    4. [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige
      sigi234 Forum Testing Most Active @sveni_lee last edited by sigi234
      @sveni_lee
      Widget Icons
      [{"tpl":"tplMfdCustom10","data":{"oid":"ping.0.Medion.192_168_178_1","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"icon0":"/icons-mfd-svg/it_router.svg","icon1":"","icon2":"","icon3":"","icon4":"","icon5":"","icon6":"","icon7":"","icon8":"","icon9":"","icon10":"/icons-mfd-svg/it_router.svg","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"min":"","max":"","show_active":false,"iconValue0":"false","iconValue1":"","iconValue2":"","iconValue3":"","iconValue4":"","iconValue5":"","iconValue6":"","iconValue7":"","iconValue8":"","iconValue9":"","iconValue10":"true","iconColor0":"#ff0000","iconColor10":"#35ff05","iconColor8":"","iconColor9":"","iconColor3":"","iconColor1":"","iconColor5":"","invert_value":false,"iconColor2":"","iconColor4":"","iconColor7":"","iconColor6":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"391px","top":"548px","z-index":"1","width":"103px","height":"100px","border-style":"solid","border-color":"#0e5bec","border-radius":"2px","border-width":"1px"},"widgetSet":"jqui-mfd"}]
      Widget Rohre (Linien)
      [{"tpl":"tplPlump_pipe_H","data":{"oid":"tr-064.0.states.wlan24","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","pipe_size":"5","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"color_on":"#35ff05","color_off":"#ff050d","conLeft":"w01273"},"style":{"left":"631px","top":"722px","width":"38px","height":"10px","z-index":"0"},"widgetSet":"plumb"}]
        sveni_lee @sigi234 last edited by sveni_lee
        @sigi234
        Danke dafür...
        das erste kann ich nicht einbinden...
        steht bei mir dann w00605 (undefiniert - undefiniert)...
        EDIT: war ein copy and past Fehler
          Könnte mir mal jemand erklären auf was genau die "Aggregation:" im history-Widget Sparkline Einfluss hat?
          Ich bin mir nicht sicher was ich verwenden muss...
            JavaMafia last edited by
            Hat jemand noch das Problem, das diese Werte nicht übereinstimmen von der FritzBox?
            upnp.0.FritzBox6490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesReceived
            upnp.0.FritzBox6490.WANDevice.WANCommonInterfaceConfig.GetAddonInfos.NewTotalBytesSent
            Wenn auch der Received einen Wert von 5GB ca erreicht hat, fängt der wieder bei 0 an.
            Alle anderen Daten werden mir richtig angezeigt.
            benchonaut 1 Reply Last reply Reply Quote 0
              aleks-83 last edited by
              Siehe hier meine Erkenntnisse dazu
                WernerS last edited by WernerS
                Hallo
                bei mir hat alles angefangen zu funktionieren. Jetzt gab es aber updates von Adaptern und nix ging mehr. Ich habe festgestellt das die Ordnerstruktur in den Objekten sich geändert hat und somit auch die Pfade. Ich habe es im Javascript und Blockly angepasst, aber es läuft nicht mehr.
                Wer hat noch das Problem, oder habe ich was übersehen?
                Werner
                  aleks-83 last edited by aleks-83
                  @WernerS
                  Richtig, die Struktur des UPnP Adapters hat sich geändert.
                  Meine FritzBox Punkte finde ich jetzt z.B. unter
                  upnp.0.FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig
                  EDIT:
                  Korrektur:
                  So sieht es jetzt aus:
                  upnp.0.WANDevice_-_FRITZ!Box_7490.WANDevice.WANCommonInterfaceConfig.
                    Hallo
                    bei mir das jetzt so aus
                    upnp.0.AVM_FRITZ!Mediaserver
                    upnp.0.InternetGatewayDeviceV2_-FRITZ!Box_7490
                    upnp.0.WANConnectionDevice
                    -FRITZ!Box_7490
                    upnp.0.WANDevice
                    -_FRITZ!Box_7490
                    Es liegt aber anscheinend nicht an den Scripten, sondern da kommen jetzt wohl keine Daten mehr an. Alle Werte sind leer.
                    Werner
                    • SBorg
                      Wie lange läuft der UPnP denn schon? Beim ersten Start kann es bis zu 20 Minuten dauern bis alle Datenpunkte angelegt sind und dann auch mit Daten befüllt werden.
                        Oh, sorry.
                        Ich habe quatsch erzählt... War zu schnell.
                        Die neue Struktur sieht so aus:
                          Hallo
                          läuft jetzt seid fast 2 Stunden und immer noch keine Daten.
                          UPNP an dere Fritzbox ist immer noch aktiv.
                          Werner
                          • SBorg
                            Hast du denn überhaupt den Scheduler für die gewünschten Datenpunkte aktiviert, bzw. bekommst du Daten wenn du einen Request manuell auslöst?
                              WernerS @SBorg last edited by
                              @SBorg
                              Also das mit dem Request kannte ich nicht. Wieder was gelernt 🙂
                              Wenn ich den auslöse kommen Daten.
                              Der Scheduler ist ja im Script angegeben. Da habe ich nichts geändert ausser die Pfade.
                              Werner
                              • SBorg
                                SBorg Forum Testing Most Active @WernerS last edited by SBorg
                                @WernerS sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                Der Scheduler ist ja im Script angegeben...
                                ... und da ist der Fehler 🙂
                                Das funktioniert mit dem neuen UPnP nicht mehr. Du musst es pro Datenpunkt, oder eben für alle Datenpunkte per request, über den Schraubenschlüssel -> Cron-Scheduler einrichten und im Script disablen, sonst bekommst du keine Daten.
                                W Thisoft 3 Replies Last reply Reply Quote 0
                                  @SBorg
                                  na da muss man erst mal drauf kommen. 🙂 Danke für die Info, werde es mir später mal anschauen.
                                  Im Javascript nur die Zeile raus machen oder den Inhalt in der Klammer löschen? Mal sehen wie das für Blockly geht. Kriege ich schon hin.
                                  gruß
                                  Werner
                                  • Thisoft
                                    Thisoft @SBorg last edited by
                                    @SBorg sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                    Gut zu wissen dass sich da in UPnP generell was geändert hat - ich hab schon an mir selber gezweifelt wieso der Wert nicht mehr aktualisiert wird...
                                    Allerdings ist der request-Datenpunkt in meinen Objekten auch nicht vorhanden. Wo bekomme ich den denn her? Hab schon die neueste Version des UPnP-Adapters installiert...
                                    • SBorg
                                      Das Script kann nun kpl. weggelassen werden. Das hat nichts weiter gemacht als die Datenpunkte abzufragen. Dies macht der UPnP-Adapter nun per Scheduling (und genau das hatte eigentlich das Script gemacht) von alleine.
                                      @Thisoft sagte in [Tutorial] VIS Fritzbox Status & Up/Downloadanzeige:
                                      Hmm, hast du mal den Broker neu gestartet? Das hatten wir auch mal während des Beta-Testes des Adapters. Kann mich nur nicht mehr an den Fix erinnern. Notfalls Adapter anhalten, sämtliche Datenpunkte des UPnP löschen (also direkt das root UPnP.0) + Adapter neu starten. Dann sollte nach ~10-20 Minuten die Datenpunkte alle da sein.
                                        @SBorg
                                        Welchen Schraubenschlüssel meinst du? Der vom Datenpunkt da konfiguriere ich ja das abspeichern in zB. einer SQL Datenbank. Ansonsten kann ich nur die gesamte UPNP Instanz per scheduler einstellen.
                                        Werner
                                          sigi234 Forum Testing Most Active @WernerS last edited by sigi234
                                            WernerS @sigi234 last edited by
                                            @sigi234
                                            Danke für die Info. Ich hatte natürlich bei den Datenpunkten gesucht 🙂
                                            Werner
                                            504
                                            130521
