    3. Entwicklung
    4. [Adapter] Neuer radar2-Adapter
      @frankjoke
      Ich habe soeben mal ein update gemacht, jedoch erscheinen nun folgende Warnmeldungen
      radar2.0 2019-03-31 22:28:02.602 warn error item Alexa-Noel=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anon
      radar2.0 2019-03-31 22:27:55.592 warn error item ACER-Extensa=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <an
      radar2.0 2019-03-31 22:27:48.662 warn error item JaninaA5=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonym
      radar2.0 2019-03-31 22:27:47.430 warn error item GalaxyS8Mario=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <a
      radar2.0 2019-03-31 22:27:44.631 warn error item Forum=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonymous
      radar2.0 2019-03-31 22:27:44.604 info Init item ECB- with { name: 'ECB-', ip: 'USD,RUB,GBP', id: 'ECB', type: 'ECB' }
      radar2.0 2019-03-31 22:27:44.573 warn error item Fritzbox=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonym
      radar2.0 2019-03-31 22:27:44.504 warn error item Ich-=%e TypeError: Cannot read property 'catch' of undefined at A.getState.then.catch.then.then.then.catch.then (/opt/iobroker/node_modules/iobroker.radar2/radar2.js:606:118) at <anonymous>
      frankjoke 2 Replies Last reply Reply Quote 0
      • frankjoke
        frankjoke @crunchip last edited by
        @crunchip
        Ok, schau mir das mal an...
        • frankjoke
          @crunchip
          Ok, das sollte jetzt auf Git behoben sein, auf npm mit v 1.0.5 kommts auch bald.
          Das kommt davon wenn man nicht selbst neu von git beim Testen installiert....
          crunchip 2 Replies Last reply Reply Quote 0
            crunchip Forum Testing Most Active @frankjoke last edited by
            @frankjoke ok
            guck ich dann gleich mal
              crunchip Forum Testing Most Active @frankjoke last edited by crunchip
              @frankjoke wie der Unwetterwarner..."No Warnings" 👌
              aber eine Frage habe ich noch
              radar2.0._nHere
              bezieht sich auf was?? irgendwas versteh ich da nicht
              habe 5 Abfragen mit true
              2 mit false
              _nHere zeigt mir den Wert 4
              frankjoke 1 Reply Last reply Reply Quote 0
              • frankjoke
                frankjoke @crunchip last edited by frankjoke
                @crunchip sagte in [Adapter] Neuer radar2-Adapter:
                radar2.0._nHere
                2 mit false
                _nHere zählt nur jene Geäte die da sind und nicht mittels '-' am Ende des Names ausgeblendet werden.
                Du kannst z.B. 10 Geräte prüfen aber für die Anwesenheitsinformation sind nur 3 davon relevant. Dann kannst bei den anderen ein '-' ans Ende des Namens setzten und _nHere wird nur die 3 restlichen zählen.
                  @frankjoke jetzt hab ichs gerafft 😀
                  danke
                  habe es angepasst, nun kommt folgendes
                  radar2.0	2019-03-31 23:38:59.885	warn	Invalid item name '''', must be at least 2 letters long
                  edit
                  Bild war unten abgeschnitten...hatte mir die letzte Zeile nicht angezeigt...die war natürlich leer 🤦
                  unter Objekte ist nun ECB- verschwunden, daran hatte ich gar nichts geändert., habe auch den Adapter nochmal neu gestartet
                  • frankjoke
                    danke
                    edit
                    Kann es ein dass du ein 'leeres' Gerät ohne Namen in deiner Konfig hast?
                    Der Fehler wird angezeigt wenn du ein Gerät mit einem Namen mit weniger als 2 Zeichen (nicht Leerzeichen) erzeugst.
                    Wenn nicht poste mir im chat deine Konfig....
                      @frankjoke
                      ja, hatte ich bereits geschrieben, war eine leere Zeile. Muss immer eine zeile hinzufügen, damit die Liste nach oben rutscht, sonst seh ich nicht alle Geräte, liegt wohl am chromcast browser...und hatte vergessen, die zeile wieder zu löschen.
                      aber das Objekt ECB fehlt seit version 1.0.5, ist nach wie vor im Adapter eingetragen, jedoch wird es nicht mehr mit aufgelistet.
                      • frankjoke
                        @frankjoke
                        Was meinst mit 'aufgelistet'? Die Daten fehlen?
                        Hast mal den Adapter im debug gestartet und z.B.
                        will scan UWZ with code UWZAT00184 every 120 minutes
                        Will scan ECB for [ 'USD,RUB,GBP' ] every 60 minutes
                        UWZ found the following (changed) warnings: No warnings
                        debug: ChangeState ack:true of _UWZ = No warnings
                        debug: ChangeState ack:true of ECB = 2019-03-29
                        debug: ChangeState ack:true of ECB.USD = 1.1235
                        debug: ChangeState ack:true of ECB.GBP = 0.8583
                        debug: ChangeState ack:true of ECB.RUB = 72.8564
                        sowas gesehen?
                          @frankjoke wenn ich auf debug stelle, kommt nur
                          radar2.0	2019-04-01 01:20:12.686	debug	system.adapter.admin.0: logging true
                          radar2.0	2019-04-01 01:20:12.340	debug	statesDB connected
                          radar2.0	2019-04-01 01:20:12.298	debug	objectDB connected
                          edit: hatte das ! vergessen
                          nein davon taucht bei mir nichts auf
                          die einzigste Zeile die sich auf ECB bezieht
                          er zeigt an
                          	radar2 found 8 devices in config
                          das ist auch korrekt, jedoch fehlt ECB
                          seit heute Nacht nur noch Störungen und Neustarts
                          	No geo location data found configured in admin to calculate UWZ AREA ID!
                          	err from getObjects: TypeError: Cannot read property 'pE' of undefined
                          	radar initialization finished with error TypeError: Cannot read property 'pE' of undefinedat pE (/opt/iobroker/node_modules/iobroker.radar2/node_modules/@frankjoke/myadapter/myAdapter.js:387:26)at <a
                          • SBorg
                            SBorg Forum Testing Most Active @frankjoke last edited by
                            @frankjoke sagte in [Adapter] Neuer radar2-Adapter:
                            Kannst mal schauen ob ifconfig auch 2x em0 bringt.
                            Der Adapter ruft gleichzueitig 1 oder mehrere Instanzen mit --interface=xxx von arp-scan auf und scannt daher auf den verschiedenen Schnittstellen gleichzeitig. Auf der Kommandozeile kannst nur die Instanzen separat aufrufen...
                            Thx, dann ist mir auch klar warum es per Shell nicht geht. Hatte mich da auf die Log-Ausgabe verlassen, dort taucht der Interface-Parameter nicht auf.
                            Noppe, ist genau wie vorher:
                            em0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                                    inet 192.168.2.1  netmask 255.255.255.0  broadcast 192.168.2.255
                                    inet6 fe80::xxx  prefixlen 64  scopeid 0x20<link>
                                    ether xxx  txqueuelen 1000  (Ethernet)
                                    RX packets 85283  bytes 6461710 (6.4 MB)
                                    RX errors 0  dropped 0  overruns 0  frame 0
                                    TX packets 193086482  bytes 12390402411 (12.3 GB)
                                    TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                                    device interrupt 17  memory 0x80120000-80140000
                            eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                                    inet 192.168.1.30  netmask 255.255.255.0  broadcast 192.168.1.255
                                    inet6 2001:xxx  prefixlen 64  scopeid 0x0<global>
                                    RX packets 167075147  bytes 145806185874 (145.8 GB)
                                    RX errors 0  dropped 557473  overruns 0  frame 0
                                    TX packets 314705354  bytes 184065188207 (184.0 GB)
                                    device interrupt 16  memory 0x80220000-80240000
                            lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                                    inet 127.0.0.1  netmask 255.0.0.0
                                    inet6 ::1  prefixlen 128  scopeid 0x10<host>
                                    loop  txqueuelen 1000  (Local Loopback)
                                    RX packets 900245719  bytes 138423683089 (138.4 GB)
                                    TX packets 900245719  bytes 138423683089 (138.4 GB)
                            Ist auch keine besondere Konfiguration:
                            Ich hatte nur keinen Port mehr am Switch frei, dafür aber einen Netzwerk-Anschluss vom Intel-Board über. Also Crosslink dran und an den Drucker gestöpselt, IP-Route eingestellt und druckt 🙂
                            Die weiteren Subnetze kann, und darf er nicht sehen, ist also soweit korrekt. Wenn du dabei neue Erkenntnisse erlangst/es wissen willst etc. immer gerne, ansonsten funktioniert es ja wie es soll und musst dir deswegen nicht extra "einen Kopp machen".
                            • frankjoke
                              @crunchip
                              das schaut nicht gut aus, wie wenn nicht richtig alles neu installiert worden wäge da du Fehler hast die alle addressiert wurden und in dieser Version behoben sein sollten!
                              Kannst nochmal vom git installieren nachdem du den Adapter gestoppt hast (kannst bei git den radar2 nehmen, sollte schon drin sein).
                              Wennst dann immer noch Probleme hast stoppe Adapter und lösche dann die Verzeichnisse sudo rm -Rf /opt/iobroker/node_modules/@frankjoke und sudo rm -Rf /opt/iobroker/node_modules/iobroker.radar2 und installierst es von git neu? Bitte dann upload machen falls das admin nicht macht!
                              Irgendwie scheinst du da mit den Versionen durcheinandergekommen zu sein...
                                @frankjoke de/neu installieren und upload hatte ich heut morgen schon probiert, jedoch die gleichen Fehler
                                probier ich es mal mit Verzeichnis löschen
                                scheint wieder zu laufen
                                dankeschön👍
                                  steimi last edited by
                                  Bei mir ändern sich mit der 1.0.5 nicht die _here-States. Während der übergeordnete Wert (Handy) auf false steht, steht der _here immervnoch auf true. Woran kann das liegen?
                                  • frankjoke
                                    frankjoke @steimi last edited by
                                    @steimi
                                    Hattest Recht, leider hat es davon abgehängt wie das Gerät gefunden wurde, die eine hat es gesetzt, die andere nicht.
                                    Auf git unter gleicher Versionsnummer upgedated, alle Teile setzten jetzt beides (bei mir).
                                      Irgendwas läuft bei mir schief. Ich habe den Adapter komplett entfernt und die von dir oben angegebenen Verzeichnisse unter /opt/iobroker gelöscht. Anschliessend habe ich Adapter über die Katze wieder neu installiert und konfiguriert. Nun habe ich unter den Objekten allerdings alle Einträge doppelt - Handy und Handy+. Wobei unter dem Handy+ nur der _here-State vorhanden ist.
                                      • frankjoke
                                        @steimi
                                        Sorry, das '+' war ein Tippfehler, schon korrigiert.
                                        p.s.: Die states sollten nach dem 1. kompletten scan dann selbst gelöscht werden...
                                        • Diginix
                                          Diginix last edited by
                                          Besteht die Chance dass der neue Adapter auch wieder getrennt anzeigt über welche Methode das Gerät erkannt wurde?
                                          Also bt_here und ip_here usw. wie beim alten Adapter auch.
                                            Muchul @Diginix last edited by
                                            An diesen Wunsch von @Diginix würde ich mich gerne anschließen.
                                            Wlan greift bei mir manchmal schon 100 meter von der Wohnung, da ist aber noch niemand zuhause.
                                            adapter radar2 adapter
                                            80
                                            840
                                            232795
