    5. Alexa Ansage bis Tür 2. mal geöffnet
    • MyzerAT
      MyzerAT last edited by MyzerAT
      probier es mal so
      f9cf79a9-06e9-4378-bb10-59c5b944a5ae-grafik.png c2f60fd2-4e18-4e4c-80f4-a481a38f71b6-grafik.png
      der eDP_#Testdatenpunkt wäre dein DP Post ist da wahr oder falsch
      • Negalein
        Negalein Global Moderator @MyzerAT last edited by
        @MyzerAT sagte in Alexa Ansage bis Tür 2. mal geöffnet:
        probier es mal so
        Danke, werd ich versuchen ihn so nachzubauen!
        • MyzerAT
          hier das blockly
            <variables>
              <variable type="undefined" id="Intervall">Intervall</variable>
              <variable type="undefined" id="timeout">timeout</variable>
            </variables>
            <block type="on" id="?eb!:)OQGofJ1y9lyhxf" x="-187" y="963">
              <field name="OID">mihome.0.devices.magnet_158d0001ef3511.state</field>
                <block type="controls_if" id="+SR.H-SJ)CI6%-M#Ex(%">
                    <block type="logic_operation" id="`?-QjO6N*%ce]5g!T/uG" inline="false">
                      <field name="OP">AND</field>
                        <block type="time_compare_ex" id="EQ(}QVm+o6Z[}B]5{6Kk">
                          <mutation end_time="true" actual_time="true"></mutation>
                          <value name="START_TIME">
                            <shadow type="text" id="sx_N@n;hg:@4$OjS54sr">
                              <field name="TEXT">9:00</field>
                          <value name="END_TIME">
                            <shadow type="text" id="J/~.VFt%1W~,Yo,oSvtW">
                              <field name="TEXT">18:00</field>
                        <block type="logic_compare" id="M6ynLH8:QA!MNs=;TQ|k">
                          <field name="OP">EQ</field>
                            <block type="get_value" id="$-CBPjf^5WwE(7]v7u=1">
                              <field name="OID">#Eigene.0.Test.TestDatenpunkt</field>
                            <block type="logic_boolean" id="R5AR]:(LyQe_|Pfn2On^">
                    <block type="control" id="xV;G|U?j^+ue8NTB_nd3">
                      <field name="OID">alexa2.0.Echo-Devices.G2A0U204850707WN.Commands.speak</field>
                        <block type="text_join" id="HOz]|0d|`mB+/ncIAV_%">
                          <value name="ADD0">
                            <block type="text" id="f=8:|x?InU8;x[OY,PX7">
                              <field name="TEXT">Post ist da</field>
                        <block type="telegram" id="VckE-IM2`(Fnm|z?#3#Z">
                          <field name="LOG"></field>
                          <value name="MESSAGE">
                            <shadow type="text" id="lzrTPc7Mp1%({G+P]ixj">
                            <block type="control" id="%J8;HEJGd`HfUo^|;bE!">
                              <mutation delay_input="true"></mutation>
                              <field name="DELAY_MS">10</field>
                                <block type="logic_boolean" id="/6}[Nn-cdqcRVHKh^tq.">
                    <block type="controls_if" id=";]$ZNB`^UhH[jM4d+d#G">
                        <block type="logic_operation" id="d^L48{qw+~h~nM1An7Vq" inline="false">
                            <block type="time_compare_ex" id="e{W:+zurf%@,I8sf~*(F">
                                <shadow type="text" id="cZd~f`xunI)Da8^uj%Ev">
                                <shadow type="text" id="d(jn2_C?K$HZnQ1Wf7|T">
                            <block type="logic_compare" id="ttg-)OMRu`-)Ixn,^5pw">
                                <block type="get_value" id="#m8k5O{gc%6Gs[td?%{D">
                                <block type="logic_boolean" id="k~{B2_D~QDWaAQRwF352">
                        <block type="timeouts_cleartimeout" id="eTEA5?MrSE()u[b,F05{">
                            <block type="timeouts_settimeout" id="B)1cbXL_FQi`6b/SBFkE">
                              <field name="DELAY">5</field>
                                <block type="control" id=":^UVszp4o[gR0mG6mL)0">
                                    <block type="logic_boolean" id="aawZ*.sWrv^,Hu}jr):c">
                <block type="on" id="._.PlbwqQIcm?61~t$9z">
                    <block type="controls_if" id="H]hlV-dm)S|*v]GFEo;1">
                        <block type="logic_operation" id="Nu,HSR(?_/y?0`pY,}PC" inline="false">
                            <block type="time_compare_ex" id="S$5z2RgVqfB@9jP*c9c8">
                                <shadow type="text" id=";z4?|ubxzhvx,V9ClXbO">
                                <shadow type="text" id="DmXpbXGyiLXcs#4[]:SD">
                            <block type="logic_compare" id="!yo}5iT]G=GnM~AZr~{~">
                                <block type="get_value" id="y7z~d7_kia]=f(y@H~(O">
                                <block type="logic_boolean" id="$~Sge9WVSn[(3DXmQ[PX">
                        <block type="timeouts_setinterval" id="H1nT3pA3rLDZfTkaL;SN">
                          <field name="NAME">Intervall</field>
                          <field name="INTERVAL">10</field>
                            <block type="control" id="W2.T-U1[lO,s-lG~u!2u">
                                <block type="text_join" id="pLqBNR[Oa|zhpUVdZO~]">
                                  <value name="ADD0">
                                    <block type="text" id="jNhsVYO2[sNq6^[io~^+">
                                <block type="telegram" id="`T+3$mH(w3%c2MuBI1Aw">
                                    <shadow type="text" id="t_1r9=#d^!qK$/K(zat2">
                      <statement name="ELSE">
                        <block type="timeouts_clearinterval" id="aj0v1mNsttMAKaZ.#tSR">
            <block type="logic_compare" id="_cLwN/QZb^|#33qoT=*n" x="250" y="1414">
                <block type="logic_boolean" id="f:`:E{5|*diPosU`f6dR">
          • MyzerAT
            wie man eigene DP erstellt weisst eh?
            • Negalein
              Objekte ---- Expertenmodus ---- auf das +
              Welchen Typ muss ich dem DP geben?
              Der DP wird dann durch das Blockly befüllt?
              Unter welchen DP leg ich am besten den neuen DP an?
              • MyzerAT
                wenn du den Block "Datenpunkt erzeugen" deinem Blockly hinzufügst macht er das automatisch
                • Negalein
                  hier das blockly
                  Wenn ich das Blockly importieren möchte, bekomm ich nur einen grauen Bildschirm.
                  • MyzerAT
                    hmm, ich kann es importieren, baue es einfach nach, ist ja eh nicht soviel
                    • Negalein
                      Bin schon dabei.
                      Dann ist aber das Mittagessen dazwischen gekommen! 😁
                      • Negalein
                        hab gerade bemerkt, dass ich diesen Block nicht habe.
                        Habe nur Zustand erzeugen.
                        JS ist 4.0.12
                          Muchul last edited by
                          Nimm mal Zustand erzeugen...
                          ich glaube es gibt unterschiedliche Versionen
                          • MyzerAT
                            liegt wohl daran das ich diese Version hier verwende
                              hab ich auch:
                              Was ich nicht habe ist irgend eine Ahnung, warum ich den Block habe und du nicht.
                              • MyzerAT
                                hier zeige ich dir wie du selbst einen Datenpunkt erstellst:
                                wenn du noch keinen Ordner "Post" hast musst du schreiben "Post.Post_ist_da" sonst reicht der Name des Datenpunktes wenn du zuvor den Ordner "markierst" wo der DP erstellt werden soll! Der "." ist hier ausschlaggebend!
                                dann auf Hinzufügen:
                                RAW muss einmal angeklicktwerden, dann erst kannst du unten links auf speichern klicken
                                • Negalein
                                  Negalein Global Moderator @Muchul last edited by
                                  @Muchul sagte in Alexa Ansage bis Tür 2. mal geöffnet:
                                  hab ich auch:
                                  Ok, würde ja gerne auf 4.1.12 updaten. Aber jedesmal spinnt dann JS rum und startet den Adapter alle x-Sekunden neu.
                                  Findet ihn dann nicht mehr und kann ihn selbstständig auch nicht installieren.
                                  Dann hilft nur ein Restore des kompletten System.
                                  MyzerAT 1 Reply Last reply Reply Quote 0
                                  • Negalein
                                    • MyzerAT
                                      MyzerAT @Negalein last edited by MyzerAT
                                      @Negalein sagte in Alexa Ansage bis Tür 2. mal geöffnet:
                                      dazu solldest du einen eigene fred aufmachen, damit man dem auf die spur gehen kann, warum dein js abstürzt wenn du update machst auf 4.1.12
                                      • Negalein
                                        Gibt es schon hier
                                        blockly
                                        1363
