    4. [Aufruf] ZigBee CC253x Adapter Version 0.10.x
      Muchul last edited by
      @Asgothian
      Ach ja
      npm list > npmlist.txt
      konnte ich nur mit sudo su durchführen und gibt in Putty folgendes aus:
      sener@iobroker:/opt/iobroker$ sudo su
      [sudo] Passwort für sener:
      root@iobroker:/opt/iobroker# npm list > npmlist.txt
      npm ERR! extraneous: binrpc@3.3.1 /opt/iobroker/node_modules/binrpc
      npm ERR! extraneous: dropbox-v2-api@2.1.22 /opt/iobroker/node_modules/dropbox-v2-api
      npm ERR! extraneous: express-fileupload@0.4.1 /opt/iobroker/node_modules/express-fileupload
      npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
      npm ERR! extraneous: homematic-xmlrpc@1.0.2 /opt/iobroker/node_modules/homematic-xmlrpc
      npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
      npm ERR! extraneous: netmask@1.0.6 /opt/iobroker/node_modules/netmask
      npm ERR! extraneous: node-pre-gyp@0.12.0 /opt/iobroker/node_modules/node-pre-gyp
      npm ERR! extraneous: node-ssdp@3.3.0 /opt/iobroker/node_modules/node-ssdp
      npm ERR! extraneous: node-telegram-bot-api@0.30.0 /opt/iobroker/node_modules/node-telegram-bot-api
      npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
      npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
      npm ERR! extraneous: suncalc@1.8.0 /opt/iobroker/node_modules/suncalc
      npm ERR! extraneous: targz@1.0.1 /opt/iobroker/node_modules/targz
      npm ERR! extraneous: typescript@2.9.2 /opt/iobroker/node_modules/typescript
      npm ERR! extraneous: virtual-tsc@0.3.4 /opt/iobroker/node_modules/virtual-tsc
      npm ERR! extraneous: wake_on_lan@0.0.4 /opt/iobroker/node_modules/wake_on_lan
      npm ERR! extraneous: zcl-id@0.4.0 /opt/iobroker/node_modules/zcl-id
      npm ERR! extraneous: zive@0.2.2 /opt/iobroker/node_modules/zive
      npm ERR! peer dep missing: stream-browserify@*, required by bl@0.7.0
      und hier die Datei:
      npmlist.txt
        Wildbill last edited by Wildbill
        So, seit der Umstellung Tradfri-Gateway -> alle Lampen und CC2531 -> 4 Repeater und alle Remotes und Bewegungsmelder läuft bislang alles. Was ich bemerke ist, dass Lampen viel schneller an gehen, wenn man einen Bereich mit Bewegungsmelder betritt. Als sie der Zigbee-Stick noch gesteuert hat, dauerte es so 1sec bis die erste Lampe anging und dann so alle Zehntelsekunde die restlichen vier. Jetzt gehen quasi sofort alle 5 Lampen gleichzeit an, kaum, dass der BWM Bewegung registriert. Die transitionDuration ist unverändert bei einer halben Sekunde.
        Wenn das ganze jetzt dauerhaft stabil bleibt, dann habe ich da für mich das Optimum gefunden.
        Gleichwohl reizt es mich irgendwie, doch nochmal alles auf Deconz umzuziehen und da zu testen. Zum Glück scheint der Conbee gerade ausverkauft. 😂
        Wenn ich noch einen freien Raspi finde, bestelle ich aber vielleicht doch noch das Raspbee-Modul. Irgendein Raspi 1 fliegt bestimmt noch rum und darauf soll es ja anscheinend auch laufen (headless).
        Gruss, Jürgen
          @Asgothian
          Ich habe noch nie bei github irgendwas gemacht, bis auf Issues. Ich hätte aber im Anhang einmal ein passendes Bild für den Tradfri motion sensor für ../Admin/img sowie eine angepasste devstates.js für ../lib. In der ist das Bild passend eingetragen, sowie für die Tradfri remote noch der state.battery. Der scheint mit gesendet zu werden, ist bei github aber auch noch nicht drin. Magst Du das dazu nehmen?
          Gruss, Jürgen
          tradfri_motion_sensor.png devstates.js
          • Asgothian
            Asgothian Developer @Wildbill last edited by
            @Wildbill Jo, mach ich.
            A.
            • V
              vistahr last edited by
              Ich versuche momentan die INNR RB 248 T zum laufen zu bekommen.
              Die Lampe wird auch erkannt, aber die Steuerung ist nicht möglich.
              Bei den Devices ist die Lampe drin:
                      zigbeeModel: ['RB 248 T'],
                      model: 'RB 248 T',
                      vendor: 'Innr',
                      description: 'E14 Candle with white spectrum',
                      extend: generic.light_onoff_brightness_colortemp,
              Bildschirmfoto 2019-04-08 um 14.09.22.png Bildschirmfoto 2019-04-08 um 14.08.49.png
              Jemand eine Idee, oder ähnliches Problem?
              zigbee-shepherd ready. version: 2.6.3 rev 20190109
              Version 0.10.2
              Node.js: v8.15.0
              NPM: 6.4.1
              • Asgothian
                Asgothian Developer @vistahr last edited by
                @vistahr
                Ja. Jeder wird dieses Problem haben. Neben den devices im zigbee-shepherd-converters muss die Lampe auch noch im devstates.js unter /lib mit eingetragen werden.
                Das ist prinzipiell eine Kleinigkeit, aber ich bin dieses Wochenende nicht dazu gekommen diese Kleinigkeiten zu machen.
                Du kannst bei dir ja mal danach schauen - es gibt hinreichend bestehende INNR Lampen, die du als "template" nutzen kannst um auch dieses Modell mit zu unterstützen - erst einmal lokal bei Dir, und wenn du magst dann auch via pull-request auf Github für alle anderen.
                A.
                • V
                  vistahr @Asgothian last edited by
                  @Asgothian said in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
                  @vistahr
                  A.
                  Vielen Dank - hat geklappt 👍
                  Ich habe leider kein Git/Githubg.
                  Bei Innr gibt es das Image für die E14 noch nicht. Ansonsten muss es als State bei "lightStatesWithColortemp" rein, aber die vorhandene ist eine GU10.
                  • Asgothian
                    @vistahr
                    Kannst du mir deine Anpassung an den devstates hier posten ? Dann kann ich das in der kommenden Änderung berücksichtigen.
                    A.
                    • V
                      @Asgothian
                      Klar. Wobei es beim Bild den e14 Sockel nicht gibt. Habe das e27 Bild genutzt.
                              vendor: 'Innr',
                              models: ['RB 248 T'],
                              icon: 'img/innr1.png',
                              states: lightStatesWithColortemp,
                              linkedStates: [comb.brightnessAndState],
                      Produkt:
                      https://www.amazon.de/Philips-kompatibel-dimmbar-Warmweiß-Tageslicht/dp/B07HB37DJ9/ref=sr_1_fkmrnull_2?__mk_de_DE=ÅMÅŽÕÑ&keywords=RB+248+T&qid=1554789800&s=gateway&sr=8-2-fkmrnull
                        Muchul @Muchul last edited by
                        @Asgothian
                        hast du Gelegenheit gehabt dir das anzuschauen?
                        @Muchul sagte in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
                        @Asgothian
                        Ach ja
                        und hier die Datei:
                        npmlist.txt
                        • Asgothian
                          Asgothian Developer @Muchul last edited by
                          @Muchul Angesehen habe ich es mir. Es sollte eigentlich auch Gehen. Mir ist jedenfalls nichts negatives mehr aufgefallen.
                          Ich hatte dich aber auch so verstanden das
                          • die Meldungen weg waren
                          • die BM auch funktionieren
                          A.
                            Muchul @Asgothian last edited by
                            @Asgothian
                            Die Bwm funktionieren.
                            Nur die Meldungen kommen jedes Mal, wenn sie angesprochen werden.
                            • MyzerAT
                              MyzerAT last edited by
                              hab schon wieder ein Problem zu vermelden, einer meiner Thernmostate zeigt keine Batteriewerte mehr an und wenn sich das Stellrad änder bleibt es dennoch auf 0%
                              • Asgothian
                                Asgothian Developer @MyzerAT last edited by
                                @MyzerAT wenn du in der Objektansicht bei dem thermostat auf das i drückst, kommt dann eine Fehlermeldung im Log ?
                                A.
                                MyzerAT 1 Reply Last reply Reply Quote 0
                                • MyzerAT
                                  MyzerAT @Asgothian last edited by
                                  @Asgothian
                                  nein
                                  • Asgothian
                                    @MyzerAT dann sollte der thermostat sauber weiter angebunden sein. Am besten du beobachtest das weiter.
                                    A.
                                      Denzel1994 last edited by Denzel1994
                                      ich mische mich hier auch mal kurz ein.
                                      Ich habe derzeit zwei "Probleme":
                                      1. Wenn ich Gruppen nutze (bspw. 4 Birnen unter der Gruppe Deckenlampe) und dann den PowerState der Gruppe auf "true" setze, dann ändern sich die PowerStates der individuellen Birnen in den Objekten nicht. Aber alle Birnen werden entsprechend eingeschaltet. Ist das so gewollt?
                                      2. Ich bekomme für den IKEA TRADFRI Signalverstärker in der Netzwerkkarte kein Bild angezeigt. In der Geräteübersicht ist jedoch eins da.
                                        Bildschirmfoto 2019-04-15 um 01.29.39.png Bildschirmfoto 2019-04-15 um 01.29.14.png
                                      zigbee-shepherd version: 2.6.3 rev 20190223
                                      Adapter version: 0.10.3
                                      node: v8.15.0
                                      Danke im Voraus
                                      Lars
                                        root_ last edited by
                                        Ist bei mir auch so aber nur im Safari. Im Firefox wird es richtig angezeigt.
                                          southparkler last edited by southparkler
                                          Hab seit einige Tagen folgende Meldungen im Log, es ist ein Hue Dimmer (hab nur einen in Betrieb) und alle Osram Plugs betroffen.
                                          zigbee.0	2019-04-17 23:13:34.248	warn	Dev 0x7cb03eaa00acab3d Plug 01 not configured yet, will try again in latest 300 sec
                                          zigbee.0	2019-04-17 23:13:34.233	warn	Dev 0x7cb03eaa00ae5d26 Plug 01 not configured yet, will try again in latest 300 sec
                                          zigbee.0	2019-04-17 23:13:34.216	warn	Dev 0x7cb03eaa00af20e8 Plug 01 not configured yet, will try again in latest 300 sec
                                          zigbee.0	2019-04-17 23:13:34.201	warn	Dev 0x84182600000e8c2e Plug 01 not configured yet, will try again in latest 300 sec
                                          zigbee.0	2019-04-17 23:13:34.163	warn	Dev 0x001788010329aee5 SML001 not configured yet, will try again in latest 300 sec
                                          zigbee.0	2019-04-17 23:13:34.140	warn	Dev 0x0017880104f6ca17 RWL021 not configured yet, will try again in latest 300 sec
                                          Neu anlernen der Geräte hilft nicht.
                                          Die Netzwerk Karte ist auch rot und zeigt nichts mehr an, der Rest läuft aber (diverse Aqara Sensoren, Hue Bewegungsmelder...)
                                          Kann mir jmd. sagen an was das liegen könnte?
                                          Hab seit Gestern wieder die aktuelle Version vom Github, Probleme bestehen aber schon bissle länger.
                                            Denzel1994 @root_ last edited by
                                            @root_ said in [Aufruf] ZigBee CC253x Adapter Version 0.10.x:
                                            Ah hast recht. In Chrome und Firefox wird es korrekt angezeigt, nur in Safari nicht.
                                            Danke 🙂
                                            31.7k
                                            79.9k
                                            0.10.x adapter zigbee
                                            27
                                            373
                                            53515
