    4. [gelöst] xml Daten einer URL weiterverarbeiten
    • htrecksler
      htrecksler Forum Testing last edited by
      Bin leider erst heute zum testen gekommen. Ich erhalte jetzt folgenden Fehler.
      2015-06-14 09:21:10.693  - info: javascript.0 script.js.xxxTESTSCRIPTxxx: received data from 192.168.178.26
      2015-06-14 09:21:10.709  - error: uncaught exception: Uncaught, unspecified "error" event.
      2015-06-14 09:21:10.709  - error: TypeError: Uncaught, unspecified "error" event.
        at TypeError (<anonymous>:null:null)
        at Parser.emit (events.js:74:15)
        at Parser.exports.Parser.Parser.parseString (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\xml2js\lib\xml2js.js:482:16)
        at Parser.parseString (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\xml2js\lib\xml2js.js:6:59)
        at IncomingMessage. <anonymous>(script.js.xxxTESTSCRIPTxxx:41:16)
        at IncomingMessage.emit (events.js:117:20)
        at _stream_readable.js:929:16
        at process._tickCallback (node.js:419:13)</anonymous></anonymous>
      xml2js habe ich in den Javascript-Adapter Settings eingetragen.
      • Bluefox
        Bluefox last edited by
        Probiere so aus:
        var xml2js = require('xml2js');
        var options = {
            explicitArray: false,
            mergeAttrs: true
        var parser = new xml2js.Parser(options);
        var request = require('request');
        request('http://192.168.178.xx:8090/now_playing', function (error, response, body) {
          if (!error && response.statusCode == 200) {
        	parser.parseString(body, function (err, result) {
                    if (err) {
                        log("Fehler: "+err);
                    } else {
                        log("Result: "+result.root.itemName);
          } else  {
              log(error);
        • htrecksler
          Dann kommt dieser Eintrag im log:
          undefined2015-06-15 05:46:43.104  - info: javascript.0 Start javascript script.js.xxxTESTSCRIPTxxx
          2015-06-15 05:46:43.104  - info: javascript.0 script.js.xxxTESTSCRIPTxxx: sunset: Mon Jun 15 2015 21:52:24 GMT+0200 (Mitteleuropäische Sommerzeit)
          2015-06-15 05:46:43.260  - info: javascript.0 script.js.xxxTESTSCRIPTxxx: registered 0 subscriptions and 0 schedules
          2015-06-15 05:46:43.322  - error: uncaught exception: Uncaught, unspecified "error" event.
          2015-06-15 05:46:43.322  - error: TypeError: Uncaught, unspecified "error" event.
            at Request._callback (script.js.xxxTESTSCRIPTxxx:23:11)
            at Request.self.callback (C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:354:22)
            at Request.emit (events.js:98:17)
            at Request. <anonymous>(C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:1207:14)
            at Request.emit (events.js:117:20)
            at IncomingMessage. <anonymous>(C:\Program Files\iobroker\node_modules\iobroker.javascript\node_modules\request\request.js:1153:12)
          2015-06-15 05:46:43.651  - error: host.IntelNuc instance system.adapter.javascript.0 terminated with code 6 (uncaught exception)
          2015-06-15 05:46:43.666  - info: host.IntelNuc Restart adapter system.adapter.javascript.0 because enabled
          2015-06-15 05:47:13.680  - info: host.IntelNuc instance system.adapter.javascript.0 started with pid 3952</anonymous></anonymous></anonymous>
          • Y
            ykuendig last edited by
            Ich hab keine Ahnung ob es einen Unterschied macht, dass Du an einem Windows System bist?! Oder was sonst.
            Jedenfalls aber:
            Da musst Du anstelle von 'itemName' den Namen eines vorhandenen Tags aus dem xml-Ergebnis einsetzen. Bei meinem Sonos testweise zB:
            log("Result: "+result.root.device.manufacturer);
            Weiterhin hoffe ich, dass Du hier die xx-en weggemacht hast:
            > request('[http://192.168.178.xx:8090/now_playing](http://192.168.178.xx:8090/now_playing)', function (error, response, body)
            • Bluefox
              Was bringt bei dir:
              var options = {
                  mergeAttrs: true
                 log("Body: " + body);
                          if (err) {
                          } else {
                } else  {
                    log(error);
              Abgestützt wird beim Parsen. D.h. Response ist vermutlich kein xml.
              • htrecksler
                Wird heute Abend direkt ausprobiert.
                😄 😄 Die xx habe ich natürlich ersetzt.
                • htrecksler
                  Nach der letzten Änderung erschein im log:
                  2015-06-15 18:21:07.828  - info: javascript.0 script.js.xxxTESTSCRIPTxxx: Body: <nowplaying deviceid="08DF1F46E63F" source="INTERNET_RADIO"><contentitem source="INTERNET_RADIO" location="32759" sourceaccount/ispresetable="true"><itemname>WDR 2 Münsterland</itemname></contentitem><track><artist></artist><album></album><stationname>WDR 2 Münsterland</stationname><art artimagestatus="IMAGE_PRESENT">http://logo.vtuner.net/007452/logo/logo-32759.jpg</art><playstatus>PLAY_STATE</playstatus><description>MP3  128 kbps  Internet Only,  Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.</description><stationlocation>Internet Only</stationlocation></nowplaying>
                  2015-06-15 18:21:07.844  - error: uncaught exception: Uncaught, unspecified "error" event.
                  2015-06-15 18:21:07.859  - error: TypeError: Uncaught, unspecified "error" event.
                    at Request._callback (script.js.xxxTESTSCRIPTxxx:24:11)
                  2015-06-15 18:21:08.187  - error: host.IntelNuc instance system.adapter.javascript.0 terminated with code 6 (uncaught exception)</anonymous></anonymous></anonymous>
                  • Bluefox
                    var parseString = require('xml2js').parseString;
                    		parseString(body, {
                    				mergeAttrs: true
                    				if (err) {
                    					log("Fehler: " + err);
                    				} else {
                    					log("Result: " + JSON.stringify(result.nowPlaying));
                    	} else  {
                    	  log(error);
                    • Y
                      Ich hab kein Bose. Aber der String kopiert und eingefügt hatte bei mir auch Probleme gemacht. Kann es sein, dass das result noch irgend wie gefiltert und / oder utf-8-ed werden muss?
                      • Bluefox
                        @ykuendig:
                        Ich hab kein Bose. Aber der String kopiert und eingefügt hatte bei mir auch Probleme gemacht. Kann es sein, dass das result noch irgend wie gefiltert und / oder utf-8-ed werden muss? `
                        Bei mir funktioniert das:
                        //request('http://192.168.178.xx:8090/now_playing', function (error, response, body) {
                            //if (!error && response.statusCode == 200) {
                            var body = '<nowplaying deviceid="08DF1F46E63F" source="INTERNET_RADIO"><contentitem source="INTERNET_RADIO" location="32759" sourceaccount/ispresetable="true"><itemname>WDR 2 Münsterland</itemname></contentitem><track><artist></artist><album></album><stationname>WDR 2 Münsterland</stationname><art artimagestatus="IMAGE_PRESENT">http://logo.vtuner.net/007452/logo/logo-32759.jpg</art><playstatus>PLAY_STATE</playstatus><description>MP3  128 kbps  Internet Only,  Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.</description><stationlocation>Internet Only</stationlocation></nowplaying>';
                              parseString(body, {
                                    mergeAttrs: true
                                    if (err) {
                                    } else {
                           //} else  {
                           //  log(error);
                        Output:
                        javascript-0	2015-06-15 21:45:30	info	script.js.Script1: registered 0 subscriptions and 0 schedules
                        javascript-0	2015-06-15 21:45:30	info	script.js.Script1: Result: {'deviceID':'08DF1F46E63F','source':'INTERNET_RADIO','ContentItem':{'source':'INTERNET_RADIO','location':'32759','sourceAccount':'','isPresetable':'true','itemName':'WDR 2 Münsterland'},'track':'','artist':'','album':'','stationName':'WDR 2 Münsterland','art':{'_':'http://logo.vtuner.net/007452/logo/logo-32759.jpg','artImageStatus':'IMAGE_PRESENT'},'playStatus':'PLAY_STATE','description':'MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.','stationLocation':'Internet Only'}
                        javascript-0	2015-06-15 21:45:30	info	script.js.Script1: Body: WDR 2 MünsterlandWDR 2 Münsterlandhttp://logo.vtuner.net/007452/logo/logo-32759.jpgPLAY_STATEMP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.Internet Only
                        javascript-0	2015-06-15 21:45:30	info	Start javascript script.js.Script1
                        • htrecksler
                          yes…
                          Der code
                          request('http://192.168.178.26:8090/now_playing', function (error, response, body) {
                              //var body = '<nowplaying deviceid="08DF1F46E63F" source="INTERNET_RADIO"><contentitem source="INTERNET_RADIO" location="32759" sourceaccount/ispresetable="true"><itemname>WDR 2 Münsterland</itemname></contentitem><track><artist></artist><album></album><stationname>WDR 2 Münsterland</stationname><art artimagestatus="IMAGE_PRESENT">http://logo.vtuner.net/007452/logo/logo-32759.jpg</art><playstatus>PLAY_STATE</playstatus><description>MP3  128 kbps  Internet Only,  Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.</description><stationlocation>Internet Only</stationlocation></nowplaying>';
                                parseString(body, {
                                      mergeAttrs: true
                                      if (err) {
                                      } else {
                             } else  {
                               log(error);
                          funktioniert. Zumindest habe ich jetzt keine Fehler mehr in der log-Datei.
                          Jetzt brauch ich nur noch ein Beispiel wie ich daraus die einzelnen Werte selektieren kann.
                          Kann ich dass jetzt wie ein Objekt ansprechen?
                          • Bluefox
                            Als Ergebnis hast du ein Objekt:
                            {"nowPlaying":
                            	'deviceID' : '08DF1F46E63F',
                            	'source' : 'INTERNET_RADIO',
                            	'ContentItem' : {
                            		'location' : '32759',
                            		'sourceAccount' : '',
                            		'isPresetable' : 'true',
                            		'itemName' : 'WDR 2 Münsterland'
                            	'track' : '',
                            	'artist' : '',
                            	'album' : '',
                            	'stationName' : 'WDR 2 Münsterland',
                            	'art' : {
                            		'_' : 'http://logo.vtuner.net/007452/logo/logo-32759.jpg',
                            		'artImageStatus' : 'IMAGE_PRESENT'
                            	'playStatus' : 'PLAY_STATE',
                            	'description' : 'MP3 128 kbps Internet Only, Aktuelle Infos, Sport, Service und Unterhaltung prägen WDR 2\. Dazu aktuelle Hits und erwachsene Rock und Popmusik der letzten 30 Jahre.',
                            	'stationLocation' : 'Internet Only'
                            Und ja das ist ein Objekt. Wenn du z.B. artImageStatus extrahieren willst dann solltest du result.nowPlaying.art.artImageStatus aufrufen.
                            • htrecksler
                              Perfekt, funktioniert. Danke Euch allen.
                                mameier1234 last edited by
                                Ich muss hier leider nochmal nachfragen…
                                ich kann meinen Heizölstand elektronisch abfragen.. unter http://192.168.xx.xx/xml bekomme ich vollgendes Ergebniss
                                This XML file does not appear to have any style information associated with it. The document tree is shown below.
                                 <seqsmartbox xmlns="http://tecson.dev.oilview.de/gateway/xsd" xmlns:xsi="http://www.w3.org/2000/10/XMLSchema-instance" xsi:schemalocation="http://tecson.dev.oilview.de/gateway/xsd/smartbox.xsd"><seqheader><indication>Manuelle Abfrage</indication>
                                <authcode>03B41236A899</authcode>
                                 <devoperator><devlocation><devid>2-852</devid>
                                <devversion>V6.02</devversion></devlocation></devoperator></seqheader>
                                 <seqdata><seqtanks><tanknumber>1</tanknumber>
                                <tankname>Heizöl</tankname>
                                 <seqtanklevel><tanklevel>490</tanklevel>
                                <tankunit>L</tankunit></seqtanklevel>
                                <tankpercent>5</tankpercent>
                                 <seqtanksize><tanksize>10000</tanksize>
                                <tankunit>L</tankunit></seqtanksize>
                                 <seqtankclear><tankclearance>9010</tankclearance>
                                <tankunit>L</tankunit></seqtankclear></seqtanks></seqdata>
                                 <seqpara><para1>30</para1>
                                <para2>15</para2>
                                <para4>0</para4>
                                <para5>5</para5>
                                <para9>0</para9></seqpara></seqsmartbox>
                                Was mich nun interessiert ist der wert von <tanklevel>490</tanklevel> …. also nur 490 in einem Objekt...
                                Ganz ehrlich... ich bekomms nicht hin.
                                Hat mir da noch jemand eine Idee ?
                                das mit dem xml2js habe ich schon probiert... Allerdings kann man unter Admin3 wohl keine Module mehr eintragen.. Der Save Button wird nicht aktiv... Zur Zeit ist es bei mir noch so, dass wenn ich über iobroker.pro gehe und damit die Admin Seite aufrufe noch eine 2.x Version kommt. Hier kann ich die xml2js eintragen (und die ist nachher auch in der 3.0 eingetragen..)
                                Ich bekomme nur einen "Error: Parse Error" , wenn ich das hier ausführe:
                                request('http://192.168.160.80/xml', function (error, response, body) {
                                      parseString(body, {
                                            mergeAttrs: true
                                            if (err) {
                                            } else {
                                               log("Result: " + JSON.stringify(result.tankLevel));
                                   } else  {
                                     log(error);
                                Irgendwelche Vorschläge ?
                                • ruhr70
                                  ruhr70 last edited by
                                  @mameier1234:
                                  Allerdings kann man unter Admin3 wohl keine Module mehr eintragen.. Der Save Button wird nicht aktiv… Zur Zeit ist es bei mir noch so, dass wenn ich über iobroker.pro gehe und damit die Admin Seite aufrufe noch eine 2.x Version kommt. Hier kann ich die xml2js eintragen (und die ist nachher auch in der 3.0 eingetragen..) `
                                  Da bin ich auch drüber gestolpert. 🙂
                                  Du musst , wenn Du im Javascript-Adapter den Modulnamen eingegeben hast, [ENTER] drücken.
                                  Ich bin anfangs immer mit [TAB] weiter und dann wird der Speicherbutton nicht aktiv.
                                  Benötigst Du nur diesen einen Wert? <tanklevel>490</tanklevel>
                                  Das ist dann wahrscheinlich am Einfachsten, wenn Du einfach den Parser oder Systeminfo-Adapter nimmst oder im Skript
                                  Ein Beispiel für ein Regex für den Wert: https://regex101.com/r/uoymuu/1
                                    Morgen…
                                    Danke für den Tipp...
                                    Das mit dem Sysinfo-Adapter hatte ich versucht... es scheiterte aber an der richtigen Regex...
                                    Nun kommt mit dem Parsermodul: arser.0 2018-02-22 07:06:51.277 error Cannot read link "http://192.168.160.80/xml": Error: Parse Error
                                    parser.0 2018-02-22 07:06:41.244 error Cannot read link "http://192.168.160.80/xml": Error: Parse Error
                                    Sysinfo: ähnliche Fehlermeldung...
                                    • ruhr70
                                      Du bekommst beim Skript, Parser Adapter und Systeminfo Adapter jeweils einen parse Error.
                                      Was bekommst Du denn im Log als Ausgabe, wenn Du bei Deinem Skript den Teil mit parseString weglässt.
                                            parseString(body, {
                                                  mergeAttrs: true
                                                  if (err) {
                                                  } else {
                                      Wird mit der Zeile log("Body: " + body); denn der Inhalt der XML im Log ausgegeben?
                                      mac89muc 1 Reply Last reply Reply Quote 0
                                        Aeeh…. Ne!
                                        • mac89muc
                                          mac89muc @ruhr70 last edited by
                                          @ruhr70
                                          ich habe eine ähnliches Problem beim auslesen meines Akkustandes vom Sonos Move, habe allerdings einen neuen Thread dazu aufgemacht nachdem der Hinweis mit dem hohen Alter dieses Threads beim erstellen meiner Antwort aufkam.
                                          Keine Ahnung wie sich das mit Doppelpostings verhält, daher möchte ich ungern hier nochmal alles komplett posten.
                                          Falls sich jemand findet, der hier schon mal helfen konnte und bereit ist sich mein Problem unter folgendem Link hier im Forum anzusehen wäre ich dankbar.
                                          [https://forum.iobroker.net/topic/44272/xml-return-in-blockly-weiter-verarbeiten](Neuer Forumsbeitrag - XML return in Blockly weiterverarbeiten)
                                          Vielen Dank im Voraus - Gruß
                                          9084
