    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Разные ошибки
    Разные ошибки
      electric69 last edited by
      В админке косяк в адаптере owfs.
      Описание походу от адаптера ping.
      • aurodionov
        aurodionov last edited by
        А подскажите, это нормальное поведение системы
        host-SmartHome	2015-05-12 19:51:57	info	Restart adapter system.adapter.pushover.0 because enabled
        host-SmartHome	2015-05-12 19:51:57	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:56	info	instance system.adapter.pushover.0 started with pid 30829
        host-SmartHome	2015-05-12 19:51:56	info	Restart adapter system.adapter.node-red.0 because enabled
        host-SmartHome	2015-05-12 19:51:56	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:55	info	instance system.adapter.node-red.0 started with pid 30823
        host-SmartHome	2015-05-12 19:51:51	info	Restart adapter system.adapter.web.0 because enabled
        host-SmartHome	2015-05-12 19:51:51	error	instance system.adapter.web.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:50	info	Restart adapter system.adapter.email.0 because enabled
        host-SmartHome	2015-05-12 19:51:50	error	instance system.adapter.email.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:49	info	instance system.adapter.web.0 started with pid 30813
        host-SmartHome	2015-05-12 19:51:49	info	instance system.adapter.email.0 started with pid 30811
        host-SmartHome	2015-05-12 19:51:42	info	Restart adapter system.adapter.javascript.0 because enabled
        host-SmartHome	2015-05-12 19:51:42	error	instance system.adapter.javascript.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:42	info	Restart adapter system.adapter.admin.0 because enabled
        host-SmartHome	2015-05-12 19:51:42	error	instance system.adapter.admin.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:40	info	instance system.adapter.javascript.0 started with pid 30801
        host-SmartHome	2015-05-12 19:51:39	info	instance system.adapter.admin.0 started with pid 30799
        host-SmartHome	2015-05-12 19:51:26	info	Restart adapter system.adapter.pushover.0 because enabled
        host-SmartHome	2015-05-12 19:51:26	error	instance system.adapter.pushover.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:25	info	instance system.adapter.pushover.0 started with pid 30793
        host-SmartHome	2015-05-12 19:51:25	info	Restart adapter system.adapter.node-red.0 because enabled
        host-SmartHome	2015-05-12 19:51:25	error	instance system.adapter.node-red.0 terminated with code 7 (Adapter already running)
        host-SmartHome	2015-05-12 19:51:24	info	instance system.adapter.node-red.0 started with pid 30787
        • Bluefox
          Bluefox last edited by
          @aurodionov:
          Нет.. Нужно перезапустить комп
          • aurodionov
            Ребутнул всё заработало, не понял что это было:)
            при загрузке вылезло малостя варнингов
            node-red-0	2015-05-13 11:00:35	warn	13 May 11:00:35 - [info] Flows file : /opt/iobroker/node_modules/iobroker.node-red/userdata/flows.json
            node-red-0	2015-05-13 11:00:35	warn	13 May 11:00:35 - [info] User Directory : /opt/iobroker/node_modules/iobroker.node-red/userdata/
            node-red-0	2015-05-13 11:00:35	warn	13 May 11:00:35 - [warn] ------------------------------------------
            node-red-0	2015-05-13 11:00:35	warn	13 May 11:00:35 - [warn] [redisout] Error: Cannot find module 'redis'
            node-red-0	2015-05-13 11:00:35	warn	13 May 11:00:35 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node.
            node-red-0	2015-05-13 11:00:35	warn	13 May 11:00:35 - [warn] [arduino] Error: Cannot find module 'arduino-firmata'
            так понимаю наследие+ не умеет с базами работать.
            Кстати хистори и нодред тоже базу хотят.
              Не пойму, вроде раньше можно было с вкладки "Объекты" редактировать значения переменных - точно помню, что писал разные тексты - игрался с адаптером sayit. Теперь не могу, щелка два раза ЛКМ - ничего))) Так и было задумано или это глюк какой?
              UPD: Сорри, тупанул, менять значения на вкладке "Состояния"
              • V
                vtec last edited by
                Подтверждаю, лог как то странно обновляется. Приходится нажимать на кнопку обновить.
                • Bluefox
                  @vtec:
                  Подтверждаю, лог как то странно обновляется. Приходится нажимать на кнопку обновить. `
                  А admin и js-controller последние?
                  • V
                    vtec last edited by
                    @Bluefox:
                    А admin и js-controller последние? `
                    admin 0.4.8
                    js-controller 0.6.6
                    • Alex1808
                      Alex1808 last edited by
                      Всем привет!
                      в Instanzen линк на /vis/edit.html без http, атображеается как > undefined://. Естественно перехода не происходит.
                      ~~![](</s><URL url=)http://i.imgur.com/mlP8zll.png" />
                      Спасибо за проделанную работу! С меня на пиво ;)~~
                      • Bluefox
                        @Alex1808:
                        Всем привет!
                        Спасибо за проделанную работу! С меня на пиво ;)~~ ` Я не стал править это. Т.к. это - использование новой функции, которая находится сейчас в тесте. Если установиться с гита, то ошибки не будет.
                        • V
                          vtec last edited by
                          Заметил во вкладке "Состояния", если в низу нажать на значек "Обновить состояния", то состояния почему то меняются на прошлые, пока автоматом сами не обновятся
                          • V
                            vtec last edited by
                            schedule("* */1 * * *", function () {
                                var date = new Date();
                                var hour = date.getHours();
                                log("Время "+ hour);
                            Почему данный скрипт отрабатывает каждую минуту? Можете у себя проверить?
                            • V
                              vtec last edited by
                              При таком раскладе, тоже самое
                              schedule("* 0-23 * * *", function () {
                                  log("Will be triggered every 1 hour!");
                              • aurodionov
                                @vtec:
                                Почему данный скрипт отрабатывает каждую минуту? Можете у себя проверить? `
                                ! javascript-0 2015-08-02 13:37:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:36:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:35:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:34:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:33:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:32:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:31:00 info script.js.Script1: Время 13
                                ! javascript-0 2015-08-02 13:30:35 info script.js.Script1: registered 0 subscriptions and 1 schedule
                                ! javascript-0 2015-08-02 13:30:35 info Start javascript script.js.Script1
                                Это первый
                                • V
                                  vtec last edited by
                                  Все верно не рабоатет, пойду напишу на гитхаб
                                  • aurodionov
                                    @vtec:
                                    При таком раскладе, тоже самое `
                                    ! javascript-0 2015-08-02 13:41:00 info script.js.Script1: Will be triggered every 1 hour!
                                    ! javascript-0 2015-08-02 13:40:00 info script.js.Script1: Will be triggered every 1 hour!
                                    ! javascript-0 2015-08-02 13:39:18 info script.js.Script1: registered 0 subscriptions and 1 schedule
                                    ! javascript-0 2015-08-02 13:39:18 info Start javascript script.js.Script1
                                    и тоже через минуту
                                    • V
                                      vtec last edited by
                                      Решение
                                      "0 * * * *"
                                      • Bluefox
                                        @vtec:
                                        "* */1 * * *" => Каждую минуту и каждый час.. То есть всегда. Всё нормально.
                                        "* 0-23 * * *" => Каждую минуту и каждый час с 0 до 23 . То есть тоже всегда. Всё нормально.
                                        ` > Решение
                                        "0 * * * *" `
                                        Всё верно.
                                          spectrekr last edited by
                                          Когда делаешь объекту
                                          setState(('sayit.0.tts.volume'),80);
                                          и тут же
                                          getState('sayit.0.tts.volume').val
                                          то возвращается "магическое" число 72. Хотя если зайти в объекты и там посмотреть, то значение стоит которое устанавливается. И History показывает правильные значения.
                                          • Bluefox
                                            @spectrekr:
                                            и тут же
                                            то возвращается "магическое" число 72. Хотя если зайти в объекты и там посмотреть, то значение стоит которое устанавливается. И History показывает правильные значения. `
                                            Функция асинхронная. Правильно так:
                                            setState('sayit.0.tts.volume',80, function () {
                                                 log(getState('sayit.0.tts.volume').val);
                                            192
                                            55981
