    4. [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige
      sveni_lee @sigi234 last edited by
      @sigi234
      okay, verstehe... Danke
      den Netzwerktraffic kann ich nicht zufällig auslesen?
        @sigi234
        Könntest Du mir noch sagen, welche Pictogramme Du für deine Netzwerkverlauf-Ansicht verwendest hast?
          sigi234 Forum Testing Most Active @sveni_lee last edited by
          @sveni_lee
          icons-mfd-svg
            @sigi234
            Danke...
            und als was hast Du diese eingebunden? wenn sie als Image einbinde kann ich die Farbe nicht ändern.
            Wenn "online" sollen die Geräte grün dargestellt werden und bei "offline" grau. Für die verbindungslinien soll das gleiche gelten...
            Könntest Du den Teil eventuell exportieren?
              sigi234 Forum Testing Most Active @sveni_lee last edited by sigi234
              @sveni_lee
              Widget Icons
              [{"tpl":"tplMfdCustom10","data":{"oid":"ping.0.Medion.192_168_178_1","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"icon0":"/icons-mfd-svg/it_router.svg","icon1":"","icon2":"","icon3":"","icon4":"","icon5":"","icon6":"","icon7":"","icon8":"","icon9":"","icon10":"/icons-mfd-svg/it_router.svg","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"min":"","max":"","show_active":false,"iconValue0":"false","iconValue1":"","iconValue2":"","iconValue3":"","iconValue4":"","iconValue5":"","iconValue6":"","iconValue7":"","iconValue8":"","iconValue9":"","iconValue10":"true","iconColor0":"#ff0000","iconColor10":"#35ff05","iconColor8":"","iconColor9":"","iconColor3":"","iconColor1":"","iconColor5":"","invert_value":false,"iconColor2":"","iconColor4":"","iconColor7":"","iconColor6":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"391px","top":"548px","z-index":"1","width":"103px","height":"100px","border-style":"solid","border-color":"#0e5bec","border-radius":"2px","border-width":"1px"},"widgetSet":"jqui-mfd"}]
              Widget Rohre (Linien)
              [{"tpl":"tplPlump_pipe_H","data":{"oid":"tr-064.0.states.wlan24","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","pipe_size":"5","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"color_on":"#35ff05","color_off":"#ff050d","conLeft":"w01273"},"style":{"left":"631px","top":"722px","width":"38px","height":"10px","z-index":"0"},"widgetSet":"plumb"}]
                sveni_lee @sigi234 last edited by sveni_lee
                @sigi234
                Danke dafür...
                das erste kann ich nicht einbinden...
                steht bei mir dann w00605 (undefiniert - undefiniert)...
                EDIT: war ein copy and past Fehler
                  Könnte mir mal jemand erklären auf was genau die "Aggregation:" im history-Widget Sparkline Einfluss hat?
                  Ich bin mir nicht sicher was ich verwenden muss...
                    JavaMafia last edited by
                    Hat jemand noch das Problem, das diese Werte nicht übereinstimmen von der FritzBox?
                    upnp.0.FritzBox6490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived
                    upnp.0.FritzBox6490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesSent
                    Wenn auch der Received einen Wert von 5GB ca erreicht hat, fängt der wieder bei 0 an.
                    Alle anderen Daten werden mir richtig angezeigt.
                    benchonaut 1 Reply Last reply Reply Quote 0
                      aleks-83 last edited by
                      Siehe hier meine Erkenntnisse dazu
                        WernerS last edited by WernerS
                        Hallo
                        bei mir hat alles angefangen zu funktionieren. Jetzt gab es aber updates von Adaptern und nix ging mehr. Ich habe festgestellt das die Ordnerstruktur in den Objekten sich geändert hat und somit auch die Pfade. Ich habe es im Javascript und Blockly angepasst, aber es läuft nicht mehr.
                        Wer hat noch das Problem, oder habe ich was übersehen?
                        Werner
                          aleks-83 last edited by aleks-83
                          @WernerS
                          Richtig, die Struktur des UPnP Adapters hat sich geändert.
                          Meine FritzBox Punkte finde ich jetzt z.B. unter
                          upnp.0.FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig
                          EDIT:
                          Korrektur:
                          So sieht es jetzt aus:
                          upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.
                            Hallo
                            bei mir das jetzt so aus
                            upnp.0.AVM_FRITZ!Mediaserver
                            upnp.0.InternetGatewayDeviceV2_-FRITZ!Box_7490
                            upnp.0.WANConnectionDevice
                            -FRITZ!Box_7490
                            upnp.0.WANDevice
                            -_FRITZ!Box_7490
                            Es liegt aber anscheinend nicht an den Scripten, sondern da kommen jetzt wohl keine Daten mehr an. Alle Werte sind leer.
                            Werner
                            • SBorg
                              Wie lange läuft der UPnP denn schon? Beim ersten Start kann es bis zu 20 Minuten dauern bis alle Datenpunkte angelegt sind und dann auch mit Daten befüllt werden.
                                Oh, sorry.
                                Ich habe quatsch erzählt... War zu schnell.
                                Die neue Struktur sieht so aus:
                                  Hallo
                                  läuft jetzt seid fast 2 Stunden und immer noch keine Daten.
                                  UPNP an dere Fritzbox ist immer noch aktiv.
                                  Werner
                                  • SBorg
                                    Hast du denn überhaupt den Scheduler für die gewünschten Datenpunkte aktiviert, bzw. bekommst du Daten wenn du einen Request manuell auslöst?
                                      WernerS @SBorg last edited by
                                      @SBorg
                                      Also das mit dem Request kannte ich nicht. Wieder was gelernt 🙂
                                      Wenn ich den auslöse kommen Daten.
                                      Der Scheduler ist ja im Script angegeben. Da habe ich nichts geändert ausser die Pfade.
                                      Werner
                                      • SBorg
                                        SBorg Forum Testing Most Active @WernerS last edited by SBorg
                                        @WernerS sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                        Der Scheduler ist ja im Script angegeben...
                                        ... und da ist der Fehler 🙂
                                        Das funktioniert mit dem neuen UPnP nicht mehr. Du musst es pro Datenpunkt, oder eben für alle Datenpunkte per request, über den Schraubenschlüssel -> Cron-Scheduler einrichten und im Script disablen, sonst bekommst du keine Daten.
                                        W Thisoft 3 Replies Last reply Reply Quote 0
                                          @SBorg
                                          na da muss man erst mal drauf kommen. 🙂 Danke für die Info, werde es mir später mal anschauen.
                                          Im Javascript nur die Zeile raus machen oder den Inhalt in der Klammer löschen? Mal sehen wie das für Blockly geht. Kriege ich schon hin.
                                          gruß
                                          Werner
                                          • Thisoft
                                            Thisoft @SBorg last edited by
                                            @SBorg sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                            Gut zu wissen dass sich da in UPnP generell was geändert hat - ich hab schon an mir selber gezweifelt wieso der Wert nicht mehr aktualisiert wird...
                                            Allerdings ist der request-Datenpunkt in meinen Objekten auch nicht vorhanden. Wo bekomme ich den denn her? Hab schon die neueste Version des UPnP-Adapters installiert...
                                            504
                                            130535
