigbee.0	2019-03-24 22:32:57.099	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:32:56.849	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:32:56.703	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:32:48.425	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:32:36.336	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:32:36.158	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:32:36.042	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:32:35.113	info	new dev 0x000d6ffffe9cc0e8 16053 TRADFRI signal repeater
            zigbee.0	2019-03-24 22:32:27.711	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:32:15.519	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:32:15.425	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:32:15.233	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:32:07.016	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:32:02.751	info	new dev 0xd0cf5efffeea2f74 33127 TRADFRI signal repeater
            zigbee.0	2019-03-24 22:31:54.771	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:31:54.734	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:31:54.476	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:31:46.308	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:31:34.033	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:31:33.954	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:31:33.724	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:31:31.271	info	new dev 0x000d6ffffe9c27d9 46341 TRADFRI signal repeater
            zigbee.0	2019-03-24 22:31:25.626	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:31:13.347	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:31:13.240	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:31:12.976	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:31:04.926	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:30:52.642	info	Attempting to configure device 0x00158d000192d1ae
            zigbee.0	2019-03-24 22:30:52.377	info	Attempting to configure device 0x00158d0001922cdf
            zigbee.0	2019-03-24 22:30:52.209	info	Attempting to configure device 0x00158d0001922dcd
            zigbee.0	2019-03-24 22:30:44.206	info	Attempting to configure device 0x00158d000192d13d
            zigbee.0	2019-03-24 22:30:19.556	info	Attempting to configure device 0x00158d000192d13d
            • Asgothian
              @MyzerAT
              In der Objektansicht - hat der Thermostat nen orangen oder blauen tag ?
              A
              • MyzerAT
                gar keinen
                • Asgothian
                  @MyzerAT dann hast du keinen Upload gemacht
                  A
                  • MyzerAT
                    wusste ich nicht das ich den auch machen muss, aber jetzt
                    ist das statt der FM die früher immer kam?
                    • Asgothian
                      Asgothian Developer last edited by
                      ja.. die andere Meldung kommt auch noch weg.
                      A.
                      • MyzerAT
                        also nach ein paar mal drauf drücken auf das orange Symbol , sind nun alle Thermostate "Successfully configured " SUPER, thx @Asgothian
                        • Asgothian
                          @MyzerAT
                          Der Trick sollte sein:
                          1mal drücken, an jedem Thermostat z.bsp. Die solltemperatur verstellen, dann ist es sauber configured.
                          • MyzerAT
                            ich werde es beobachten, eine Verbesserung ist es jedenfalls! thx für deine Tolle Arbeit!!!
                              Wildbill @Asgothian last edited by Wildbill
                              @Asgothian sagte in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
                              Installation von hier:
                              https://github.com/asgothian/ioBroker.zigbee/tarball/Admin_Changes
                              Hi, erstmal Danke für die neue Version. Ich habe eben die Möglichkeit gefunden, sie zu installieren. Parallel habe ich dem Stick eine neue Firmware gegönnt von hier:
                              https://github.com/Koenkk/Z-Stack-firmware/blob/dev/coordinator/max_stability/CC2531/CC2531_MAX_STABILITY_20190315.zip
                              Die max_stable soll dafür sorgen, dass das Netz möglichst stabil läuft und der Stick nur mit 5 Routern redet und der Rest dann mit denen.
                              Aktuell habe ich nun 17 Lampen, 5 Bewegungsmelder (die habe ich wieder manuell eingefügt), 2 Remotes und einen Dimmer angelernt. Alles Tradfri bis auf eine Innr E14.
                              Es scheint alles zu laufen und die Fehlermeldungen beim Start waren die Üblichen bis alles stabil ist. Im Adapter sind nun alle End devices als konfiguriert angezeigt. Nun schauen wir mal, ob, und wie lange das so läuft.
                              BTW, ich habe heute nach einigem Lesen, auch bei Koenkk mal das Queuing ausgeschaltet, da sich hier die Geister streiten. Hat da jemand hier schon Erfahrungen im Vergleich mit/ohne gemacht?
                              Gruss, Jürgen
                              Kleines EDIT: Interessanterweise sehe ich nun zum ersten Mal die End devices jeweils mit der Lampe (Router) verbunden, die ihnen funktechnisch am nächsten sind. Wenn auch mit Status 255 (OFF) aber das ist ja normal. Das war bislang auch nicht immer so gegeben.
                                Matdos last edited by
                                Also habe es drauf gemacht und bei mir wurden die orangen Fenster von selber blau mit dem Haken ohne das ich was machen musste.
                                Bin jetzt überall durch und habe alles ausprobiert, soweit geht alles was noch nicht gut geht ist der Türsensor bei Selina hier musste ich 4 mal die Türe auf und zu machen bis er mal den richtigen Zustand hatte nach Betätigen vom Anlern Knopf hat der Aqara Sensor 4 mal geblinkt (so solls sein wenn er ein Netz erkannt hat) danach habe ich mind 15 mal hintereinander auf und zu gemacht ohne Fehler mal schauen ob das so bleibt.
                                Hier glaube ich aber langsam das die HW kacke ist da der schon irgendwie von Anfang an Probleme macht🤔
                                Was ich noch habe das er beim setzen vom Wert 32 immer ne Fehlermeldung bringt, das hat jetzt aber nix mit dem Update zu tun das war vorher schon.
                                  Matdos last edited by Matdos
                                  Habt ihr noch mehr verändert? Soll ich die 2 Steckdosen und 2 Temp Sensoren auch wieder anlernen und schauen ob Probleme auftreten oder erst mal nen Tag so beobachten ob alles sauber läuft?
                                  • MyzerAT
                                    habt ihr auch das Problem das die Thermostate nicht immer auf 0% gehen, ich versteh nicht warum, im Wohnzimmer habe ich zur Zeit 24°C und er steht auf 2% Problem ist das mein Sonoff 5v der die Therme ein ausschaltet, dann nicht off geht, weil über 0% als Heizaufforderung zählt
                                    • Asgothian
                                      Asgothian Developer @MyzerAT last edited by Asgothian
                                      @MyzerAT
                                      Das hat etwas mit der Mechanik der Thermostate zu tun. Er will auf 0% regeln, bekommt den Stößel aber nicht so weit gefahren wie er das beim anlernen nach der Montage getan hat. Das kann nur dadurch korrigiert werden das der Thermostat regelmäßig den schaltweg des Reglers neu ausmisst - was die Batterie schnell leer macht. Ich ignoriere Abweichungen unter 5% (sowohl nach oben als auch nach unten)
                                      A.
                                      MyzerAT 1 Reply Last reply Reply Quote 1
                                      • MyzerAT
                                        MyzerAT last edited by MyzerAT
                                        @Asgothian
                                        danke für die Info, wusste ich nicht, mir ist das aber gestern, schon aufgefallen, als ich den Sonoff 5v zur Steuerung der Therme eingesetzt habe und habe mein Script auch fürs ein und ausschalten mit <5% oder >5% umgeschrieben.
                                          gosund last edited by
                                          Woran liegt es, daß ich die Querverbindungen zwischen den Routern sowie die Anzeige der beiden Signale (Rx/Tx) nicht sehe? Nachdem ich alles entfernt und neu angelernt hatte, war es kurz zu sehen, nach ein paar Minuten ist es jedoch wieder verschwunden. Seitdem habe ich wieder nur die 'alte' Ansicht.
                                          • Asgothian
                                            Asgothian Developer @gosund last edited by
                                            @gosund
                                            Wähl mal einen Router aus, dann solltest du die Aktiven Verbindungen sehen.
                                            A.
                                            79.9k
                                            0.10.x adapter zigbee
                                            27
                                            373
                                            53547
