    3. Cloud Dienste
    4. IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!
    • dslraser
      dslraser Forum Testing Most Active @padrino last edited by dslraser
      @padrino
      hier mal so ein bearbeitetes Blockly als Beispiel
      (es ist nur ein Auszug aus einem Blockly, das gesamte Blockly passt wegen der 50.000 Zeichen Begrenzung hier nicht rein)
        <variables>
          <variable type="undefined" id="timeout">timeout</variable>
          <variable type="" id="R@M~;im)0{[Hr=?(h|5w">Ansage</variable>
          <variable type="undefined" id="Intervall">Intervall</variable>
        </variables>
        <block type="on_ext" id="fe.2R9i}D/kAoY[-p?:[" x="37" y="-487">
          <value name="OID0">
            <shadow type="field_oid" id="szgKNr=Na+GnoreGP-7c">
              <field name="oid">tr-064.0.callmonitor.ringing</field>
            <block type="timeouts_settimeout" id="FmocBx!eX~(@Tx(~PlQ!">
              <field name="DELAY">1000</field>
              <field name="UNIT">ms</field>
                <block type="timeouts_clearinterval" id=",S%t8|Q^%Y}.wVI8evY;">
                  <field name="NAME">Intervall</field>
                    <block type="controls_if" id="]:,w4wpX_~t8xRe{JB|d">
                        <block type="logic_operation" id="l:c0pvxDfp87H[uRMuB5" inline="false">
                          <field name="OP">AND</field>
                            <block type="logic_compare" id="zfp)gh;Itxu{Sd1Fzdj2">
                              <field name="OP">EQ</field>
                                <block type="get_value" id="N.cN6*yHi%Qm?EA`.y.m">
                                  <field name="OID">tr-064.0.callmonitor.ringing</field>
                                <block type="logic_boolean" id="Uz6[P=iQW/G?,5YtS7;8">
                            <block type="logic_compare" id="@voAVLj,.vSY-hH~@`lu">
                              <field name="OP">NEQ</field>
                                <block type="get_value" id="HaqE^g0XyO=#pse7SFGP">
                                  <field name="OID">tr-064.0.callmonitor.inbound.callerName</field>
                                <block type="text" id="}!,e7x(rjG9.`7fTkuk}">
                                  <field name="TEXT"></field>
                        <block type="variables_set" id=".G;pLh!r:GaT7Gr!D=!j">
                          <field name="VAR" id="R@M~;im)0{[Hr=?(h|5w" variabletype="">Ansage</field>
                            <block type="text_join" id="bs]))?ID)xpyGqr3p|kH">
                              <mutation items="4"></mutation>
                              <value name="ADD0">
                                <block type="text" id="PxYRF1I~}.R;;M:;]+FY">
                                  <field name="TEXT">&lt;speak&gt;&lt;voice name="Alexa"&gt;</field>
                              <value name="ADD1">
                                <block type="get_value" id="|5X6FcnbE8`~H%+^_N2I">
                              <value name="ADD2">
                                <block type="text" id="ua-Zx2ma6}q#2]H@3w[g">
                                  <field name="TEXT">ruft gerade an . </field>
                              <value name="ADD3">
                                <block type="text" id="{L^F]%fU2)0pAcrT?TkM">
                                  <field name="TEXT">&lt;/voice&gt;&lt;/speak&gt;</field>
                            <block type="control" id="=cOG116(JQ+pqcIS^SFg">
                              <field name="OID">alexa2.0.Echo-Devices.xxx.Commands.ssml</field>
                                <block type="variables_get" id="8Lj1..PCYx|_*6qIv(!D">
                                <block type="timeouts_setinterval" id="[OFLd4?uD+LyYt#w7qkg">
                                  <field name="INTERVAL">5000</field>
                                    <block type="variables_set" id="pL}we2zx]L1%xDC_/d8)">
                                        <block type="text_join" id="l|{R,E@ruBsNE8A=(`e_">
                                          <mutation items="5"></mutation>
                                          <value name="ADD0">
                                            <block type="text" id="w_`yn3xWb|q+Pfiua{a_">
                                          <value name="ADD1">
                                            <block type="text" id="+[wv=h*Bdxb]|Zlt-Q}8">
                                              <field name="TEXT">Ich wiederhole . </field>
                                          <value name="ADD2">
                                            <block type="get_value" id="GpLq#Wq3g+qc7}FkEn:y">
                                          <value name="ADD3">
                                            <block type="text" id="@ihp9I|u9=?zNk3=|;o/">
                                          <value name="ADD4">
                                            <block type="text" id="ei;L`NFAaUhBT4*X5[bg">
                                        <block type="comment" id="Sbi{Wr,sa3mP1G:3|fi.">
                                          <field name="COMMENT">ECHO Wohnzimmer</field>
                                            <block type="control" id="[Mz|)~I5lM;=RNee:zGs">
                                              <mutation delay_input="true"></mutation>
                                              <field name="DELAY_MS">1000</field>
                                                <block type="variables_get" id="tT[a=tC~X[.iJ?WXtPkK">
                                                <block type="comment" id="QuKv|fO6a2^w%4RM^r84">
                                                  <field name="COMMENT">ECHO Badezimmer</field>
                                                    <block type="control" id="8p80(wBWw@)Vu.KL*%3G">
                                                        <block type="variables_get" id="Cg*STqbFsympaAC%:VAC">
                                                        <block type="comment" id="TsmL!cckPt9*`MZaY!6S">
                                                          <field name="COMMENT">Echo Küche</field>
                                                            <block type="control" id="^wK9k%)Jix=KG^hv=uq9">
        <block type="variables_get" id="{Xh^YDDV8_:Vxe~8.xZs">
        <block type="comment" id="6~#OoS3d1tF?67d:SkBY">
        <field name="COMMENT">ECHO Werkstatt</field>
        <block type="control" id="q`YXtGhPf[T[(7.]XKLm">
        <block type="variables_get" id="GahpLkQh^3Q37/{rD~ON">
        <block type="comment" id="H45.XNG:@1=#Xj0Mqag^">
        <field name="COMMENT">ECHO Keller-Flur</field>
        <block type="control" id="B9HZw3+aVZ{kp]0K:1nt">
        <block type="variables_get" id="mO]o{(sMM-@n8@c%/%|i">
      padrino 1 Reply Last reply Reply Quote 1
      • padrino
        padrino Most Active @dslraser last edited by
        @dslraser
        Alles klar. Vielen Dank.
        Wenn das so von Hand kein Thema ist, dann kann ich damit leben. 😉
        • padrino
          padrino Most Active last edited by
          hat evtl. noch jemand das Problem, dass
          alexa2.0.Echo-Devices.....Player.volume
          sich ständig von alleine auf "0" stellt?
          Das Seltsame, die Lautstärke ist davon nicht betroffen, sprich, frage ich "Alexa, wie ist die Lautstärke", bekomme ich den korrekten Wert (also z.B. "4") angesagt.
          Nach einem "Alexa, lauter" steht dann (zumindest für eine Weile) im Beispiel "50" drin, biss es dann (20 Minuten später, oder eine Stunde...) wieder genullt wird. 😞
          Matten Matten 1 Reply Last reply Reply Quote 0
          • padrino
            @apollon77
            Gibt es irgendwie ein Debug-Modus mit dem herausfinden kann, wieso der Adapter einenen Datenpunkt ändert, bzw. woher der "Auftrag" zur Änderung kommt?
            Ich kann ja nur mit JS einen Datenpunkt überwachen und triggern, ob es eine Änderung gibt...
            Diginix apollon77 2 Replies Last reply Reply Quote 0
            • Diginix
              Diginix @padrino last edited by Diginix
              @padrino Bin zwar nicht apollon aber vllt hilft dir auch meine Antwort: History Adapter. Mit dem siehst du wann und von wem die Änderung kam und auch ob sie bestätigt war (ack=true).
              Das ist adapterunabhängig und funktioniert mit jedem Datenpunkt ohne debug level.
              padrino 1 Reply Last reply Reply Quote 0
              • padrino
                padrino Most Active @Diginix last edited by
                @Diginix
                Danke für die Info.
                Der Adapter war hier schon (deaktiviert) installiert, aber erst jetzt habe ich mich dran getraut. 🙂
                Denke, leider hilft er mir aber nix, steht nur drin
                Wert Bestätigt Quelle   Zeit                    Geändert
                0    true      alexa2.0 2019-03-25 00:35:52.123
                was für mich bedeutet, der Adapter macht diese (stündliche) Änderung... 🤔
                • Diginix
                  @padrino Korrekt, der Wert 0 wurde vom Adapter selbst geschrieben. Vermutlich bekommt dieser den Wert aber so von Amazon. Bei meinen 2 Echo Dot 3 steht dauerhaft der korrekte Lautstärke Wert in dem Datenpunkt.
                  Da kann evtl. wirklich nur @apollon77 helfen.
                  • Matten Matten
                    Matten Matten @padrino last edited by
                    @padrino sagte in IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!:
                    Ich kann mich erinnern, das ich vor Monaten ein Wunsch hatte nach einer Stunde Inaktivität, die Werte wie Sender Interpret usw. zu Nullen (löschen), da eine Wiedergabe fortsetzen danach eh nicht mehr möglich ist.
                    Denn exakt nach dieser Stunde wird auch in der original App nichts mehr angezeigt. Vielleicht hängt es damit zusammen.
                    Gruß matten
                    • Diginix
                      Diginix @Matten Matten last edited by
                      @Matten-Matten Dann müsste es bei allen anderen aber auch so sein und das ist es bei mir auf jeden Fall nicht. Ich sehe 24/7 die eingestellte Lautstärke. Sehe auch kein Grund die zu nullen, denn sie ist permanent gültig. Wenn man einen Sender startet, greift genau dieser Wert.
                        wahlfisch last edited by
                        Ich check es nicht 😞
                        Wie macht ihr das nun wenn ihr angenommen den "Radio Blabla" auf einem Echo device per Tunein abspielen wollt?
                        Bei mir funktioniert die Tunein-Phrase und die Tunein-Playlist nicht 😞
                        LG
                        • Diginix
                          Diginix @Diginix last edited by
                          @wahlfisch Was ist dir denn bei meiner Anleitung noch unklar?
                          @Diginix sagte in IoBroker Alexa2 v2.0 ALPHA!!! Status GitHub Version!:
                          Benutze die Alpha seit vielen Wochen und am Anfang war das Problem nicht. Dürfte also nichts mit dem Adapter selbst zu tun haben. Mittlerweile umgehe ich das Problem mit einer Alexa Routine.
                          In der Routine wird TuneIn als Provider und der passende Sender gewählt.
                          Die Routine selbst hat als Trigger z.B. den Sprachbefehl "TuneIn Sender x", ist aber belanglos solange man die Routine nicht auch per Sprache starten will.
                          Auslösen tue ich die Routine dann in ioBroker über den Datenpunkt im Adapter.
                          Das funktioniert seit Tagen stabil im Gegensatz zum Setzen des Music-Provider Datenpunktes.
                            wahlfisch @Diginix last edited by
                            @Diginix AAAH, Alles klar....Hab's gecheckt 🙂
                            Danke für deine Unterstützung 🙂
                              mireki1975 last edited by
                              bekomme die Beta nicht installiert
                              npm install iobroker.alexa2@2.2.0
                              funktioniert leider nicht - kann mir jemand einen Tipp geben?
                              ich kann damit ja die 1.1.3 direkt überschreiben , oder?
                                apollon77 @mireki1975 last edited by
                                @mireki1975 So wie es hier ganz oben im Post steht: Installation über GitHub
                                  apollon77 @padrino last edited by
                                  @padrino Ja stell die Instanz auf Debug dann siehst Du auch was Amazon zurückliefert
                                  • padrino
                                    padrino Most Active @apollon77 last edited by padrino
                                    @apollon77
                                    Hmm, hab in der Sekunde in der es passiert nur das hier... (die letzte Zeile ist die Ausgabe meines Triggers)
                                    2019-04-04 13:11:11.987 - debug: alexa2.0 Alexa-Remote WS-MQTT: Send Ping
                                    2019-04-04 13:11:12.089 - debug: alexa2.0 Alexa-Remote WS-MQTT: Received Pong
                                    2019-04-04 13:11:49.533 - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/bootstrap?version=0","method":"GET","timeout":10000,"headers":{}}
                                    2019-04-04 13:11:50.078 - debug: alexa2.0 Alexa-Remote: Response: {"authentication":{"authenticated":true,"canAccessPrimeMusicContent":true,"customerEmail":"a@bc.de","customerId":"A1TI0E9SQ466JG","customerName":"Mario XXXXXXXX"}}
                                    2019-04-04 13:11:50.082 - debug: alexa2.0 Alexa-Remote: Authentication check successfull
                                    2019-04-04 13:11:50.083 - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/devices-v2/device?cached=true&_=1554376310082","method":"GET","timeout":10000,"headers":{}}
                                    2019-04-04 13:11:51.173 - debug: alexa2.0 Alexa-Remote: Response: {"devices":[{"accountName":"Überall","appDeviceList":[],"capabilities":["AMAZON_MUSIC","AUDIBLE","MICROPHONE","SALMON","KINDLE_BOOKS","I_HEART_RADIO","MUSIC_SKILL","VOLUME_SETTING","PANDORA","TUNE_IN","AUDIO_PLAYER"],"charging":null,"clusterMembers":["G090LF11XXXXXXXX","G090LF11XXXXXXXX","G090L911XXXXXXXX"],"deviceAccountId":"A1B744PQOMXFPM","deviceFamily":"WHA","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A3C9PE6TNYLTCH","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"xxx","softwareVersion":"0"},{"accountName":"Küche/Bad","appDeviceList":[],"capabilities":["AUDIBLE","ASCENDING_ALARM_VOLUME","REMINDERS","ACTIVE_AFTER_FRO","MICROPHONE","GADGETS","VOICE_TRAINING","FAR_FIELD_WAKE_WORD","DREAM_TRAINING","LEMUR_ALPHA","GOLDFISH","EARCONS","PAIR_REMOTE","AUDIO_PLAYER","SUPPORTS_SOFTWARE_VERSION","SUPPORTS_CONNECTED_HOME","DS_VOLUME_SETTING","TIMERS_AND_ALARMS","I_HEART_RADIO","PAIR_BT_SOURCE","TAHOE_BYOD","VOLUME_SETTING","DEREGISTER_DEVICE","PERSISTENT_CONNECTION","TUNE_IN","FLASH_BRIEFING","SALMON","CHANGE_NAME","SUPPORT_CALENDAR_ALERT","MUSIC_SKILL","SET_LOCALE","PAIR_BT_SINK","CUSTOM_ALARM_TONE","AMAZON_MUSIC","POPTART","UPDATE_WIFI","KINDLE_BOOKS","SOUND_SETTINGS","SUPPORTS_CONNECTED_HOME_ALL","DEREGISTER_FACTORY_RESET","REQUIRES_OOBE_FOR_SETUP","PANDORA","SLEEP"],"charging":null,"clusterMembers":[],"deviceAccountId":"A07048225W62SBXV9MAP","deviceFamily":"ECHO","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A3S5BH2HU6VAYF","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":["xxx"],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G090LF11XXXXXXXX","softwareVersion":"631550720"},{"accountName":"Italien","appDeviceList":[],"capabilities":["AUDIBLE","REMINDERS","ACTIVE_AFTER_FRO","MICROPHONE","GADGETS","VOICE_TRAINING","FAR_FIELD_WAKE_WORD","DREAM_TRAINING","LEMUR_ALPHA","TUPLE_CATEGORY_A","GOLDFISH","EARCONS","PAIR_REMOTE","AUDIO_PLAYER","SUPPORTS_SOFTWARE_VERSION","DS_VOLUME_SETTING","TIMERS_AND_ALARMS","I_HEART_RADIO","PAIR_BT_SOURCE","TAHOE_BYOD","VOLUME_SETTING","DEREGISTER_DEVICE","PERSISTENT_CONNECTION","TUNE_IN","FLASH_BRIEFING","SALMON","CHANGE_NAME","SUPPORT_CALENDAR_ALERT","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","MUSIC_SKILL","SET_LOCALE","PAIR_BT_SINK","CUSTOM_ALARM_TONE","AMAZON_MUSIC","POPTART","UPDATE_WIFI","KINDLE_BOOKS","TUPLE","SOUND_SETTINGS","DEREGISTER_FACTORY_RESET","REQUIRES_OOBE_FOR_SETUP","PANDORA","SLEEP"],"charging":null,"clusterMembers":[],"deviceAccountId":"A04221082HC8JBEFARNOL","deviceFamily":"ECHO","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A7WXQPH584YP","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":false,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G090RF04XXXXXXXX","softwareVersion":"631550720"},{"accountName":"Schlafzimmer","appDeviceList":[],"capabilities":["AUDIBLE","ASCENDING_ALARM_VOLUME","REMINDERS","ACTIVE_AFTER_FRO","MICROPHONE","GADGETS","VOICE_TRAINING","FAR_FIELD_WAKE_WORD","DREAM_TRAINING","LEMUR_ALPHA","GOLDFISH","EARCONS","PAIR_REMOTE","AUDIO_PLAYER","SUPPORTS_SOFTWARE_VERSION","SUPPORTS_CONNECTED_HOME","DS_VOLUME_SETTING","TIMERS_AND_ALARMS","I_HEART_RADIO","PAIR_BT_SOURCE","TAHOE_BYOD","VOLUME_SETTING","DEREGISTER_DEVICE","PERSISTENT_CONNECTION","TUNE_IN","FLASH_BRIEFING","SALMON","CHANGE_NAME","SUPPORT_CALENDAR_ALERT","MUSIC_SKILL","SET_LOCALE","PAIR_BT_SINK","CUSTOM_ALARM_TONE","AMAZON_MUSIC","POPTART","UPDATE_WIFI","KINDLE_BOOKS","SOUND_SETTINGS","SUPPORTS_CONNECTED_HOME_ALL","DEREGISTER_FACTORY_RESET","REQUIRES_OOBE_FOR_SETUP","PANDORA","SLEEP"],"charging":null,"clusterMembers":[],"deviceAccountId":"A03639462SEBV3P9Y7UT","deviceFamily":"ECHO","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A3S5BH2HU6VAYF","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":["xxx"],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G090L911XXXXXXXX","softwareVersion":"631550720"},{"accountName":"Fire TV Stick","appDeviceList":[],"capabilities":["ARTHUR_TARGET","SUPPORTS_SOFTWARE_VERSION","ACTIVE_AFTER_FRO","FLASH_BRIEFING","MICROPHONE","CHANGE_NAME","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","VOLUME_SETTING","PERSISTENT_CONNECTION"],"charging":null,"clusterMembers":[],"deviceAccountId":"A03869332WPD67G6K6583","deviceFamily":"FIRE_TV","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A2LWARUGJLBYEW","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G070L808XXXXXXXX","softwareVersion":"632552020"},{"accountName":"Mario's Alexa App for PC","appDeviceList":[],"capabilities":["AUDIBLE","FLASH_BRIEFING","REMINDERS","MICROPHONE","CHANGE_NAME","DREAM_TRAINING","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","MUSIC_SKILL","EARCONS","SET_LOCALE","AUDIO_PLAYER","AMAZON_MUSIC","KINDLE_BOOKS","TIMERS_AND_ALARMS","I_HEART_RADIO","VOLUME_SETTING","SOUND_SETTINGS","DEREGISTER_DEVICE","PERSISTENT_CONNECTION","TUNE_IN","SLEEP"],"charging":null,"clusterMembers":[],"deviceAccountId":"A0002403W6RIYYQEWR1S","deviceFamily":"REAVER","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A1RTAM01W29CUP","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":false,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"xxx","softwareVersion":"0"},{"accountName":"Wohnzimmer","appDeviceList":[],"capabilities":["AUDIBLE","ASCENDING_ALARM_VOLUME","REMINDERS","ACTIVE_AFTER_FRO","MICROPHONE","GADGETS","VOICE_TRAINING","FAR_FIELD_WAKE_WORD","DREAM_TRAINING","LEMUR_ALPHA","GOLDFISH","EARCONS","PAIR_REMOTE","AUDIO_PLAYER","SUPPORTS_SOFTWARE_VERSION","SUPPORTS_CONNECTED_HOME","DS_VOLUME_SETTING","TIMERS_AND_ALARMS","I_HEART_RADIO","PAIR_BT_SOURCE","TAHOE_BYOD","VOLUME_SETTING","DEREGISTER_DEVICE","PERSISTENT_CONNECTION","TUNE_IN","FLASH_BRIEFING","SALMON","CHANGE_NAME","SUPPORT_CALENDAR_ALERT","MUSIC_SKILL","SET_LOCALE","PAIR_BT_SINK","CUSTOM_ALARM_TONE","AMAZON_MUSIC","POPTART","UPDATE_WIFI","KINDLE_BOOKS","SOUND_SETTINGS","SUPPORTS_CONNECTED_HOME_ALL","DEREGISTER_FACTORY_RESET","REQUIRES_OOBE_FOR_SETUP","PANDORA","SLEEP"],"charging":null,"clusterMembers":[],"deviceAccountId":"AMF69LY72MBOY","deviceFamily":"ECHO","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A3S5BH2HU6VAYF","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":["xxx"],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"G090LF11XXXXXXXX","softwareVersion":"631550720"},{"accountName":"Bespoken Device (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device)","appDeviceList":[],"capabilities":["AUDIBLE","MICROPHONE","CHANGE_NAME","DREAM_TRAINING","SUPPORTS_CONNECTED_HOME_CLOUD_ONLY","MUSIC_SKILL","GOLDFISH","AUDIO_PLAYER","AMAZON_MUSIC","KINDLE_BOOKS","I_HEART_RADIO","TIMERS_AND_ALARMS","VOLUME_SETTING","DEREGISTER_DEVICE","PERSISTENT_CONNECTION","PEONY","TUNE_IN","SLEEP"],"charging":null,"clusterMembers":[],"deviceAccountId":"A057865210N5NWFKU7SLK","deviceFamily":"UNKNOWN","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A1X7HJX9QL16M5","deviceTypeFriendlyName":"Virtual Device","essid":null,"language":null,"macAddress":null,"online":false,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"xxx","softwareVersion":"0"},{"accountName":"This Device","appDeviceList":[{"deviceAccountId":"A0964566C0UDQE5I97V8","deviceType":"A2TF17PFR55MTB","serialNumber":"xxx"},{"deviceAccountId":"A039643019XKK1NWNE8AW","deviceType":"A2TF17PFR55MTB","serialNumber":"xxx"},{"deviceAccountId":"A08008372N64U3TX4IEAQ","deviceType":"A2IVLV5VM2W81","serialNumber":"xxx"}],"capabilities":["MICROPHONE","REMINDERS","VOLUME_SETTING"],"charging":null,"clusterMembers":[],"deviceAccountId":"A0964566C0UDQE5I97V8","deviceFamily":"VOX","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A2TF17PFR55MTB","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":true,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"xxx","softwareVersion":"130050002"},{"accountName":"Mario's Alexa Apps","appDeviceList":[{"deviceAccountId":"A09834032LIN3ZLDA5OAZ","deviceType":"A1DL2DVDQVK3Q","serialNumber":"C488XXXXXXXX"}],"capabilities":["MICROPHONE","VOLUME_SETTING","PEONY"],"charging":null,"clusterMembers":[],"deviceAccountId":"A09834032LIN3ZLDA5OAZ","deviceFamily":"AMAZONMOBILEMUSIC_ANDROID","deviceOwnerCustomerId":"A1TI0E9SQ466JG","deviceType":"A1DL2DVDQVK3Q","deviceTypeFriendlyName":null,"essid":null,"language":null,"macAddress":null,"online":false,"parentClusters":[],"postalCode":null,"registrationId":null,"remainingBatteryLevel":null,"serialNumber":"C488XXXXXXXX","softwareVersion":"7020810"}]}
                                    2019-04-04 13:11:51.261 - debug: alexa2.0 Alexa-Remote: No authentication check needed (time elapsed 1179)
                                    2019-04-04 13:11:51.262 - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/bluetooth?cached=true&_=1554376311262","method":"GET","timeout":10000,"headers":{}}
                                    2019-04-04 13:11:51.280 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.online: {"val":true,"ack":true,"ts":1554376311221,"q":0,"from":"system.adapter.alexa2.0","lc":1541772718602}
                                    2019-04-04 13:11:51.281 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.capabilities: {"val":"AMAZON_MUSIC,AUDIBLE,MICROPHONE,SALMON,KINDLE_BOOKS,I_HEART_RADIO,MUSIC_SKILL,VOLUME_SETTING,PANDORA,TUNE_IN,AUDIO_PLAYER","ack":true,"ts":1554376311269,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311269}
                                    2019-04-04 13:11:51.281 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomDevice: {"val":true,"ack":true,"ts":1554376311273,"q":0,"from":"system.adapter.alexa2.0","lc":1536502012681}
                                    2019-04-04 13:11:51.291 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.multiroomMembers: {"val":"G090LF11XXXXXXXX,G090LF11XXXXXXXX,G090L911XXXXXXXX","ack":true,"ts":1554376311275,"q":0,"from":"system.adapter.alexa2.0","lc":1549813309470}
                                    2019-04-04 13:11:51.298 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311275,"q":0,"from":"system.adapter.alexa2.0","lc":1536502012704}
                                    2019-04-04 13:11:51.299 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceType: {"val":"A3C9PE6TNYLTCH","ack":true,"ts":1554376311276,"q":0,"from":"system.adapter.alexa2.0","lc":1536502012716}
                                    2019-04-04 13:11:51.299 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceTypeString: {"val":"Multiroom","ack":true,"ts":1554376311277,"q":0,"from":"system.adapter.alexa2.0","lc":1536502012727}
                                    2019-04-04 13:11:51.300 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.serialNumber: {"val":"xxx","ack":true,"ts":1554376311277,"q":0,"from":"system.adapter.alexa2.0","lc":1536502012739}
                                    2019-04-04 13:11:51.300 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.name: {"val":"Überall","ack":true,"ts":1554376311278,"q":0,"from":"system.adapter.alexa2.0","lc":1536502012750}
                                    2019-04-04 13:11:51.301 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.online: {"val":true,"ack":true,"ts":1554376311278,"q":0,"from":"system.adapter.alexa2.0","lc":1554339578713}
                                    2019-04-04 13:11:51.301 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.capabilities: {"val":"AUDIBLE,ASCENDING_ALARM_VOLUME,REMINDERS,ACTIVE_AFTER_FRO,MICROPHONE,GADGETS,VOICE_TRAINING,FAR_FIELD_WAKE_WORD,DREAM_TRAINING,LEMUR_ALPHA,GOLDFISH,EARCONS,PAIR_REMOTE,AUDIO_PLAYER,SUPPORTS_SOFTWARE_VERSION,SUPPORTS_CONNECTED_HOME,DS_VOLUME_SETTING,TIMERS_AND_ALARMS,I_HEART_RADIO,PAIR_BT_SOURCE,TAHOE_BYOD,VOLUME_SETTING,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,TUNE_IN,FLASH_BRIEFING,SALMON,CHANGE_NAME,SUPPORT_CALENDAR_ALERT,MUSIC_SKILL,SET_LOCALE,PAIR_BT_SINK,CUSTOM_ALARM_TONE,AMAZON_MUSIC,POPTART,UPDATE_WIFI,KINDLE_BOOKS,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_ALL,DEREGISTER_FACTORY_RESET,REQUIRES_OOBE_FOR_SETUP,PANDORA,SLEEP","ack":true,"ts":1554376311279,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311279}
                                    2019-04-04 13:11:51.301 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311279,"q":0,"from":"system.adapter.alexa2.0","lc":1536502013249}
                                    2019-04-04 13:11:51.301 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.isMultiroomMember: {"val":true,"ack":true,"ts":1554376311280,"q":0,"from":"system.adapter.alexa2.0","lc":1537460668338}
                                    2019-04-04 13:11:51.302 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.multiroomParents: {"val":"xxx","ack":true,"ts":1554376311280,"q":0,"from":"system.adapter.alexa2.0","lc":1537460670490}
                                    2019-04-04 13:11:51.302 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.deviceType: {"val":"A3S5BH2HU6VAYF","ack":true,"ts":1554376311281,"q":0,"from":"system.adapter.alexa2.0","lc":1536502013275}
                                    2019-04-04 13:11:51.302 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.deviceTypeString: {"val":"Echo Dot 2.Gen","ack":true,"ts":1554376311281,"q":0,"from":"system.adapter.alexa2.0","lc":1536502013296}
                                    2019-04-04 13:11:51.302 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.serialNumber: {"val":"G090LF11XXXXXXXX","ack":true,"ts":1554376311281,"q":0,"from":"system.adapter.alexa2.0","lc":1536502013315}
                                    2019-04-04 13:11:51.302 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.name: {"val":"Küche/Bad","ack":true,"ts":1554376311282,"q":0,"from":"system.adapter.alexa2.0","lc":1544565121859}
                                    2019-04-04 13:11:51.302 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.online: {"val":false,"ack":true,"ts":1554376311282,"q":0,"from":"system.adapter.alexa2.0","lc":1552960737833}
                                    2019-04-04 13:11:51.304 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.capabilities: {"val":"AUDIBLE,REMINDERS,ACTIVE_AFTER_FRO,MICROPHONE,GADGETS,VOICE_TRAINING,FAR_FIELD_WAKE_WORD,DREAM_TRAINING,LEMUR_ALPHA,TUPLE_CATEGORY_A,GOLDFISH,EARCONS,PAIR_REMOTE,AUDIO_PLAYER,SUPPORTS_SOFTWARE_VERSION,DS_VOLUME_SETTING,TIMERS_AND_ALARMS,I_HEART_RADIO,PAIR_BT_SOURCE,TAHOE_BYOD,VOLUME_SETTING,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,TUNE_IN,FLASH_BRIEFING,SALMON,CHANGE_NAME,SUPPORT_CALENDAR_ALERT,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MUSIC_SKILL,SET_LOCALE,PAIR_BT_SINK,CUSTOM_ALARM_TONE,AMAZON_MUSIC,POPTART,UPDATE_WIFI,KINDLE_BOOKS,TUPLE,SOUND_SETTINGS,DEREGISTER_FACTORY_RESET,REQUIRES_OOBE_FOR_SETUP,PANDORA,SLEEP","ack":true,"ts":1554376311298,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311298}
                                    2019-04-04 13:11:51.337 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311300,"q":0,"from":"system.adapter.alexa2.0","lc":1541213200129}
                                    2019-04-04 13:11:51.344 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311301,"q":0,"from":"system.adapter.alexa2.0","lc":1541213200142}
                                    2019-04-04 13:11:51.344 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.deviceType: {"val":"A7WXQPH584YP","ack":true,"ts":1554376311301,"q":0,"from":"system.adapter.alexa2.0","lc":1541213200153}
                                    2019-04-04 13:11:51.345 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.deviceTypeString: {"val":"Echo 2.Gen","ack":true,"ts":1554376311302,"q":0,"from":"system.adapter.alexa2.0","lc":1541213200163}
                                    2019-04-04 13:11:51.345 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.serialNumber: {"val":"G090RF04XXXXXXXX","ack":true,"ts":1554376311302,"q":0,"from":"system.adapter.alexa2.0","lc":1541213200172}
                                    2019-04-04 13:11:51.345 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090RF04XXXXXXXX.Info.name: {"val":"Italien","ack":true,"ts":1554376311302,"q":0,"from":"system.adapter.alexa2.0","lc":1552697057083}
                                    2019-04-04 13:11:51.345 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.online: {"val":true,"ack":true,"ts":1554376311303,"q":0,"from":"system.adapter.alexa2.0","lc":1554351060747}
                                    2019-04-04 13:11:51.346 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.capabilities: {"val":"AUDIBLE,ASCENDING_ALARM_VOLUME,REMINDERS,ACTIVE_AFTER_FRO,MICROPHONE,GADGETS,VOICE_TRAINING,FAR_FIELD_WAKE_WORD,DREAM_TRAINING,LEMUR_ALPHA,GOLDFISH,EARCONS,PAIR_REMOTE,AUDIO_PLAYER,SUPPORTS_SOFTWARE_VERSION,SUPPORTS_CONNECTED_HOME,DS_VOLUME_SETTING,TIMERS_AND_ALARMS,I_HEART_RADIO,PAIR_BT_SOURCE,TAHOE_BYOD,VOLUME_SETTING,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,TUNE_IN,FLASH_BRIEFING,SALMON,CHANGE_NAME,SUPPORT_CALENDAR_ALERT,MUSIC_SKILL,SET_LOCALE,PAIR_BT_SINK,CUSTOM_ALARM_TONE,AMAZON_MUSIC,POPTART,UPDATE_WIFI,KINDLE_BOOKS,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_ALL,DEREGISTER_FACTORY_RESET,REQUIRES_OOBE_FOR_SETUP,PANDORA,SLEEP","ack":true,"ts":1554376311303,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311303}
                                    2019-04-04 13:11:51.346 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311304,"q":0,"from":"system.adapter.alexa2.0","lc":1542660498530}
                                    2019-04-04 13:11:51.346 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.isMultiroomMember: {"val":true,"ack":true,"ts":1554376311304,"q":0,"from":"system.adapter.alexa2.0","lc":1549813309502}
                                    2019-04-04 13:11:51.346 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.multiroomParents: {"val":"xxx","ack":true,"ts":1554376311305,"q":0,"from":"system.adapter.alexa2.0","lc":1542664109919}
                                    2019-04-04 13:11:51.347 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.deviceType: {"val":"A3S5BH2HU6VAYF","ack":true,"ts":1554376311305,"q":0,"from":"system.adapter.alexa2.0","lc":1542660498561}
                                    2019-04-04 13:11:51.347 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.deviceTypeString: {"val":"Echo Dot 2.Gen","ack":true,"ts":1554376311306,"q":0,"from":"system.adapter.alexa2.0","lc":1542660498576}
                                    2019-04-04 13:11:51.347 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.serialNumber: {"val":"G090L911XXXXXXXX","ack":true,"ts":1554376311306,"q":0,"from":"system.adapter.alexa2.0","lc":1542660498626}
                                    2019-04-04 13:11:51.347 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090L911XXXXXXXX.Info.name: {"val":"Schlafzimmer","ack":true,"ts":1554376311306,"q":0,"from":"system.adapter.alexa2.0","lc":1542660498636}
                                    2019-04-04 13:11:51.347 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.online: {"val":true,"ack":true,"ts":1554376311307,"q":0,"from":"system.adapter.alexa2.0","lc":1545931680416}
                                    2019-04-04 13:11:51.348 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.capabilities: {"val":"ARTHUR_TARGET,SUPPORTS_SOFTWARE_VERSION,ACTIVE_AFTER_FRO,FLASH_BRIEFING,MICROPHONE,CHANGE_NAME,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,VOLUME_SETTING,PERSISTENT_CONNECTION","ack":true,"ts":1554376311307,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311307}
                                    2019-04-04 13:11:51.348 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311307,"q":0,"from":"system.adapter.alexa2.0","lc":1545931680441}
                                    2019-04-04 13:11:51.348 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311308,"q":0,"from":"system.adapter.alexa2.0","lc":1545931680450}
                                    2019-04-04 13:11:51.348 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.deviceType: {"val":"A2LWARUGJLBYEW","ack":true,"ts":1554376311308,"q":0,"from":"system.adapter.alexa2.0","lc":1545931680463}
                                    2019-04-04 13:11:51.363 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.deviceTypeString: {"val":"Fire TV Stick V2","ack":true,"ts":1554376311309,"q":0,"from":"system.adapter.alexa2.0","lc":1545931680477}
                                    2019-04-04 13:11:51.363 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.serialNumber: {"val":"G070L808XXXXXXXX","ack":true,"ts":1554376311309,"q":0,"from":"system.adapter.alexa2.0","lc":1545931680486}
                                    2019-04-04 13:11:51.363 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G070L808XXXXXXXX.Info.name: {"val":"Fire TV Stick","ack":true,"ts":1554376311309,"q":0,"from":"system.adapter.alexa2.0","lc":1546083803650}
                                    2019-04-04 13:11:51.363 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.online: {"val":false,"ack":true,"ts":1554376311310,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528363}
                                    2019-04-04 13:11:51.363 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.capabilities: {"val":"AUDIBLE,FLASH_BRIEFING,REMINDERS,MICROPHONE,CHANGE_NAME,DREAM_TRAINING,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MUSIC_SKILL,EARCONS,SET_LOCALE,AUDIO_PLAYER,AMAZON_MUSIC,KINDLE_BOOKS,TIMERS_AND_ALARMS,I_HEART_RADIO,VOLUME_SETTING,SOUND_SETTINGS,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,TUNE_IN,SLEEP","ack":true,"ts":1554376311310,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311310}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311311,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528408}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311311,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528420}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceType: {"val":"A1RTAM01W29CUP","ack":true,"ts":1554376311312,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528430}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceTypeString: {"val":"Windows App","ack":true,"ts":1554376311312,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528447}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.serialNumber: {"val":"xxx","ack":true,"ts":1554376311313,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528457}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.name: {"val":"Mario's Alexa App for PC","ack":true,"ts":1554376311313,"q":0,"from":"system.adapter.alexa2.0","lc":1548364528467}
                                    2019-04-04 13:11:51.364 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.online: {"val":true,"ack":true,"ts":1554376311314,"q":0,"from":"system.adapter.alexa2.0","lc":1554336305990}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.capabilities: {"val":"AUDIBLE,ASCENDING_ALARM_VOLUME,REMINDERS,ACTIVE_AFTER_FRO,MICROPHONE,GADGETS,VOICE_TRAINING,FAR_FIELD_WAKE_WORD,DREAM_TRAINING,LEMUR_ALPHA,GOLDFISH,EARCONS,PAIR_REMOTE,AUDIO_PLAYER,SUPPORTS_SOFTWARE_VERSION,SUPPORTS_CONNECTED_HOME,DS_VOLUME_SETTING,TIMERS_AND_ALARMS,I_HEART_RADIO,PAIR_BT_SOURCE,TAHOE_BYOD,VOLUME_SETTING,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,TUNE_IN,FLASH_BRIEFING,SALMON,CHANGE_NAME,SUPPORT_CALENDAR_ALERT,MUSIC_SKILL,SET_LOCALE,PAIR_BT_SINK,CUSTOM_ALARM_TONE,AMAZON_MUSIC,POPTART,UPDATE_WIFI,KINDLE_BOOKS,SOUND_SETTINGS,SUPPORTS_CONNECTED_HOME_ALL,DEREGISTER_FACTORY_RESET,REQUIRES_OOBE_FOR_SETUP,PANDORA,SLEEP","ack":true,"ts":1554376311314,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311314}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311315,"q":0,"from":"system.adapter.alexa2.0","lc":1536502010894}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.isMultiroomMember: {"val":true,"ack":true,"ts":1554376311315,"q":0,"from":"system.adapter.alexa2.0","lc":1536502010909}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.multiroomParents: {"val":"xxx","ack":true,"ts":1554376311315,"q":0,"from":"system.adapter.alexa2.0","lc":1536502010921}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.deviceType: {"val":"A3S5BH2HU6VAYF","ack":true,"ts":1554376311316,"q":0,"from":"system.adapter.alexa2.0","lc":1536502010934}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.deviceTypeString: {"val":"Echo Dot 2.Gen","ack":true,"ts":1554376311316,"q":0,"from":"system.adapter.alexa2.0","lc":1536502010946}
                                    2019-04-04 13:11:51.365 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.serialNumber: {"val":"G090LF11XXXXXXXX","ack":true,"ts":1554376311317,"q":0,"from":"system.adapter.alexa2.0","lc":1536502010983}
                                    2019-04-04 13:11:51.366 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Info.name: {"val":"Wohnzimmer","ack":true,"ts":1554376311317,"q":0,"from":"system.adapter.alexa2.0","lc":1536502011004}
                                    2019-04-04 13:11:51.366 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.online: {"val":false,"ack":true,"ts":1554376311317,"q":0,"from":"system.adapter.alexa2.0","lc":1553889484412}
                                    2019-04-04 13:11:51.366 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.capabilities: {"val":"AUDIBLE,MICROPHONE,CHANGE_NAME,DREAM_TRAINING,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,MUSIC_SKILL,GOLDFISH,AUDIO_PLAYER,AMAZON_MUSIC,KINDLE_BOOKS,I_HEART_RADIO,TIMERS_AND_ALARMS,VOLUME_SETTING,DEREGISTER_DEVICE,PERSISTENT_CONNECTION,PEONY,TUNE_IN,SLEEP","ack":true,"ts":1554376311318,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311318}
                                    2019-04-04 13:11:51.366 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311318,"q":0,"from":"system.adapter.alexa2.0","lc":1552009296128}
                                    2019-04-04 13:11:51.366 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311319,"q":0,"from":"system.adapter.alexa2.0","lc":1552009296138}
                                    2019-04-04 13:11:51.366 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceType: {"val":"A1X7HJX9QL16M5","ack":true,"ts":1554376311319,"q":0,"from":"system.adapter.alexa2.0","lc":1552009296148}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceTypeString: {"val":"Bespoken.io","ack":true,"ts":1554376311320,"q":0,"from":"system.adapter.alexa2.0","lc":1552009296159}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.serialNumber: {"val":"xxx","ack":true,"ts":1554376311320,"q":0,"from":"system.adapter.alexa2.0","lc":1552009296169}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.name: {"val":"Bespoken Device (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device) (Virtual Device)","ack":true,"ts":1554376311321,"q":0,"from":"system.adapter.alexa2.0","lc":1552718715558}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.online: {"val":true,"ack":true,"ts":1554376311321,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856586}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.capabilities: {"val":"MICROPHONE,REMINDERS,VOLUME_SETTING","ack":true,"ts":1554376311322,"q":0,"from":"system.adapter.alexa2.0","lc":1554372702590}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311322,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856587}
                                    2019-04-04 13:11:51.367 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311323,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856588}
                                    2019-04-04 13:11:51.368 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceType: {"val":"A2TF17PFR55MTB","ack":true,"ts":1554376311323,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856588}
                                    2019-04-04 13:11:51.368 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.deviceTypeString: {"val":"Apps","ack":true,"ts":1554376311324,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856589}
                                    2019-04-04 13:11:51.368 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.serialNumber: {"val":"xxx","ack":true,"ts":1554376311325,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856590}
                                    2019-04-04 13:11:51.368 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.xxx.Info.name: {"val":"This Device","ack":true,"ts":1554376311325,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856590}
                                    2019-04-04 13:11:51.368 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.online: {"val":false,"ack":true,"ts":1554376311325,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856584}
                                    2019-04-04 13:11:51.368 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.capabilities: {"val":"MICROPHONE,VOLUME_SETTING,PEONY","ack":true,"ts":1554376311326,"q":0,"from":"system.adapter.alexa2.0","lc":1554376311326}
                                    2019-04-04 13:11:51.369 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.isMultiroomDevice: {"val":false,"ack":true,"ts":1554376311326,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856584}
                                    2019-04-04 13:11:51.369 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.isMultiroomMember: {"val":false,"ack":true,"ts":1554376311327,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856585}
                                    2019-04-04 13:11:51.369 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.deviceType: {"val":"A1DL2DVDQVK3Q","ack":true,"ts":1554376311327,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856585}
                                    2019-04-04 13:11:51.369 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.deviceTypeString: {"val":"Apps","ack":true,"ts":1554376311327,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856585}
                                    2019-04-04 13:11:51.369 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.serialNumber: {"val":"C488XXXXXXXX","ack":true,"ts":1554376311328,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856586}
                                    2019-04-04 13:11:51.369 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.C488XXXXXXXX.Info.name: {"val":"Mario's Alexa Apps","ack":true,"ts":1554376311328,"q":0,"from":"system.adapter.alexa2.0","lc":1549499856586}
                                    2019-04-04 13:11:52.230 - debug: alexa2.0 Alexa-Remote: Response: {"bluetoothStates":[{"deviceSerialNumber":"xxx","deviceType":"A3C9PE6TNYLTCH","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"0","streamingState":null},{"deviceSerialNumber":"G090LF11XXXXXXXX","deviceType":"A3S5BH2HU6VAYF","friendlyName":null,"gadgetPaired":false,"online":true,"pairedDeviceList":[{"address":"8A:11:11:AB:56:65","connected":false,"deviceClass":"OTHER","friendlyName":"NANO BT-X11","profiles":["A2DP-SINK","AVRCP"]}],"sconeBattery":null,"sconePaired":true,"softwareVersion":"631550720","streamingState":null},{"deviceSerialNumber":"G090RF04XXXXXXXX","deviceType":"A7WXQPH584YP","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"631550720","streamingState":null},{"deviceSerialNumber":"G090L911XXXXXXXX","deviceType":"A3S5BH2HU6VAYF","friendlyName":null,"gadgetPaired":false,"online":true,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"631550720","streamingState":null},{"deviceSerialNumber":"G070L808XXXXXXXX","deviceType":"A2LWARUGJLBYEW","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"632552020","streamingState":null},{"deviceSerialNumber":"xxx","deviceType":"A1RTAM01W29CUP","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"0","streamingState":null},{"deviceSerialNumber":"G090LF11XXXXXXXX","deviceType":"A3S5BH2HU6VAYF","friendlyName":null,"gadgetPaired":false,"online":true,"pairedDeviceList":[{"address":"FC:58:FA:06:DD:14","connected":false,"deviceClass":"OTHER","friendlyName":"MusicMan NANO BT-X7","profiles":["A2DP-SINK","AVRCP"]}],"sconeBattery":null,"sconePaired":false,"softwareVersion":"631550720","streamingState":null},{"deviceSerialNumber":"xxx","deviceType":"A1X7HJX9QL16M5","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"0","streamingState":null},{"deviceSerialNumber":"xxx","deviceType":"A2TF17PFR55MTB","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"130050002","streamingState":null},{"deviceSerialNumber":"C488XXXXXXXX","deviceType":"A1DL2DVDQVK3Q","friendlyName":null,"gadgetPaired":false,"online":false,"pairedDeviceList":null,"sconeBattery":null,"sconePaired":false,"softwareVersion":"7020810","streamingState":null}]}
                                    2019-04-04 13:11:52.233 - debug: alexa2.0 Alexa-Remote: No authentication check needed (time elapsed 2151)
                                    2019-04-04 13:11:52.234 - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/np/player?deviceSerialNumber=xxx&deviceType=A3C9PE6TNYLTCH&screenWidth=1392&_=1554376312233","method":"GET","timeout":10000,"headers":{}}
                                    2019-04-04 13:11:52.245 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Bluetooth.8A:11:11:AB:56:65.connected: {"val":false,"ack":true,"ts":1554376312232,"q":0,"from":"system.adapter.alexa2.0","lc":1554313487182}
                                    2019-04-04 13:11:52.247 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Bluetooth.8A:11:11:AB:56:65.unpair: {"val":false,"ack":true,"ts":1554376312243,"q":0,"from":"system.adapter.alexa2.0","lc":1537380239177}
                                    2019-04-04 13:11:52.250 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Bluetooth.FC:58:FA:06:DD:14.connected: {"val":false,"ack":true,"ts":1554376312246,"q":0,"from":"system.adapter.alexa2.0","lc":1543009589964}
                                    2019-04-04 13:11:52.258 - debug: alexa2.0 State changed alexa2.0.Echo-Devices.G090LF11XXXXXXXX.Bluetooth.FC:58:FA:06:DD:14.unpair: {"val":false,"ack":true,"ts":1554376312249,"q":0,"from":"system.adapter.alexa2.0","lc":1539373369214}
                                    2019-04-04 13:11:53.019 - debug: alexa2.0 Alexa-Remote: Response: {"message":"Music metadata was not found for reference id: c434360b-f6ea-4da0-86fa-2e8afe8cbf42:1"}
                                    2019-04-04 13:11:53.019 - debug: alexa2.0 Alexa-Remote: No authentication check needed (time elapsed 2937)
                                    2019-04-04 13:11:53.020 - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/np/player?deviceSerialNumber=G090LF11XXXXXXXX&deviceType=A3S5BH2HU6VAYF&screenWidth=1392&_=1554376313020","method":"GET","timeout":10000,"headers":{}}
                                    2019-04-04 13:11:53.297 - debug: alexa2.0 Alexa-Remote: Response: {"playerInfo":{"hint":null,"infoText":null,"isPlayingInLemur":false,"lemurVolume":null,"lyrics":null,"mainArt":null,"mediaId":null,"miniArt":null,"miniInfoText":null,"playbackSource":null,"playingInLemurId":null,"progress":null,"provider":null,"queueId":null,"state":null,"template":null,"transport":null,"upNextItems":null,"volume":null}}
                                    2019-04-04 13:11:53.297 - debug: alexa2.0 Alexa-Remote: No authentication check needed (time elapsed 3215)
                                    2019-04-04 13:11:53.298 - debug: alexa2.0 Alexa-Remote: Sending Request with {"host":"alexa.amazon.de","path":"/api/media/state?deviceSerialNumber=G090LF11XXXXXXXX&deviceType=A3S5BH2HU6VAYF&screenWidth=1392&_=1554376313297","method":"GET","timeout":10000,"headers":{}}
                                    2019-04-04 13:11:53.812 - debug: alexa2.0 Alexa-Remote: Response: {"message":null}
                                    2019-04-04 13:11:53.817 - error: javascript.0 script.js.Volume_Zero_Warning: !!! Volume auf "0%": Küche/Bad (alexa2.0.Echo-Devices.G090LF11XXXXXXXX) !!!
                                      @padrino Duhast welche Version am laufen? An sich sollten "Null" Werte von volume schon lange ignoriert werden ... ich sehe auch irgendwie nicht das das volume gesetzt wird, sollte auch im Log sein
                                      • Diginix
                                        Diginix last edited by Diginix
                                        Habe seit 3 Tagen einen Echo Dot Gen. 2 und der hat auch das Lautstärke 0 Problem.
                                        08:30 Uhr wird per Skript die Lautstärke auf 80 gesetzt. Gegen 18:40 habe ich mich gewundert dass er so leise ist und auf die Frage wie seine Lautstärke wäre, kam 5 als Antwort. Das ist aber die Lautstärke die ab 22 Uhr gilt und eben 08:30 auf 8 geändert wurde.
                                        18:43 Uhr habe ich die Lautstärke dann per Sprachbefehl auf 8 gesetzt und bekomme das auch als Antwort wenn ich danach frage. Dennoch steht 0 im Datenpunkt.
                                        Meine zwei Echo Dot Gen. 3 zeigen dieses Verhalten nicht.
                                        @padrino Was für einen Echo hast du?
                                          Dann auch bitte hier Debug Log ...
                                          • XxJooO
                                            XxJooO last edited by
                                            Hallo Zusammen,
                                            ich habe hier schon länger nicht mehr mitgelesen, meine mich aber zu erinnern, dass mit der über git installierten Version 2.2.0 die cookie-Probleme der Vergangenheit angehören sollten. Der Adapter geht aber bei mir immer noch alle 2 Wochen auf gelb und muss über den im Log vorhandenen Link mit neuem Cookie versorgt werden, dann wird er wieder grün.
                                            Verzeiht also meine unwissende Frage, geht es nun oder nicht? Wenn es geht, wo kann ich nachlesen, warum es bei mir nicht geht?
                                            Vielen Dank für die Nachsicht, dass ich die 383 Beiträge jetzt nicht eben schnell lesen möchte.
                                            Noch einen schönen sonnigen Rest-Sonntag.
                                            MyzerAT 1 Reply Last reply Reply Quote 0
                                            643
                                            136035
