    4. [Aufruf] Adapter: Snips - Offline Speak2Text
      rascal last edited by
      Hey,
      snips gibt mir seit einem Tag Sprachmeldungen 3-5x aus, anstatt nur ein mal.
      Ich habe mittlerweile alles neu gestartet, Snips + assistant upgedatet, den Iobroker Adapter neu installiert.
      Auch wenn ich in den \send\text direkt reinschreibe, sagt er es öfter.
      Im "sam watch" zeigt er mir die mehrfache Ausgabe auch an.
      Ich weis nicht was ich noch ausprobieren kann 😞 - Hat jemand eine Idee?
      unltdnetworx 1 Reply Last reply Reply Quote 0
      • unltdnetworx
        unltdnetworx Developer @rascal last edited by
        @rascal
        Kannst du die Sam watch Ausgabe mal posten?
          rascal last edited by rascal
          1x Eingabe beim Snips Object \devices\default\send\text "Test neu"
          [16:34:36] Watching on localhost:1883 (MQTT)
          [16:35:09] [Dialogue] was asked to start a session on site default
          [16:35:09] [Asr] was asked to stop listening on site default
          [16:35:09] [Hotword] was asked to toggle itself 'off' on site default
          [16:35:09] [Dialogue] session with id 'c2bb9c6a-c03e-4634-adb7-2db26d6f4e47' was queued on site default
          [16:35:09] [Dialogue] session with id '9b964493-e6a8-408d-81c6-f4f48834d488' was queued on site default
          [16:35:09] [Dialogue] session with id 'c2bb9c6a-c03e-4634-adb7-2db26d6f4e47' was started on site default
          [16:35:09] [Dialogue] session with id '9b964493-e6a8-408d-81c6-f4f48834d488' was started on site default
          [16:35:09] [Tts] was asked to say "test neu"
          [16:35:09] [AudioServer] was asked to play a wav of 28.0 kB with id 'c1eb5403-7c1f-4c9a-bf99-0b49cd91fbe9' on site default
          [16:35:09] [AudioServer] was asked to play a wav of 28.0 kB with id 'b991e91c-5e92-4929-8d8b-419255d4fdb1' on site default
          [16:35:09] [AudioServer] was asked to play a wav of 28.0 kB with id '660fa648-a7dd-4b3d-a4b8-9a66430708ee' on site default
          [16:35:09] [AudioServer] was asked to play a wav of 28.0 kB with id 'ced29b8e-0eeb-4fb9-95c5-b1bb59d9fb20' on site default
          [16:35:10] [AudioServer] finished playing wav with id 'c1eb5403-7c1f-4c9a-bf99-0b49cd91fbe9'
          [16:35:10] [Tts] finished speaking with id '3e779b27-d656-4ebf-a068-504e193c1485'
          [16:35:10] [Dialogue] session with id 'c2bb9c6a-c03e-4634-adb7-2db26d6f4e47' was ended on site default. The session ended as expected
          [16:35:10] [Asr] was asked to stop listening on site default
          [16:35:10] [Hotword] was asked to toggle itself 'on' on site default
          [16:35:11] [AudioServer] finished playing wav with id 'b991e91c-5e92-4929-8d8b-419255d4fdb1'
          [16:35:11] [Tts] finished speaking with id 'e3c2410e-a1ea-42e2-9557-08deea238e2d'
          [16:35:11] [Dialogue] session with id '9b964493-e6a8-408d-81c6-f4f48834d488' was ended on site default. The session ended as expected
          [16:35:11] [Asr] was asked to stop listening on site default
          [16:35:11] [Hotword] was asked to toggle itself 'on' on site default
          [16:35:13] [AudioServer] finished playing wav with id '660fa648-a7dd-4b3d-a4b8-9a66430708ee'
          [16:35:13] [Tts] finished speaking with id '3e779b27-d656-4ebf-a068-504e193c1485'
          [16:35:14] [AudioServer] finished playing wav with id 'ced29b8e-0eeb-4fb9-95c5-b1bb59d9fb20'
          [16:35:14] [Tts] finished speaking with id 'e3c2410e-a1ea-42e2-9557-08deea238e2d'
          Was mir noch aufgefallen ist: Nach "Hey Snips" piepst er 2x
          [16:38:26] Watching on localhost:1883 (MQTT)
          [16:38:28] [Hotword] detected on site default, for model hey_snips
          [16:38:28] [Asr] was asked to stop listening on site default
          [16:38:28] [Hotword] was asked to toggle itself 'off' on site default
          [16:38:28] [Dialogue] session with id 'fe1deb90-e468-4596-b45d-91242c3b5a05' was started on site default
          [16:38:28] [AudioServer] was asked to play a wav of 41.1 kB with id 'e64d7d0b-5d8e-4208-bca7-fc48e0254a2e' on site default
          [16:38:28] [Dialogue] session with id '5a356b31-6fd6-4d3a-b17c-59d9fe8cca6d' was started on site default
          [16:38:28] [AudioServer] was asked to play a wav of 41.1 kB with id 'a9142a80-e274-4377-99e4-854a3c58e8a2' on site default
          [16:38:28] [AudioServer] finished playing wav with id 'e64d7d0b-5d8e-4208-bca7-fc48e0254a2e'
          [16:38:28] [Asr] was asked to listen on site default
          [16:38:29] [AudioServer] finished playing wav with id 'a9142a80-e274-4377-99e4-854a3c58e8a2'
          [16:38:29] [Asr] was asked to listen on site default
          • unltdnetworx
            @rascal
            Ich habe eine Theorie. Es liegt zumindest nicht am Adapter.
            Wieviele Geräte hast du am laufen? Das dürfte ein Satellit sein, oder?
              das war der Main, ich habe auch noch einen Satelliten laufen.
              • unltdnetworx
                @rascal
                Kannst du mal schauen, ob am Satelliten TTS läuft und dort ausschalten.
                sudo systemctl stop snips-tts
                sudo systemctl disable snips-tts
                  @unltdnetworx sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                  Hey,
                  ja ist gelaufen. Ich habe ihn jetzt gestoppt.
                  Jetzt gibt er mir die Ausgabe "nur" mehr 2x (Auch das "Ping" nach "Hey snips" ist noch 2x)
                  • unltdnetworx
                    @rascal
                    Stoppe mal den ganzen Satelliten und starte den Main neu. Evtl. liegt es an der Konfiguration.
                    Welche Variante der Satelliten-Anbindung hast du verwendet? Anleitung A oder B?
                      Bei Sprachbefehlen reagiert er ganz komisch, auch erkennt er sie im Moment überhaupt nicht.
                      Hey snips -> 2x ping -> 1x "nicht erkannt Ping" -> 2-5x ! ping
                      watch am Main:
                      [12:38:33] Watching on localhost:1883 (MQTT)
                      [12:38:35] [Hotword] detected on site default, for model hey_snips
                      [12:38:35] [Asr] was asked to stop listening on site default
                      [12:38:35] [Hotword] was asked to toggle itself 'off' on site default
                      [12:38:35] [Dialogue] session with id '92a8dce2-d34c-4793-a2ed-33799610d394' was started on site default
                      [12:38:35] [AudioServer] was asked to play a wav of 41.1 kB with id 'e18b94f7-9a33-4a2f-a466-2f418c171eee' on site default
                      [12:38:35] [Dialogue] session with id 'b4dc7a3c-4bc0-4e79-924d-9bd2ac2cea49' was started on site default
                      [12:38:35] [AudioServer] was asked to play a wav of 41.1 kB with id '1bb16720-fbef-482c-ba12-cc1a1fad21c9' on site default
                      [12:38:36] [AudioServer] finished playing wav with id 'e18b94f7-9a33-4a2f-a466-2f418c171eee'
                      [12:38:36] [Asr] was asked to listen on site default
                      [12:38:36] [AudioServer] finished playing wav with id '1bb16720-fbef-482c-ba12-cc1a1fad21c9'
                      [12:38:39] [Asr] captured text "an" in 3.0s
                      [12:38:39] [Asr] was asked to stop listening on site default
                      [12:38:39] [AudioServer] was asked to play a wav of 93.1 kB with id 'f2bab4c5-6adf-4dc8-be6a-e7b65d941635' on site default
                      [12:38:40] [Asr] captured text "licht an" in 3.0s
                      [12:38:40] [AudioServer] was asked to play a wav of 61.1 kB with id 'a37913d8-7489-48d1-a902-730c26d28fbe' on site default
                      [12:38:41] [AudioServer] finished playing wav with id 'f2bab4c5-6adf-4dc8-be6a-e7b65d941635'
                      [12:38:41] [AudioServer] finished playing wav with id 'a37913d8-7489-48d1-a902-730c26d28fbe'
                      [12:38:41] [Dialogue] session with id '92a8dce2-d34c-4793-a2ed-33799610d394' was ended on site default. The session was ended because an error happened: Event not supported: Response { waiting: AudioFinishedPayload  }, with response: AsrCapture(AsrPayload { text: "licht an", tokens: Some([AsrTokenPayload { value: "licht", confidence: 0.7844479, range_start: 0, range_end: 5, time: AsrDecodingDurationPayload { start: 0.0, end: 1.57888 } }, AsrTokenPayload { value: "an", confidence: 0.8506282, range_start: 6, range_end: 8, time: AsrDecodingDurationPayload { start: 1.57888, end: 3.1499999 } }]), likelihood: 0.8168681, seconds: 3.0 })
                      [12:38:41] [Asr] was asked to stop listening on site default
                      [12:38:41] [Hotword] was asked to toggle itself 'on' on site default
                      [12:38:52] [Dialogue] session with id 'b4dc7a3c-4bc0-4e79-924d-9bd2ac2cea49' was ended on site default. The session was ended because one of the component didn't respond in a timely manner
                      [12:38:52] [Asr] was asked to stop listening on site default
                      [12:38:52] [Hotword] was asked to toggle itself 'on' on site default
                      [12:41:12] [Asr] captured text "schalte das nicht an" in 4.0s
                      [12:41:12] [Asr] was asked to stop listening on site default
                      [12:41:12] [AudioServer] was asked to play a wav of 93.1 kB with id 'abc3e691-c4bb-44a2-b8e7-276380be0d83' on site default
                      [12:41:12] [Asr] captured text "schalte das licht an" in 4.0s
                      [12:41:12] [AudioServer] was asked to play a wav of 61.1 kB with id 'fe6cd879-5366-464d-94e5-4dca113be55c' on site default
                      [12:41:13] [AudioServer] finished playing wav with id 'abc3e691-c4bb-44a2-b8e7-276380be0d83'
                      [12:41:14] [AudioServer] finished playing wav with id 'fe6cd879-5366-464d-94e5-4dca113be55c'
                      [12:41:14] [Dialogue] session with id '1b1cbd31-6f78-4691-a257-1f86dadd3719' was ended on site default. The session was ended because an error happened: Event not supported: Response { waiting: AudioFinishedPayload  }, with response: AsrCapture(AsrPayload { text: "schalte das licht an", tokens: Some([AsrTokenPayload { value: "schalte", confidence: 1.0, range_start: 0, range_end: 7, time: AsrDecodingDurationPayload { start: 0.0, end: 2.34 } }, AsrTokenPayload { value: "das", confidence: 1.0, range_start: 8, range_end: 11, time: AsrDecodingDurationPayload { start: 2.34, end: 2.79 } }, AsrTokenPayload { value: "licht", confidence: 1.0, range_start: 12, range_end: 17, time: AsrDecodingDurationPayload { start: 2.79, end: 2.97 } }, AsrTokenPayload { value: "an", confidence: 1.0, range_start: 18, range_end: 20, time: AsrDecodingDurationPayload { start: 2.97, end: 3.99 } }]), likelihood: 1.0, seconds: 4.0 })
                      [12:41:14] [Asr] was asked to stop listening on site default
                      [12:41:14] [Hotword] was asked to toggle itself 'on' on site default
                        A oder B
                        Ich habe das Script verwendet und bis vor 2 Tagen hat auch alles ganz gut funktioniert:
                        https://github.com/Psychokiller1888/satConnect
                        • unltdnetworx
                          @rascal
                          Okay, dazu kann ich persönlich nichts sagen. Evtl. schilderst du dein Problem mal im Snips-Forum.
                          Einen eigenen Namen (nicht default) hat der Satellit aber schon?
                            dein letzter Tipp hat geholfen: snips über sam am Satelliten ausgeschaltet, Main neu gestartet und siehe da, der Main funkt ganz normal
                            • unltdnetworx
                              @rascal
                              Dann passt die Konfiguration nicht. Schau dir mal die Anleitung zum Satellitenbetrieb oder die Posts dazu weiter oben an. Evtl. kannst du was nachbessern. Es brauchen auf dem Satelliten nur wenige Dienste von Snips laufen.
                              • unltdnetworx
                                unltdnetworx Developer last edited by unltdnetworx
                                Neue Funktion in der Adapter-Version 1.1.6:
                                Bei allen Satelliten kann jetzt das Hotword/Wakeword (de)aktiviert werden.
                                • V
                                  vore last edited by vore
                                  Hallo! Ich habe jetzt die Hardware für einen Snips Satelliten (Raspi-Zero und 2Hat Mic Array). Es gibt eine Anleitung bei Snips, wie ich einen Satelliten hinzufüge Satellites. Muss ich diese nutzen? Oder hilft mit der Punkt "Create Satellite" im Adpater? Und wenn ja, was muss ich da eintragen? Die IP?
                                  Vore
                                  • unltdnetworx
                                    unltdnetworx Developer @vore last edited by
                                    @vore
                                    Ja, du kannst diese nutzen. Alternativ gibt es auch Skript, das die Anbindung durchführt.
                                    Was zum Anbinden nicht funktioniert, ist der Punkt "create Satellite". Dieser Punkt legt, nach Eingabe des zuvor definierten Namens des Satelliten-Gerätes, die Datenpunkte in ioBroker an. Das ist allerdings auch nur nötig, falls man kein Mikrophon am Gerät hat. Ansonsten werden die Datenpunkte bei der ersten Spracheingabe automatisch generiert.
                                    • V
                                      vore @unltdnetworx last edited by
                                      Dieses Script macht das alles von alleine. 2Min und der Satellite ist angemeldet: https://github.com/Psychokiller1888/satConnect
                                        Findus last edited by Findus
                                        Kurze Frage: Wollte den Adapter installieren bekomme aber folgende Message beim Installieren.
                                        l@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
                                        iobroker 2019-05-13 10:38:23.033 info WARN
                                        iobroker 2019-05-13 10:38:23.030 info npm
                                        iobroker 2019-05-13 10:37:03.193 info npm install https://github.com/unltdnetworx/ioBroker.snips/tarball/master --production --save --prefix "/opt/iobroker" (System call)
                                        iobroker 2019-05-13 10:37:00.894 info install https://github.com/unltdnetworx/ioBroker.snips/tarball/master
                                        iobroker 2019-05-13 10:36:58.974 info url "https://github.com/unltdnetworx/ioBroker.snips/tarball/master" snips
                                        Kann mir da jemand einen Tipp geben was ich genau machen muss?
                                        Node.js: v8.15.1
                                        NPM: 6.4.1
                                        Danke und Gruesse
                                        Findus
                                        • unltdnetworx
                                          @Findus sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                                          Hallo Findus,
                                          versuch es mal über die Github-Katze zu installieren. Das ist momentan die gleiche Version. Jetzt fehlen komischerweise Abhängigkeiten, ich habe aber nichts geändert. Somit hat sich vermutlich eine andere Abhängkeit geändert. Wenn noch mehrere das Problem haben, muss ich wohl diese Abhängigkeit einfügen. Obwohl das nicht Sinn der Sache wäre.
                                          • unltdnetworx
                                            Mit meiner npm-Version läuft es einwandfrei. 8.13.*
                                            snips
                                            43
                                            635
                                            134142
