    4. Test Adapter SourceAnalytix v0.2.x
    • kmxak
      Caught	2019-03-31 20:35:36.555	error	by controller[6]: (node:6422) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
      Caught	2019-03-31 20:35:36.555	error	by controller[6]: at process._tickCallback (internal/process/next_tick.js:189:7)
      Caught	2019-03-31 20:35:36.555	error	by controller[6]: at <anonymous>
      Caught	2019-03-31 20:35:36.555	error	by controller[6]: at Sourceanalytix.calculation_handler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:640:42)
      Caught	2019-03-31 20:35:36.555	error	by controller[6]: (node:6422) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'sourceanalytix.0' of undefined
      Caught	2019-03-31 20:35:36.555	error	by controller[5]: (node:6422) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
      Caught	2019-03-31 20:35:36.555	error	by controller[5]: at process._tickCallback (internal/process/next_tick.js:189:7)
      Caught	2019-03-31 20:35:36.555	error	by controller[5]: at <anonymous>
      Caught	2019-03-31 20:35:36.555	error	by controller[5]: at Sourceanalytix.calculation_handler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:640:42)
      Caught	2019-03-31 20:35:36.555	error	by controller[5]: (node:6422) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'sourceanalytix.0' of undefined
      Caught	2019-03-31 20:35:36.555	error	by controller[4]: (node:6422) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
      Caught	2019-03-31 20:35:36.555	error	by controller[4]: at process._tickCallback (internal/process/next_tick.js:189:7)
      Caught	2019-03-31 20:35:36.554	error	by controller[4]: at <anonymous>
      Caught	2019-03-31 20:35:36.554	error	by controller[4]: at Sourceanalytix.calculation_handler (/opt/iobroker/node_modules/iobroker.sourceanalytix/main.js:640:42)
      Caught	2019-03-31 20:35:36.554	error	by controller[4]: (node:6422) UnhandledPromiseRejectionWarning: TypeError: Cannot read property 'sourceanalytix.0' of undefined
      Caught	2019-03-31 20:35:36.554	error	by controller[4]: (node:6422) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin
      Caught	2019-03-31 20:35:36.554	error	by controller[4]: at process._tickCallback (internal/process/next_tick.js:189:7)
      sourceanalytix.0	2019-03-31 20:35:36.522	info	Adapter SourceAnalytix stopped !
      sourceanalytix.0	2019-03-31 20:35:36.513	info	Adapter SourceAnalytix stopped !
      Installierte Version: 0.2.281
      Der Fehler kommt auch mit der neuesten Version beim restart des Adapters.
      • Dutchman
        Dutchman Developer Most Active Administrators last edited by Dutchman
        @kmxak sagte in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
        640:42
        danke fuer das neue log damit konnte ich was anfangen 640:42
        Habe es gefixt beim naesten update wird's drin sein
        • Fenriswolf
          Fenriswolf last edited by
          ich würde gerne einen Teil meiner gesammelten Daten an meine CCU übergeben um die dort weiter zu verarbeiten. Allerdings bekomme ich dabei immer eine Fehlermeldung das angeblich ein Wert ein String ist.
          var stromuebersicht_in_CCU;
          stromuebersicht_in_CCU = schedule('*/1 * * * *', function () {
            // SpaceCenter- Stromkosten
            setState("hm-rega.0.37864"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__LEQ1345283__2__ENERGY_COUNTER.cost.05_current_year").val);
            setState("hm-rega.0.37867"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__LEQ1345283__2__ENERGY_COUNTER.cost.01_current_day").val);
          // SpaceCenter- Leistung
            setState("hm-rega.0.37869"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__LEQ1345283__2__ENERGY_COUNTER.consumption.05_current_year").val);
            setState("hm-rega.0.37872"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__LEQ1345283__2__ENERGY_COUNTER.consumption.01_current_day").val);
          // Waschmaschine und Trockner - Stromkosten
            setState("hm-rega.0.37874"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__MEQ1126409__2__ENERGY_COUNTER.cost.05_current_year").val);
            setState("hm-rega.0.37877"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__MEQ1126409__2__ENERGY_COUNTER.cost.01_current_day").val);
          // Waschmaschine und Trockner - Leistung
            setState("hm-rega.0.37879"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__MEQ1126409__2__ENERGY_COUNTER.consumption.05_current_year").val);
            setState("hm-rega.0.37882"/*sv.iobroker.verbrauch.spacecenter.use.tag*/, getState("sourceanalytix.0.hm-rpc__1__MEQ1126409__2__ENERGY_COUNTER.consumption.01_current_day").val);
          Im Log steht dann folgende Meldung:
          javascript.2	2019-04-05 14:11:00.161	warn	at Timer.listOnTimeout (timers.js:290:5)
          javascript.2	2019-04-05 14:11:00.161	warn	at tryOnTimeout (timers.js:323:5)
          javascript.2	2019-04-05 14:11:00.161	warn	at ontimeout (timers.js:498:11)
          javascript.2	2019-04-05 14:11:00.161	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
          javascript.2	2019-04-05 14:11:00.160	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
          javascript.2	2019-04-05 14:11:00.160	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
          javascript.2	2019-04-05 14:11:00.160	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
          javascript.2	2019-04-05 14:11:00.159	warn	at Object.<anonymous> (script.js.common.verbrauch_in_ccu_neu:5:3)
          javascript.2	2019-04-05 14:11:00.159	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
          javascript.2	2019-04-05 14:11:00.157	warn	Wrong type of hm-rega.0.37864: "string". Please fix, while deprecated and will not work in next versions.
          entsprechen für die anderen "hm-rega.0.xxxxx" Werte ebenfalls. (Wollte nur nicht alle reinkopieren).
          Ich bin eigentlich davon ausgegangen, das auf beiden Seiten Zahlenwerte und keine Strings verwendet werden.
          schönes WE
          sigi234 Dutchman 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @Fenriswolf last edited by sigi234
            @Fenriswolf sagte in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
            hm-rega.0.37864
            Zeig mal den DP davon und ev. die RAW
            Und die SYS Variable von der CCU
            Fenriswolf 2 Replies Last reply Reply Quote 0
            • Fenriswolf
              Fenriswolf @sigi234 last edited by
              @sigi234 sagte in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
              hm-rega.0.37864
              Ich muss leider ganz dämlich fragen, was du genau meinst, und wie bekomme ich die RAW Daten?
                @Fenriswolf
                Objekte - HM REGA.0 - hm-rega.0.37864 - Bleistiftsymbol - RAW
                • Dutchman
                  Dutchman Developer Most Active Administrators @Fenriswolf last edited by Dutchman
                  Die Fehlermeldung entsteht durch den hm-rega.0.37864, kommt also nicht vom state des SourceAnalytix adapters sondern hm-rega :).
                  Wie hast du die variable in der CCU erstellt, mach mal bitte screenshot (von der variable in der CCU!).
                  • Fenriswolf
                    Fenriswolf @sigi234 last edited by Fenriswolf
                    hm-rega.0.37864
                    246628B5-17E5-4A52-80FC-E4CB16AB0B67.jpeg 8BCB7EE6-5A73-44E6-8F06-834B95A00A65.jpeg
                    Ich hoffe das sind die richtigen Daten. Habe gerade gesehen, das die Bemerkungen im JavaScript falsch sind, aber das sollte ja nicht stören.
                      @Fenriswolf
                      Bist du sicher das du einen Sys Variable angelegt hast..........
                      Meine schaut so aus:
                      Fenriswolf 1 Reply Last reply Reply Quote 0
                      • Fenriswolf
                        @Fenriswolf
                        • Fenriswolf
                          Ich habe auch nochmal geguckt, und dabei ist mir aufgefallen, das zwar Fehler im Log auftauchen, aber trotzdem die Werte in die CCU geschrieben werden.
                          javascript.2	2019-04-05 21:37:00.127	warn	at Timer.listOnTimeout (timers.js:290:5)
                          javascript.2	2019-04-05 21:37:00.127	warn	at tryOnTimeout (timers.js:323:5)
                          javascript.2	2019-04-05 21:37:00.127	warn	at ontimeout (timers.js:498:11)
                          javascript.2	2019-04-05 21:37:00.127	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:501:7)
                          javascript.2	2019-04-05 21:37:00.127	warn	at /opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:543:11
                          javascript.2	2019-04-05 21:37:00.126	warn	at Job.invoke (/opt/iobroker/node_modules/iobroker.javascript/node_modules/node-schedule/lib/schedule.js:173:10)
                          javascript.2	2019-04-05 21:37:00.126	warn	at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
                          javascript.2	2019-04-05 21:37:00.126	warn	at Object.<anonymous> (script.js.common.verbrauch_in_ccu_neu:5:3)
                          javascript.2	2019-04-05 21:37:00.126	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
                          javascript.2	2019-04-05 21:37:00.126	warn	Wrong type of hm-rega.0.37864: "string". Please fix, while deprecated and will not work in next versions.
                          • hg6806
                            hg6806 Most Active last edited by
                            @Dutchman Wann können wir denn das Feature "add object states for previous [x]day, [x]week, [x]month, [x]quarter, [x]year configurable in adapter settings" erwarten?
                            Das macht es dann noch viel interessanter
                            Dutchman 1 Reply Last reply Reply Quote 1
                            • Dutchman
                              Dutchman Developer Most Active Administrators @hg6806 last edited by
                              @hg6806 sagte in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                              working on it, traue mich aber noch nicht um da ne zeit fuer zu nennen da sitzen ein par komplexe bastellen um code.
                              Lehne mich jetzt aber nicht wider 2 Monate zurück also die nahest tage/wochen werden updates kommen nur wan genau das Funktionieren wird weis ich leider noch nicht.
                              Stay tuned 📅
                              K D 2 Replies Last reply Reply Quote 0
                                Kueppert @Dutchman last edited by
                                @Dutchman da steht 17.Juli im Icon...das is ja noch was hin :lol:
                                  sigi234 Forum Testing Most Active @Kueppert last edited by
                                  @Kueppert sagte in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                  Ich glaube er meint 17.April...........
                                  • Dutchman
                                    Dutchman Developer Most Active Administrators @sigi234 last edited by
                                    Lol purer Zufall das ist n Standard icon
                                      darkbrain85 @Dutchman last edited by
                                      @Dutchman said in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                      Stay tuned 📅
                                      Bist ein guter! 😉
                                      Sobald die Funktion läuft, kann ich meine sonstigen Zählerskripte endlich löschen 😄
                                        highline last edited by
                                        Hallo, eine Frage zwischendurch: Ich habe für ein Objekt die Analyse aktiviert, er zählt auch die kWh hoch, sobald ich jedoch ein in einem zweiten Objekt die Analyse aktiviere, zählt der erste nicht weiter...
                                        • Dutchman
                                          Dutchman Developer Most Active Administrators @highline last edited by
                                          @highline sagte in [Neuer Adapter Beta 0.2.275] SourceAnalytix (Verbrauch Protokollierung von Strom/Gas/Flüssigkeiten):
                                          Welche Version benutzt du ?
                                          Was für Werte sind es genau ?
                                          Könntest du Mal den das logging für 5minutrn auf debug stellen und mir die Log Daten schicken ?
                                            highline last edited by highline
                                            ich setze die aktuelle Version 0.2.281 ein.
                                            Es handelt sich um modbus-Werte aus meiner PV-Anlage.
                                            Hausverbrauch, PV-Leistung, Netzanschluss.
                                            Sorry bin noch am Anfang, meinst du das Log direkt aus der iobroker-Oberfläche über den Tab Log?
                                            Der Zähler der PV-Leistung bleibt stehen, sobald ich Netz_Leistung aktiv schalten.
                                            PS: Ja ich habe es am Tage probiert, weil nachts zählt PV-Leistung nicht weiter, das weiß ich 😉
                                            adapter test
                                            103
                                            958
                                            288048
