    4. Telegram funktioniert nicht mehr
    UNSOLVED Telegram funktioniert nicht mehr
    • radicalreel
      radicalreel last edited by radicalreel
      Danke für die Antwort.
      Telegram 1.3.0
      Node.js: v8.15.1
      NPM: 6.4.1
      JS Controller 4.1.12
      Außer:
      2019-04-02 05:04:06.729  - error: telegram.0 polling_error:EFATAL, EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
      Steht im Log:
      2019-04-02 00:30:17.593  - debug: telegram.0 bot polling OK
      2019-04-02 05:04:03.683  - debug: telegram.0 objectDB connected
      2019-04-02 05:04:03.722  - debug: telegram.0 statesDB connected
      2019-04-02 05:04:03.728  - info: telegram.0 States connected to redis: xxx.x.x.xxxx
      2019-04-02 05:04:03.911  - info: telegram.0 starting. Version 1.3.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.15.1
      2019-04-02 05:04:04.033  - debug: telegram.0 Schedule restart: 4 5 * * *
      2019-04-02 05:04:04.081  - debug: telegram.0 Start polling with: 300(number) ms interval
      2019-04-02 05:04:04.134  - debug: telegram.0 redis pmessage  io.telegram.0.communicate.request io.telegram.0.communicate.request {"val":"","ack":true,"ts":1554xxxxx28,"q":0,"from":"system.adapter.telegram.0","lc":15xxxxx3678}
      2019-04-02 05:04:04.137  - debug: telegram.0 redis pmessage  io.telegram.0.communicate.response io.telegram.0.communicate.response {"val":"","ack":true,"ts":155417xxxxx9,"q":0,"from":"system.adapter.telegram.0","lc":154xxxxx43679}
      2019-04-02 09:44:25.108  - debug: telegram.0 redis pmessage  messagebox.system.adapter.telegram.0 messagebox.system.adapter.telegram.0 {"command":"send","message":{"text":"Fenster Bad unten offen"},"from":"system.adapter.javascript.0","_id":xxxxxxxxx}
      2019-04-02 09:44:25.121  - debug: telegram.0 Send message to "P": Fenster Bad unten offen
      2019-04-02 09:44:25.126  - debug: telegram.0 Send message to "L": Fenster Bad unten offen
      2019-04-02 09:44:25.157  - error: telegram.0 Cannot send message [chatId - xxxxxxxxx]: Error: EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
      2019-04-02 09:44:25.165  - error: telegram.0 Cannot send message [chatId - xxxxxxxxx]: Error: EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
      2019-04-02 05:04:04.217  - error: telegram.0 polling_error:EFATAL, EFATAL: Error: connect ECONNREFUSED xxx.xxx.xxx.xxx:xxx
      2019-04-02 17:36:55.115  - debug: telegram.0 redis pmessage  io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":155xxxxxxx4,"q":0,"from":"system.adapter.admin.0","lc":155xxxxxxx14}
      Hoffe das reicht. Wollte nicht alles posten, da mir der Adapter jede Sekunde 2 Zeilen reinknallt...
      • wendy2702
        wendy2702 last edited by
        Wir sind aktuell ein paar Versionen weiter. Mal ein Update versucht?
        Und mit JS-Controller meinte ich nicht die JavaScript Adapter Version sondern die unter Hosts angezeigte.
        • radicalreel
          radicalreel last edited by Negalein
          Was genau meinst du? Was würdest du updaten?
          Unter Hosts: 1.4.2
          • wendy2702
            Na den Telegram Adapter meine ich.
            • radicalreel
              Mir wird kein Update angeboten. Sorry wenn ich mich blöd anstelle und Danke für die Geduld.
              • wendy2702
                Oha...
                Da haben es offensichtlich einige Versionen noch nicht ins Stable geschafft.
                Stell mal deinen Verwahrungsort auf „latest“ und schaue was du dann angeboten bekommst.
                Aber bitte nicht alles was neuer angeboten wird dann updaten!
                radicalreel 1 Reply Last reply Reply Quote 0
                  Arnulf last edited by
                  @wendy2702 sagte in Telegram funktioniert nicht mehr:
                  Oha...
                  Bei mir scheint der Telegram-Adapter auch Probleme zu bereiten.
                  Kann es sein, dass er ein Memory-Leak hat und sogar ioBroker zum erliegen bringen kann?
                  Zumindest passiert das bei mir manchmal.
                  Und er startet ab und zu von selbst neu:
                  Gerade eben wieder:
                  telegram.0	2019-04-04 22:32:40.845	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.telegram, node: v8.14.0
                  host.ioBroker2	2019-04-04 22:32:37.282	info	instance system.adapter.telegram.0 started with pid 1781
                  host.ioBroker2	2019-04-04 22:32:36.268	info	Restart adapter system.adapter.telegram.0 because enabled
                  host.ioBroker2	2019-04-04 22:32:36.267	error	instance system.adapter.telegram.0 terminated with code 7 (Adapter already running)
                  telegram.0	2019-04-04 22:32:36.248	error	already running
                  telegram.0	2019-04-04 22:32:36.148	warn	Reconnection to DB.
                  telegram.0	2019-04-04 22:32:36.144	warn	Reconnection to DB.
                  • wendy2702
                    Ich weiß nichts von einem Memory Leak oder so.
                    Auch die Probleme mit dem Telegramm Adapter sind aktuell ziemlich gering was ich hier im Forum so mit bekomme.
                    • radicalreel
                      radicalreel @wendy2702 last edited by
                      @wendy2702
                      Verwahrungsort habe ich auf latest gestellt. Zumindest, wenn das bedeutet den Default Pfad mal wegzunehmen. Ich habe da auch keine andere Version angeboten bekommen.
                      • dslraser
                        dslraser Forum Testing Most Active @radicalreel last edited by
                        @radicalreel
                        den Verwahrungsort kannst Du hier einstellen.
                        • radicalreel
                          radicalreel @dslraser last edited by
                          @dslraser
                          Achso den Eintrag hatte ich übersehen. Allerdings war es schon auf lastet eingestellt. Frage mich nur warum ich dann nicht die neuste Version angeboten bekomme. Die Pfade sind doch so OK oder?
                          • dslraser
                            @radicalreel
                            ja, die sind genau wie meine...
                            • radicalreel
                              radicalreel @Arnulf last edited by radicalreel
                              @Arnulf
                              Funktioniert der Adapter bei dir mittlerweile wieder?
                              Habe ein neues token generiert, den Adapter gelöscht, neu installiert, bisschen hin und her gestellt.... da tut sich gar nichts
                              • wendy2702
                                Was heisst:
                                @radicalreel sagte in Telegram funktioniert nicht mehr:
                                Adapter Instanz mal auf "Debug" für das loggen gestellt?
                                Da steht bestimmt "irgendwas" drin.
                                • radicalreel
                                  @wendy2702
                                  Ja habe ich, siehe Post vom 02.04.
                                    Arnulf @radicalreel last edited by
                                    @radicalreel
                                    Sorry. Habe nicht weiter getestet, da ich den Telegram Adapter kurz danach deaktiviert und nicht wieder aktiviert habe.
                                    Es hatte mich zu sehr genervt, dass plötzlich bei meinem (Slave-ioBroker) alle Prozese blockiert wurden und dann einige wichtige Funktionen nicht mehr gingen.
                                    Erst Recht, wenn man morgens aufwacht und das Licht nicht mehr ging.
                                    Wie ich sehe, haben andere Nutzer auch/immer noch Probleme, so dass ich den Adapter wohl weiterhin deaktiviert lasse.
                                    Ich informiere mich seit dem per Mail statt Telegramm.
                                    Ist zwar nicht so schick, funktioniert aber
                                    econnrefused telegram
                                    1908
