    5. Gelöst: Temperaturen Vergleichen Alarm zu Lüften
    • iomountain
      iomountain last edited by iomountain
      @Madaraxa
      magst du mal das Probieren, ob das hinkommt?
      Mit viel Logausgaben zum Testen
        <variables>
          <variable type="" id="NX%n(s|t2x3hUpzX)v}y">BitteLueften</variable>
          <variable type="undefined" id="timeout">timeout</variable>
          <variable type="undefined" id="timeout3">timeout3</variable>
        </variables>
        <block type="variables_set" id=".tAJ.SM#4%C=e$}v!TGK" x="687" y="-238">
          <field name="VAR" id="NX%n(s|t2x3hUpzX)v}y" variabletype="">BitteLueften</field>
            <block type="logic_boolean" id=":?$IEB3U$WbG){,19P{2">
            <block type="comment" id="~pbXrcpHb(rW0xJd$Lb]">
              <field name="COMMENT">Trigger</field>
                <block type="on_ext" id="`QAQQ=;Mv-!s8Xisv`Q[">
                  <value name="OID0">
                    <shadow type="field_oid" id="x3Az;0]0yDfTN#aGm8{3">
                    <block type="field_oid" id="fJE1{[S|hKT$]p%?%]p%">
                      <field name="oid">javascript.1.Datenpunkte_own.Systemvariable.Temperaturen.Sensor1</field>
                    <block type="debug" id="oT;n):)AnZ+:xI~rUI1f">
                      <value name="TEXT">
                        <shadow type="text" id="{bu.{n,(L}xf`/~P_54{">
                        <block type="text_join" id="dJPM%6y8S^!`cC,nf2)l">
                          <value name="ADD0">
                            <block type="text" id="}^2MZ${H[EM,3r55F)*v">
                              <field name="TEXT">Temperatur hat sich geändert, Bitte Lüften: </field>
                          <value name="ADD1">
                            <block type="variables_get" id="GUgbd0GO`)`e$Kqac`sk">
                        <block type="controls_if" id="o~?pt_u4s*XtqU`Z69`2">
                            <block type="logic_compare" id="Bhp(J%#1%=gs0dCb,O+,">
                              <field name="OP">GT</field>
                                <shadow type="text" id="Cv-OS@sUAXD~9P5{(8tR">
                                  <field name="TEXT"></field>
                                <block type="get_value" id="yM=9zWrslsViHeXAVGm6">
                                  <field name="OID">mihome.0.devices.sensor_ht_158d00025efa37.temperature</field>
                                <block type="get_value" id="/3eNhoAte1niWVsZs5d7">
                                  <field name="OID">mihome.0.devices.weather_v1_158d00027347cf.temperature</field>
                            <block type="comment" id="bFw@l$0Fm!-qk}S{YQ03">
                              <field name="COMMENT">Wenn der 1 &gt; 2 für 30 Minuten</field>
                                <block type="controls_if" id="{@9RQR`h3S{^4F,u)*cd">
                                    <block type="logic_negate" id="G2-k]hm)8`(hmpxVkVRi">
                                      <value name="BOOL">
                                        <block type="variables_get" id="|gX5jP?PSPld$)zpp5q:">
                                          <field name="VAR" id="timeout" variabletype="undefined">timeout</field>
                                    <block type="comment" id="bMz^T%zW)}k_)*jj4Ky1">
                                      <field name="COMMENT">Falls noch kein Timer läuft</field>
                                        <block type="debug" id="^z00JlMMNMqWC,Y9CEg0">
                                          <value name="TEXT">
                                            <shadow type="text" id="o.hhPSwcRcS#WPV-lTJo">
                                              <field name="TEXT">Timer starten</field>
                                            <block type="timeouts_settimeout" id="V5PJ*,eX}qP)$s%TheU~">
                                              <field name="NAME">timeout3</field>
                                              <field name="DELAY">1</field>
                                                <block type="debug" id="WvB9$WY;fB=*qM(JGs8m">
                                                  <value name="TEXT">
                                                    <shadow type="text" id="Tz~]w[#}$ZiSGnN0GA:*">
                                                      <field name="TEXT">Timer Start</field>
                                                    <block type="text" id="`m+|3DX[$K6^LNnAay{u">
                                                      <field name="TEXT">Timer erstellt</field>
                                                    <block type="variables_set" id="qBMEMk#9`MHVln^6NaiI">
                                                        <block type="logic_boolean" id="A[_;W]rc/aqi6cD3HT9+">
                                                        <block type="comment" id="%fCNONVnNmc(?mxn$(CU">
                                                          <field name="COMMENT">Logausgabe anstatt Telegram</field>
                                                            <block type="debug" id="6A**$|OP!fP3@|pt(l(d">
                                                              <value name="TEXT">
        <shadow type="text" id=",dG*QXcM[^)?4#s+Xl!0">
        <block type="text_join" id="A=(!|CSF}k^!6s`s4]mk">
        <value name="ADD0">
        <block type="text" id="jf/4`;Un*H+Ti6sb2N[$">
        <field name="TEXT">BitteLüften: </field>
        <value name="ADD1">
        <block type="variables_get" id="J9dZnTATfjeDQh+3^HfO">
                                  <statement name="ELSE">
                                    <block type="debug" id="7R0Athvq3vh|fA:#0~(L">
                                      <value name="TEXT">
                                        <block type="text" id="]j^f#+~[;yUk2{,B6Lv}">
                                          <field name="TEXT">Timer läuft schon</field>
                            <block type="variables_set" id="9lYuqps4Uhduuomv/fTU">
                                <block type="logic_boolean" id="WCh]?BUKoRH=Nm%#}[E2">
                                <block type="debug" id="+?~TFH!VN=_6`-kDCfph">
                                  <value name="TEXT">
                                    <block type="text_join" id="z~mfjen-.E4R|v~Md5I}">
                                      <value name="ADD0">
                                        <block type="text" id="0sDKuV6Y7jnxq6bZZXK?">
                                      <value name="ADD1">
                                        <block type="variables_get" id=",!U$~0E+6oF#D|b4@pz~">
                                    <block type="timeouts_cleartimeout" id="|!MS6zf2yP.||Fu8sVm%">
      Habe 1 Minute anstatt 30, sonst dauert das testen so lang und Logausgabe anstatt Telegram.
        Hey.
        Habe das Testskript mal eingefügt und folgende Meldungen bekommen
        javascript.0	2019-04-24 17:31:51.369	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: true
        javascript.0	2019-04-24 17:31:51.368	info	script.js.Temperaturen.Testskript_Lüften: Timer erstellt
        javascript.0	2019-04-24 17:30:51.367	info	script.js.Temperaturen.Testskript_Lüften: Timer starten
        javascript.0	2019-04-24 17:30:51.366	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: true
        javascript.0	2019-04-24 17:11:36.974	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: true
        javascript.0	2019-04-24 17:11:36.974	info	script.js.Temperaturen.Testskript_Lüften: Timer erstellt
        javascript.0	2019-04-24 17:10:36.971	info	script.js.Temperaturen.Testskript_Lüften: Timer starten
        javascript.0	2019-04-24 17:10:36.971	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 16:54:23.557	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 16:54:23.555	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 16:37:09.363	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 16:37:09.362	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 16:33:08.342	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 16:33:08.341	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 16:16:34.759	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 16:16:34.758	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 16:01:11.269	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 16:01:11.268	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 15:44:37.528	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 15:44:37.527	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        javascript.0	2019-04-24 15:42:56.525	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: false
        javascript.0	2019-04-24 15:42:56.524	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
        Noch habe ich 24,5 Grad außen und 24,1 Grad innen 🙂 Ich weiß also noch nicht, was passiert sobald außen < innen ist 🙂
        EDIT: Habe das Log erweitert. Dein Testscript scheint zu funktionieren 🙂
        Allerdings gibt er ja jetzt mehrfach das "Bitte Lüften: true" aus. Das sollte durch den Timer verhindert werden? Oder wie kann ich das machen? Im Prinzip muss er ja nur so lange die Ausgabe stoppen, bis das nächste Mal von false auf true gestellt wird, oder? Also
        "Falls Objekt "bitteLüften" wurde geändert" vor alles stellen?
        • iomountain
          Probier mal Den timeout Block mit dem fallsblock zu steuern;
          Passt es dann?
            Hey.
            Schon mal vielen Dank für die rasche und kompetente Hilfe.
            Du meinst zusätzlich das Falls BitteLüften = falsch? also so:
            EDIT:
            javascript.0	2019-04-24 19:26:50.934	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: true
            javascript.0	2019-04-24 19:24:40.144	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: true
            javascript.0	2019-04-24 19:23:59.265	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: true
            javascript.0	2019-04-24 19:20:17.824	info	script.js.Temperaturen.Testskript_Lüften: BitteLüften: true
            javascript.0	2019-04-24 19:20:17.823	info	script.js.Temperaturen.Testskript_Lüften: Timer erstellt
            javascript.0	2019-04-24 19:19:17.821	info	script.js.Temperaturen.Testskript_Lüften: Timer starten
            javascript.0	2019-04-24 19:19:17.820	info	script.js.Temperaturen.Testskript_Lüften: Temperatur hat sich geändert, Bitte Lüften: false
            javascript.0	2019-04-24 19:15:39.043	info	script.js.Temperaturen.Testskript_Lüften: registered 1 subscription and 0 schedules
            Leider immer noch Doppelmeldungen
            • iomountain
              @Madaraxa sagte in Temperaturen Vergleichen Alarm zu Lüften:
              kompetente
              Kompetent sieht anders aus, Danke für Deine Geduld. 🙂
              Der Log Eintrag: "Temperatur hat sich geändert, Bitte Lüften: true" ist irreführend.
              Ich hätte es so gedacht, jetzt mit "verständlicheren?" Logeinträgen:
                <variables>
                </variables>
                <block type="variables_set" id=".tAJ.SM#4%C=e$}v!TGK" x="387" y="-213">
                          <value name="OID0">
                              <value name="TEXT">
                                  <field name="TEXT">Temperatur hat sich geändert, Script startet: </field>
                                        <block type="get_value_var" id="p(u{,,i((^q+_gOwFJnf">
                                          <value name="OID">
                                            <block type="field_oid" id="P?6LRq}b5-hnv,r8e:M%">
                                        <block type="get_value_var" id="ox%AZ#9BafWV3;65Td0W">
                                          <value name="OID">
                                            <block type="field_oid" id="KEX+%~^N_I,*:qDcLX?}">
                                              <field name="oid">javascript.1.Datenpunkte_own.Systemvariable.Temperaturen.Sensor2</field>
                                              <value name="BOOL">
                                                <block type="controls_if" id=",.@]!HNMEMI6=2/4D)!O">
                                                    <block type="logic_compare" id="C#t.x4*`xL,4$`!sllp)">
                                                      <field name="OP">EQ</field>
                                                        <block type="variables_get" id="FAvf^;GU26(]G3w/H1Ve">
                                                        <block type="logic_boolean" id="3ui]rdh([_lUGBGrJU(e">
                                                      <value name="TEXT">
                                                          <field name="DELAY">20</field>
                                                              <value name="TEXT">
        <block type="debug" id="-]3.I`b6DG]%vWL6%QI=">
        <value name="TEXT">
        <block type="text_join" id="2vp|$?WeVVMl:RoIN/;G">
        <mutation items="7"></mutation>
        <value name="ADD0">
        <block type="text" id="zke^3|w`m5:$Xl1VCMQ)">
        <field name="TEXT">Meldung Telegram: </field>
        <value name="ADD1">
        <block type="text" id="[^K3H1}u~7-8ddZpKJJ{">
        <field name="TEXT">Bitte Lüften,  </field>
        <value name="ADD2">
        <block type="text" id="!;cPz?icO035_RtA7KeH">
        <field name="TEXT">die Außentemperatur beträgt: </field>
        <value name="ADD3">
        <block type="get_value" id="*dYKF)6Mf@UFO^]/=ieP">
        <value name="ADD4">
        <block type="text_newline" id="^#i`-=!y4c.6jSzcN-tk">
        <field name="Type">\n</field>
        <value name="ADD5">
        <block type="text" id="E6r1Pae=c)]?:memjmd9">
        <value name="ADD6">
        <block type="get_value" id="*,r/Cf)KEkYBz;_*w6qn">
        <block type="telegram" id="|/-TIZT/oIb_+as.0:V)" disabled="true">
        <field name="LOG"></field>
        <value name="MESSAGE">
        <shadow type="text" id="U@hA8(_QTSFaS!0ujq~b">
        <block type="text_join" id="gyr2k29+L!mgQtEwH0Dz">
        <value name="ADD0">
        <block type="text" id=").51GvRei)NtO2;0J/|n">
        <value name="ADD1">
        <block type="text" id="Z)Mr42-m7vS#RUqYrE`#">
        <value name="ADD2">
        <block type="text" id="~XKNIBD9Mk0+1bue?!X#">
        <value name="ADD3">
        <block type="get_value" id="^Wm5yamavgzT,M:YKLzc">
        <value name="ADD4">
        <block type="text_newline" id="A6nOQUdLG-z^%B:v?{8=">
        <value name="ADD5">
        <block type="text" id="2K^?WURd@xn5g/D+?O@2">
        <value name="ADD6">
        <block type="get_value" id="warmXe8vM?w1/e`bDzWl">
                                              <value name="TEXT">
                                          <value name="TEXT">
                                              <value name="ADD0">
                                              <value name="ADD1">
              oben im Vergleich Deine Datenpunkte anstatt meiner eintragen und wenn es geht, Zeit anpassen und Rechtsklick auf den Telegram Block und aktivieren.
                Hey,
                sieht gut aus (Außer, dass du im Text des Debug / Telegram zweimal Außentemperatur geschrieben hast^^)
                Kannst du mir (unabhängig davon, dass es jetzt anscheind klappt) erklären, warum du beim blauen "falls" Objekt ID vom Objekt ID .... nimmst und nicht nur einmal Objekt ID und dann direkt auf die Temperatur verlinkst?
                javascript.0	2019-04-24 20:57:51.682	info	script.js.Temperaturen.Testskript2: Timer läuft schon
                javascript.0	2019-04-24 20:57:51.681	info	script.js.Temperaturen.Testskript2: Temperatur hat sich geändert, Script startet:
                javascript.0	2019-04-24 20:54:40.435	info	script.js.Temperaturen.Testskript2: Meldung Telegram: Bitte Lüften, die Innentemperatur beträgt: 24.14 die Außentemperatur beträgt: 11.31
                javascript.0	2019-04-24 20:54:40.431	info	script.js.Temperaturen.Testskript2: Timer erstellt
                javascript.0	2019-04-24 20:54:20.428	info	script.js.Temperaturen.Testskript2: Timer starten
                javascript.0	2019-04-24 20:54:20.428	info	script.js.Temperaturen.Testskript2: Temperatur hat sich geändert, Script startet:
                javascript.0	2019-04-24 20:54:08.569	info	script.js.Temperaturen.Testskript2: registered 1 subscription and 0 schedules
                javascript.0	2019-04-24 20:54:08.568	info	Start javascript script.js.Temperaturen.Testskript2
                EDIT: Da ich die Meldung derzeit ca. alle 3 Minuten bekomme, gehe ich davon aus, dass der Sensor nur alle 3 Minuten sendet und daher die 20 Sekunden im Skript "egal" sind? Ich kann es nur auf über 3 Minuten setzen und damit Abfragen sparen? Ganz weglassen macht keinen Sinn, falls die Temperatur kurzzeitig hin und her schwankt?
                Edit 2: ich habe mich geirrt. Das mit den 3 Minuten war Zufall. Es kommt (denke ich) jedesmal ne Meldung wenn sich die Temperatur ändert
                • iomountain
                  , warum du beim blauen "falls" Objekt ID vom Objekt ID vom Objekt ID .... nimmst und nicht nur einmal Objekt ID und dann direkt auf die Temperatur verlinkst?
                  meinst du da?
                    A Former User @iomountain last edited by
                    @iomountain
                    Ja 🙂
                    • iomountain
                      Edit 2: Richtig: Der Log Eintrag: "Temperatur hat sich geändert, Script startet:" müsste bei jeder Temperaturänderung kommen. Diente nur zur Kontrolle und kannst du löschen oder ignorieren.
                      Der Log Eintrag: "Meldung Telegram: Bitte Lüften, die Innentemperatur beträgt: xx.xx die Außentemperatur beträgt: xx.xx" kommt wenn die Innentemp größer als die Außentemp ist und das für mindestens durchgehend 20 Sekunden (timeout: du wolltest 30 Minuten)
                      Sobald die Innentemp dann mal kleiner als die Außentemp ist, wird der Timer zurückgesetzt und wenn dann wieder die Innentemp größer als die Außentemp für durchgehend 20 Sekunden ist wird wieder eine Meldung "Meldung Telegram: Bitte Lüften, die Innentemperatur beträgt: xx.xx die Außentemperatur beträgt: xx.xx" ausgegeben.
                      Weil es bei mir so funktioniert hat :), bin aber auch noch am lernen. Wie würdest du es machen?
                        A Former User @iomountain last edited by A Former User
                        @iomountain
                        Bin aber nicht sicher ob das klappt 🙂
                        Vielen Lieben Dank für all die Mühe und Zeit, die du investiert hast. Habe viel gelernt und nen funktionierendes Skript.
                        • iomountain
                          Jetzt weiß ich was du meinst, wenn du jetzt die ObjektID auswählst, kommst du auf das gleiche wie ich. Dürfte keinen Unterschied ergeben.
                          Ansonsten: Gern gemacht, ich hab auch dabei gelernt, viel Spass noch.
                            @iomountain
                            Danke, dir auch
                            748
