    4. Astro-Tageszeit abfragen und in Datenpunkt eintragen
      MyMeyer last edited by
      Hallo ich bekomme nach einem Umzug auf eine Debian Server jetzt auch folgende Fehlermeldung wenn ich Astro startet !
      Kann mir jemand sagen woran das liegt ?
      javascript.0	2018-10-24 08:49:01.395	error	at Object. <anonymous>(script.js.common.AstroZeit:376:46)
      javascript.0	2018-10-24 08:49:01.395	error	Error in callback: TypeError: Cannot read property 'toLocaleTimeString' of undefined
      javascript.0	2018-10-24 08:49:01.395	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2018-10-24 08:49:01.393	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2018-10-24 08:49:00.397	error	Error in callback: TypeError: Cannot read property 'toLocaleTimeString' of undefined
      javascript.0	2018-10-24 08:49:00.397	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2018-10-24 08:49:00.396	warn	at Object. <anonymous>(script.js.common.AstroZeit:436:5)
      javascript.0	2018-10-24 08:49:00.395	warn	at getAstroday (script.js.common.AstroZeit:420:5)
      javascript.0	2018-10-24 08:49:00.394	warn	Wrong type of javascript.0.Astro.Astrotag: "undefined". Please fix, while deprecated and will not work in next versions.
      javascript.0	2018-10-24 08:49:00.393	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2018-10-24 08:48:58.397	error	TypeError: Cannot read property 'toLocaleTimeString' of undefined
      javascript.0	2018-10-24 08:48:58.397	error	^
      javascript.0	2018-10-24 08:48:58.397	error	startTime = startTime.toLocaleTimeString([], {
      javascript.0	2018-10-24 08:48:58.397	error	script.js.common.AstroZeit: /opt/iobroker/node_modules/iobroker.javascript/javascript.js:2547
      javascript.0	2018-10-24 08:48:58.395	error	Longitude or latitude does not set. Cannot use astro.
      javascript.0	2018-10-24 08:48:58.390	warn	Cannot calculate "night" for NaN, NaN
      javascript.0	2018-10-24 08:48:58.390	warn	Cannot calculate "dusk" for NaN, NaN
      javascript.0	2018-10-24 08:48:58.390	warn	Cannot calculate "solarNoon" for NaN, NaN
      javascript.0	2018-10-24 08:48:58.390	warn	Cannot calculate "sunrise" for NaN, NaN
      javascript.0	2018-10-24 08:48:58.390	warn	Cannot calculate "nightEnd" for NaN, NaN
      javascript.0	2018-10-24 08:48:58.389	warn	Cannot calculate "night" for NaN, NaN
      javascript.0	2018-10-24 08:48:58.385	info	Start javascript script.js.common.AstroZeit</anonymous></anonymous></anonymous>
        pix last edited by
        in deinem log gibt zumindest einen Hinweis:
        Stelle mal im Javascript Adapter deine Koordinaten ein.
        Ach nee, … Long und Lat bitte in den Admin Systemeinstellungen (Schraubenschlüssel oben im blauen Balken) festlegen und dann in den Javascript Adapter Einstellungen einen Haken setzen für "Verwenden Sie die Systemeinstellungen".
        Naja, geht beides ... 😉
        Pix
          bishop last edited by
          sehr geniales Script habe ich schon länger im Einsatz, hätte da aber noch ein Wunsch!
          Ist es möglich auch die Jahreszeiten mit in das Script hineinzunehmen?
          Mein Vorhaben!
          Ich habe auf meiner Terrasse Sonos Lautsprecher verbaut die wenn sie an sind und es dunkel ist die Beleuchtung anschalten sowie auch wenn Stop oder pause als state ist wieder nach 2 min aus gehen!
          Da es jetzt aber Herbst oder bald Winter wird/ist hänge ich die Lautsprecher in den Keller und halte mich dort auf. Ganz klar wenn ich im Keller die Lautsprecher anschalten geht auf der Terrasse das Licht an dass ich jetzt ja nicht mehr benötige.
          Wenn ich jetzt ein State Sommer, Frühling, Herbst und Winter hätte könnte ich das in mein Script mit rein nehmen und die Beleuchtung würde nicht einschalten.
          Danke schon mal!!!
            stoepselinho last edited by
            Bekomm immer diese Fehlermeldung, kann mir jemand helfen
            javascript.0 2019-01-03 19:54:28.404 error Longitude or latitude does not set. Cannot use astro.
            javascript.0 2019-01-03 19:54:28.404 error at Object. <anonymous>(script.js.Programme.Astrozeiten:377:47)
            javascript.0 2019-01-03 19:54:28.404 error Error in callback: TypeError: Cannot read property 'toLocaleTimeString' of undefined</anonymous> `
              Zeig doch mal bitte, wo du deine Längen- und Breitengrade eingetragen hast!
              Enrico
                dondaik last edited by
                doch sind nicht da ganzen daten schon in blockly ? … da kann man sie doch nutzen ( wenn die standortdaten in der ccu/iobroker ) eingetragen sind, oder verstehe ich da was nicht?
                  Die Daten können einmal im Admin eingetragen werden oder im Javascript-Adapter selbst, da kann aber auch ausgewählt werden, dass die Admin-Werte verwendet werden sollen.
                  Enrico
                  • eumats
                    eumats last edited by
                    Moin. Oben im 2. Post zu diesem Thread steht, dass die neueste Version unter http://forum.iobroker.net/viewtopic.php?f=21&t=2757&p=129167#p129167 zu finden ist.
                    Wenn man auf den Link klickt ist das ein Loop auf den gleichen Post.
                    Weis jemand wo die neuste Version liegt?
                      darkiop Most Active last edited by
                      @pix Kannst du die aktuelle Version des Skripts nochmal posten? Der Link oben funktioniert nicht mehr. Vielen Dank!
                        pix last edited by
                        Hallo, hier eine funktionierende Version von paul53.
                        https://forum.iobroker.net/post/159899
                        Es ist etwas aufwendig, die Steuerzeichen (bedingt durch Forumumstellung) zu entfernen, aber es lohnt 🐶
                        Pix
                          Jan1 @darkiop last edited by
                          @darkiop
                          oder man bastelt sich das geschwind mit Blockly selber:
                            fischmir @paul53 last edited by
                            @paul53 Hallo Paul, ich wollte dein Script einsetzen, erhalte aber einen Fehler hier:
                               temp = getAstroDate(fname, next_event);
                            Der Parameter "next_event" wird angemeckert. Kannst du sagen, wieso?
                            Danke und Gruß,
                            Christian
                              paul53 @fischmir last edited by
                              @fischmir sagte:
                              Nein. In Zeile 293 wird next_event deklariert und in den Folgezeilen wird ein Wert zugewiesen.
                                craysee last edited by
                                ich habe das Script genutzt und die Datenpunkte werden alle angelegt. Nur leider hat mein System die falsche Zeit und somit auch die Datenpunkte. Mit den Debug-Info Blockly erhalte ich als Ergebnis 2 Stunden vor unserer Zeit (allerdings ist die Zeit, die vorne steht, richtig, also die "Eintragzeit" für den Protokollpunkt. Die Koordinaten sind im Adapter und in den Systemeinstellungen richtig eingegeben. ioBroker und der Javascript-Adapter sind neugestartet, hat alles nichts geholfen. Laufen tut alles auf einem Raspi. Jemand noch einen Tipp, was ich noch machen kann ?
                                Danke und Gruß
                                Cray
                                  ple @paul53 last edited by
                                  @paul53 sagte in Astro-Tageszeit abfragen und in Datenpunkt eintragen:
                                  Anbei ein vereinfachtes Skript, das ohne "night", "nightEnd" und Astrozeit auskommt. Die Zeiten werden unter Astro.Zeiten neu erstellt. Eine Astrozeit, die den ganzen Tag bis zum Abend nur "goldenHourEnd" anzeigt, ist wenig aussagekräftig.
                                  const sec = false; // Sekunden darstellen oder nicht
                                  const fC = false; // forceCreation ein/aus
                                  const pfad = "Astro"; // Pfad zum Objekt - Objektbaum-Hauptverzeichnis
                                  // TAGESZEITEN - T E I L
                                  // Tageszeiten nach eigenem Gusto (Shifts siehe schedules weiter unten)
                                  const tageszeiten = ["Nacht",
                                                      "Morgendämmerung",
                                                      "Sonnenaufgang",
                                                      "Morgen",
                                                      "Vormittag",
                                                      "Mittag",
                                                      "Nachmittag",
                                                      "Abend",
                                                      "Sonnenuntergang",
                                                      "Abenddämmerung"
                                  const idTageszeit = "javascript." + instance  + "." + pfad + ".Tageszeit.current" /*Tageszeit*/,
                                       idTageszeitNext = "javascript." + instance  + "." + pfad + ".Tageszeit.next";
                                  createState(idTageszeit, "nächsten Wechsel abwarten", fC, {
                                     desc: "Name der Tageszeit",
                                     type: "string"
                                  createState(idTageszeitNext, "nächsten Wechsel abwarten", fC, {
                                     name: "nächste Tageszeit",
                                     desc: "Name der nächsten Tageszeit",
                                     type: "string"
                                  function neue_tageszeit(abschnitt) {
                                     var akt = tageszeiten[parseInt(abschnitt, 10)],
                                     // wenn aktuelles Element ist letztes, dann nächstes ist erstes :-D
                                     nxt = (abschnitt + 1 === tageszeiten.length) ? tageszeiten[0] : tageszeiten[parseInt(abschnitt + 1, 10)];
                                     setState(idTageszeit, akt);
                                     setState(idTageszeitNext, nxt);
                                     log("neue Tagezeit: " + akt);
                                     log("nächte kommende Tagezeit: " + nxt);
                                  // Nacht
                                  schedule({
                                     astro: "nauticalDusk",
                                     shift: 45
                                  }, function () {
                                     neue_tageszeit(0);
                                  // Morgengdämmerung
                                  schedule({
                                     astro: "nauticalDawn",
                                     shift: -45
                                  }, function () {
                                     neue_tageszeit(1);
                                  // Sonnenaufgang
                                  schedule({
                                     astro: "sunrise"
                                  }, function() {
                                     neue_tageszeit(2);
                                  // Morgen
                                  schedule({
                                     astro: "sunriseEnd"
                                  }, function () {
                                     neue_tageszeit(3);
                                  // Vormittag
                                  schedule({
                                     astro: "goldenHourEnd",
                                     shift: 60
                                  }, function () {
                                     neue_tageszeit(4);
                                  // Mittag
                                  schedule({
                                     astro: "solarNoon",
                                     shift: -30
                                  }, function () {
                                     neue_tageszeit(5);
                                  // Nachmittag
                                  schedule({
                                     astro: "solarNoon",
                                     shift: 30
                                  }, function () {
                                     neue_tageszeit(6);
                                  // Abend
                                  schedule({
                                     astro: "goldenHour",
                                     shift: -60
                                  }, function () {
                                     neue_tageszeit(7);
                                  // Sonnenuntergang
                                  schedule({
                                     astro: "sunsetStart",
                                  }, function () {
                                     neue_tageszeit(8);
                                  // Abenddämmerung (nach Sonnenuntergang)
                                  schedule({
                                     astro: "sunset"
                                  }, function () {
                                     neue_tageszeit(9);
                                  // A S T O - T E I L
                                  /* Objekt Astrotag
                                    Astrotag liegt zwischen Sonnauf- und untergang,
                                    Astronacht liegt zwischen Sonnenunter- und aufgang */
                                  const idAstrotag =  "javascript." + instance + "." + pfad + ".Astrotag";
                                  // Objekt für Uhrzeiten der Astrozeiten
                                  const astrotime = {
                                     "elements" : [
                                         // Astrotag beginnt
                                             "fname" : "sunrise", // function name
                                             "de" : {
                                                 "name" : "Sonnenaufgang",
                                                 "nxt" : "nächster",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Sunrise",
                                                 "desc" : "top edge of the sun appears on the horizon"
                                             "astroday" : true //during astroday
                                             "fname" : "sunriseEnd", // function name
                                             "de" : {
                                                 "name" : "Ende Sonnenaufgang",
                                                 "nxt" : "nächstes",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "End of sunrise",
                                                 "desc" : "bottom edge of the sun touches the horizon"
                                             "fname" : "goldenHourEnd", // function name
                                             "de" : {
                                                 "name" : "Ende der goldenen Stunde am Morgen",
                                                 "nxt" : "nächstes",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "End of golden hour",
                                                 "desc" : "morning golden hour (soft light, best time for photography) ends"
                                             "fname" : "solarNoon", // function name
                                             "de" : {
                                                 "name" : "Sonnenhöchststand",
                                                 "nxt" : "nächster",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Solar noon",
                                                 "desc" : "sun is in the highest position"
                                             "fname" : "goldenHour", // function name
                                             "de" : {
                                                 "name" : "Goldene Stunde (am Abend)",
                                                 "nxt" : "nächste",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Golden hour",
                                                 "desc" : "evening golden hour starts"
                                             "fname" : "sunsetStart", // function name
                                             "de" : {
                                                 "name" : "Beginn Sonnenuntergang",
                                                 "nxt" : "nächster",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Sunset starts",
                                         // Astronacht beginnt
                                             "fname" : "sunset", // function name
                                             "de" : {
                                                 "name" : "Sonnenuntergang",
                                                 "nxt" : "nächster",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Sunset",
                                                 "desc" : "sun disappears below the horizon, evening civil twilight starts"
                                             "astroday" : false //during astronight
                                             "fname" : "dusk",
                                             "de" : {
                                                 "name" : "Abenddämmerung",
                                                 "nxt" : "nächste",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Dusk",
                                                 "desc" : "evening nautical twilight starts"
                                             "fname" : "nauticalDusk",
                                             "de" : {
                                                 "name" : "nautische Abenddämmerung",
                                                 "nxt" : "nächste",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Nautical dusk",
                                                 "desc" : "evening astronomical twilight starts"
                                             "fname" : "nadir",
                                             "de" : {
                                                 "name" : "Nadir",
                                                 "nxt" : "nächster",
                                                 "desc" : "Fußpunkt gegenüber dem Zenit"
                                             "en" : {
                                                 "name" : "Nadir",
                                                 "desc" : "darkest moment of the night, sun is in the lowest position"
                                             "fname" : "nauticalDawn",
                                             "de" : {
                                                 "name" : "nautische Morgendämmerung",
                                                 "nxt" : "nächste",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "Nautical dawn",
                                                 "desc" : "morning nautical twilight starts"
                                             "fname" : "dawn",
                                             "de" : {
                                                 "name" : "Morgendämmerung",
                                                 "nxt" : "nächste",
                                                 "desc" : ""
                                             "en" : {
                                                 "name" : "dawn",
                                                 "desc" : "morning nautical twilight ends, morning civil twilight starts"
                                  function writeAstroTimes(i) {
                                     // führende Nummer zur Sortierung in Admin/Objekte
                                     var nr = (i+1 < 10) ? "0" + (i+1) : (i+1);
                                     // Erstelle Objekt, falls nicht bereits vorhanden
                                     var idAstroObject = "javascript." + instance + "." + pfad + ".Zeiten." + nr + " - " + astrotime.elements[i].fname;
                                     createState(idAstroObject, " ", fC, {
                                         name: astrotime.elements[i].de.nxt + " " + astrotime.elements[i].de.name + " Uhrzeit",
                                         desc: astrotime.elements[i].en.desc,
                                         type: "string"
                                     setTimeout(function() { // kurz warten, damit Objekte ggf. erst angelgt werden können
                                         var astrotag = getState(idAstrotag).val,
                                             temp;
                                         var today = new Date();
                                         var tomorrow = today.setDate(today.getDate()+1);
                                         var next_event;
                                         if (astrotag) {
                                             // Wenn Tag (Aufgang vorbei (erst wieder morgen, Untergang kommt noch heute)
                                             next_event = (astrotime.elements[i].astroday) ? tomorrow : today; // prüfen
                                         } else {
                                             // nach Nacht (Untergang vorbei (erst wieder morgen, Aufgang kommt heute oder morgen)
                                             next_event = (astrotime.elements[i].astroday) ? today : tomorrow; // prüfen
                                         var fname = astrotime.elements[i].fname;
                                         setState(idAstroObject, checkSec(temp.toLocaleTimeString()) );
                                     }, 3 * 1000);
                                  // Zeit mit oder ohne Sekunden anzeigen
                                  function checkSec (zeit) {
                                     if (!sec) {
                                         var newString_arr = zeit.split(":");
                                         var newString = newString_arr[0] + ":" + newString_arr[1];
                                         return (newString);
                                     } else return (zeit);
                                  function getAstroday() {
                                     // Astrotag bestimmen (boolean)
                                     createState(idAstrotag, false, fC, {
                                         type: "boolean",
                                         desc: "Liegt die aktuelle Zeit zwischen Sonnenauf- und untergang"
                                     setState(idAstrotag, isAstroDay());
                                  function iterateAstrotimes() {
                                     // Zeiten für jede Astrozeit schreiben
                                     for (var i = 0; i < astrotime.elements.length; i++) {
                                         writeAstroTimes(i);
                                  // Astrotag checken
                                  schedule("*/1 * * * *", function () { // jede Minute
                                     getAstroday();
                                     iterateAstrotimes();
                                  getAstroday();
                                  Moin Paul,
                                  leider funktioniert mein Astroscript von Pix nicht mehr, hab da was gelesen, dass ich zweit nördlich bin.
                                  Naja, ich hab mal deins soweit am laufen, nur leider werden mir die ermittelten Zeiten nicht als format 24h angezeigt. sonder nur als 12h. Weißt du vielleicht woran das liegt?
                                  System ist gestern aktualisiert worden.
                                  Betriebssystem
                                  linux
                                  Architektur
                                  x64
                                  CPUs
                                  Geschwindigkeit
                                  1895 MHz
                                  Modell
                                  Common KVM processor
                                  RAM
                                  3.86 GB
                                  System Betriebszeit
                                  14:31:47
                                  Node.js
                                  v10.16.0 (Recommended version v8.16.0)
                                  NPM
                                  6.9.0
                                  Javascript ist auf 4.1.12
                                  Gruß und Danke
                                    paul53 @ple last edited by
                                    @ple sagte:
                                    Von Github ? Dann ändere bitte die Zeile
                                    in
                                            var tomorrow = new Date(today.setDate(today.getDate()+1));
                                    Ein PR auf Github ist erstellt, aber noch nicht merged.
                                      Jan1 last edited by Jan1
                                      Kein Plan warum man sich da ein JavaScript dafür von jemand übernimmt (@paul53 kann man machen und nichts gegen Dein Script).
                                      Wenn man schlicht die Astrozeiten als DP haben möchte und von Javascript nichts versteht, dann bietet Blockly schon alles was man braucht.
                                      sieht dann so aus:
                                      Hier dann mal der Blockly Export, falls es einer haben möchte:
                                      <block type="create" id="v72H-N1#%w_zseA#CMc" x="13" y="13">
                                      <field name="NAME">01-Nachtende</field>
                                      <block type="create" id="@kYi)AXak/ydmJCF!oo]">
                                      <field name="NAME">02-Morgendämmerung</field>
                                      <block type="create" id=";T8PP:ZCKeM4
                                      +U5?yi">
                                      <field name="NAME">03-Sonnenaufgang</field>
                                      <block type="create" id="gIfB:POQ4@(+!BTUapf">
                                      <field name="NAME">04-Sonneneaufgang_Ende</field>
                                      <block type="create" id="MFJk^e%f2^,QG[vUK4ee">
                                      <field name="NAME">05-Golden_Houer_Ende</field>
                                      <block type="create" id="hO7B(a7I~WK~vu8.7gDH">
                                      <field name="NAME">06-Mittag</field>
                                      <block type="create" id="eYe;t8x=FwBT4B,.|k."> <field name="NAME">07-Golden_Houer</field> <statement name="STATEMENT"> <block type="create" id="tVROR/kUT3MINh%SOcdY"> <field name="NAME">08-Sonnenuntergang_Anfang</field> <statement name="STATEMENT"> <block type="create" id="kCb|+j}(0FzG/abd,q1">
                                      <field name="NAME">09-Sonnenuntergang</field>
                                      <block type="create" id="4UB
                                      zNj{JG:saTpO/G">
                                      <field name="NAME">10-Abenddämmerung</field>
                                      <block type="create" id="%kf8::E|Nt2i
                                      cPYM.aB">
                                      <field name="NAME">11-Nacht</field>
                                      <block type="schedule" id="c;,oPug#y[hH+R/Az:)Z">
                                      <field name="SCHEDULE">0 0,6,12,18 * * *</field>
                                      <block type="update" id="QIMsUa0@3?Vo;jj}r-U">
                                      <field name="OID">javascript.0.01-Nachtende</field>
                                      <block type="convert_from_date" id="^E3;~IY|ubg5}Cw9eYrO">
                                      <mutation format="false" language="false"></mutation>
                                      <field name="OPTION">hh:mm:ss</field>
                                      <block type="time_astro" id="J0d,%PB7t8lb@8mXXXZ(">
                                      <field name="TYPE">nightEnd</field>
                                      <field name="OFFSET">0</field>
                                      <block type="update" id="HB^8MQ(4ds+W5/u^OW4m">
                                      <field name="OID">javascript.0.02-Morgendämmerung</field>
                                      <block type="convert_from_date" id="oN=Uv}fYcHBCDPHtpXiw">
                                      <block type="time_astro" id=":/y;e5awTDC:Cev;TUCS">
                                      <field name="TYPE">dawn</field>
                                      <block type="update" id="+A7|YpLw]g_!(9]PC@UH">
                                      <field name="OID">javascript.0.03-Sonnenaufgang</field>
                                      <block type="convert_from_date" id="AMyc:3
                                      Tp9XP+4kq(nv-">
                                      <block type="time_astro" id=",4bKmH_J8szFEb.4u{OB">
                                      <field name="TYPE">sunrise</field>
                                      <block type="update" id="DwtR_scz+f42pEJ/sKn?">
                                      <field name="OID">javascript.0.04-Sonneneaufgang_Ende</field>
                                      <block type="convert_from_date" id="a~M9OAt|LRQe5:d]~}H?">
                                      <block type="time_astro" id="7/scA1O-iX|.x-iB_~X3">
                                      <field name="TYPE">sunriseEnd</field>
                                      <block type="update" id="F.Y:ABQw?pppVIMuzXC4">
                                      <field name="OID">javascript.0.05-Golden_Houer_Ende</field>
                                      <block type="convert_from_date" id="jgDe(t)05^f2gQyGIaI6">
                                      <block type="time_astro" id="]qS[Z+Pab*WUXun969T"> <field name="TYPE">goldenHourEnd</field> <field name="OFFSET">0</field> </block> </value> </block> </value> <next> <block type="update" id="FjU7x+vB-{|nz?Ntgi]B"> <mutation delay_input="false"></mutation> <field name="OID">javascript.0.06-Mittag</field> <field name="WITH_DELAY">FALSE</field> <value name="VALUE"> <block type="convert_from_date" id="Ewd,fX4o;ftqhEAKr)^">
                                      <block type="time_astro" id="}2iN_uE[d~xeJMc]9~%p">
                                      <field name="TYPE">solarNoon</field>
                                      <block type="update" id="(slH?vH:Tx73fJ(J2HY]">
                                      <field name="OID">javascript.0.07-Golden_Houer</field>
                                      <block type="convert_from_date" id="kh1//%:x4My;~kFU,E^"> <mutation format="false" language="false"></mutation> <field name="OPTION">hh:mm:ss</field> <value name="VALUE"> <block type="time_astro" id="~MgPI%%B44O6EzrHu._C"> <field name="TYPE">goldenHour</field> <field name="OFFSET">0</field> </block> </value> </block> </value> <next> <block type="update" id="g|Q7g?g_fO6AjzFr(le">
                                      <field name="OID">javascript.0.08-Sonnenuntergang_Anfang</field>
                                      <block type="convert_from_date" id="r6N{VKoWDb6,=S=QyNF"> <mutation format="false" language="false"></mutation> <field name="OPTION">hh:mm:ss</field> <value name="VALUE"> <block type="time_astro" id="!nNaC0sNkzDc_CZkch6">
                                      <field name="TYPE">sunsetStart</field>
                                      <block type="update" id="5k::E!c_Nzjkf_4MU}_U">
                                      <field name="OID">javascript.0.09-Sonnenuntergang</field>
                                      <block type="convert_from_date" id=",z]tcWXKDj7^syvxRkU[">
                                      <block type="time_astro" id="e.#C/a~nk+lc9h!VRKIG">
                                      <field name="TYPE">sunset</field>
                                      <block type="update" id="okk0X1l~(0(nUW+Re46b">
                                      <field name="OID">javascript.0.10-Abenddämmerung</field>
                                      <block type="convert_from_date" id="jT6:rKIF[@`bgdN2Ei+R">
                                      <block type="time_astro" id="CeiV[rNfs^|Wwo/^8]}L">
                                      <field name="TYPE">dusk</field>
                                      <block type="update" id="y3QMbYJ8biR5l7@~Vd92">
                                      <field name="OID">javascript.0.11-Nacht</field>
                                      <block type="convert_from_date" id="5z?E1xsLp;YRIJ6YIaB!">
                                      <block type="time_astro" id="Y[SLp]Z~a7!a0aht:]j?">
                                      <field name="TYPE">night</field>
                                      • Q
                                        quorle last edited by
                                        @paul53 :
                                        Bei mir funktioniert dein Script leider nicht.
                                        Javascript Adapter ist auf 4.1.12
                                        js-controller ist auf 1.5.11
                                        Fehlerlog:
                                        javascript.0	2019-06-02 18:36:53.028	error	at Timer.listOnTimeout (timers.js:290:5)
                                        javascript.0	2019-06-02 18:36:53.028	error	at tryOnTimeout (timers.js:323:5)
                                        javascript.0	2019-06-02 18:36:53.028	error	at ontimeout (timers.js:511:34)
                                        javascript.0	2019-06-02 18:36:53.028	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1886:34)
                                        javascript.0	2019-06-02 18:36:53.027	error	at Object.<anonymous> (script.js.common.System.Astrozeiten_berechnen_V2:302:16)
                                        javascript.0	2019-06-02 18:36:53.027	error	at getAstroDate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1220:42)
                                        javascript.0	2019-06-02 18:36:53.027	error	Error in callback: TypeError: date.getDate is not a function
                                        javascript.0	2019-06-02 18:36:53.027	error	at Timer.listOnTimeout (timers.js:290:5)
                                        javascript.0	2019-06-02 18:36:53.027	error	at tryOnTimeout (timers.js:323:5)
                                        javascript.0	2019-06-02 18:36:53.027	error	at ontimeout (timers.js:511:34)
                                        javascript.0	2019-06-02 18:36:53.027	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1886:34)
                                        javascript.0	2019-06-02 18:36:53.026	error	at getAstroDate (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1220:42)
                                        javascript.0	2019-06-02 18:36:53.026	error	Error in callback: TypeError: date.getDate is not a function
                                        javascript.0	2019-06-02 18:36:53.026	error	at Timer.listOnTimeout (timers.js:290:5)
                                        javascript.0	2019-06-02 18:36:53.026	error	at tryOnTimeout (timers.js:323:5)
                                        javascript.0	2019-06-02 18:36:53.026	error	at ontimeout (timers.js:511:34)
                                        javascript.0	2019-06-02 18:36:53.026	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1886:34)
                                        javascript.0	2019-06-02 18:36:53.026	error	at Object.<anonymous> (script.js.common.System.Astrozeiten_berechnen_V2:302:16)
                                        J paul53 2 Replies Last reply Reply Quote 0
                                          Jan1 @quorle last edited by
                                          @quorle
                                          Deshalb nimmst einfach das Blockly, weil das immer funktioniert und so ziehmich auch exakt das Selbe rauskommt.
                                            paul53 @quorle last edited by paul53
                                            @quorle sagte:
                                            Fehlerlog:
                                            Dann verwendest Du die JS-Version von Github, die noch einen Fehler enthält, wenn date an getAstroDate() in ms übergeben wird. Deshalb ändere Zeile 292 in
                                            P 2 Replies Last reply Reply Quote 0
                                            349
                                            91731
