    2. English
    3. Visualization
    4. getting started with visualisations
      Taragorm last edited by
      It's showing in the toolbox now - many thanks!
        Much progress, but another small issue.
        My visualisation shows values ok in the edit dialog.
        In the normal view, it shows the "undefined" value... unless the value is used by a different widget.
        This suggests I've done something wrong in binding, but as far as I can see, I've done pretty much what the template does.
        Have I missed something out? It feels like whatever code that populates vis.states[] hasn't been invoked correctly. (i.e. the view seems to be unaware of the points I'm asking for).
          ps: Changed the repo to: https://github.com/Taragorm/ioBroker.vistaragorm
          Bluefox 1 Reply Last reply Reply Quote 0
          • Bluefox
            Bluefox @Taragorm last edited by Bluefox
            @Taragorm It can be, that I forgot to describe, that all ObjectID Variables Names must start with "oid..." or end with "...oid" or "...oidN" (N is any number from 0 to 99)
            Please use following files, that work:
            vistaragorm.js
            vistaragorm.html
              Ah, that would be it then - I may have missed it.
              I assumed that the /id type in the attr declaration was what did it.
                That works nicely, thanks.
                Out of curiosity, is there any way to force subscription?
                I have a case where I have mutiple values on a sensor, and I'd like to be able to just specify the sensor oid for the widget, and have the implementation figure out the values.
                e.g. I have
                foo.bah.x
                foo.bah.y
                foo.bah.z
                .. I'd like to only have to supply an oid of foo.bah - the widget can add .x, .y etc as those are fixed.
                or does supplying an oid = "foo.bah" create a subscription for changes of all children too?
                  In case it's not obvious, I'd like a widget to be able to generate oids based on, or relative to, an oid in an attribute, and have the object correctly added to the widget/view so I can get data from it.
                  Surely there must be a way to do this?
                  • Bluefox
                    @Taragorm I must check it
                      Appreciated
                      • Bluefox
                        @Taragorm Now I understand, what you want.
                        The solution is to provide all OIDs during configuration. You can see the example:
                        • https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets.html#L61
                        • https://github.com/ioBroker/ioBroker.vis-hqwidgets/blob/master/widgets/hqwidgets/js/hqwidgets.js#L3069
                        If your first OID is changed, the defined function (in example vis.binds.hqwidgets.changedButtonId) will be called and you can define other fields there with desired OIDs.
                          Thanks- that solves the problem!
                            goodDay14 last edited by goodDay14
                            I have a case where I have mutiple values on a sensor, and I'd like to be able to just specify auto clicker wordunscrambler jumblesolver
                              sonusfaber @Bluefox last edited by
                              @Bluefox I do struggle with the following instruction:
                              "replace index.html and edit.html replace files in /opt/iobroker/iobroker-data/files/vis/index.html and edit.html with files from /opt/iobroker/node_modules/iobroker.vis/www/index.html.original and edit.html.original. Change the file /opt/iobroker/iobroker-data/files/vis/cache.manifest. No matter what, just one symbol to trigger the browser to load files anew. The files must be smaller than 200k. If you have got wrong files, so they are definitly largen than 400k."
                              I understood ..
                              Replace the following two files /opt/iobroker/iobroker-data/files/vis/index.html & /opt/iobroker/iobroker-data/files/vis/edit.html with
                              /opt/iobroker/node_modules/iobroker.vis/www/index.html.original and /opt/iobroker/node_modules/iobroker.vis/www/edit.html.original.
                              in other words..
                              cp /opt/iobroker/node_modules/iobroker.vis/www/index.html.original /opt/iobroker/iobroker-data/files/vis/index.html
                              cp /opt/iobroker/node_modules/iobroker.vis/www/edit.html.original /opt/iobroker/iobroker-data/files/vis/edit.html
                              Is this correct ?
                              If yes, in my installation
                              /opt/iobroker/node_modules/iobroker.vis/www/index.html.original and /opt/iobroker/node_modules/iobroker.vis/www/edit.html.original do not exist!
                              vis
                              5539
