    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Onkyo
    Onkyo
    • I
      instalator last edited by
      После обновления вообще не работает, постоянно переподключается
      ! onkyo-0 2015-05-14 19:06:01 debug statesDB connected
      ! onkyo-0 2015-05-14 19:06:01 debug objectDB connected
      ! onkyo-0 2015-05-14 19:05:39 debug statesDB connected
      ! onkyo-0 2015-05-14 19:05:39 debug objectDB connected
      ! onkyo-0 2015-05-14 19:05:27 debug statesDB connected
      ! onkyo-0 2015-05-14 19:05:27 debug objectDB connected
      ! onkyo-0 2015-05-14 19:05:17 debug statesDB connected
      ! onkyo-0 2015-05-14 19:05:17 debug objectDB connected
      ! onkyo-0 2015-05-14 19:05:04 info Connecting to AVR 192.168.1.210:60128
      ! onkyo-0 2015-05-14 19:05:04 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
      ! onkyo-0 2015-05-14 19:05:03 debug statesDB connected
      ! onkyo-0 2015-05-14 19:05:03 debug objectDB connected
      ! onkyo-0 2015-05-14 19:04:51 info Connecting to AVR 192.168.1.210:60128
      ! onkyo-0 2015-05-14 19:04:51 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
      ! onkyo-0 2015-05-14 19:04:50 debug statesDB connected
      ! onkyo-0 2015-05-14 19:04:50 debug objectDB connected
      ! onkyo-0 2015-05-14 19:04:37 debug statesDB connected
      ! onkyo-0 2015-05-14 19:04:37 debug objectDB connected
      ! onkyo-0 2015-05-14 19:04:27 info Connecting to AVR 192.168.1.210:60128
      ! onkyo-0 2015-05-14 19:04:27 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
      ! onkyo-0 2015-05-14 19:04:27 debug statesDB connected
      ! onkyo-0 2015-05-14 19:04:27 debug objectDB connected
      ! onkyo-0 2015-05-14 19:04:12 info Connecting to AVR 192.168.1.210:60128
      ! onkyo-0 2015-05-14 19:04:12 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
      ! onkyo-0 2015-05-14 19:04:12 debug statesDB connected
      ! onkyo-0 2015-05-14 19:04:12 debug objectDB connected
      ! onkyo-0 2015-05-14 19:03:58 info Connecting to AVR 192.168.1.210:60128
      ! onkyo-0 2015-05-14 19:03:58 info starting. Version 0.1.3 in c:/ioBroker/node_modules/iobroker.onkyo
      ! onkyo-0 2015-05-14 19:03:58 debug statesDB connected
      ! onkyo-0 2015-05-14 19:03:58 debug objectDB connected
      host-Server-PC 2015-05-14 19:08:29 info Restart adapter system.adapter.onkyo.0 because enabled
      host-Server-PC 2015-05-14 19:08:29 error instance system.adapter.onkyo.0 terminated with code 6 (uncaught exception)
      386_discovery_-_fronius.txt
      • I
        Так и не работает драйвер вообще, постоянно перезапускается, пока отключил вообще.
          electric69 last edited by
          @instalator:
          Так и не работает драйвер вообще, постоянно перезапускается, пока отключил вообще. `
          Тоже адаптер не стартует, в логе ошибки:
          • Bluefox
            Bluefox last edited by
            Можешь новую версию попробовать?
              @Bluefox:
              Можешь новую версию попробовать? `
              Сейчас вроде не вылетает, переменные появились, в логе что то пишется))
              Я просто не пользовался этим адаптером, руки не доходили…
              Если чо, у меня TX-NR509.
              • Bluefox
                Было бы интересно узнать, что пишет
                • I
                  @Bluefox:
                  Было бы интересно узнать, что пишет `
                  ! onkyo-0 2015-05-16 08:49:55 info stateChange onkyo.0.command {"val":"MVL19","ack":true,"ts":1431744596,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:55 debug message onkyo.0.* onkyo.0.command val=MVL19, ack=true, ts=1431744596, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:55 info stateChange onkyo.0.volume {"val":25,"ack":true,"ts":1431744596,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:55 debug message onkyo.0.* onkyo.0.volume val=25, ack=true, ts=1431744596, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:55 info stateChange onkyo.0.master-volume {"val":25,"ack":true,"ts":1431744596,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:55 debug message onkyo.0.* onkyo.0.master-volume val=25, ack=true, ts=1431744596, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:55 debug Received: command[MVL19]
                  ! onkyo-0 2015-05-16 08:49:55 debug Received: volume[25]
                  ! onkyo-0 2015-05-16 08:49:55 debug Received: master-volume[25]
                  ! onkyo-0 2015-05-16 08:49:55 info Got message: {"command":["master-volume","volume"],"argument":25,"iscp_command":"MVL19","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:55 debug DEBUG (received_data) Received data from 192.168.1.210:60128 - {"command":["master-volume","volume"],"argument":25,"iscp_command":"MVL19","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:55 debug DEBUG (sent_command) Sent command to 192.168.1.210:60128 - MVLQSTN
                  ! onkyo-0 2015-05-16 08:49:55 info stateChange onkyo.0.command {"val":"MVL19","ack":true,"ts":1431744595,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:55 debug message onkyo.0.* onkyo.0.command val=MVL19, ack=true, ts=1431744595, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:55 info stateChange onkyo.0.volume {"val":25,"ack":true,"ts":1431744595,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:55 debug message onkyo.0.* onkyo.0.volume val=25, ack=true, ts=1431744595, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:55 info stateChange onkyo.0.master-volume {"val":25,"ack":true,"ts":1431744595,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:55 debug message onkyo.0.* onkyo.0.master-volume val=25, ack=true, ts=1431744595, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:54 debug DEBUG (sent_command) Sent command to 192.168.1.210:60128 - MVLQSTN
                  ! onkyo-0 2015-05-16 08:49:54 info stateChange onkyo.0.command {"val":"AMT00","ack":true,"ts":1431744595,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:54 debug message onkyo.0.* onkyo.0.command val=AMT00, ack=true, ts=1431744595, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:54 info stateChange onkyo.0.mute {"val":false,"ack":true,"ts":1431744595,"from":"system.adapter.onkyo.0","lc":1431744595}
                  ! inMem 2015-05-16 08:49:54 debug message onkyo.0.* onkyo.0.mute val=false, ack=true, ts=1431744595, from=system.adapter.onkyo.0, lc=1431744595
                  ! onkyo-0 2015-05-16 08:49:54 debug Received: command[AMT00]
                  ! onkyo-0 2015-05-16 08:49:54 debug Received: audio-muting[off]
                  ! onkyo-0 2015-05-16 08:49:54 info Got message: {"command":"audio-muting","argument":"off","iscp_command":"AMT00","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:54 debug DEBUG (received_data) Received data from 192.168.1.210:60128 - {"command":"audio-muting","argument":"off","iscp_command":"AMT00","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:54 debug DEBUG (sent_command) Sent command to 192.168.1.210:60128 - AMTQSTN
                  ! onkyo-0 2015-05-16 08:49:53 info stateChange onkyo.0.command {"val":"PWR00","ack":true,"ts":1431744594,"from":"system.adapter.onkyo.0","lc":1431744594}
                  ! inMem 2015-05-16 08:49:53 debug message onkyo.0.* onkyo.0.command val=PWR00, ack=true, ts=1431744594, from=system.adapter.onkyo.0, lc=1431744594
                  ! onkyo-0 2015-05-16 08:49:53 info stateChange onkyo.0.power {"val":"standby","ack":true,"ts":1431744594,"from":"system.adapter.onkyo.0","lc":1431744594}
                  ! inMem 2015-05-16 08:49:53 debug message onkyo.0.* onkyo.0.power val=standby, ack=true, ts=1431744594, from=system.adapter.onkyo.0, lc=1431744594
                  ! onkyo-0 2015-05-16 08:49:53 debug Received: command[PWR00]
                  ! onkyo-0 2015-05-16 08:49:53 debug Received: system-power[standby]
                  ! onkyo-0 2015-05-16 08:49:53 info Got message: {"command":"system-power","argument":"standby","iscp_command":"PWR00","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (received_data) Received data from 192.168.1.210:60128 - {"command":"system-power","argument":"standby","iscp_command":"PWR00","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (sent_command) Sent command to 192.168.1.210:60128 - PWRQSTN
                  ! onkyo-0 2015-05-16 08:49:53 info stateChange onkyo.0.command {"val":"SLI05","ack":true,"ts":1431744593,"from":"system.adapter.onkyo.0","lc":1431744593}
                  ! inMem 2015-05-16 08:49:53 debug message onkyo.0.* onkyo.0.command val=SLI05, ack=true, ts=1431744593, from=system.adapter.onkyo.0, lc=1431744593
                  ! onkyo-0 2015-05-16 08:49:53 info stateChange onkyo.0.input {"val":["video6","pc"],"ack":true,"ts":1431744593,"from":"system.adapter.onkyo.0","lc":1431744593}
                  ! inMem 2015-05-16 08:49:53 debug message onkyo.0.* onkyo.0.input val=[video6, pc], ack=true, ts=1431744593, from=system.adapter.onkyo.0, lc=1431744593
                  ! onkyo-0 2015-05-16 08:49:53 debug Received: command[SLI05]
                  ! onkyo-0 2015-05-16 08:49:53 debug Received: input-selector[video6,pc]
                  ! onkyo-0 2015-05-16 08:49:53 info Got message: {"command":"input-selector","argument":["video6","pc"],"iscp_command":"SLI05","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (received_data) Received data from 192.168.1.210:60128 - {"command":"input-selector","argument":["video6","pc"],"iscp_command":"SLI05","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (sent_command) Sent command to 192.168.1.210:60128 - SLIQSTN
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) raw command "MVLQSTN"
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) Zone: main | Command: master-volume | Argument: query
                  ! onkyo-0 2015-05-16 08:49:53 info Initial query: master-volume
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) Zone: main | Command: volume | Argument: query
                  ! onkyo-0 2015-05-16 08:49:53 info Initial query: volume
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) raw command "AMTQSTN"
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) Zone: main | Command: audio-muting | Argument: query
                  ! onkyo-0 2015-05-16 08:49:53 info Initial query: audio-muting
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) raw command "PWRQSTN"
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) Zone: main | Command: system-power | Argument: query
                  ! onkyo-0 2015-05-16 08:49:53 info Initial query: system-power
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) raw command "SLIQSTN"
                  ! onkyo-0 2015-05-16 08:49:53 debug DEBUG (command_to_iscp) Zone: main | Command: input-selector | Argument: query
                  ! onkyo-0 2015-05-16 08:49:53 info Initial query: input-selector
                  ! onkyo-0 2015-05-16 08:49:48 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1431744588,"from":"system.adapter.onkyo.0","lc":1431744588}
                  ! inMem 2015-05-16 08:49:48 debug message onkyo.0.* onkyo.0.connected val=true, ack=true, ts=1431744588, from=system.adapter.onkyo.0, lc=1431744588
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dab-display-info, ["pt","at","mn","mf","up"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dab-sation-name, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dab-preset, ["no-1-40","up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-list-info, []
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-play-status, ["prs","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-track-info, ["cccc-tttt","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-time-info, ["mm-ss-mm-ss","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-title-name, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-album-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-artist-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: universal-port, ["0","1","2","3","4","5","6","7","8","9","10","setup","up","down","left","right","enter","return","disp","play","stop","pause","skip-f","skip-
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: cd-r-recorder, ["1","2","3","4","5","6","7","8","9","power","p-mode","play","stop","skip-f","skip-r","pause","rec","clear","repeat","10-0","scroll","op-cl","d
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: md-recorder, ["1","2","3","4","5","6","7","8","9","power","play","stop","ff","rew","p-mode","skip-f","skip-r","pause","rec","memory","disp","scroll","m-scan",
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dvd-player, ["0","1","2","3","4","5","6","7","8","9","10","power","pwron","pwroff","play","stop","skip-f","skip-r","ff","rew","pause","lastplay","subton-off",
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dat-recorder, ["play","rc-pau","stop","skip-f","skip-r","ff","rew"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: graphics-equalizer, ["power","preset"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tape2-b, ["play-f","play-r","stop","rc-pau","ff","rew","op-cl","skip-f","skip-r","rec"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tape1-a, ["play-f","play-r","stop","rc-pau","ff","rew"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: cd-player, ["0","1","2","3","4","5","6","7","8","9","10","power","track","play","stop","pause","skip-f","skip-r","memory","clear","repeat","random","disp","d-
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: ipod-mode-change, ["std","ext","vdc","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-popup-message, []
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-keyboard, ["ll"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-service, []
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-jacket-art, ["tp-xx-xx-xx-xx-xx-xx"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-list-info, ["ti"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: internet-radio-preset, ["no-1-40","set"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-play-status, ["prs","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-track-info, ["cccc-tttt","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-time-info, ["mm-ss-mm-ss","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-title-name, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-album-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: net-usb-artist-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: network-usb, ["0","1","2","3","4","5","6","7","8","9","play","stop","pause","trup","trdn","ff","rew","repeat","random","display","album","artist","genre","pla
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-tuner-status, ["mmnnoo","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-blend-mode, ["auto","analog","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-channel-program, ["directly","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-detail-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-title-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-channel-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hd-radio-artist-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sirius-parental-lock, ["input","wrong"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sirius-category, ["up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sirius-channel-number, ["INTRANGES","up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sirius-title-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sirius-artist-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sirius-channel-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: xm-category, ["up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: xm-channel-number, ["INTRANGES","up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: xm-title-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: xm-artist-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: xm-channel-name-info, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tp-scan, ["enter"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: pty-scan, ["no-0-30","enter"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: rds-information, ["00","01","02","up"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: preset-memory, ["INTRANGES"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: preset, ["no-1-40","no-1-30","up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tuning, ["up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: music-optimizer, ["off","on","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dolby-volume, ["off","low","on","mid","high","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: audyssey-dynamic-volume, ["off","light","medium","heavy","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: audyssey-dynamic-eq, ["off","on","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: audyssey-2eq-multeq-multeq-xt, ["off","on","movie","music","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: cinema-filter, ["off","on","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: late-night, ["off","low-dolbydigital","on-dolby-truehd","high-dolbydigital","auto-dolby-truehd","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: listening-mode, ["pure-audio","multiplex","full-mono","dolby-virtual","dts-surround-sensation","audyssey-dsx","straight-decode","dolby-ex","thx-cinema","thx-s
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: video-picture-mode, ["through","custom","cinema","game","isf-day","isf-night","streaming","direct","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: video-wide-mode, ["auto","4-3","full","zoom","smart-zoom","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: isf-mode, ["custom","day","night","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: monitor-out-resolution, ["through","auto","480p","720p","1080i","1080p","24fs","4k-upcaling","source","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hdmi-audio-out, ["off","on","auto","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: hdmi-output-selector, ["no","analog","yes","out","out-sub","sub","both","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: video-output-selector, ["d4","component","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: 12v-trigger-c, ["off","on"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: 12v-trigger-b, ["off","on"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: 12v-trigger-a, ["off","on"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: audio-selector, ["auto","multi-channel","analog","ilink","hdmi","coax","opt","balance","arc","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: recout-selector, ["dvd","tape","tape2","phono","cd","fm","am","tuner","music-server","internet-radio","multi-ch","xm","source","video1","video2","video3","vid
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: input-selector, ["dvd","bd","tape-1","tv","tape","tape2","phono","cd","fm","am","tuner","music-server","p4s","dlna","internet-radio","iradio-favorite","usb","
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: video-infomation, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: audio-infomation, ["query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: memory-setup, ["str","rcl","lock","unlk"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: setup, ["menu","up","down","right","left","enter","exit","audio","video","home"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: dimmer-level, ["bright","dim","dark","shut-off","bright-led-off","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: display-mode, ["selector-volume","selector-listening","02","03","toggle","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: center-temporary-level, ["12db-0db-12db","up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: subwoofer-temporary-level, ["15db-0db-12db","up","down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: speaker-level-calibration, ["test","chsel","up","down"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: sleep-set, ["time-1-90min","time-off","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-subwoofer, ["bass-up","bass-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-surround-back, ["bass-up","bass-down","treble-up","treble-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-surround, ["bass-up","bass-down","treble-up","treble-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-center, ["bass-up","bass-down","treble-up","treble-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-front-high, ["bass-up","bass-down","treble-up","treble-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-front-wide, ["bass-up","bass-down","treble-up","treble-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: tone-front, ["bass-up","bass-down","treble-up","treble-down","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: volume, ["INTRANGES","level-up","level-down","level-up-1db-step","level-down-1db-step","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: master-volume, ["INTRANGES","level-up","level-down","level-up-1db-step","level-down-1db-step","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: speaker-layout, ["surrback","front-high","surrback-front-high-speakers","front-wide","surrback-front-wide-speakers","front-high-front-wide-speakers","up","que
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: speaker-b, ["off","on","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: speaker-a, ["off","on","up","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: audio-muting, ["off","on","toggle","query"]
                  ! onkyo-0 2015-05-16 08:49:48 debug Please send following info to developer: system-power, ["standby","on","query"]
                  ! onkyo-0 2015-05-16 08:49:48 info Successfully connected to AVR
                  ! onkyo-0 2015-05-16 08:49:48 debug INFO (connected) Connected to 192.168.1.210:60128 (model: TX-NR818)
                  ! onkyo-0 2015-05-16 08:49:48 debug INFO (connecting) Connecting to 192.168.1.210:60128 (model: TX-NR818)
                  ! onkyo-0 2015-05-16 08:49:48 debug DEBUG (received_discovery) Received discovery packet from 192.168.1.210:60128 ([{"host":"192.168.1.210","port":"60128","model":"TX-NR818","mac":"0009B0469B14","areacode":"XX"}])
                  ! onkyo-0 2015-05-16 08:49:48 debug DEBUG (sent_discovery) Sent broadcast discovery packet to 192.168.1.210:60128
                  ! onkyo-0 2015-05-16 08:49:48 info Connecting to AVR 192.168.1.210:60128
                  ! onkyo-0 2015-05-16 08:49:48 info starting. Version 0.1.4 in c:/ioBroker/node_modules/iobroker.onkyo
                  ! onkyo-0 2015-05-16 08:49:48 debug statesDB connected
                  ! onkyo-0 2015-05-16 08:49:48 debug objectDB connected
                  ! host-Server-PC 2015-05-16 08:49:45 info instance system.adapter.onkyo.0 started with pid 3816
                  Громкость так и не регулирует(
                  onkyo-0 2015-05-16 09:08:56 error Error: ERROR (arg_not_in_range) Command master-volume=38 is not available on this model
                  onkyo-0 2015-05-16 09:08:56 debug DEBUG (command_to_iscp) Zone: main | Command: master-volume | Argument: 38
                  • Bluefox
                    Теперь должен регулировать.
                    • I
                      @Bluefox:
                      Теперь должен регулировать. `
                      Very nice!!!
                      Отлично работает!!!
                      • I
                        @Bluefox:
                        Если заработает, то надо подумать, какие ещё комманды необходимы, кроме громкости и вкл/выкл. `
                        Вообщем нужно добавить пока управляющие команды.
                        • вкл\выкл*
                        • Выбор входа (PC, TV, Tuner и тд)*
                        • Можно навесить на переменные кнопки пульта (Не все а самые часты и необходимые для сценариев)
                        • ну и громкость не поломать)
                        Это пока основное что нужно.
                        Для Onkyo есть приложение для телефона, в приложении можно выбрать например можно выбрать V-tuner (интернет радио) находится в input NET, сложно ли с помощью библиотечки отобразить в iobrokere список радиостанций? Есть еще и dlna.
                          • Нужны в первую очередь
                        • I
                          В vis нету переменных для power, выбора источников и т.д. хотя в списке состояний они есть.
                          • Bluefox
                            Перезапусти web
                            • I
                              @Bluefox:
                              Перезапусти web `
                              Дак их там никогда и не было. Перезапускался уже 1000 раз.
                              • Bluefox
                                Удали неработающие states и обнови onkyo. Должно заработать.
                                • I
                                  @Bluefox:
                                  Удали неработающие states и обнови onkyo. Должно заработать. `
                                  Удалил, обновил. Ресивер включил, выключил. Новых не добавилось, только те что и были.
                                  Что должно было появится?
                                  Сегодня уже ночь, поиграться с ресивером нет возможности.
                                  • Bluefox
                                    Не должно было новых добавиться. Но те что были неправильными, должны были создаться заново с правильными атрибутами.
                                    Был тип number, а должен быть state.
                                    • I
                                      @Bluefox:
                                      Был тип number, а должен быть state. `
                                      Удалил заново. Поставил. Новых не добавилось. в логе ошибки
                                      ! host-Server-PC 2015-06-18 11:52:04 error instance system.adapter.onkyo.0 terminated with code 6 (uncaught exception)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at readableAddChunk (_stream_readable.js:166:9)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at emitReadable (stream_readable.js:423:5)
                                      (_stream_readable.js:427:10)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at Socket.emit (events.js:92:17)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at Socket. (_stream_readable.js:765:14)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at Socket.emit (events.js:95:17)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at Socket. (c:\ioBroker\node_modules\iobroker.onkyo\node_modules\eiscp\eiscp.js:376:8)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at EventEmitter.emit (events.js:95:17)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at EventEmitter. (c:\ioBroker\node_modules\iobroker.onkyo\onkyo.js:200:13)
                                      ! ReferenceError: 2015-06-18 11:52:04 error at notifyCommand (c:\ioBroker\node_modules\iobroker.onkyo\onkyo.js:108:102)
                                      ! ReferenceError: 2015-06-18 11:52:04 error type is not defined
                                      ! uncaught 2015-06-18 11:52:04 error exception: type is not defined
                                      ! onkyo-0 2015-06-18 11:53:44 info Got message: {"command":"net-usb-time-info","iscp_command":"NTM01:32/–:--","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:53:43 info Got message: {"command":"net-usb-list-info","iscp_command":"NLSC-P","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:53:43 info stateChange onkyo.0.command {"val":"NLT0222000000000000000200","ack":true,"ts":1434606824,"from":"system.adapter.onkyo.0","lc":1434606724}
                                      ! onkyo-0 2015-06-18 11:53:43 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1434606824,"from":"system.adapter.onkyo.0","lc":1434606502}
                                      ! onkyo-0 2015-06-18 11:53:43 error Empty command string! (value: undefined
                                      ! onkyo-0 2015-06-18 11:53:43 info Got message: {"iscp_command":"NLT0222000000000000000200","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:53:43 info Successfully connected to AVR
                                      ! onkyo-0 2015-06-18 11:53:43 info Starting AVR discovery
                                      ! onkyo-0 2015-06-18 11:53:43 info starting. Version 0.1.6 in c:/ioBroker/node_modules/iobroker.onkyo
                                      ! onkyo-0 2015-06-18 11:53:11 info Got message: {"command":"net-usb-time-info","iscp_command":"NTM00:59/--:--","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:53:10 info Got message: {"command":"net-usb-list-info","iscp_command":"NLSC-P","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:53:10 info stateChange onkyo.0.command {"val":"NLT0222000000000000000200","ack":true,"ts":1434606791,"from":"system.adapter.onkyo.0","lc":1434606724}
                                      ! onkyo-0 2015-06-18 11:53:10 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1434606791,"from":"system.adapter.onkyo.0","lc":1434606502}
                                      ! onkyo-0 2015-06-18 11:53:10 error Empty command string! (value: undefined
                                      ! onkyo-0 2015-06-18 11:53:10 info Got message: {"iscp_command":"NLT0222000000000000000200","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:53:10 info Successfully connected to AVR
                                      ! onkyo-0 2015-06-18 11:53:10 info Starting AVR discovery
                                      ! onkyo-0 2015-06-18 11:53:10 info starting. Version 0.1.6 in c:/ioBroker/node_modules/iobroker.onkyo
                                      ! onkyo-0 2015-06-18 11:52:37 info Got message: {"command":"net-usb-list-info","iscp_command":"NLSC-P","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:52:37 info stateChange onkyo.0.command {"val":"NLT0222000000000000000200","ack":true,"ts":1434606757,"from":"system.adapter.onkyo.0","lc":1434606724}
                                      ! onkyo-0 2015-06-18 11:52:37 info stateChange onkyo.0.connected {"val":true,"ack":true,"ts":1434606757,"from":"system.adapter.onkyo.0","lc":1434606502}
                                      ! onkyo-0 2015-06-18 11:52:37 error Empty command string! (value: undefined
                                      ! onkyo-0 2015-06-18 11:52:37 info Got message: {"iscp_command":"NLT0222000000000000000200","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:52:37 info Successfully connected to AVR
                                      ! onkyo-0 2015-06-18 11:52:37 info Starting AVR discovery
                                      ! onkyo-0 2015-06-18 11:52:37 info starting. Version 0.1.6 in c:/ioBroker/node_modules/iobroker.onkyo
                                      ! onkyo-0 2015-06-18 11:52:04 info Got message: {"command":"net-usb-list-info","iscp_command":"NLSC-P","host":"192.168.1.210","port":"60128","model":"TX-NR818"}
                                      ! onkyo-0 2015-06-18 11:52:04 info stateChange onkyo.0.command {"val":"NLT0222000000000000000200","ack":true,"ts":1434606724,"from":"system.adapter.onkyo.0","lc":1434606724}
                                      ! onkyo-0 2015-06-18 11:52:04 error Empty command string! (value: undefined
                                      ! host-Server-PC 2015-06-18 11:55:37 info instance system.adapter.email.0 started with pid 4860
                                      ! host-Server-PC 2015-06-18 11:55:36 info instance system.adapter.mqtt.0 started with pid 4668
                                      ! host-Server-PC 2015-06-18 11:55:35 warn instance system.adapter.history.0 already running with pid 4748
                                      ! host-Server-PC 2015-06-18 11:55:33 info instance system.adapter.web.0 started with pid 4736
                                      ! host-Server-PC 2015-06-18 11:55:33 info instance system.adapter.history.0 started with pid 4748
                                      ! host-Server-PC 2015-06-18 11:55:33 info instance system.adapter.javascript.1 started with pid 4732
                                      ! pushover-0 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! simple-api-0 2015-06-18 11:55:33 warn Reconnection to DB.
                                      ! simple-api-0 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! web-0 2015-06-18 11:55:33 warn Reconnection to DB.
                                      ! node-red-0 2015-06-18 11:55:33 warn Reconnection to DB.
                                      ! email-0 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! example-0 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! admin-0 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! javascript-1 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! host-Server-PC 2015-06-18 11:55:32 info instance system.adapter.onkyo.0 started with pid 4260
                                      ! history-0 2015-06-18 11:55:32 warn Reconnection to DB.
                                      ! host-Server-PC 2015-06-18 11:55:32 info instance system.adapter.node-red.0 started with pid 4392
                                      ! socketio-0 2015-06-18 11:55:31 warn Reconnection to DB.
                                      ! mqtt-0 2015-06-18 11:55:31 warn Reconnection to DB.
                                      ! host-Server-PC 2015-06-18 11:55:31 info instance system.adapter.admin.0 started with pid 4340
                                      ! host-Server-PC 2015-06-18 11:55:31 info starting 13 instances
                                      ! host-Server-PC 2015-06-18 11:55:31 info 22 instances found
                                      ! host-Server-PC 2015-06-18 11:55:31 info InMemoryDB connected
                                      ! inMem-objects 2015-06-18 11:55:31 info listening on port 9001
                                      ! host-Server-PC 2015-06-18 11:55:28 info Restart adapter system.adapter.socketio.0 because enabled
                                      ! host-Server-PC 2015-06-18 11:55:28 error instance system.adapter.socketio.0 terminated with code 7 (Adapter already running)
                                      ! fragmentedOperation: 2015-06-18 11:55:28 error restart objects
                                      ! host-Server-PC 2015-06-18 11:55:27 info Restart adapter system.adapter.javascript.1 because enabled
                                      ! host-Server-PC 2015-06-18 11:55:27 error instance system.adapter.javascript.1 terminated with code 7 (Adapter already running)
                                      ! host-Server-PC 2015-06-18 11:55:27 info Restart adapter system.adapter.pushover.0 because enabled
                                      ! host-Server-PC 2015-06-18 11:55:27 error instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
                                      ! host-Server-PC 2015-06-18 11:55:23 info Restart adapter system.adapter.node-red.0 because enabled
                                      ! host-Server-PC 2015-06-18 11:55:23 error instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
                                      ! host-Server-PC 2015-06-18 11:55:21 info instance system.adapter.pushover.0 started with pid 3504
                                      ! host-Server-PC 2015-06-18 11:55:21 info Restart adapter system.adapter.onkyo.0 because enabled
                                      И драйвер останавливается.
                                      • I
                                        Что то вывалилось в лог.
                                        Так и не работает. все драйвера перезапускаются без конца.
                                        Пока что вообще удалил Onkyo
                                        ! onkyo-0 2015-06-18 13:05:51 debug Please send following info to developer: master-volume, ['INTRANGES','level-up','level-down','level-up-1db-step','level-down-1db-step','query']
                                        ! onkyo-0 2015-06-18 13:05:51 debug Please send following info to developer: speaker-layout, ['surrback','front-high','surrback-front-high-speakers','front-wide','surrback-front-wide-speakers','front-high-front-wide-speakers','up','query']
                                        ! onkyo-0 2015-06-18 13:05:51 debug Please send following info to developer: speaker-b, ['off','on','up','query']
                                        ! onkyo-0 2015-06-18 13:05:51 debug Please send following info to developer: speaker-a, ['off','on','up','query']
                                        ! onkyo-0 2015-06-18 13:05:51 debug Please send following info to developer: audio-muting, ['off','on','toggle','query']
                                        ! onkyo-0 2015-06-18 13:05:51 debug Please send following info to developer: system-power, ['standby','on','query']
                                        • Bluefox
                                          Мне просто интересно:
                                          Неужели не видно по сообщению об ошибке:
                                          Где ошибка в строчке 108 (позиция 102)
                                                  adapter.log.info('Create new object: ' + adapter.namespace + '.' + cmdstring + ', type = ' + type);
                                          "type is not defined" означает, что переменная type не существует.
                                          Попробуй этот файл. 48_onkyo.js
                                          • I
                                            @Bluefox:
                                            Попробуй этот файл. filename="onkyo.js" index="1">~~ `
                                            ) Я не программист! Но радиолюбитель! В школе информатики не было. Изучал Бейсик методом научного тыка на БК типа спектрум т.к. из литературы была только книжка от самого спектрума. Помню было там пару строк на мнемонике - это вообще был темный лес.
                                            В универе изучали Паскаль и то общий курс. На предмете микропроцессорная техника изучали Z80 на него же писали программы (возведение в квадрат и т.п)на ассемблере.
                                            На микроконтроллеры тоже писали под диктовку препода в тетрадке программы на асме. Си вообще не изучали, про node.js узнал из-за проекта CCU. Первый микроконтроллер прошил на дипломной(диплом делал в железе), прогу писал в AVR Studio на Си (Прибор для измерения ЭМИ, с разложением через FFT(библиотека на асме от одного японца:)) сигнала на частотный спектр и вывод на дисплей уровня и спектра.).
                                            Как то так.
                                            Я понимаю что iobroker твое детище и ты в его когде как рыба в воде, для меня например эта строка adapter.log.info('Create new object: ' + adapter.namespace + '.' + cmdstring + ', type = ' + type); говорит о том что просто пишется отчет о созданном объекте в который подставляются переменные и из за чего начинают все драйвера перезапускаться мне не понятно.
                                            21946
