    4. Skript für DarkSky Wetterdaten
      Dschaedl last edited by Dschaedl
      Hallo zusammen
      Da WU keine Daten mehr liefert (zumindest gratis nicht) habe ich mir heute ein Skript zum auslesen der DarkSky Daten gebaut (quick&dirty).
      Wenn's jemand gebrauchen kann, nur zu.
      Falls ich mal Zeit finde werde ich evtl. einen Adapter daraus machen - oder jemand von euch übernimmt 😉
      var request = require('request');
      var moment = require('moment');
      extractDarkSkyData(null);
      // Trigger
      schedule("*/5 * * * *", function (data) {
          extractDarkSkyData(data);
      function extractDarkSkyData(data) {
          log("calling Darksky Wetter URL", 'info');
          //https://api.darksky.net/forecast/2cd....997/47.2694981,8.6569669?units=si&lang=de
          request('https://api.darksky.net/forecast/<yourApiKey>/<yourCoordinates>?units=si&lang=de',
                   {json:true}, function (error, response, body) {
              log("looking for DarkSky data...", 'info');
              if (!error && response.statusCode == 200) {
                  log ("error:" + error);
                  log ("basics", 'info');
                  setIfDifferent('darksky.latitude', "Latitude", body.latitude, 0, "°", true);
                  setIfDifferent('darksky.longitude', "Longitude", body.longitude, 0, "°", true);
                  setIfDifferent('darksky.timezone', "Timezone", body.timezone, "n/a", "", false);
                  log ("current", 'info');
                  setIfDifferent('darksky.currently.time', "time (unix, local)", body.currently.time, 0, " unix", true);
                  setIfDifferent('darksky.currently.summary', "Weather", body.currently.summary, "n/a", "", false);
                  setIfDifferent('darksky.currently.icon', "", body.currently.icon, "", "", false);
                  setIfDifferent('darksky.currently.precipIntensity', "Niederschlag", body.currently.precipIntensity, 0, "mm/h", true);
                  setIfDifferent('darksky.currently.precipProbability', "Niederschlag Wahrscheinlichkeit", body.currently.precipProbability *100, 0, "%", true);
                  setIfDifferent('darksky.currently.precipType', "Niederschlag Typ", body.currently.precipType, "", "", false);
                  setIfDifferent('darksky.currently.temperature', "Temperatur", body.currently.temperature, 0, "°C", true);
                  setIfDifferent('darksky.currently.apparentTemperature', "Temperatur (Windchill)", body.currently.apparentTemperature, 0, "°C", true);
                  setIfDifferent('darksky.currently.dewPoint', "Taupunkt", body.currently.dewPoint, 0, "°C", true);
                  setIfDifferent('darksky.currently.humidity', "Luftfeuchtigkeit", body.currently.humidity *100, 0, "%", true);
                  setIfDifferent('darksky.currently.pressure', "Luftdruck", body.currently.pressure, 0, "hPa", true);
                  setIfDifferent('darksky.currently.windSpeed', "Windgeschwindigkeit", body.currently.windSpeed, 0, "m/s", true);
                  setIfDifferent('darksky.currently.windGust', "Boen", body.currently.windGust, 0, "m/s", true);
                  setIfDifferent('darksky.currently.windBearing', "Windrichtung", body.currently.windBearing, 0, "°", true);
                  setIfDifferent('darksky.currently.cloudCover', "Bedeckungsgrad", body.currently.cloudCover *100, 0, "%", true);
                  setIfDifferent('darksky.currently.uvIndex', "UV Index", body.currently.uvIndex, 0, "", true);
                  setIfDifferent('darksky.currently.visibility', "Sichtweite", body.currently.visibility, 0, "km", true);
                  setIfDifferent('darksky.currently.ozone', "Ozon", body.currently.ozone, 0, "DU", true);
                  var obsDate = moment.unix(body.currently.time);
                  var now = moment();
                  var age = moment.duration(now.diff(obsDate));
                  log("age in Seconds: " + age.asSeconds(), 'info');
                  setIfDifferent('darksky.currently.age', 'current_age', age.asSeconds(), 0, 's', true);
                  setIfDifferent('darksky.currently.time2', 'Zeit', obsDate.format("DD.MM.YYYY HH:mm:ss ZZ"), "", '', false);
                  log ("hourly", 'info');
                  var i=0;
                  body.hourly.data.forEach(function(value, index, array){
                      var obsDate = moment.unix(value.time);
                      var now = moment();
                      //I'm only interested in future data. If you want all data, remove the 'if'
                      if (age < 0) {
                          log("future entry. store it", 'debug');
                          setIfDifferent('darksky.hourly.'+i+'.time', "time (unix, local)", value.time, 0, "unix", true);
                          setIfDifferent('darksky.hourly.'+i+'.summary', "Weather", value.summary, "n/a", "", false);
                          setIfDifferent('darksky.hourly.'+i+'.icon', "", value.icon, "", "", false);
                          setIfDifferent('darksky.hourly.'+i+'.precipIntensity', "Niederschlag", value.precipIntensity, 0, "mm/h", true);
                          setIfDifferent('darksky.hourly.'+i+'.precipProbability', "Niederschlag Wahrscheinlichkeit", value.precipProbability *100, 0, "%", true);
                          setIfDifferent('darksky.hourly.'+i+'.precipType', "Niederschlag Typ", value.precipType, "", "", false);
                          setIfDifferent('darksky.hourly.'+i+'.temperature', "Temperatur", value.temperature, 0, "°C", true);
                          setIfDifferent('darksky.hourly.'+i+'.apparentTemperature', "Temperatur (Windchill)", value.apparentTemperature, 0, "°C", true);
                          setIfDifferent('darksky.hourly.'+i+'.dewPoint', "Taupunkt", value.dewPoint, 0, "°C", true);
                          setIfDifferent('darksky.hourly.'+i+'.humidity', "Luftfeuchtigkeit", value.humidity *100, 0, "%", true);
                          setIfDifferent('darksky.hourly.'+i+'.pressure', "Luftdruck", value.pressure, 0, "hPa", true);
                          setIfDifferent('darksky.hourly.'+i+'.windSpeed', "Windgeschwindigkeit", value.windSpeed, 0, "m/s", true);
                          setIfDifferent('darksky.hourly.'+i+'.windGust', "Boen", value.windGust, 0, "m/s", true);
                          setIfDifferent('darksky.hourly.'+i+'.windBearing', "Windrichtung", value.windBearing, 0, "°", true);
                          setIfDifferent('darksky.hourly.'+i+'.cloudCover', "Bedeckungsgrad", value.cloudCover *100, 0, "%", true);
                          setIfDifferent('darksky.hourly.'+i+'.uvIndex', "UV Index", value.uvIndex, 0, "", true);
                          setIfDifferent('darksky.hourly.'+i+'.visibility', "Sichtweite", value.visibility, 0, "km", true);
                          setIfDifferent('darksky.hourly.'+i+'.ozone', "Ozon", value.ozone, 0, "DU", true);
                          setIfDifferent('darksky.hourly.'+i+'.age', 'current_age', age.asSeconds(), 0, 's', true);
                          setIfDifferent('darksky.hourly.'+i+'.time2', 'Zeit', obsDate.format("DD.MM.YYYY HH:mm:ss ZZ"), "", '', false);
                          i++
                      } else {
                          log("past entry - not stored");
                  log ("daily", 'info');
                  i=0;
                  body.daily.data.forEach(function(value, index, array){
                      var now = moment();
                      if (age < 0) {
                          setIfDifferent('darksky.daily.'+i+'.time', "time (unix, local)", value.time, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.summary', "Weather", value.summary, "n/a", "", false);
                          setIfDifferent('darksky.daily.'+i+'.icon', "", value.icon, "", "", false);
                          setIfDifferent('darksky.daily.'+i+'.sunriseTime', "Sonnenaufgang", value.sunriseTime, "", "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.sunsetTime', "Sonnenuntergang", value.sunsetTime, "", "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.moonPhase', "Mondphase", value.moonPhase *100, 0, "%", true);
                          setIfDifferent('darksky.daily.'+i+'.precipIntensity', "Niederschlag", value.precipIntensity, 0, "mm/h", true);
                          setIfDifferent('darksky.daily.'+i+'.precipIntensityMax', "Niederschlag MAX", value.precipIntensityMax, 0, "mm/h", true);
                          setIfDifferent('darksky.daily.'+i+'.precipIntensityMaxTime', "Niederschlag MAX Zeit", value.precipIntensityMaxTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.precipProbability', "Niederschlag Wahrscheinlichkeit", value.precipProbability *100, 0, "%", true);
                          setIfDifferent('darksky.daily.'+i+'.precipType', "Niederschlag Typ", value.precipType, "", "", false);
                          setIfDifferent('darksky.daily.'+i+'.temperatureHigh', "Temperatur High", value.temperatureHigh, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureHighTime', "Temperatur High Zeit", value.temperatureHighTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureLow', "Temperatur Low", value.temperatureLow, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureLowTime', "Temperatur Low Zeit", value.temperatureLowTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureHigh', "Temperatur High (Windchill)", value.apparentTemperatureHigh, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureHighTime', "Temperatur (Windchill) High Zeit", value.apparentTemperatureHighTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureLow', "Temperatur Low (Windchill)", value.apparentTemperatureLow, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureLowTime', "Temperatur (windchill) Low Zeit", value.apparentTemperatureLowTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.dewPoint', "Taupunkt", value.dewPoint, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.humidity', "Luftfeuchtigkeit", value.humidity *100, 0, "%", true);
                          setIfDifferent('darksky.daily.'+i+'.pressure', "Luftdruck", value.pressure, 0, "hPa", true);
                          setIfDifferent('darksky.daily.'+i+'.windSpeed', "Windgeschwindigkeit", value.windSpeed, 0, "m/s", true);
                          setIfDifferent('darksky.daily.'+i+'.windGust', "Boen", value.windGust, 0, "m/s", true);
                          setIfDifferent('darksky.daily.'+i+'.windGustTime', "Boen Zeit", value.windGustTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.windBearing', "Windrichtung", value.windBearing, 0, "°", true);
                          setIfDifferent('darksky.daily.'+i+'.cloudCover', "Bedeckungsgrad", value.cloudCover *100, 0, "%", true);
                          setIfDifferent('darksky.daily.'+i+'.uvIndex', "UV Index", value.uvIndex, 0, "", true);
                          setIfDifferent('darksky.daily.'+i+'.uvIndexTime', "UV Index Zeit", value.uvIndexTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.visibility', "Sichtweite", value.visibility, 0, "km", true);
                          setIfDifferent('darksky.daily.'+i+'.ozone', "Ozon", value.ozone, 0, "DU", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureMax', "Temperatur MAX", value.temperatureMax, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureMaxTime', "Temperatur MAX Zeit", value.temperatureMaxTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureMin', "Temperatur MIN", value.temperatureMin, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.temperatureMinTime', "Temperatur MIN Zeit", value.temperatureMinTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMax', "Temperatur MAX (Windchill)", value.apparentTemperatureMax, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMaxTime', "Temperatur (Windchill) MAX Zeit", value.apparentTemperatureMaxTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMin', "Temperatur MIN (Windchill)", value.apparentTemperatureMin, 0, "°C", true);
                          setIfDifferent('darksky.daily.'+i+'.apparentTemperatureMinTime', "Temperatur (windchill) MAX Zeit", value.apparentTemperatureMinTime, 0, "unix", true);
                          setIfDifferent('darksky.daily.'+i+'.age', 'current_age', age.asSeconds(), 0, 's', true);
                          setIfDifferent('darksky.daily.'+i+'.time2', 'Zeit', obsDate.format("DD.MM.YYYY HH:mm:ss ZZ"), "", '', false);
                          i++
                      } else {
              } else {
                  log ("error:" + error.stack, 'error');
              log("END Darksky Wetter data...", 'info');
      function setIfDifferent(id, name, value, initVal, unit, isNumber) {
          var oldVal = getState(id);
          if (oldVal.notExist) {
              createState(id, {name: name, initialValue: initVal, unit: unit}, function(){
              log("new State created: " + id + " ->" + name);
              setIfDifferent(id, name, value, initVal, unit);
          else if (oldVal.val != value) {
              if (isNumber) {
                  setState(id, parseFloat(value));
              } else {
                  setState(id, value);
              log("new Value set for " + name + " (" + id + ")" + ": " + value + " / old: " + oldVal.val, 'info');
      viele Grüsse
      Daniel
        martin111 last edited by
        Wollte das Script ausprobieren.
        Nur bekomme ich es nicht zum laufen.
        Fehlermeldungen direkt aus dem Script-Editor und aus dem Log habe ich angehängt.
        Habe ich da ein Problem in Zeile 16 mit constants ? Wenn ich mit Maus über das Wort fahre erhalte ich folgenden Text:
        Cannot find name 'constants'. Did you mean '"constants"'?
        any
        Wahrscheinlich ist es eh nur eine Kleinigkeit, aber für mich sind Scripte Neuland.
        LG
        Martin
          Hallo Martin
          Lass diese Option einfach mal weg. die braucht es eigentlich gar nicht:
          also
          viele Grüsse
          Daniel
          P.S.
          Ich nehme sie oben auch raus.
            Danke, danke, danke.
            Funktioniert nun perferkt.
              dos1973 last edited by
              das script funktioniert bei mir und holt Daten, aber mein iobroker schmiert total ab???
                sigi234 Forum Testing Most Active @Dschaedl last edited by
                @Dschaedl sagte in Skript für DarkSky Wetterdaten:
                Siehe mal da:
                Link
                  da gibts aber wieder kein "current" also aktuelles wetter, oder?
                  Darksky hat auch das "jetzt" wetter
                    sigi234 Forum Testing Most Active @dos1973 last edited by
                    @dos1973 sagte in Skript für DarkSky Wetterdaten:
                    Doch, ein Auszug davon:
                      ok, dann schau ich da mal rein, Danke
                        martin111 @dos1973 last edited by
                        hmm, also bei mir rennt das Script nun seit 28.März ohne Probleme durch, und auch Iobroker macht keine Zicken
                          JB72 last edited by
                          deute ich das hier richtig:
                          das die 5 bedeutet alle 5 Minuten werden die aktuellen Daten geholt? Weil ich mich gewundert habe in der Darksky API, das da schon über 200 Aufrufe waren, wobei das
                          Script erst ein paar Stunden lief.
                          Kann man hier einen kleineren Intervall einstellen? So oft muss das ja nicht sein die Daten abzurufen, auch wenn 1000 Aufrufe kostenfrei sind.
                          JB
                          climate javascript
                          1523
