    4. [Aufruf] fullyBrowser Adapter
    • 0
      0018 last edited by
      @arteck bei Installation aus eigener URL mit "https://github.com/arteck/ioBroker.fullybrowser" bekomme ich nur die 16.
        mach jetzt
        • 0
          0018 last edited by
          @arteck Installation hat geklappt, läuft aber nicht:
          fullybrowser.0	2019-05-03 09:57:59.281	info	terminating
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:369:33)
          fullybrowser.0	2019-05-03 09:57:59.234	error	at /opt/iobroker/node_modules/iobroker.fullybrowser/main.js:508:9
          fullybrowser.0	2019-05-03 09:57:59.234	error	at getHost (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:437:5)
          fullybrowser.0	2019-05-03 09:57:59.234	error	ReferenceError: stopTimer is not defined
          fullybrowser.0	2019-05-03 09:57:59.233	error	uncaught exception: stopTimer is not defined
          fullybrowser.0	2019-05-03 09:57:59.074	info	starting. Version 0.0.17 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v8.15.1
          habe versucht den Adapter zu deinstallieren und den 16er zu installieren, ohne Erfolg. Die Deinstallation scheint erfolgreich, die Adapterversion bleibt aber auf 16 stehen, obwohl sie eigentlich gelöscht ist.
            man sollte nix zwischendurch machen 🙂
            probier mal noch mal bitte.. von GIT
            • 0
              0018 last edited by
              @arteck
              host.BrokerNUC	2019-05-03 10:12:18.786	error	instance system.adapter.fullybrowser.0 terminated with code 0 (OK)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitNone (events.js:111:20)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Object.onceWrapper (events.js:313:30)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:211:7)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitOne (events.js:116:13)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.emit (events.js:214:7)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at emitTwo (events.js:126:13)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
              host.BrokerNUC	2019-05-03 10:12:18.786	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24)
              host.BrokerNUC	2019-05-03 10:12:18.785	error	Caught by controller[0]: ReferenceError: leti is not defined
              fullybrowser.0	2019-05-03 10:12:18.649	error	ReferenceError: leti is not defined at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24) at Request.self.callback (/opt/iobroker/node_modules/request/request.
              fullybrowser.0	2019-05-03 10:12:18.648	error	uncaught exception: leti is not defined
                arteck Developer Most Active @0018 last edited by
                @0018 ok das wird nix.... muss ich mir am system anschauen...
                heute abend.. installiere die Stable bitte 0.0.16..
                ich mach heute Abend ein Update
                0 1 Reply Last reply Reply Quote 0
                • 0
                  0018 @arteck last edited by
                  @arteck Ok, leider schaffe ich es nicht den Adapter zu deinstallieren. Die 0.17 bleibt immer sichtbar. Hast du einen Tipp?
                  • 0
                    0018 @0018 last edited by
                    @0018 sagte in [Aufruf] fullyBrowser Adapter:
                    Hat sich erledigt, downgrade auf 16 mit "npm install iobroker.fullybrowser@0.0.16 --production" hat geklappt und läuft erstmal wieder
                      liv-in-sky last edited by
                      kurze zwischeninfo: habe 0.17 installiert. wenn ich den adapter stoppe, läuft er trotzdem noch weiter (in htop)
                        arteck Developer Most Active @liv-in-sky last edited by
                        @liv-in-sky ne das wird die 0.0.16 sein die nicht beendet wurde..
                          so 0.0.17 sollte laufen
                            liv-in-sky @arteck last edited by
                            @arteck
                            jup - du hattest recht - neustart und getestet(aus/eingeschaltet) - funktioniert - danke dir
                            • I
                              intruder7 last edited by
                              Moin,
                              seit zwei Tagen funktioniert der Adapter nicht mehr. Meine beiden Tabs sind leer gelaufen da die Ladeüberwachung nicht mehr funktioniert. Fully ist normal über web erreichbar. Nur der Adapter baut keine Verbindung auf. Neustart, installieren der 17er Version haben nichts gebracht. Was mir aufgefallen ist, die App auf den Tabs ist aktualisiert worden und da sind einige Neuerungen bezügliche Java drin?
                                arteck Developer Most Active @intruder7 last edited by
                                @intruder7 welche Version des Fullybrowser ??
                                I 2 Replies Last reply Reply Quote 0
                                • I
                                  intruder7 @arteck last edited by
                                  @arteck ich habe auf beiden Tabs die Version 1.31
                                  • I
                                    @arteck Hab jetzt den Adapter nochmal komplet neu installiert. Er funktioniert trotzdem nicht. Was verwunderlich ist, Befehle sendet er. Also z.B. Sceen on. Nur sämtliche Infos erhält er nicht
                                      @intruder7 muss ich mir mal anschauen.. vor WE wird das aber nix
                                      I 3 Replies Last reply Reply Quote 0
                                      • I
                                        @arteck Lass dir Zeit. Die Tabs sind im Moment am Dauerstrom. Hoffe nur du findest eine Lösung✊
                                        • I
                                          @arteck Achso, und eins noch. Besteht die Möglichkeit in den Objekten anstatt der IP einen unter Einstellungen vergebenen Namen zu nutzen? Das wäre auch noch Klasse. ansonsten hat der Adapter von Anfang bis eben vor ein paar Tagen super funktioniert. 👍
                                          • I
                                            @arteck Hab mal geschaut bei Git. Unter Umständen hilft es schon wenn du das timeout von 2000 bei Abfrage der Infos etwas erhöhst. Die Abfrage über das REST Interface dauert ziemlich lange.
                                            function updateDevice(ip,port,psw) {
                                            var id = ip.replace(/[.\s]+/g, '_');
                                            var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
                                            var vari = '';
                                            var thisOptions = {
                                                uri: statusURL,
                                                method: "GET",
                                                timeout: 2000,
                                                followRedirect: false,
                                                maxRedirects: 0
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            43581
