    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Node red
    Node red
    • I
      instalator last edited by
      @Bluefox:
      Ты запостил не ВЕСЬ flow. Авторизации не было.
      [{"id":"b2457b04.4dba88","type":"inject","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":110,"y":142,"z":"a3d5aaa9.5c2a58","wires":[["a4b814e9.5b47e8"]]},{"id":"a4b814e9.5b47e8","type":"http request","name":"","method":"GET","ret":"txt","url":"https://www.sistemagorod.ru/lk/","x":430,"y":143,"z":"a3d5aaa9.5c2a58","wires":[["673656c9.98c9a8","892e892.f76d178"]]},{"id":"8aebf8b1.751408","type":"http request","name":"","method":"POST","ret":"txt","url":"","x":429,"y":207,"z":"a3d5aaa9.5c2a58","wires":[["f398e11c.0c672","2e09ba5d.d1f646"]]},{"id":"6d01402.f92fec","type":"http request","name":"","method":"GET","ret":"txt","url":"","x":428,"y":284,"z":"a3d5aaa9.5c2a58","wires":[["3d2f1fc5.c2d0e","7138683e.8ec798"]]},{"id":"f398e11c.0c672","type":"function","name":"Get \"indications\"","func":"if (msg.payload.indexOf('>ok<') != -1) {\n\tmsg.payload = '';\n\tvar parts = msg.headers['set-cookie'][0].split(';');\n\t\n\tmsg.headers = {\n\t    'Host': 'www.sistemagorod.ru',\n\t    'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64; rv:38.0) Gecko/20100101 Firefox/38.0',\n\t    'Accept': '*/*',\n\t    'Accept-Language': 'ru-RU,ru;q=0.8,en-US;q=0.5,en;q=0.3',\n\t    'Accept-Encoding': '',\n\t    'Content-Type': 'application/x-www-form-urlencoded; charset=UTF-8',\n\t    'X-Requested-With': 'XMLHttpRequest',\n\t    'Referer': 'https://www.sistemagorod.ru/lk/',\n\t    'Cookie': parts[0],\n\t    'Connection': 'keep-alive',\n\t    'Pragma': 'no-cache',\n\t    'Cache-Control': 'no-cache'\n\t};\n\t\n\t//msg.headers.Cookie = msg.headers[0]['set-cookie'],\n\tmsg.url = \"https://www.sistemagorod.ru/lk/indications\";\n\treturn msg;\n}\n","outputs":1,"x":236,"y":284,"z":"a3d5aaa9.5c2a58","wires":[["6d01402.f92fec"]]},{"id":"3d2f1fc5.c2d0e","type":"debug","name":"","active":true,"console":"false","complete":"true","x":636,"y":284,"z":"a3d5aaa9.5c2a58","wires":[]},{"id":"673656c9.98c9a8","type":"debug","name":"","active":true,"console":"false","complete":"true","x":632,"y":144,"z":"a3d5aaa9.5c2a58","wires":[]},{"id":"2e09ba5d.d1f646","type":"debug","name":"","active":true,"console":"false","complete":"true","x":633,"y":207,"z":"a3d5aaa9.5c2a58","wires":[]},{"id":"892e892.f76d178","type":"function","name":"Authenticate","func":"msg.url='https://www.sistemagorod.ru/lk/auth?type-auth=phone&answer-captcha=&phone=xxx&pin=yyyy'\nreturn msg;","outputs":1,"x":257,"y":207,"z":"a3d5aaa9.5c2a58","wires":[["8aebf8b1.751408"]]},{"id":"9d88bc37.62774","type":"debug","name":"","active":true,"console":"false","complete":"payload","x":416,"y":381,"z":"a3d5aaa9.5c2a58","wires":[]},{"id":"7138683e.8ec798","type":"function","name":"Extract values","func":"var m = msg.payload.match(/data-previos-reading=\"([\\d.]*)\"/g);\nmsg.payload = [];\nif (m) {\n\tfor (var i = 0; i < m.length; i++) {\n\t\tvar parts = m[i].split('=\"');\n\t\tif (parts.length == 2) {\n\t\t    msg.payload.push(parts[1].replace('\"', ''));\n\t\t}\n\t}\n}\nreturn msg;","outputs":1,"x":241,"y":382,"z":"a3d5aaa9.5c2a58","wires":[["9d88bc37.62774"]]}]
      Ещё была ошибка, что "'Accept-Encoding': 'gzip, deflate',"
      И поэтому ты получал зазипованный ответ.
      Я довел до ответа
      [ "375", "7", "7", "1.351" ]
      Дальше сам. `
      Воу! Спасибо большое!
      • I
        @Bluefox:
        Дальше сам. `
        Я все воскресенье убил, вроде что то получатся начало но на выходе кракозябры… теперь понятно в чем ошибка.
        • I
          Как в node red завести данные датчиков? Выбираю в input IoBroker, переменная передается только когда значение изменяется. Мне нужно получить доступ к текущим показаниям датчика, как эти данные поместить в функцию во время выполения скрипта?
          • еще если переменная изменяется то она запускает скрипт который после этой переменной
          • Bluefox
            Bluefox last edited by
            @instalator:
            • еще если переменная изменяется то она запускает скрипт который после этой переменной `
              Никак. В этом вся проблема node-red. Он stateless и event triggered.
            Можно только через хак и сохранять значения в context.global (http://nodered.org/docs/writing-functions.html)
            • I
              @Bluefox:
              @instalator:
              Можно только через хак и сохранять значения в context.global (http://nodered.org/docs/writing-functions.html) `
              Ок. Будем делать через глобальные.
              msg.Hot_curr = h.substring(0, h.length - 2); выдает ошибку TypeError: Object 722 has no method 'substring' (line 4, col 19)
              Как обрезать последние два символа в значении?
              PS Посоветуй литературу почитать по Node red'у
              • I
                Пока сделал так:
                 var h = context.global.Hot_curr;
                 h = '' + h;
                 msg.Hot_curr = h.substr(0, h.length - 2);
                 var c = context.global.Cold_curr;
                 c = '' + c;
                 msg.Cold_curr = c.substr(0, c.length - 2)
                • Bluefox
                  @instalator:
                  Пока сделал так:
                   h = '' + h;
                   c = '' + c;
                  Ну в принципе именно так:
                   var h = context.global.Hot_curr.toString();
                  • I
                    Как происходит взаимодействие из нодрэда с другими драйверами?
                    Например как из нодреда отправить сообщение Pushover.
                    • I
                      Написал условие, переменная меняет свое состояние но клиенту mqtt не уходит команда, что я делаю не так?
                      [{"id":"acda5939.5325a8","type":"ioBroker in","name":"myhome/Bathroom/Humidity_room","topic":"mqtt.0.myhome.Bathroom.Humidity_room","payloadType":"value","x":167,"y":131,"z":"865a081c.79a5f8","wires":[["20e9eada.df1616","207b73cb.df848c"]]},{"id":"ffc2e396.003d2","type":"ioBroker out","name":"myhome/Bathroom/Ventilator","topic":"mqtt.0.myhome.Bathroom.Ventilator","ack":"true","autoCreate":"false","x":677,"y":139,"z":"865a081c.79a5f8","wires":[]},{"id":"20e9eada.df1616","type":"debug","name":"","active":true,"console":"false","complete":"false","x":328,"y":292,"z":"865a081c.79a5f8","wires":[]},{"id":"207b73cb.df848c","type":"function","name":"","func":"if (msg.payload > 56){\n    msg.payload = 1;\n}\nelse {\n     msg.payload = 0;\n}\nreturn msg;","outputs":1,"valid":true,"x":431,"y":127,"z":"865a081c.79a5f8","wires":[["9fe832be.6017d","ffc2e396.003d2"]]},{"id":"9fe832be.6017d","type":"debug","name":"1111111111111111","active":true,"console":"false","complete":"payload","x":609,"y":219,"z":"865a081c.79a5f8","wires":[]}]
                      • I
                        @instalator:
                        Написал условие, переменная меняет свое состояние но клиенту mqtt не уходит команда, что я делаю не так? `
                        Понял в чем была ошибка, нужно было в выводе поставить не value а command.
                        Возникает следующий вопрос.
                        Как написать чтобы данные отсылались только один раз при срабатывание условия а не постоянно слались на клиента?
                        приведенный код срабатывает только раз т.к. flag постоянно устанавливается в 0. В ардуино хорошо можно при инициализации объявить переменные, а как поступить в нодред?
                        var flag = 0;
                        if (msg.payload > 56 && flag === 0){
                            msg.payload = 1;
                            var flag = 1;
                            return msg;
                        else if (msg.payload < 56 && flag === 1){
                             msg.payload = 0;
                             var flag = 0;
                             return msg;
                        • Bluefox
                          @instalator:
                          @instalator:
                          var flag = 0;
                              msg.payload = 1;
                              var flag = 1;
                              return msg;
                               msg.payload = 0;
                               var flag = 0;
                               return msg;
                          Поменяй на
                          if (context.global.flag === undefined) {
                              context.global.flag = msg.payload > 56;
                          if (msg.payload > 56 && !context.global.flag){
                              msg.payload = 1;
                              context.global.flag= true;
                              return msg;
                          else if (msg.payload < 56 && context.global.flag){
                               msg.payload = 0;
                               context.global.flag= false;
                               return msg;
                          • I
                            @Bluefox:
                            Поменяй на
                                msg.payload = 1;
                                return msg;
                                 msg.payload = 0;
                                 return msg;
                            Спасибо заработало. Вчера начинал уже мудрить с глобальными переменными, думал может есть другой способ.
                            Как из нодреда отправить сообщение на Pushover?
                            • I
                              @instalator:
                              Например как из нодреда отправить сообщение Pushover. `
                              Так и не понял как отправить сообщение. Или только через javascript?
                              • I
                                @Bluefox:
                                Вроде работал код, сегодня решил проверить ругается на toString. Было обновление?
                                Добавлено:
                                Нодред не подхватывает значения счетчиков воды.
                                От электросчетчика подхватывает.
                                [{"id":"249fe99a.db6016","type":"debug","name":"","active":true,"console":"false","complete":"true","x":701,"y":802,"z":"2c2981e2.d3d67e","wires":[]},{"id":"4ad0b93e.b52f48","type":"function","name":"Текущие показания Холодной воды","func":"context.global.Cold_curr = msg.payload.val;\nreturn msg;","outputs":1,"valid":true,"x":426,"y":789,"z":"2c2981e2.d3d67e","wires":[["249fe99a.db6016"]]},{"id":"c6b46d56.394b9","type":"function","name":"Текущие показания Горячей воды","func":"context.global.Hot_curr = msg.payload.val;\nreturn msg;","outputs":1,"valid":true,"x":420,"y":846,"z":"2c2981e2.d3d67e","wires":[["249fe99a.db6016"]]},{"id":"4c6b878d.b39478","type":"ioBroker in","name":"myhome/Mother/Electro_counter","topic":"mqtt.0.myhome.Mother.Electro_counter","payloadType":"value","x":134,"y":904,"z":"2c2981e2.d3d67e","wires":[["269c6eea.d96392"]]},{"id":"269c6eea.d96392","type":"function","name":"Текущие показания Электросчетчика","func":"context.global.Electro_curr = msg.payload;\nreturn msg;","outputs":1,"valid":true,"x":436,"y":904,"z":"2c2981e2.d3d67e","wires":[[]]},{"id":"fca376ea.035c88","type":"ioBroker in","name":"myhome/Bathroom/Cold_water","topic":"mqtt.0.myhome.Bathroom.Cold_water","payloadType":"value","x":128.5,"y":789,"z":"2c2981e2.d3d67e","wires":[["4ad0b93e.b52f48"]]},{"id":"3729a205.c8d65e","type":"ioBroker in","name":"myhome/Bathroom/Hot_water","topic":"mqtt.0.myhome.Bathroom.Hot_water","payloadType":"value","x":126,"y":846,"z":"2c2981e2.d3d67e","wires":[["c6b46d56.394b9"]]}]
                                Добавлено:
                                Чудеса, сегодня все работает ок.
                                • I
                                  Как через Node red создать переменную в iobrokere?
                                  • I
                                    Node red вообще заглючил.
                                    Завис на http reqest.
                                    Код не подсвечивает.
                                    Перезапустил в логе ошибки
                                    ! node-red-0 2015-06-17 10:49:38 warn
                                    ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] –----------------------------------------
                                    ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [redisout] Error: Cannot find module 'redis'
                                    ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [tail] Info : Currently not supported on Windows.
                                    ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
                                    ! node-red-0 2015-06-17 10:49:38 warn 17 Jun 10:49:36 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
                                    ! node-red-0 2015-06-17 10:49:36 warn
                                    ! node-red-0 2015-06-17 10:49:36 warn js-bson: Failed to load c++ bson extension, using pure JS version
                                    ! node-red-0 2015-06-17 10:49:34 warn
                                    ! node-red-0 2015-06-17 10:49:34 warn js-bson: Failed to load c++ bson extension, using pure JS version
                                      bondrogeen last edited by
                                      @instalator:
                                      Как через Node red создать переменную в iobrokere? `
                                      Возник тот же вопрос.
                                      В корне получается создать (пример test) , а вот чтобы добавить сразу топик нет (пример stat/test)
                                      И вообще где можно почитать про создание переменных "для чайников" в iobroker?
                                      • I
                                        @bondrogeen:
                                        И вообще где можно почитать про создание переменных "для чайников" в iobroker? А если так - stat.test ? > И вообще где можно почитать про создание переменных "для чайников" в iobroker? `
                                        В JS например так - createState('Climat.Mode_Pritochka_GuestRoom', '');
                                          @instalator:
                                          @bondrogeen:
                                          В iobrokere как создать переменную вроде-бы научился.
                                          У меня при работе с ним возникло ложное, как сейчас понял, восприятия древовидной структуры папок и под папок где хранятся переменные.
                                          Это сейчас я уже вроде-бы понял, что это переменные типа «object» и сделана это для удобства поиска.
                                          Я правильно понял? если нет поправьте меня.
                                          Получается нужно создавать переменную test.test.test1, test.test.test2 и т.д.
                                          тогда получится
                                          test
                                          ____test
                                          ________test1 1
                                          ________test2 2
                                          В NODE RED не хочет.
                                          Не получается, как только делаешь точку в топике, то не создает переменную вообще.
                                          Просто "test" создает переменную и значение.
                                          Хотел настроить чтобы NODE RED сам создавал переменные в iobrokere.
                                            electric69 last edited by
                                            Через консоль не устанавливается node-red. Права chmod 777 для папки /opt/iobroker. Версии nodejs v4.4.4 npm 2.15.1.
                                            19470
