    4. Weatherunderground Reborn 3.0.0 Alpha
    • Nashra
      Ohne Haken bei WU-Api, aber mit Station-ID
      host.ioBroker-Slave	2019-04-19 07:54:07.668	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      weatherunderground.0	2019-04-19 07:54:05.343	debug	all forecast values set
      weatherunderground.0	2019-04-19 07:54:05.342	debug	all current conditions values set
      weatherunderground.0	2019-04-19 07:54:04.904	debug	get hourly forecast data: https://api.weather.com/v1/geocode/51.39/6.28/forecast/hourly/48hour.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=m&language=de
      weatherunderground.0	2019-04-19 07:54:04.829	debug	get daily forecast data: https://api.weather.com/v1/geocode/51.39/6.28/forecast/daily/5day.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=m&language=de
      weatherunderground.0	2019-04-19 07:54:04.528	debug	get current observation data: https://api.weather.com/v2/pws/observations/current?stationId=IDFWACHT4&format=json&units=m&apiKey=6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-04-19 07:54:04.528	debug	Use new API Key 6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-04-19 07:54:04.527	debug	Use New API
      weatherunderground.0	2019-04-19 07:54:04.526	debug	fetched new stationKey from WU webpage-0419: d8585d80376a429e
      unifi.0	2019-04-19 07:54:03.040	info	getAccessDevices: 2
      weatherunderground.0	2019-04-19 07:54:02.737	debug	get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IDFWACHT4
      weatherunderground.0	2019-04-19 07:54:02.737	debug	location has not changed, reuse extracted URLs
      weatherunderground.0	2019-04-19 07:54:02.663	debug	initialize Hourly Forecast Url: https://api.weather.com/v1/geocode/51.39/6.28/forecast/hourly/240hour.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
      weatherunderground.0	2019-04-19 07:54:02.659	debug	initialize Daily Forecast Url: https://api.weather.com/v1/geocode/51.39/6.28/forecast/daily/5day.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
      weatherunderground.0	2019-04-19 07:54:02.655	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IDFHERON2&format=json
      weatherunderground.0	2019-04-19 07:54:02.477	debug	initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-04-19 07:54:01.961	debug	init forecast objects
      weatherunderground.0	2019-04-19 07:54:01.961	debug	init conditions objects
      weatherunderground.0	2019-04-19 07:54:01.961	debug	on ready: DL true true true true
      weatherunderground.0	2019-04-19 07:54:01.961	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.1
      Mit Haken und Station-ID
      host.ioBroker-Slave	2019-04-19 07:58:06.876	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      weatherunderground.0	2019-04-19 07:58:04.512	debug	all forecast values set
      weatherunderground.0	2019-04-19 07:58:04.511	debug	all current conditions values set
      weatherunderground.0	2019-04-19 07:58:02.576	debug	get WU legacy data: http://api.wunderground.com/api/d8585d80376a429e/forecast/hourly/conditions/units:m/lang:DL/q/pws:IDFWACHT4.json
      weatherunderground.0	2019-04-19 07:58:02.576	debug	Use legacy API Key d8585d80376a429e
      weatherunderground.0	2019-04-19 07:58:02.576	debug	Use Legacy API
      weatherunderground.0	2019-04-19 07:58:02.575	debug	location has not changed, reuse extracted URLs
      weatherunderground.0	2019-04-19 07:58:02.545	debug	initialize Hourly Forecast Url: https://api.weather.com/v1/geocode/51.39/6.28/forecast/hourly/240hour.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
      weatherunderground.0	2019-04-19 07:58:02.542	debug	initialize Daily Forecast Url: https://api.weather.com/v1/geocode/51.39/6.28/forecast/daily/5day.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
      weatherunderground.0	2019-04-19 07:58:02.538	debug	initialize Current Observation url: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IDFHERON2&format=json
      weatherunderground.0	2019-04-19 07:58:02.354	debug	initialize Web Key: 6532d6454b8aa370768e63d6ba5a832e
      weatherunderground.0	2019-04-19 07:58:02.095	debug	initialize PWS Station Key: d8585d80376a429e
      weatherunderground.0	2019-04-19 07:58:02.048	debug	init forecast objects
      weatherunderground.0	2019-04-19 07:58:02.048	debug	init conditions objects
      weatherunderground.0	2019-04-19 07:58:02.048	debug	on ready: DL true true true true
      weatherunderground.0	2019-04-19 07:58:02.048	info	starting. Version 3.0.9 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v8.15.1
      host.ioBroker-Slave	2019-04-19 07:58:00.033	info	instance system.adapter.weatherunderground.0 started with pid 8417
        apollon77 last edited by
        Also geht jetzt, gell?
        Nashra 1 Reply Last reply Reply Quote 1
        • Nashra
          Nashra Most Active Forum Testing @apollon77 last edited by
          @apollon77 sagte in Weatherunderground Reborn 3.0.0 Alpha:
          Ja soweit bis jetzt keine Warnungen mehr. Einzigst, das einige wenige Datenpunkte nicht aktualisiert werden.
          Aber Du hattest ja geschrieben das WU die Seite am umbauen ist und dies könnte natürlich der Grund sein.
          Werde es weiter beobachten.
          Danke @apollon77 👍
            dos1973 last edited by
            Wie kann ich denn die 3.09 installieren
            Ich würde auch gerne testen um den Fehler in invalid date zu beheben
            Nashra apollon77 2 Replies Last reply Reply Quote 0
            • Nashra
              Nashra Most Active Forum Testing @dos1973 last edited by
              @dos1973 sagte in Weatherunderground Reborn 3.0.0 Alpha:
              Im ioBroker auf Adapter, dann oben auf den kleinen runden Button "Installieren aus eigener URL".
              Es öffnet ein Popup, hier auf "Beliebig" und diese URL https://github.com/iobroker-community-adapters/ioBroker.weatherunderground bei "URL oder Dateipfad" eintragen. Installieren, fertig.
                apollon77 @Nashra last edited by
                @Nashra Was fehlt denn? Vor allem:Mit oder ohne "Lagacy Haken"? Ohne den Haken (siehe Readme) stehen ein paar weniger Daten zur Verfügung ....
                  apollon77 @dos1973 last edited by
                  @dos1973 Gern testen, glaube aber nicht das es da was neues gibt
                    Nee, leider immer noch nicht erfolgreich.
                    Es spielt keine Rolle welche Messstation oder Koordinaten/ ort eintrage. Ich bekomme werte, Aber kein Datum
                    • Nashra
                      War alles gesetzt und hat sich erledigt, alle Daten da.
                      Hatte diesmal keine Station-ID eingetragen und er hatte über die Koordinaten eine
                      Station genommen die einige Daten nicht liefert. ID der Station vom Nachbarort
                      wieder rein und alles ist gut.
                      Danke @apollon77
                        papper371 last edited by
                        Hallo all,
                        ich habe leider noch immer Pobleme. Habe heute den Adapter neu installiert, da ich keine Objekte mehr hatte. Auch die Station-ID ist im LOG immer wieder als nicht existent angezeigt worden.
                        Nach der Neuinstallition habe ich noch immer keine Pbjekte und das LOG sagt folgendes:
                        2019-04-25 21:12:00.118 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 4742
                        2019-04-25 21:12:02.528 - debug: weatherunderground.0 objectDB connected
                        2019-04-25 21:12:02.608 - debug: weatherunderground.0 statesDB connected
                        2019-04-25 21:12:02.705 - info: weatherunderground.0 starting. Version 3.0.8 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v6.14.2
                        2019-04-25 21:12:02.716 - debug: weatherunderground.0 on ready: DL true true true true
                        2019-04-25 21:12:02.728 - debug: weatherunderground.0 init conditions objects
                        2019-04-25 21:12:02.734 - debug: weatherunderground.0 init forecast objects
                        2019-04-25 21:12:05.473 - debug: weatherunderground.0 location change detected, extract URLs
                        2019-04-25 21:12:05.479 - debug: weatherunderground.0 get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IGEVENIC1
                        2019-04-25 21:12:07.313 - debug: weatherunderground.0 get WU weather page: https://www.wunderground.com/hourly/DE/IGEVENIC1
                        2019-04-25 21:12:07.715 - debug: weatherunderground.0 get WU weather page: https://www.wunderground.com/hourly/DE/q/IGEVENIC1
                        2019-04-25 21:12:09.046 - debug: weatherunderground.0 fetched new webkey from WU weather page: 6532d6454b8aa370768e63d6ba5a832e
                        2019-04-25 21:12:09.051 - debug: weatherunderground.0 fetched current observations Url from WU weather page: https://api.weather.com/v2/pws/observations/current?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&stationId=IGEVENIC1&format=json
                        2019-04-25 21:12:09.053 - debug: weatherunderground.0 fetched forecast 5 day Url from WU weather page: https://api.weather.com/v1/geocode/50.989/6.31/forecast/daily/5day.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
                        2019-04-25 21:12:09.055 - debug: weatherunderground.0 fetched hourly forecast Url from WU weather page: https://api.weather.com/v1/geocode/50.989/6.31/forecast/hourly/240hour.json?apiKey=6532d6454b8aa370768e63d6ba5a832e&units=e&language=en-US
                        2019-04-25 21:12:09.056 - debug: weatherunderground.0 Use Legacy API
                        2019-04-25 21:12:09.058 - debug: weatherunderground.0 Use legacy API Key undefined
                        2019-04-25 21:12:09.059 - debug: weatherunderground.0 get WU legacy data: http://api.wunderground.com/api/undefined/forecast/hourly/conditions/units:m/lang:DL/q/pws:IGEVENIC1.json
                        2019-04-25 21:12:09.669 - error: weatherunderground.0 Error: this key does not exist, Reset Station Key
                        2019-04-25 21:12:09.671 - debug: weatherunderground.0 get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IGEVENIC1
                        2019-04-25 21:12:10.030 - debug: weatherunderground.0 Use Legacy API
                        2019-04-25 21:12:10.031 - debug: weatherunderground.0 Use legacy API Key
                        2019-04-25 21:12:10.031 - debug: weatherunderground.0 get WU legacy data: http://api.wunderground.com/api//forecast/hourly/conditions/units:m/lang:DL/q/pws:IGEVENIC1.json
                        2019-04-25 21:12:10.273 - error: weatherunderground.0 Error: this key does not exist, Reset Station Key
                        2019-04-25 21:12:10.277 - debug: weatherunderground.0 get PWS dashboard page: https://www.wunderground.com/personal-weather-station/dashboard?ID=IGEVENIC1
                        2019-04-25 21:12:10.623 - debug: weatherunderground.0 Use Legacy API
                        2019-04-25 21:12:10.624 - debug: weatherunderground.0 Use legacy API Key
                        2019-04-25 21:12:10.624 - debug: weatherunderground.0 get WU legacy data: http://api.wunderground.com/api//forecast/hourly/conditions/units:m/lang:DL/q/pws:IGEVENIC1.json
                        2019-04-25 21:12:10.878 - error: weatherunderground.0 Error: this key does not exist, Reset Station Key
                        2019-04-25 21:12:13.449 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                        Wo liegt der Fehler. Die Daten waren sonst klasse, da die Station sehr professionell und direkt im die Ecke ist. Wäre schön es wieder ans Laufen zu bekommen.
                          Installier bitte mal die Version vom GitHub.
                            Hallo apollon77,
                            Version3.0.8 habe ich über iobroker nstalliert. Auf GitHub wird nichts anderes angezeigt. Was muss ich tun?
                              dos1973 @Nashra last edited by
                              @papper371
                              Siehe wie folgt.
                              @Nashra sagte in Weatherunderground Reborn 3.0.0 Alpha:
                                Vielen Dank. Klappt wunderbar!
                                  dos1973 last edited by dos1973
                                  @apollon77
                                  ich habe hier noch ein komisches Phänomen entdeckt. Vielleicht kannst du nochmals schauen...
                                  wenn ich über Iobroker "Objekte" gehe habe ich kein Datum. Das konntest du nicht nachstellen...
                                  aber wenn ich aus VIS Heraus den Datenpunkt auswähle "Select ID" dann habe ich ein Datum, allerdings im falschen Format??
                                  mein System ist auf Deutsch eingestellt...
                                  ich bin eigentlich mehr durch Zufall darauf gestossen :-), wäre Dir dankbar, wenn du nochmals draufschaust.
                                    Das kann auch nur ein Anzeigeproblem sein weil der Select-ID Dialog und Admin verschieden sind
                                      Wie mich das nervt, das der bei nicht funktioniert:(
                                        Du kannst mal folgendes machen. Nimm die State-ID und den JavaScript adapter und lass dir mal den Wert dort ausgeben (Blockly oder mit getState als kleines JavaScript). Was steht da für ein Wert drin?
                                        Ich habe alles versuche und kann es nicht nachstellen und es scheint auch sonst ausser Dir keiner dieses Problem zu haben ... Ansonsten funktioniert der Adapzer ja, nur das eine Feld mag bei Dir irgendwie nicht
                                          das habe ich gemacht:
                                           var state = getState('weatherunderground.0.forecast.0d.date').val;
                                                      console.log(state); ```
                                          Ergebnis: ein Datum ist drin, aber irgendwie falsch formatiert...
                                          9.5.2019, 19:24:49.510	[info ]: javascript.0 Start javascript script.js.Überwachung_Wohnung.testweather
                                          9.5.2019, 19:24:49.510	[info ]: javascript.0 script.js.Überwachung_Wohnung.testweather: 2019-5-9
                                          9.5.2019, 19:24:49.510	[info ]: javascript.0 script.js.Überwachung_Wohnung.testweather: registered 0 subscriptions and 0 schedules
                                            adapter macht wieder Probleme und aktualisiert nicht mehr
                                            im log
                                            	Wunderground reported an error: null, 401
                                            date steht auf
                                            Tue Jul 09 2019 00:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
                                            localtimeRFC822
                                            Tue, 09 Jul 2019 00:30:03 +0200
                                            zeitstempel 1:15 heute nacht
                                            letzte Änderung 0:30 heute nacht
                                            adapter weatherunderground wetter
                                            23
                                            225
                                            29625
