    4. Weatherunderground Reborn 3.0.0 Alpha
      dos1973 @apollon77 last edited by
      @apollon77
      anbei das Log
      host.ioBroker	2019-04-07 12:51:05.115	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      weatherunderground.0	2019-04-07 12:51:02.851	debug	all forecast values set
      weatherunderground.0	2019-04-07 12:51:02.851	debug	all current conditions values set
      weatherunderground.0	2019-04-07 12:51:01.278	debug	get WU legacy data: http://api.wunderground.com/api/606f3f6977348613/forecast/hourly/conditions/units:m/lang:DL/q/pws:IBADHOMB116.json
      weatherunderground.0	2019-04-07 12:51:01.278	debug	Use legacy API Key 606f3f6977348613
      weatherunderground.0	2019-04-07 12:51:01.278	debug	Use Legacy API
      weatherunderground.0	2019-04-07 12:51:01.278	debug	location has not changed, reuse extracted URLs
      weatherunderground.0	2019-04-07 12:51:01.262	debug	initialize Hourly Forecast Url: https://api.weather.com/v1/geocode/50.21/8.64/forecast/hourly/240hour.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
      weatherunderground.0	2019-04-07 12:51:01.260	debug	initialize Daily Forecast Url: https://api.weather.com/v1/geocode/50.21/8.64/forecast/daily/5day.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
      weatherunderground.0	2019-04-07 12:51:01.245	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IBADHOMB116&format=json
      weatherunderground.0	2019-04-07 12:51:01.241	debug	initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-04-07 12:51:01.226	debug	initialize PWS Station Key: 606f3f6977348613
      weatherunderground.0	2019-04-07 12:51:01.143	debug	init forecast objects
      weatherunderground.0	2019-04-07 12:51:01.143	debug	init conditions objects
      weatherunderground.0	2019-04-07 12:51:01.143	debug	on ready: DL true true true true
      weatherunderground.0	2019-04-07 12:51:01.143	info	starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.0
      host.ioBroker	2019-04-07 12:51:00.028	info	instance system.adapter.weatherunderground.0 started with pid 16153
      und die Settings
      Besten Dank für die Hilfe
        Das ist strange ... bei mir tut das alles. habe mal genau deins nachgestellt. Welches Admin? Welcher js-controller?
          dos1973 last edited by
          anbei die Infos ✌
          admin: 3.6.0
          js script engine: 4.1.12
          Node.js: v8.15.0
          NPM: 6.4.1
          js Controller 1.4.2 (es steht es wäre 1.5.7 verfügbar, keine Ahnung wie ich das updaten kann)
            Geh mal mit der Maus über das "Incalid date". Was sterht denn da in dem Popup was da kommt?
            (js.controller update auf Seite "Hosts" 🙂
              so schaut aus...
                @apollon77
                Hast du noch eine Idee?
                  aufgrund meiner Fehler mit dem Datum habe ich den Adapter, die Instanz und alle DP gelöscht und alles neu installiert.
                  jetzt geht gar nichts mehr 😞
                  jetzt erhalte nachfolgende FM, dabei spielt es keine Rolle, ob ich den Haken bei "ältere WU-API nutzen" setze oder rausnehme. Ich habe auch andere Mess Stationen verwendet -> aktuell "IFRANKFU924"
                  host.ioBroker	2019-04-14 13:34:06.834	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                  weatherunderground.0	2019-04-14 13:34:04.317	error	Error: this key does not exist, Reset Station Key
                  weatherunderground.0	2019-04-14 13:34:04.066	error	The given Location can not be found. Please check on https://wunderground.com or try geo coordinates (lat,lon) or nearby cities!
                  weatherunderground.0	2019-04-14 13:34:03.558	error	Error: this key does not exist, Reset Station Key
                  weatherunderground.0	2019-04-14 13:34:03.298	error	The given Location can not be found. Please check on https://wunderground.com or try geo coordinates (lat,lon) or nearby cities!
                  weatherunderground.0	2019-04-14 13:34:02.814	error	Error: this key does not exist, Reset Station Key
                  weatherunderground.0	2019-04-14 13:34:02.528	error	The given Location can not be found. Please check on https://wunderground.com or try geo coordinates (lat,lon) or nearby cities!
                  weatherunderground.0	2019-04-14 13:34:00.865	info	starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.0
                  klappt das bei euch noch?
                    ich bin jetzt wieder im Ausgangszustand... ich erhalte Werte aber immer "invalid date" beim Datum. Es spielt keine Rolle, welche Mess Station ich eingebe.
                    könnte jemand mal eine funktionierende Konfiguriert posten, also ein Bild des adapters. Danke
                      dos1973 @dos1973 last edited by
                      @dos1973 sagte in Weatherunderground Reborn 3.0.0 Alpha:
                      anbei die Infos ✌
                      admin: 3.6.0
                      Node.js: v8.15.0
                      NPM: 6.4.1
                      den js Controller habe ich inzwischen auch auf 1.5.7 ugegradet, keine Änderung.
                        Das interessante ist das bei mir das Datum korrekt angezeigt wird. Ich kann das nicht nachstellen. habe mehreres Versucht bisher aber "Ohne Erfolg".
                        Stelle mal auf Debug Logging falls nichts mehr geht bei Dir
                          Ich habe bei mir in unregelmässigen Abständen vereinzelt diese Meldungen
                          Besitzer eines eigenen Api-key´s bin ich nicht
                          Fehler : weatherunderground.0 Wunderground hat einen Fehler gemeldet: null, 404
                          Fehler : weatherunderground.0 Wunderground hat einen Fehler gemeldet: null, 500
                            Ja bei mir auch, da scheint wohl die Webseite in dem Augenblick zu spinnen ... Man könnte die Fehler höchstens noch eher warnungen machen?!
                              Mein iobroker läuft in einem Docker Container... falls das relevant sein sollte.
                                @apollon77
                                Wäre denn ein Teamviewer session auf mein System hilfreich um den Fehler beizukommen?
                                • Nashra
                                  Hm, bekomme jetzt nach dem ändern der Station auch nur noch
                                  die Meldung: Error: this key does not exist, Reset Station Key
                                  Ok gehen wir zurück auf die alte Station, mist, der selbe Fehler ☹
                                  • Nashra
                                    Fehler wohl gefunden...
                                    Bei "Ältere WU-APIs nutzen" war ein Haken gesetzt, diesen entfernt und schon liefert WU wieder Daten.
                                    Seltsam ist nur, das dieser Haken von Anfang an aktiviert war und es auch bis gestern funktioniert hat.
                                    Werde es mal im Auge behalten ob es auch weiterhin funktioniert.
                                      Muss ich mal schauen, nicht das WU was geändert hat ... 🙂
                                        apollon77 @Nashra last edited by
                                        @Nashra Da würde mich der Debug Output vom Adapter mal interessieren. Kann es nicht nachstellen
                                          apollon77 @dos1973 last edited by
                                          @dos1973 Danke für das Angebot. Weiss nicht ob das so viel bringen würde. Kanst DU mal eine andere Station versuchen ob es da geht?
                                            sigi234 Forum Testing Most Active @apollon77 last edited by
                                            @apollon77
                                            Hallo, also bei mir geht alles, Haken ist gesetzt und keine Stations ID eingetragen.........
                                            adapter weatherunderground wetter
                                            23
                                            225
                                            29555
