    5. [Gelößt] Hilfe brauche ein Script
      paul53 @winny1900 last edited by paul53
      @winny1900 sagte:
      Wie bekomme ich diese Zahl jetzt in VIS ?
      Erstelle unter javascript.0 zwei Datenpunkte vom Typ Zahl. Die kannst Du in Vis anzeigen.
      Hier noch eine einfachere Variante in Blockly:
        <variables>
          <variable type="" id="^qm4e^`2czKZoH]v$#fl">svalue</variable>
        </variables>
        <block type="comment" id="9n9v:t+^YMFN!FcVt%`," x="-412" y="37">
          <field name="COMMENT">mqtt.0.domoticz.in</field>
            <block type="on_ext" id="GT`:hBV!3yxgm!|!K~71">
              <value name="OID0">
                <shadow type="field_oid" id="QsKav`scUw[F2b`k4|:0">
                <block type="variables_set" id="Oj_j6{/t`(UmgHca?z{h">
                  <field name="VAR" id="^qm4e^`2czKZoH]v$#fl" variabletype="">svalue</field>
                    <block type="lists_split" id="BWP{vz7kklj8g/$9Z9w1">
                      <mutation mode="SPLIT"></mutation>
                      <field name="MODE">SPLIT</field>
                      <value name="INPUT">
                        <block type="get_attr" id=".(zz43SmwgHL-7;k06`A">
                          <value name="PATH">
                            <shadow type="text" id="p3x_XG,@)4*`}n1$EPK!">
                              <field name="TEXT">svalue</field>
                          <value name="OBJECT">
                            <block type="on_source" id="{ci9/]DbojUFy#dg!346">
                      <value name="DELIM">
                        <shadow type="text" id="mVDhf?jm!P!+1axeKFt7">
                          <field name="TEXT">;</field>
                    <block type="comment" id="vlRRKrcDW%0k~i/!$qCg">
                      <field name="COMMENT">Temperatur</field>
                        <block type="update" id="bEl[~{A}71F!?sOPMSE#">
                            <block type="convert_tonumber" id="q4kt:./.w7)aJ@R]Hrdm">
                                <block type="lists_getIndex" id="c{lQ3iLBC_o=6LI!9r7j">
                                    <block type="variables_get" id="C.*hD-!6honAqqOr`{uk">
                                  <value name="AT">
                                    <block type="math_number" id="j}{GiOwS*(,Zgm2]Kcr:">
                                      <field name="NUM">1</field>
                            <block type="comment" id="7:hpc2shYp-{jw${9Owx">
                              <field name="COMMENT">Luftfeuchtigkeit</field>
                                <block type="update" id="zJiYj1wb9T6W[3{b:ip}">
                                    <block type="convert_tonumber" id="59Kp#ayU+-[lR:fq23M8">
                                        <block type="lists_getIndex" id="uJH|GQie1lqx|6%EqSpH">
                                            <block type="variables_get" id="!2HC:9{c}JjO~-b?(bV}">
                                          <value name="AT">
                                            <block type="math_number" id="G,t04Tbinp}-ph0J;r|~">
                                              <field name="NUM">2</field>
        Der ansatz ist doch richtig. Der soll den wert in den neu angelegten Datenpunkt schreiben. Wenn ich da Liste eintrage schreibt der mir 3 Werte da rein.
        Wie bekomme ich das gelößt ?
        Ich mus auf jedenfall einen zweiten schreibe Block hinzufügen der mit ID Luftfeuchte.
          @winny1900 sagte:
          Schau mal in den Post davor: Die Variable Liste heißt dort svalue.
            winny1900 @paul53 last edited by
            bei aktualisiere Objekt ID kommt domoticz rein oder ?
            Weil das Script bei mir nicht läuft.
            17:30:05.712 error javascript.0 script.js.common.Test_2: Cannot get svalue of undefined
            17:30:05.713 error javascript.0 at Object.<anonymous> (script.js.common.Test_2:7:35)
              @winny1900 sagte in Hilfe brauche ein Script:
              Nein, beim ersten kommt die ID des Datenpunktes für die Temperaturanzeige und beim zweiten für die Feuchteanzeige rein (steht im Kommentar darüber). domoticz/in kommt beim Trigger rein.
                hatte ich auch aber klappt nicht !
                  @winny1900 sagte:
                  klappt nicht !
                  Poste mal den Javascript-Code zu dem Blockly.
                      <variables>
                        <variable type="" id="M3M(d4mStWF20,0YTs8-">svalue</variable>
                        <variable type="" id="rXRrCB6TjAFBN}u0m?94">Wert</variable>
                      </variables>
                      <block type="on_ext" id="?0aUoyJ54YONx4lpTknk" x="-62" y="38">
                        <value name="OID0">
                          <shadow type="field_oid" id="X@|.GI#NMkm!tpElg:0N">
                            <field name="oid">mqtt.0.domoticz.in</field>
                          <block type="field_oid" id="=|F.L85D:FZ~uR(VAqL9">
                          <block type="variables_set" id=",$-$oLn`tLQuKnm=HAP?">
                            <field name="VAR" id="M3M(d4mStWF20,0YTs8-" variabletype="">svalue</field>
                              <block type="lists_split" id="7:n2~,g/#UErIRm78!bd">
                                  <block type="get_attr" id="P6Gq~]6C.+XQ}:j%rL!Q">
                                    <value name="PATH">
                                      <shadow type="text" id="UA6bAniM.d`]{i.G)AUU">
                                      <block type="text" id="/]q34ws4q$)`qxanFm83">
                                      <block type="variables_get" id="#8(Jdx2lV75rL:?gh}!A">
                                        <field name="VAR" id="rXRrCB6TjAFBN}u0m?94" variabletype="">Wert</field>
                                  <shadow type="text" id="YI.KKD*:?hqMram{#d:R">
                                  <block type="text" id=",XR}u%x}l|~rfkM?eg/.">
                              <block type="update" id="+Qw~Z-c]b(7XXG;SQ=,-">
                                <field name="OID">javascript.0.Außentemp</field>
                                  <block type="convert_tonumber" id=",KQE85]PB{DEo.#kx,1B">
                                      <block type="lists_getIndex" id="R+k,Tks}7GP2k!0U7x)8">
                                          <block type="variables_get" id="wZ6)t!iOCh%It;@{4GZ$">
                                        <value name="AT">
                                          <block type="math_number" id="5_zkgF{7ky)jKLqU|;lA">
                                  <block type="update" id="idUi)E`+(nGu=!Zgf}L`">
                                    <field name="OID">javascript.0.Außenluftfeuchte</field>
                                      <block type="convert_tonumber" id="(hT.wec}=+(x8(|n@ckG">
                                          <block type="lists_getIndex" id="|y-mRDdVe%`abvj`+39I">
                                              <block type="variables_get" id="|1kG5WAlJ35yF,10|i-h">
                                            <value name="AT">
                                              <block type="math_number" id="7)gDqXV+Lv~A9(v,]*;}">
                      @winny1900 Wert ist keine Variable, sondern eine Eigenschaft des Triggerdatenpunktes (unter Blöcke Trigger) !
                      Du kannst auch die Variable Wert umbenennen nach value, damit es funktioniert.
                        DANKE !! Danke für dein Geduld es Klappt !!!!
                          So eins noch . Versprochen !!!
                          Unter JAvascript null zeigt der mir bei der Temp 17 % an statt Grad ?
                          Wie lösen wir das ?
                            Schon erledigt habe was überlesen. War unter einstellungen.
                            1449
