    4. [Vorstellung] Meine zweite Visualisierung
      Kuddel @David16 last edited by Kuddel
      @David16
        <variables>
          <variable type="undefined" id="timeout2">timeout2</variable>
          <variable type="undefined" id="Intervall">Intervall</variable>
          <variable type="undefined" id="timeout">timeout</variable>
        </variables>
        <block type="comment" id="G#1eVC9]T6os%Z1:::W^" x="-438" y="-188">
          <field name="COMMENT">VM Neustart</field>
            <block type="controls_if" id="N!iI}^5vnz^Cm}MWyn*{" collapsed="true">
                <block type="logic_operation" id="D_#z![BhlBINb0hL%qG1" inline="false">
                  <field name="OP">AND</field>
                    <block type="logic_compare" id="tZ*%pcX[-zh08]9%9H:.">
                      <field name="OP">EQ</field>
                        <block type="get_value" id="mXf*^Az|bn-7]z@0pK1l">
                          <field name="OID">system.adapter.rpi2.0.connected</field>
                        <block type="logic_boolean" id="fM=r}MG|zC;,uz,(ZqG,">
                    <block type="logic_compare" id="OejL%7x:w5%B/2r8NQzA">
                      <field name="OP">LT</field>
                        <block type="get_value" id="pk_{/2)7@cSzs+S8lLte">
                          <field name="OID">rpi2.0.uptime.uptime</field>
                        <block type="math_number" id="z_WqYvo6W7pZ!Ymv`0.c">
                          <field name="NUM">300</field>
                <block type="timeouts_settimeout" id="UxHLu@%S?ZMau!4D;7K8">
                  <field name="DELAY">30</field>
                    <block type="email" id=")tU5~uR+es6na*!~.z:@">
                      <field name="IS_HTML">TRUE</field>
                      <field name="LOG"></field>
                      <value name="TO">
                        <shadow type="text" id=",22dv|19tQmS?T-2V/kn">
                          <field name="TEXT">daniel@dkulinski.de</field>
                      <value name="TEXT">
                        <shadow type="text" id="IHu[*vJ9NcnDG.c6Frnv">
                          <field name="TEXT"></field>
                        <block type="text_join" id="_8p)3,}W|LD;y:m;N[V:">
                          <value name="ADD0">
                            <block type="text_join" id="L|uAuxg^]A1#z9w,8{;J">
                              <value name="ADD0">
                                <block type="text_join" id="FOL,#i;METt1Y`mhr}}A">
                                  <value name="ADD0">
                                    <block type="text" id="!suAu3)AU;pFaTzg]*K!">
                                      <field name="TEXT">ioBroker-VM wurde neugestartet.</field>
                                  <value name="ADD1">
                                    <block type="text" id="s6H.humnVkjPn|!ie%~n">
                                      <field name="TEXT">&lt;br&gt;</field>
                              <value name="ADD1">
                                <block type="text" id="QdqA(XpMp;m7p0YS}UVA">
                          <value name="ADD1">
                            <block type="text_join" id="T(8P}cea7Jz}GE#h)/6R">
                              <value name="ADD0">
                                <block type="text" id="X:Dt5aCs4**!?^K6nV1]">
                                  <field name="TEXT">Uptime: </field>
                              <value name="ADD1">
                                <block type="get_value" id="IU~t8*S=)dz@Vn/8iSx8">
                                  <field name="OID">javascript.0.uptime.iobroker</field>
                      <value name="SUBJECT">
                        <shadow type="text" id="#^,:0esM^+@}M?rP8~vc">
                          <field name="TEXT">+++ ioBroker-VM neugestartet +++</field>
                      <value name="FROM">
                        <block type="text" id="VeQkf1^TE4fBFC[YOM/v">
                          <field name="TEXT">iobroker@dkulinski.de</field>
                        <block type="debug" id="M@ZtC{YG@|+l#(u`FAC.">
                          <value name="TEXT">
                            <shadow type="text" id="H.b4eqZx{5%Fu}zqYFZ%">
              <statement name="ELSE">
                <block type="timeouts_setinterval" id="ted=Q]K6k!MX@1beB;iu">
                  <field name="NAME">Intervall</field>
                  <field name="INTERVAL">10</field>
                    <block type="controls_if" id="^QQ@0f@U|z~UIK?ZUGz;">
                        <block type="logic_compare" id="d85J~z78ld2pZdI@u3Fy">
                            <block type="get_value" id=";.fxX}n3XE_u;y9/bLSZ">
                            <block type="logic_boolean" id="myBugI8PeWRKHn`pd_~}">
                        <block type="controls_if" id="G4P3*~F%tBw;A.3jY/0?">
                            <block type="logic_compare" id="BUPBeUitS)qQi=sL`UeG">
                                <block type="get_value" id="Hn@vDzeK)xawfi~0V%zC">
                                <block type="math_number" id="9kT|d{4W){ek+)yEaKO$">
                            <block type="email" id="?ZsLo7%3mZ0k(16p+k_*">
                              <value name="TO">
                                <shadow type="text" id="Y}]4iuo.z!~y.by,~/eI">
                              <value name="TEXT">
                                <block type="text_join" id="?/x@2URDylfu5(oRPAHX">
                                  <value name="ADD0">
                                    <block type="text_join" id="0,!Jzhly+y(BOOtweBXR">
                                      <value name="ADD0">
                                        <block type="text_join" id="V=^V9_rmLLCx?X1[U+F;">
                                          <value name="ADD0">
                                            <block type="text" id="gJzqd@O8~0W@{FewD*k4">
                                          <value name="ADD1">
                                            <block type="text" id="mL{LF2+!IzT7+sEELU8)">
                                      <value name="ADD1">
                                        <block type="text" id="e+C%~;p,n)Em|BG=z3Q%">
                                  <value name="ADD1">
                                    <block type="text_join" id="emfADTvV12AdADlOV/bA">
                                      <value name="ADD0">
                                        <block type="text" id="rf@8h1:%bfkFaehGR2Q4">
                                      <value name="ADD1">
                                        <block type="get_value" id="Dg!6LX}iz~%QH3r6E8G}">
                                <shadow type="text" id="ip#]fYjVJ8nt73:H;qO-">
                              <value name="FROM">
                                <block type="text" id="2{vsBmyv|`eovUYQ3:C?">
                                <block type="debug" id="H`iR5f=;%Ljnzq)sUB04">
                                  <value name="TEXT">
                                    <shadow type="text" id="U;1bM~:d8Ru82V~.jz5@">
                                    <block type="timeouts_clearinterval" id="`p=ZS5%D;R9-mT%oGuMu">
                <block type="comment" id="Ups9ZR?DbYb417IWrZo]">
                  <field name="COMMENT">JavaSkript Neustart</field>
                    <block type="timeouts_settimeout" id="z,84GVliz{uGH/McJ)+[" collapsed="true">
                      <field name="DELAY">2</field>
                        <block type="controls_if" id="?=-Cyev917JQ8+#K1!bp">
                            <block type="logic_operation" id="q8WO6j=n1]3v_K5;|N?S" inline="false">
                                <block type="logic_compare" id="ItD^?qv3/an/V7C5PSKT">
                                  <field name="OP">GT</field>
                                    <block type="get_value" id="?n=[p?R9KWysdt-b)=`B">
                                    <block type="math_number" id="`|dfzAV08L2`alT!8D{e">
                                      <field name="NUM">600</field>
                                <block type="logic_compare" id="~yV@hHI6fjFpLIWd{,!E">
                                    <block type="get_value" id="q)p;)1vHu^lD7}j9;T/3">
                                      <field name="OID">system.adapter.javascript.0.uptime</field>
                                    <block type="math_number" id="qJL1BeIWZ;v8{!JZxP=+">
                            <block type="email" id=";%+sr4@5RIv2Pz.LJnA,">
                              <value name="TO">
                                <shadow type="text" id="e#U2su+@8)clMa},F5aC">
                              <value name="TEXT">
                                <block type="text_join" id="lyXd[F(/Oq0Fobn}Uy[)">
                                  <value name="ADD0">
                                    <block type="text_join" id="3C)?9h=Qtv@[06nY@N8(">
                                      <value name="ADD0">
                                        <block type="text_join" id="tBrR0pW*D[b/,W|lZDg2">
                                          <value name="ADD0">
                                            <block type="text" id="tO`#QDVa39TR*]_pw;%?">
                                              <field name="TEXT">JavaSkript Adapter wurde neugestartet.</field>
                                          <value name="ADD1">
                                            <block type="text" id="8Ia%qKmrGY]YIx~%mtuF">
                                      <value name="ADD1">
                                        <block type="text" id="@h%o6gZBY)8;K3K^Mf,3">
                                  <value name="ADD1">
                                    <block type="text_join" id="x*|+nj(uS)JmF!/U5`6v">
                                      <value name="ADD0">
                                        <block type="text" id="G0c;~Mlspkk7{LEfI/Y(">
                                          <field name="TEXT">VM Uptime: </field>
                                      <value name="ADD1">
                                        <block type="get_value" id=":mNvSR;ghA}K,M2q^/a+">
                                <shadow type="text" id="1E@J7]6TNdKt)7D^/h8`">
                                  <field name="TEXT">+++ JavaSkript neugestartet +++</field>
                              <value name="FROM">
                                <block type="text" id="0oc~Ak~~cQG9n=shF4F3">
                                <block type="debug" id="b-/E@|rbc?m[YKIn20z^">
                                  <value name="TEXT">
                                    <shadow type="text" id="AnsdYBaJqZFfsq!uQ|b@">
                                      <field name="TEXT">+++ JavaSkript Adapter neugestartet +++</field>
        David16 @Kuddel last edited by
        @Kuddel Vielen Dank, hat wohl auch am fehlenden Mail-Adapter gelegen.
          Kuddel last edited by Kuddel
          Und weiter gehts es:
          Auslastung ioBroker:
          Auslastung ESX-NUC:
          EDIT: ESX Auslastung jetzt farbig
          sigi234 S 2 Replies Last reply Reply Quote 0
            sigi234 Forum Testing Most Active @Kuddel last edited by
            @Kuddel
            Auslastung ist ziemlich Hoch bei dir?
              Kuddel @sigi234 last edited by
              @sigi234 jop. mein NUC ist so zimelich am Ende. Ist aber kein Wunder (Celeron 4x 1,5 GHz).
              Auf Sicht werde ich mir einen NUC mit I7 zulegen
                skokarl @Kuddel last edited by
                @Kuddel sagte in [Vorstellung] Meine zweite Visualisierung:
                Wie geil ist das denn ?
                Das will ich auch ...... 😱
                Hoffe das ist weiter oben beschrieben 😀
                  Kuddel @skokarl last edited by
                  @skokarl ist im Export auf Seite 1 noch nicht enthalten.
                  Ich werde nächste Woche mal wieder eine neue Version vom Export hochladen und die Screenshots aktualisieren
                    Kuddel, wenn ich das kriegen kann mach ich den Grill an....nur für Dich.... 😇
                    Hammeranzeige.... sowas wünsche ich mir schon länger
                    • Q
                      quorle last edited by
                      Mal eine Frage, wie funktioniert das genau mit der Wetteranzeige?
                      • frana120500
                        frana120500 last edited by
                        Wie bekommt man denn die Skripte importiert? HAbe jetzt meine und die heruntergeladenen Skripte in einer zip Datei zusammengefügt. Wenn ich dann aber auf Skripe importieren klicke, geht zwar das upload Fenster auf, wenn ich aber die zip dann da reinziehe, passiert nix.
                          @sigi234 mein neuer NUC (NUC8i7BEH) ist in Betrieb gegangen:
                          sigi234 S 2 Replies Last reply Reply Quote 1
                            Kuddel @quorle last edited by
                            @quorle was genau möchtest du denn wissen ?
                            Am einfachsten ist es, wenn du dir mein Probjekt importiertst und dir dann einfach mal im Editor anschaust, wie ich das alles zusammengebaut habe.
                            So habe ich es bei meiner VIS auch gemacht
                              Kuddel @frana120500 last edited by
                              @frana120500 geht der Export und dann der Import von deinen Skripten ? Also ohne meine hinzuzufügen?
                              Dann könnte man schon einmal einen Fehler beim Import ausschließen
                                Super, Neu ist Neu....das sind mal Werte............👍
                                  Auf Seite 1 habe ich aktuelle Screenshots und einen neuen Export bereitgestellt 🙂
                                    VIS-Export 10.05.19:
                                    Hallo, ist das jetzt als Projekt zu importieren?
                                      @sigi234 ja genau. leider ohne Icons. habe noch keinen weg gefunden, das alles in einem Paket hoch zu laden
                                      sigi234 Negalein 2 Replies Last reply Reply Quote 0
                                        Ok, erfolgreich importiert, ABER du musst die Passwörter bei den Kameras unbedingt rausnehmen bzw. sofort ändern!
                                        • Negalein
                                          Negalein Global Moderator @Kuddel last edited by
                                          -> Leider wieder ohne Icons da das Paket sonst 16 MB groß wäre
                                          Wenn du möchtest, kann ich dir auf meinem Webserver einen FTP zur Verfügung stellen.
                                            @sigi234 habs gerade im Export geändert.
                                            Danke für den Hinweis
                                            template vis
                                            148
                                            1324
                                            489849
