Set State ( Timestamp ) Zeitverzögert [gelöst].
Morgen,
ist immer noch das Problem. Die Meldung kommt wenn ich die 2 Minuten gewartet habe und dann die Pumpe Abschalte.
08:35:05.587 [info] javascript.0 Start javascript script.js.Pool_Dosierungneuändern 08:35:05.587 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rega.0.25168, timerId=0) => {"val":true,"ack":true,"ts":1540149504039,"q":0,"from":"system.adapter.hm-rega.0","lc":1540149488439} 08:35:05.588 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rega.0.19785, timerId=0) => {"val":true,"ack":true,"ts":1540152954516,"q":0,"from":"system.adapter.hm-rega.0","lc":1540152930487} 08:35:05.588 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rega.0.25719, timerId=0) => {"val":false,"ack":true,"ts":1540148123864,"q":0,"from":"system.adapter.hm-rega.0","lc":1540148115625} 08:35:05.589 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rega.0.25721, timerId=0) => {"val":45,"ack":true,"ts":1540190042760,"q":0,"from":"system.adapter.hm-rega.0","lc":1540190020568} 08:35:05.589 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rega.0.25722, timerId=0) => {"val":0,"ack":true,"ts":1540189892818,"q":0,"from":"system.adapter.hm-rega.0","lc":1540189892386} 08:35:05.590 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rpc.1.NEQ1810472.13.STATE, timerId=0) => {"val":true,"ack":true,"ts":1540190099846,"q":0,"from":"system.adapter.hm-rpc.1","lc":1540190099846} 08:35:05.591 [info] javascript.0 script.js.Pool_Dosierungneuändern: setTimeout(ms=120000) 08:35:05.592 [info] javascript.0 script.js.Pool_Dosierungneuändern: subscribe: {"pattern":{"id":"hm-rega.0.25168","change":"ne"},"name":"script.js.Pool_Dosierungneuändern"} 08:35:05.593 [info] javascript.0 script.js.Pool_Dosierungneuändern: subscribe: {"pattern":{"id":"hm-rpc.1.NEQ1810472.13.STATE","change":"ne"},"name":"script.js.Pool_Dosierungneuändern"} 08:35:05.593 [info] javascript.0 script.js.Pool_Dosierungneuändern: subscribe: {"pattern":{"id":"hm-rega.0.19785","change":"ne"},"name":"script.js.Pool_Dosierungneuändern"} 08:35:05.594 [info] javascript.0 script.js.Pool_Dosierungneuändern: subscribe: {"pattern":{"id":"hm-rega.0.25719","change":"ne"},"name":"script.js.Pool_Dosierungneuändern"} 08:35:05.594 [info] javascript.0 script.js.Pool_Dosierungneuändern: schedule(cron=30 0 0 * * *) 08:35:05.595 [info] javascript.0 script.js.Pool_Dosierungneuändern: registered 4 subscriptions and 1 schedule 08:37:05.595 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rpc.1.NEQ1810472.13.STATE, timerId=0) => {"val":true,"ack":true,"ts":1540190099846,"q":0,"from":"system.adapter.hm-rpc.1","lc":1540190099846} 08:37:05.596 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rega.0.25720, state="chlor") 08:37:05.597 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=parser.0.Pool-orp, timerId=0) => {"val":717,"ack":true,"ts":1540189706648,"q":0,"from":"system.adapter.parser.0","lc":1540189706648} 08:37:05.597 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rega.0.25721, state=90) 08:37:05.598 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rpc.1.NEQ1810472.19.STATE, state=true) 08:37:05.598 [info] javascript.0 script.js.Pool_Dosierungneuändern: setTimeout(ms=45000) 08:37:05.599 [info] javascript.0 script.js.Pool_Dosierungneuändern: setInterval(ms=60000) 08:37:50.584 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rpc.1.NEQ1810472.19.STATE, state=false) 08:37:55.687 [warn] javascript.0 script.js.Pool_Dosierungneuändern: clearTimeout() => not found 08:37:55.695 [info] javascript.0 script.js.Pool_Dosierungneuändern: clearInterval() => cleared 08:37:55.696 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rpc.1.NEQ1810472.19.STATE, timerId=0) => {"val":false,"ack":true,"ts":1540190270674,"q":0,"from":"system.adapter.hm-rpc.1","lc":1540190270585} 08:37:55.696 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rpc.1.NEQ1810472.18.STATE, timerId=0) => {"val":false,"ack":true,"ts":1540189759938,"q":0,"from":"system.adapter.hm-rpc.1","lc":1540189759863}
Wenn der Fehler einmal da war kommt er beim nächsten abschalten nicht wieder:
09:36:34.952 [info] javascript.0 script.js.Pool_Dosierungneuändern: setTimeout(ms=120000) 09:37:06.148 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rpc.1.NEQ1810472.19.STATE, state=false) 09:38:34.961 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rega.0.25720, state="chlor") 09:38:34.961 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=parser.0.Pool-orp, timerId=0) => {"val":689,"ack":true,"ts":1540193843366,"q":0,"from":"system.adapter.parser.0","lc":1540193843366} 09:38:34.962 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rega.0.25721, state=160) 09:38:34.962 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rpc.1.NEQ1810472.19.STATE, state=true) 09:38:34.963 [info] javascript.0 script.js.Pool_Dosierungneuändern: setTimeout(ms=45000) 09:38:34.963 [info] javascript.0 script.js.Pool_Dosierungneuändern: setInterval(ms=60000) 09:38:40.077 [info] javascript.0 script.js.Pool_Dosierungneuändern: clearInterval() => cleared 09:38:40.077 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rpc.1.NEQ1810472.19.STATE, timerId=0) => {"val":true,"ack":true,"ts":1540193915046,"q":0,"from":"system.adapter.hm-rpc.1","lc":1540193914959} 09:38:40.078 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rpc.1.NEQ1810472.19.STATE, state=false) 09:38:40.078 [info] javascript.0 script.js.Pool_Dosierungneuändern: getState(id=hm-rpc.1.NEQ1810472.18.STATE, timerId=0) => {"val":false,"ack":true,"ts":1540193044915,"q":0,"from":"system.adapter.hm-rpc.1","lc":1540193044838} 09:39:19.954 [info] javascript.0 script.js.Pool_Dosierungneuändern: setForeignState(id=hm-rpc.1.NEQ1810472.19.STATE, state=false)
Wenn der Fehler einmal da war kommt er beim nächsten abschalten nicht wieder: `
Dann fällt mir noch eine Möglichkeit ein, das zu unterbinden (beim Skriptstart).// Skriptstart if(getState(idPoolPumpe).val) { timerPool = setTimeout(function() { timerPool = null; pumpePool = getState(idPoolPumpe).val; if(pumpePool) Dosierung(); }, 120000); }
Sauber jetzt passt es….. Danke !!!!
Letzte frage hab ich noch. Wenn der Chlor Wert nicht plausibel ist unter 100 oder über 1000 ist und der PH Wert nicht plausibel unter 6.5 oder über 8.0 dann soll auf Störung gehen. ( Drahtbruch )
Das muss noch irgendwie hier rein oder ?
//Dosierung ist noch nicht abgeschaltet oder ORP-Wert,PH-Wert ist zu alt Parser 1200000 = 20 Minuten ??? if(getState(idPumpeChlor).val || getState(idPumpePH).val || Date.now() - getState(idORPWert).ts > 1200000 || Date.now() - getState(idPHWert).ts > 1200000) { stoerung = true; setState(idStoerung, true); } else { acid = !acid; if(acid) dosingPH(); else dosingChlor(); } },60000); // alle 1 Minuten } }
Sauber jetzt passt es `
Das freut mich
@kasperfunsurfer:Wenn der Chlor Wert nicht plausibel ist unter 100 oder über 1000 ist und der PH Wert nicht plausibel unter 6.5 oder über 8.0 dann soll auf Störung gehen.
Das muss noch irgendwie hier rein oder ? `
Möglich mit 4 weiteren Oder (||). Eleganter ist es innerhalb der Dosierungfunktionen dosingPH() und dosingChlor().// DosingTime abhängig von PH Differenz festlegen setState(idChlorAcidAlternative, "acid"); var phIstWert = parseFloat(getState(idPHWert).val); if(phIstWert < 6.5 || phIstWert > 8) { stoerung = true; setState(idStoerung, true); return; }
bzw.
// DosingTime abhängig von ORP-Differenz festlegen setState(idChlorAcidAlternative, "chlor"); var orpIstWert = parseFloat(getState(idORPWert).val); // parseFloat, falls ORPWert ein String ist if(orpIstWert < 100 || orpIstWert > 1000) { stoerung = true; setState(idStoerung, true); return; }
},60000); // alle 1 Minuten ```` `
Jede Minute ist zu kurz, wenn die maximale dosingTime 80 s beträgt (Chlor). Dann läuft das Programm bei 80 s in die Störung.
Noch eleganter ist es, wenn Du die Überprüfung der Zeitstempel aus der Hauptfunktion Dosierung() entfernst und es der jeweiligen Funktion hinzufügst.
dosingChlor():
var stateORP = getState(idORPWert); var orpIstWert = parseFloat(stateORP.val); // parseFloat, falls ORPWert ein String ist if(orpIstWert < 100 || orpIstWert > 1000 || Date.now() - stateORP.ts > 1200000) { stoerung = true; setState(idStoerung, true); return; }
dosingPH():
var statePH = getState(idPHWert); var phIstWert = parseFloat(statePH.val); if(phIstWert < 6.5 || phIstWert > 8 || Date.now() - statePH.ts > 1200000) { stoerung = true; setState(idStoerung, true); return; }
Meinst du so ? Scheint zu passen
//Dosierung ist noch nicht abgeschaltet if(getState(idPumpeChlor).val || getState(idPumpePH).val ) { stoerung = true; setState(idStoerung, true); } else { acid = !acid; if(acid) dosingPH(); else dosingChlor(); } },180000); // alle 3 Minuten } }
// DosingTime abhängig von PH Differenz festlegen setState(idChlorAcidAlternative, "acid"); var statePH = getState(idPHWert); var phIstWert = parseFloat(statePH.val); if(phIstWert < 6.5 || phIstWert > 8 || Date.now() - statePH.ts > 1200000) { stoerung = true; setState(idStoerung, true); return; } var dosingTime = 35; if (PHZielwert - phIstWert < 0.1) dosingTime = 25; if (PHZielwert - phIstWert < 0.05) dosingTime = 20; if (PHZielwert - phIstWert < 0.03) dosingTime = 10; if (PHZielwert <= phIstWert) dosingTime = 0;
// DosingTime abhängig von ORP-Differenz festlegen setState(idChlorAcidAlternative, "chlor"); var stateORP = getState(idORPWert); var orpIstWert = parseFloat(stateORP.val); // parseFloat, falls ORPWert ein String ist if(orpIstWert < 100 || orpIstWert > 1000 || Date.now() - stateORP.ts > 1200000) { stoerung = true; setState(idStoerung, true); return; } var dosingTime = 80; if (orpZielwert - orpIstWert < 100) dosingTime =60; if (orpZielwert - orpIstWert < 60) dosingTime = 50; if (orpZielwert - orpIstWert < 40) dosingTime = 45; if (orpZielwert - orpIstWert < 20) dosingTime = 35; if (orpZielwert - orpIstWert < 10) dosingTime = 20; if (orpZielwert - orpIstWert < 5) dosingTime = 10; if (orpZielwert <= orpIstWert) dosingTime = 0;
Das mit der 1 Minute ist mir bewusst ist nur zum testen damit es schneller geht.
Meinst du so ? `
Ja, genau so. -
Sauber geht DANKE nochmal !!!!!
Hallo nochmal,
da die Pool Saison jetzt anfängt und ich die Reglung über Java laufen habe ist gerade noch ein Problem aufgetaucht. Folgendes Problem:
Das Funktioniert auch Super.
Das leider nicht. Die Dosierzeit ist immer 35 sec. Irgendwie werden die Werte nicht berechnet. Liegt das Irgendwie am . ??
Hat wer eine Idee ??Achso die Werte frage ich über einen Parser Adapter ab.
Grüße Timo
@kasperfunsurfer
Ein Skript läuft immer und wird nicht gestartet.Die Ausführung sollte eventbasiert oder zeitgesteuert erfolgen
Das ganz Script läuft super ist nur ein ausschnitt wo das Problem liegt. Es gibt ein Problem mit der Berechnung vom Ph Wert.
Der Berechnung vom Orp Wert funktioniert dagegen super. Habe gedacht das es irgendwie an dem Punkt liegt also 0.1, 0.05 und 0.03.
Ist das möglich ?Grüße Timo
Hier mal ei Ausschnitt vielleicht kann man da mehr sehen.
javascript.0 2019-04-11 18:17:51.554 info script.js.Pool_Dosierung: setForeignState(id=hm-rpc.1.NEQ1810472.18.STATE, state=false) javascript.0 2019-04-11 18:17:33.569 info script.js.Pool_Dosierung: setTimeout(ms=18000) javascript.0 2019-04-11 18:17:33.568 info script.js.Pool_Dosierung: setForeignState(id=hm-rpc.1.NEQ1810472.18.STATE, state=true) javascript.0 2019-04-11 18:17:33.567 info script.js.Pool_Dosierung: setForeignState(id=hm-rega.0.25722, state=603) javascript.0 2019-04-11 18:17:33.566 info script.js.Pool_Dosierung: getState(id=parser.0.Pool-ph, timerId=undefined) => {"val":7.25,"ack":false,"ts":1554999366086,"q":0,"from":"system.adapter.admin.0","lc":1554999366086} javascript.0 2019-04-11 18:17:33.565 info script.js.Pool_Dosierung: setForeignState(id=hm-rega.0.25720, state="acid") javascript.0 2019-04-11 18:17:33.563 info script.js.Pool_Dosierung: getState(id=hm-rpc.1.NEQ1810472.18.STATE, timerId=undefined) => {"val":false,"ack":true,"ts":1554998097090,"q":0,"from":"system.adapter.hm-rpc.1","lc":1554998097014}
Der eingestellt Wert ist 7.2 und der übertragene Wert ist 7.25 demnach müsste das ganze 5 sec laufen. Es sind aber immer 18 sec egal welchen Ph Wert ich einstelle.
Servus,
habe nochmal bisschen rumgespielt. Wenn ich die < umdrehe der Funktioniert die Berechnung wieder.
var dosingTime = 18; if (PHZielwert - phIstWert < 0.1) dosingTime = 13; if (PHZielwert - phIstWert < 0.05) dosingTime = 10; if (PHZielwert - phIstWert < 0.03) dosingTime = 5; if (PHZielwert <= phIstWert) dosingTime = 0;
Leide funktioniert es so falsch rum. Ändere ich es in so. Funktioniert es leider nicht mehr. Warum ????
var dosingTime = 18; if (PHZielwert - phIstWert > 0.1) dosingTime = 13; if (PHZielwert - phIstWert > 0.05) dosingTime = 10; if (PHZielwert - phIstWert > 0.03) dosingTime = 5; if (PHZielwert >= phIstWert) dosingTime = 0;
Grüße Timo
@kasperfunsurfer
Wahrscheinlich müsstest du mit elseif arbeiten.Oder die Reihenfolge umdrehen
