    3. Entwicklung
    4. Adapter: broadlink2
    Adapter: broadlink2
    • frankjoke
      frankjoke @padrino last edited by frankjoke
      @padrino
      Ich habe eine Version auf git welche die originalen Namen (vor dem umbenennen) im debug-mode zu jedem Gerät listet.
      Das schaut z.B. bei mir so aus:
      Device SP:Gibssi3 dedected: address=192.168.178.118, mac=34:ea:34:f4:9e:2d, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
      Device AirAZ1 dedected: address=192.168.178.104, mac=34:ea:34:b2:bf:3d, typ=a1, id=0x2714 devtype=A1, originalName=A1:EAIR1
      Device RMAZ1 dedected: address=192.168.178.102, mac=34:ea:34:f4:53:11, typ=rmp, id=0x272a devtype=RM2 Pro Plus, originalName=RM:RMPROPLUS
      Device SP:Gibssi1 dedected: address=192.168.178.53, mac=34:ea:34:f5:75:dc, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
      Device SP:Jessi3-Switch dedected: address=192.168.178.100, mac=34:ea:34:f4:fe:a2, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
      Device SP:Steckdose-BL1 dedected: address=192.168.178.39, mac=34:ea:34:f5:27:06, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
      Device SP:SDKlima dedected: address=192.168.178.50, mac=34:ea:34:f4:9d:57, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
      Device Beok313 dedected: address=192.168.178.111, mac=78:0f:77:fa:83:7c, typ=t1, id=0x4ead devtype=T1 Floureon, originalName=T1:BroadLink-OEM-T1-fa-83-7c
      Device SP:SP3S dedected: address=192.168.178.121, mac=34:ea:34:9d:2c:95, typ=sp3p, id=0x947a devtype=SP3SPower
      Device SP:Gibssi2 dedected: address=192.168.178.117, mac=34:ea:34:f4:ce:f7, typ=sp2, id=0x2728 devtype=OEM branded SPMini2
      Device SP:SM1 dedected: address=192.168.178.114, mac=34:ea:34:bd:92:4a, typ=sp2, id=0x7547 devtype=OEM branded SPMini2
      debug: ChangeState ack:true of _NewDeviceScan = false
      debug: broadlink2 has 94 old states!
      seems that device SP:BroadLink-SPmini-T1-f5-75-dc got renamed to SP:Gibssi1! You may delete old device and change your scripts!
      seems that device SP:BroadLink-SPmini-T1-f5-27-06 got renamed to SP:Steckdose-BL1! You may delete old device and change your scripts!
      seems that device SP:BroadLink-SPmini-T1-f4-9d-57 got renamed to SP:SDKlima! You may delete old device and change your scripts!
      Die letzten 3 Meldungen bedeuten dass alte und neue Namen im Objektbaum sind da sich Geräte zwischenzeitlich umbenannt haben, aber der Adapter hat dann wieder das Gerät mit dem richtigen namen (über die mac-adresse) gefunden.
      p.s.: Löschen tut er nur RM's die erfolgreich umbenannt werden, sonst nix, da ja Logik in scripten dahinterstecken kann die noch geändert werden muss...
      p.s.: Du siehst auch dass ich jetzt mehr mit den alten Namen arbeite, RMAZ1 heißt der Test-RM im Arbeitszimmer jetzt, sein Original-Name mit Fritz-Box zugewiesen ist aber RM:RMPROPLUS und wenn ich ihm keine feste Adresse und speziellen Namen in der Fritzbox gegeben hätte dann würde der origional-Name auch RM:Broadlink.....
      Ach übrigens, du kannst beim Umbenennen links nur originalnamen verwenden, das ist der Originalname bei diesen die schon umbenannt sind oder die namen die bei 'Device .... found' im .... stehen wenn kein Originalname angegeben ist.
      Also kannst auch keinen namen umbenennen welcher schon umbenannt wurde!
      ? padrino 2 Replies Last reply Reply Quote 0
        A Former User @frankjoke last edited by
        @frankjoke Super, die Version 1.99 auf Git funktioniert mit meinen SPMini's jetzt einwandfrei, auch der RM-Mini und der RM-ProPlus wird erkannt und beide funktionieren.
        Nur ist beim RMProPlus die Temp.Anzeige verloren gegangen.. die ging in 1.9.1 noch 🙂
        Aber von der Erkennung und den States etc. jetzt bitte nichts mehr aendern... 🙂
        padrino frankjoke 2 Replies Last reply Reply Quote 0
        • padrino
          padrino Most Active @Guest last edited by
          @ilovegym sagte in Adapter: broadlink2:
          Hmm, seltsam. Eigentlich hat der RMpro+ überhaupt keinen Sensor mehr verbaut und der Wert müsste 0 gewesen sein... 😃
          • frankjoke
            frankjoke @Guest last edited by
            @ilovegym
            Ok, das passiert wenn man ein Property einmal mit großem und einmal mit kleinem Buchstaben schreibt....
            @padrino
            Der neue Adapter versucht bei jedem RM die Temperatur zu lesen und zeigt sie also überall an wo es eben geht.
            Egal, habe grad nen update auf Git gemacht und sollte nun gehen.
              @frankjoke sagte in Adapter: broadlink2:
              @ilovegym
              leider zeigt er bei der Temp null C an, und nicht die Temperatur.. wenn ich mir den Code ansehe, dann sieht das so aus, als ob das Value falsch gesetzt ist..??
              hier der Auszug aus V1.9.9 Beta2:
              und hier vom alten V1.9.1:
              Im log von iobroker steht leider nichts, obwohl der Adapter auf debug steht.. hmm.. ?
              frankjoke 1 Reply Last reply Reply Quote 0
              • frankjoke
                @ilovegym
                Hast du die Beta am Nachmittag runtergeladen? Hatte erst nach 14h das Update mit der Temperatur gemacht.
                Übrigens, 'Learn' hjeisst jetzt '_Learn', natürlich musst das alte 'Learn' rauslöschen, der Adapter machts nicht automatisch...
                Bei mir auf 3 Rechnern getestet, aber nur mit einem RM?-Plus.
                • padrino
                  padrino Most Active @frankjoke last edited by
                  Sorrym ich blick es nicht. 😞
                  Und so eine Auflistung, wie Du sie zeigst, sehe ich im debug log auch nicht.
                  Mein rmpro+ hieß immer "rm-mac-Adresse-local".
                  Nun mit dem neuen Adapter heißt er nur noch "rm-mac-Adresse".
                  Im Objektbaum gibt es beide "Ordner", der "-local" mit all meinen Befehlen, der ohne "-local" ist leer.
                  Umbennen geht weder bei mit oder ohne "-local", der Objektebaum bleibt unverändert.
                  Glaube, ich muss einfach alles wieder komplett neu anlernen. 😞
                  • frankjoke
                    @padrino sagte in Adapter: broadlink2:
                    Der ohne '-local' ist der alte (du hattest in deiner alten Konfig nicht angegeben das '.local' am Ende entfernt werden soll (um die Namen zu kürzen), beim neuen Adapter brauchst das nicht mehr da er das '.local' nicht mehr nimmt ('.local' weil die Punkte auf '-' umbenannt werden da kein '.' im Namen eines ioBroker-Gerätes vorkommen darf)!
                    In deinem Fall so vorgehen:
                    • Stoppe adapter
                    • Lösche die neue Instanz des Gerätes (ohne '-local')
                    • In Admin/Instanzen gib in konfig/rename ein 'neuerName=alterName' wobei alter name mit '-local' und neuer ohne ist.
                    • Starte adapter
                    Warum? Der neue Adapter findet dein Gerät jetzt mit dem neuen Namen und du willst ihn auf den alten Namen umbenennen!
                    Dann sollte ein neues Gerät ohne '-local' entstehen und die gelernten States vom alten enthalten.
                    Er kann nicht umbenennen wenn der neue Name schon besteht!
                    p.s.: Kannst den neuen Namen natürlich auch anders nennen, wie z.B: FernsteuerungWohnzimmer anstatt rm-mac-Adresse-local
                    • frankjoke
                      Sogar wenn dein Adapter im Admin auf Info ist wirst die Geräte sehen die er findet, alles wirst nur auf debug sehen!
                      padrino 1 Reply Last reply Reply Quote 0
                      • padrino
                        padrino Most Active @frankjoke last edited by padrino
                        @frankjoke
                        Es geht leider nicht. 😞
                        Habe mich Schritt für Schritt an Deine Anweisung gehalten.
                        Das Ergebnis, mein -local heißt wie vorher und es wird ein neues leeres Objekt angelegt, dass den Namen ohne -local hat.
                        Adapter steht auf "debug", aber im Log steht nicht wirklich etwas drin (muss evtl. noch ein anderer Adapter zusätzlich auf "debug" stehen?).
                        Wichtig ist nur der Broaslink mit "x", der mit "y" ist im Moment nicht angeschlossen, aber noch Teil der Konfig.
                        ~~gelöscht~~
                          @ilovegym
                          Hi, hab nochmal drueber installiert, funktioniert jetzt, war anscheinend zu schnell ..
                          Jetzt geht alles einwandfrei, super! Kommt heute abend aufs produktivsystem, sofern sich heute auf dem test keine macken mehr finden lassen.. 🙂
                          Vielen Dank!
                          • padrino
                            Dann hast Du aber "nur" einen RM pro und keinen RM pro+, oder? 😉
                            @frankjoke
                            Wäre es evtl. möglich, dass der Adapter ein Setting bekommt, ob die Erweiterung gestrippt wird, oder nicht?
                            Könnte mir vorstellen, dass es noch Leute wie mich 😄 gibt, die in der alten Konfig "-local" Geräte haben und die würden dann ja auch mit den Problemen kämpfen wie ich - es sei denn natürlich bei denen klappt das Umbennen problemlos. 😉
                            Kann man denn die Datenpunkte irgendwie manuell exportieren und dann extern editieren und wieder zurück schreiben? 🤔
                              liv-in-sky @padrino last edited by
                              im object-tab gibt es einen "export als json" - ich habe das genutzt um auf den adapter umzusteigenImage 1.png
                              frankjoke 1 Reply Last reply Reply Quote 1
                              • frankjoke
                                @frankjoke
                                broadlink2.0	2019-04-03 01:35:40.438	info	3 were not found: RM:RMPROPLUS-xx-xx-xx-local,RM:RMPROPLUS-yy-yy-yy-local,T1:BroadLink_OEM-zz-zz-zz-zz
                                broadlink2.0	2019-04-03 01:35:40.437	info	broadlink2.0 started and found 1 devices named 'RM:RMPROPLUS-xx-xx-xx'.
                                broadlink2.0	2019-04-03 01:35:34.586	warn	device T1:BroadLink_OEM-zz-zz-zz-zz not found, please rescan later again or delete it! It was: 192.168.2.115,80,7,20141,[object Object],34:ea:34:9f:b5:a7,t1,T1:BroadLink_OEM-zz-zz-zz-zz,0x4ead,T1 Flou
                                broadlink2.0	2019-04-03 01:35:34.585	warn	device RM:RMPROPLUS-yy-yy-yy-local not found, please rescan later again or delete it! It was: 192.168.2.122,IPv4,80,128,10141,rm,RM:RMPROPLUS-yy-yy-yy-local,RM3 Pro Plus,9d:27:7a:yy:yy:yy> broadlink2.0	2019-04-03 01:35:34.567	warn	device RM:RMPROPLUS-xx-xx-xx-local not found, please rescan later again or delete it! It was: 192.168.2.100,IPv4,80,128,10141,rm,RM:RMPROPLUS-xx-xx-xx-local,RM3 Pro Plus,9d:27:64:yy:yy:yy
                                broadlink2.0	2019-04-03 01:35:26.774	info	Device RM:RMPROPLUS-xx-xx-xx dedected: address=192.168.2.100, mac=34:ea:34:xx:xx:xx, typ=rmp, id=0x279d devtype=RM3 Pro Plus
                                broadlink2.0	2019-04-03 01:35:26.626	info	Discover Broadlink devices for 10sec on broadlink2.0
                                broadlink2.0	2019-04-03 01:35:26.625	info	UDP socket listening on 0.0.0.0:15001
                                broadlink2.0	2019-04-03 01:35:26.446	info	Devices to rename:
                                Anbei meine Analyse zu deinem Log (man muss ihn von unten nach oben lesen):
                                Du hast KEIN rename in der Konfig!
                                Dein RM wurde gefunden und hat eine Mac-Adresse 34:ea:34:xx:xx:xx. Übrigens das xx-xx-xx was du ausgeblendet hast sind normalerweise die letzten 3 Stellen der Mac, also ??-??-?? in dem Fall. Anhand der Mac-Adresse sehe ich dass der Hersteller HangZhou Gubei Electronics Technology Co.,Ltd ist
                                Dein altes war It was: 192.168.2.100,IPv4,80,128,10141,rm,RM:RMPROPLUS-xx-xx-xx-local,RM3 Pro Plus,9d:27:64:yy:yy:yy, und das eigenartige ist die mac-adresse da: 9d:27:64:yy:yy:yy, bei ihr ist der Vendor unbekannt (genauso wie beim noch älteren yy-yy-yy! Ist das wirklich das selbe Geät?
                                Hast du irgendawas mit dem Netztwerk gemacht? Die Broadlink-Geräte ändern ihre mac-Adressen wenn du am Netwerk (SSID, passwort, router-Mac, ...) irgendwas änderst und sie neu ins netz einbindest.
                                Die letzten Meldungen sagen dass die alten Geräte nicht gefunden wurden (klar, sind nicht dran oder haben jetzt eine neue Mac)!
                                Zum Umbenennen: Du müsstest in deinem rename-Feld eingeben:
                                RM:RMPROPLUS-xx-xx-xx=RM:RMPROPLUS-xx-xx-xx-local
                                Vorher jedoch Adapter stoppen und den kompletten Baum von RM:RMPROPLUS-xx-xx-xx löschen.
                                Und dann erst Adapter mit der rename-konfig starten.
                                p.s.: Habe alle Mac-Adressen auf Wunsch von @padrino unkenntlich gemacht.
                                • frankjoke
                                  frankjoke @frankjoke last edited by
                                  Ich vergaß: Hast auch immer ein Upload gemacht nachdem du die neuie Version von Git geladen hast?
                                  Im Admin.Adapter (wenn du ListeenAnsicht hast expertenmodus ein) dann bei broadlink2 den Pfeil nach oben!
                                  • padrino
                                    @liv-in-sky sagte in Adapter: broadlink2:
                                    Super, das hab ich komplett übersehen. 😞
                                    Vielen Dank, damit konnte erfolgreich umziehen. 😄
                                    @frankjoke
                                    Toll, jetzt habe ich meine meine Mac doch komplett gepostet. 😞
                                    Könntest Du das Zitat aus meiner Beitrag und die Adressen von Dir geschrieben bitte bei Dir raus editieren, dake. 😃
                                    Und ja, ich habe ein "rename" in meiner Konfig.
                                    Vermutlich liegt es an dem "upload", das habe ich nicht gemacht, da ich nicht mal weiß, was das ist/tut. 😞
                                    Wie oben geschrieben habe ich inzwischen, über json exportiert, editiert und re-importiert.
                                    Zu Deiner Frage, ob es die selben Geräte sind, ja, auch an meiner Konfig habe ich schon lange nix mehr geändert.
                                    Bei mir haben die Namen des alten -local und des neuen Eintrags aber in den Datenpunkt, die selben 3 Stellen der Macadresse.
                                    • frankjoke
                                      frankjoke @liv-in-sky last edited by
                                      @liv-in-sky
                                      Ja @liv-in-sky , danke für die Erinnerung, das geht natürlich!
                                      Im Objektbaum auf den alten RM klicken (wichtig! nicht auf das L oder das gesamte broadlink2!) und dann das json runterladen.
                                      Das ergibt bei einem code in '.L.' sowas:
                                      "broadlink2.0.alterName.L.CODE_2600a0009692120f120f120f120f12301230120f11101131113111311130120f120f120f120f1193120f101110111011103210111011101110321131113011101110123012301230120f120f120f12301200071c9692120f120f120f120f12301230120f120f122f123012301230120f120f120f120f1292120f120f120f120f1230120f120f120f122f12301230120f120f123012301230120f120f120f123012000d050000000000000000": {
                                          "common": {
                                            "name": "_Rename_learned_  2019-04-02@17:21:05",
                                            "read": true,
                                            "write": true,
                                            "state": "state",
                                            "role": "button",
                                            "type": "boolean"
                                          "type": "state",
                                          "_id": "broadlink2.0.alterName.L.CODE_2600a0009692120f120f120f120f12301230120f11101131113111311130120f120f120f120f1193120f101110111011103210111011101110321131113011101110123012301230120f120f120f12301200071c9692120f120f120f120f12301230120f120f122f123012301230120f120f120f120f1292120f120f120f120f1230120f120f120f122f12301230120f120f123012301230120f120f120f123012000d050000000000000000",
                                          "native": {
                                            "code": "2600a0009692120f120f120f120f12301230120f11101131113111311130120f120f120f120f1193120f101110111011103210111011101110321131113011101110123012301230120f120f120f12301200071c9692120f120f120f120f12301230120f120f122f123012301230120f120f120f120f1292120f120f120f120f1230120f120f120f122f12301230120f120f123012301230120f120f120f123012000d050000000000000000"
                                          "from": "system.adapter.broadlink2.0",
                                          "user": "system.user.admin",
                                          "ts": 1554218465235,
                                          "acl": {
                                            "object": 1638,
                                            "state": 1636,
                                            "owner": "system.user.admin",
                                      wobei ich den Namen auf alterName gesetzt habe und '.....' soll weitere States bedeuten.
                                      Alle anderen state die nicht broadlink2.0.alterName.L.* sind bitte löschen
                                      Nun änderst du in der Datei alle Vorkommen von alterName durch neuerName und speicherst sie als json.
                                      Wenn du nun im AdminObjekte auf den neuenNamen klickst und dann das json importierst solltest du alle codes dort vorfinden.
                                      • padrino
                                        @frankjoke
                                        Danke. Aber wie bereits erwähnt
                                        war ich über den Weg schon erfolgreich. 😄
                                        Habe exportiert, dann im Editor alle xx-local durch xx ersetzen lassen und dann importiert.
                                        Nun habe ich ich alle Befehle, die Funktionieren ohne "-local".
                                        Muss jetzt nur noch in ein paar Skripten die Datenpunkte anpassen, aber das sollte ja kein Ding sein. 😃
                                        Wie gesagt, wäre nett von Dir, wenn Du in Deinem Beitrag oben mein Zitat löschen und dort in Deinem Text meine Mac Adresse einfach rausnehmen könntest. 🙂
                                        • frankjoke
                                          @padrino
                                          Die Mac-Adressen sind komplett egal, brauchst sie nicht verheimlichen: Wie schon mehrmals berichtet ändern die Geräte ihre mac's wenn sich das W-Lan ändert, also sind sie nur für dich in deinem Netztwerk gültig.
                                          Und: Du hast kein Rename in der Konfig, in der Zeile 2019-04-03 01:35:26.446 info Devices to rename: steht nix, da muss dein rename stehen!
                                          De Macs sind für mich wichtig da ich da sehen ob ein Gerät das selbe ist wie vorher oder was geändert wurde, aber kannst das nächste mal ja die macs per chat schicken wennst nicht magst dass sie hier erkennbar sind, aber wie gesagt, es kann (bei Broadlink-Geräten) keiner was damit anfangen...
                                          Du solltest jedoch im router alle broadlink-Geräte das Sprechen mit dem Internet verbieten da sie sonst alle nach Hause telefonieren (und deine Mac-Adressen dorthin melden inklusive allen Befehlen die du ihnen gibst).!
                                          • padrino
                                            @padrino
                                            Ok.
                                            Hmm, was ist dann das?
                                            broad2 broadlink rm pro rm3 mini rm4
                                            169
                                            1365
                                            618530
