    4. ZigBee Stick Fehler?
    UNSOLVED ZigBee Stick Fehler?
      rtamas @arteck last edited by
      @arteck Im Log steht nur "Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)", danach "Starting zigbee-shepherd", geht nicht weiter, siehe oben den Screenshot, unten alles. Kann ich irgendwie weitere Einträge auslesen?
      Mit welcher Firmware hast du ein Problem gehabt? Wie hast du es gelöst?
      2019-04-05 09:19:45.341 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.0.52
      2019-04-05 09:19:45.710 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.0.52
      2019-04-05 09:19:45.802 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.0.52
      2019-04-05 09:19:45.925 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.0.52 habpanel.0
      2019-04-05 09:19:46.279 - info: web.0 <==Disconnect system.user.admin from ::ffff:192.168.0.52 vis.0
      2019-04-05 09:19:47.120 - debug: zigbee.0 objectDB connected
      2019-04-05 09:19:47.229 - debug: zigbee.0 statesDB connected
      2019-04-05 09:19:47.313 - info: host.raspberrypi instance system.adapter.terminal.0 started with pid 809
      2019-04-05 09:19:47.458 - info: zigbee.0 starting. Version 0.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.1
      2019-04-05 09:19:47.514 - info: zigbee.0 Start on port: /dev/ttyACM0 with panID 6754 channel 25
      2019-04-05 09:19:47.515 - info: zigbee.0 Queue is: true
      2019-04-05 09:19:47.664 - info: zigbee.0 Reset coordinator
      2019-04-05 09:19:47.764 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.0.52
      2019-04-05 09:19:49.252 - info: zigbee.0 Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
      2019-04-05 09:19:49.626 - info: terminal.0 starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.terminal, node: v8.15.1
      2019-04-05 09:19:49.758 - info: terminal.0 http server listening on port 8088
      2019-04-05 09:19:49.828 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.0.52
      2019-04-05 09:19:50.052 - info: web.0 ==>Connected system.user.admin from ::ffff:192.168.0.52
      2019-04-05 09:19:51.314 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 879
      2019-04-05 09:19:54.208 - info: telegram.0 starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.15.1
      2019-04-05 09:19:55.311 - info: host.raspberrypi instance system.adapter.pushover.0 started with pid 895
      2019-04-05 09:19:56.621 - info: pushover.0 starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.pushover, node: v8.15.1
      2019-04-05 09:19:59.305 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 909
      2019-04-05 09:20:03.772 - info: javascript.0 starting. Version 4.1.12 in /opt/iobroker/node_modules/iobroker.javascript, node: v8.15.1
      2019-04-05 09:20:03.841 - info: javascript.0 requesting all states
      2019-04-05 09:20:03.854 - info: javascript.0 requesting all objects
      2019-04-05 09:20:04.362 - info: javascript.0 received all states
      2019-04-05 09:20:04.865 - info: javascript.0 received all objects
      2019-04-05 09:20:04.805 - info: vis.0 starting. Version 1.1.10 in /opt/iobroker/node_modules/iobroker.vis, node: v8.15.1
      2019-04-05 09:20:05.080 - info: vis.0 vis license is OK.
      2019-04-05 09:20:06.190 - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
      2019-04-05 09:20:07.305 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 937
      2019-04-05 09:20:08.604 - info: node-red.0 starting. Version 1.7.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v8.15.1
      2019-04-05 09:20:09.057 - info: node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      2019-04-05 09:20:11.306 - info: host.raspberrypi instance system.adapter.text2command.0 started with pid 958
      2019-04-05 09:20:12.669 - info: text2command.0 starting. Version 1.2.5 in /opt/iobroker/node_modules/iobroker.text2command, node: v8.15.1
      2019-04-05 09:20:15.306 - info: host.raspberrypi instance system.adapter.scenes.0 started with pid 982
      2019-04-05 09:20:16.611 - info: scenes.0 starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.scenes, node: v8.15.1
      2019-04-05 09:20:19.305 - info: host.raspberrypi instance system.adapter.sonoff.0 started with pid 1000
      2019-04-05 09:20:21.109 - info: sonoff.0 starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v8.15.1
      2019-04-05 09:20:21.220 - info: sonoff.0 Starting MQTT authenticated server on port 1883
      2019-04-05 09:20:22.812 - warn: node-red.0 5 Apr 09:20:22 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
      2019-04-05 09:20:23.302 - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 1014
      2019-04-05 09:20:24.844 - info: alexa2.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v8.15.1
      2019-04-05 09:20:27.322 - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1028
      2019-04-05 09:20:29.041 - info: backitup.0 starting. Version 1.1.3 in /opt/iobroker/node_modules/iobroker.backitup, node: v8.15.1
      2019-04-05 09:20:29.127 - info: backitup.0 [minimal] backup was activated at 02:00 every 1 day(s)
      2019-04-05 09:20:29.172 - info: backitup.0 [total] backup was activated at 03:00 every 3 day(s)
      2019-04-05 09:20:29.736 - info: alexa2.0 Alexa-Push-Connection established. Disable Polling
      2019-04-05 09:20:31.324 - info: host.raspberrypi instance system.adapter.info.0 started with pid 1042
      2019-04-05 09:20:32.832 - info: info.0 starting. Version 1.2.7 in /opt/iobroker/node_modules/iobroker.info, node: v8.15.1
      2019-04-05 09:20:33.044 - info: alexa2.0 Smarthome-Device Capability Alexa.AcousticEventSensor unknown. Report to developer this and next log line from logfile on disk!
      2019-04-05 09:20:33.131 - info: info.0 Popup-News readed...
      2019-04-05 09:20:38.346 - info: cloud.0 Trying to connect as system.user.admin
      2019-04-05 09:20:38.562 - info: cloud.0 Connection changed: connect
      2019-04-05 09:20:49.255 - info: zigbee.0 Starting zigbee-shepherd
      2019-04-05 09:21:37.368 - debug: zigbee.0 system.adapter.admin.0: logging false
      2019-04-05 09:25:45.887 - debug: zigbee.0 system.adapter.admin.0: logging true
      2019-04-05 09:27:20.891 - debug: zigbee.0 system.adapter.admin.0: logging false
      2019-04-05 09:31:13.926 - debug: zigbee.0 system.adapter.admin.0: logging true
        Wildbill last edited by
        @rtamas
        drück mal die Reset-Taste am Stick (die, die näher an der USB-Buchse liegt) und stecke ihn einmal aus und wieder ein. Dann anschliessend den Adapter restarten, dann sollte er laufen.
        Gruss, Jürgen
        R arteck 2 Replies Last reply Reply Quote 0
          rtamas @Wildbill last edited by
          @Wildbill
          Hi Jürgen,
          Danke für die gute Idee! 🙂 Leider macht keinen Unterschied (geht nicht weiter nach "Starting zigbee-shepherd"). Soll ich die Reset-Taste drücken halten? (Ich habe beide Möglichkeiten ausprobiert leider ohne Erfolg.)
          2019-04-05 13:07:01.064 - info: host.raspberrypi object change system.adapter.zigbee.0
          2019-04-05 13:07:01.070 - debug: zigbee.0 cleaned everything up...
          2019-04-05 13:07:01.065 - info: host.raspberrypi stopInstance system.adapter.zigbee.0
          2019-04-05 13:07:01.066 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 9682
          2019-04-05 13:07:01.096 - info: zigbee.0 zigbee-shepherd stopped
          2019-04-05 13:07:01.159 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 0 (OK)
          2019-04-05 13:07:03.593 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 10877
          2019-04-05 13:07:05.490 - debug: zigbee.0 objectDB connected
          2019-04-05 13:07:05.537 - debug: zigbee.0 statesDB connected
          2019-04-05 13:07:05.627 - info: zigbee.0 starting. Version 0.10.3 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.15.1
          2019-04-05 13:07:05.666 - info: zigbee.0 Start on port: /dev/ttyACM0 with panID 6754 channel 25
          2019-04-05 13:07:05.666 - info: zigbee.0 Queue is: true
          2019-04-05 13:07:05.744 - info: zigbee.0 Reset coordinator
          2019-04-05 13:07:07.292 - info: zigbee.0 Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds)
          2019-04-05 13:08:07.297 - info: zigbee.0 Starting zigbee-shepherd
          Lg, Thomas
            arteck Developer Most Active @Wildbill last edited by
            @Wildbill und klatschmal in die Hände.. ach und einmal um die eigene Ache drehen....
            nein ernst.. was soll das bringen..... der knopp macht ein Soft reset ... das erreichst du auch wenn du den Stick einmal ziehst und wieder rein steckst...
              arteck Developer Most Active @rtamas last edited by
              @rtamas wie schon @Asgothian geschrieben hat... Adapter auf debug stellen und hier Ergebniss posten
                @arteck Zigbee adapter ist schon ab Anfang auf debug gestellt. Kann ich irgendwie (Konsol?) weitere Einträge auslesen? Oder soll ich auch andere Adaptern auch auf debug stellen?
                  der Zigbee Adapter ist nicht auf debug gestell. sonst würde der mehr Protokollieren
                  der steht auf Info wie ich das sehe
                    @arteck Kann ich noch irgendwo auf debug stellen? Was mache ich falsch? 🙄
                      nö das ist die einzige stelle..bei neustart sollten mehr Infos kommen
                        @arteck Das ist hier alles was bei neustart kommt. 🤔
                        @rtamas said in ZigBee Stick Fehler?:
                          Ich habe den Stick wieder geflasht, jetzt funktioniert alles - ich hoffe diesmal länger als einige Tagen. ☺
                          • Xsev
                            Xsev last edited by
                            ich häng mich hier mal ran, da ich ein ähnliches Problem habe und nicht weiß wo es besser aufgehoben wäre…
                            Zu meiner Hardware:
                            Raspi 3b+ (Rasbian)
                            Node.js v8.15.0
                            NPM:6.8.0
                            Sheperd 2.6.3 rev 20190223
                            CC2531 Coordinator und ein CC2531 Router (Koenkk/Stack Firmware von Github)
                            Mein Problem:
                            Mein Netz ist relativ instabil und baut sich anscheinend mehrfach täglich wieder auf, teils mit Coordinator reset teils ohne, zumindest ist nicht immer was im Log zu finden. Ich sehe bzw. merke nur das manche Bereiche wieder nicht gehen und wenn ich die Netzwerkkarte ansehe ist fast kein Gerät erreichbar. Dies ändert sich dann nach paar Minuten und das Netz baut sich wieder auf.
                            Ich habe folgende Maßnahmen bereits ergriffen,
                            • CC2531 Sticks mit Antennmod versehen (Zigbee Stabantenne +3dB)
                            • Wlan Kanal 3 – Zigbee 25
                            • Verschiedene Postitionen für Coordinator und Router, zzgl. Osram Plugs nur als router für Funkerweiterung installiert und CC2531 Router gegen Osram getauscht und umgekehrt.
                            Eigentlich habe ich jetzt überall gutem Empfang, mein CC2531 Router geht teils mit 70 empfang auf false...
                            Anbei mal ein Screen meines heutigen Ausfalls. Mir sagt das so leider nichts.
                            Falls ich etwas vergessen habe reiche ich es gerne nach.
                            Asgothian R 2 Replies Last reply Reply Quote 0
                            • Asgothian
                              Asgothian Developer @Xsev last edited by
                              @Xsev
                              Bitte versucht die fw von hier auf den Stick zu flashen. Es gibt mehrere Hinweise das die fw 20190223 nicht immer problemfrei läuft.
                              A.
                              • Xsev
                                Xsev last edited by
                                Vielen Dank das probiere ich heute sofort aus!
                                  rtamas @Xsev last edited by
                                  @Xsev
                                  Ich sollte heute schon dreimal neustarten. ☹
                                    rtamas @Asgothian last edited by
                                    @Asgothian Danke sehr, werde sofort ausprobieren! ☺ 👍
                                      rtamas @rtamas last edited by rtamas
                                      @Asgothian Geflasht, funktioniert, hoffe daß ich in einigen Tagen positive Rückmeldungen schreiben kann. Danke nochmals! ✌ 😎
                                      • Xsev
                                        Xsev last edited by
                                        Dito!
                                        Bei mir läuft aktuell auch alles wie es soll. Ich werds auch beobachten und Rückmeldung erstatten.
                                        Merci nochmal und schönen Abend!!! 👌 👍
                                          @Xsev 👍
                                          Ups, ich wollte nicht markieren und neben "Quote" die Nummer ändern (wofür ist das eigentlich?). Wie kann ich beide zurücksetzen?
                                          • Negalein
                                            Negalein Global Moderator @rtamas last edited by
                                            @rtamas sagte in ZigBee Stick Fehler?:
                                            Die Markierung (grüner Rahmen) bedeutet, dass dieser Beitrag als Lösung markiert wurde.
                                            Hab ich für dich wieder weggenommen.
                                            Die beiden Pfeile bedeuten quasi "gefällt mir (Pfeil rauf)" oder "gefällt mir nicht (Pfeil runter)".
                                            zigbee stick
                                            4662
