    4. [Neuer Adapter] LinkedDevices
    • Scrounger
      Scrounger Developer last edited by
      Find ich nicht, da ich mir aus mehreren datenpunkten ein device basteln kann 😉
      Stell den Adpater auf debug, starte ihn neu und poste das log.
        paul53 @Scrounger last edited by
        @Scrounger sagte in [Neuer Adapter] LinkedDevices:
        linkeddevices.0	2019-05-07 16:48:01.066	debug	system.adapter.admin.1: logging true
        linkeddevices.0	2019-05-07 16:47:58.873	debug	system.adapter.admin.1: logging false
        linkeddevices.0	2019-05-07 16:47:56.487	info	[initialObjects] finished
        linkeddevices.0	2019-05-07 16:47:56.485	debug	[initialObjects] 'dicLinkedObjectsStatus' items count: 1
        linkeddevices.0	2019-05-07 16:47:56.485	debug	[createAllLinkedObjects] active linkedObjects {"hm-rpc.0.NEQ1234567.1.AUTO_MODE":"linkeddevices.0.Bad.HKT.Auto_Mode"}
        linkeddevices.0	2019-05-07 16:47:56.485	info	[createAllLinkedObjects] count of active linkedObjects: 1
        linkeddevices.0	2019-05-07 16:47:56.485	debug	[createAllLinkedObjects] 'dicLinkedObjectsStatus' items count: 1
        linkeddevices.0	2019-05-07 16:47:56.481	debug	[createLinkedObject] linkedObject 'hm-rpc.0.NEQ1234567.1.AUTO_MODE' to 'linkeddevices.0.Bad.HKT.Auto_Mode'
        linkeddevices.0	2019-05-07 16:47:56.416	debug	[createLinkedObject] keep custom settings '{"linkeddevices.0":{"enabled":true,"parentId":"hm-rpc.0.NEQ1234567.1.AUTO_MODE","isLinked":false}}' for linkedObject 'linkeddevices.0.Bad.HKT.Auto_Mode'
        linkeddevices.0	2019-05-07 16:47:56.415	debug	[createLinkedObject] using custom name 'Bad HKT Auto-Mode' for: 'linkeddevices.0.Bad.HKT.Auto_Mode' (parentObj: 'hm-rpc.0.NEQ1234567.1.AUTO_MODE')
        linkeddevices.0	2019-05-07 16:47:56.314	debug	[resetAllLinkedObjectsStatus] 'dicLinkedObjectsStatus' items count: 1
        linkeddevices.0	2019-05-07 16:47:56.314	debug	[resetLinkedObjectStatus] 'isLinked' status reseted for 'linkeddevices.0.Bad.HKT.Auto_Mode'
        linkeddevices.0	2019-05-07 16:47:56.293	info	[initialObjects] started...
        linkeddevices.0	2019-05-07 16:47:56.292	debug	[onReady] notDeleteDeadLinkedObjects: 'true'
        linkeddevices.0	2019-05-07 16:47:56.245	info	starting. Version 0.0.1 in C:/Program Files/ioBroker/node_modules/iobroker.linkeddevices, node: v8.15.1
        linkeddevices.0	2019-05-07 16:47:56.162	debug	statesDB connected
        linkeddevices.0	2019-05-07 16:47:56.142	debug	objectDB connected
        host.FP-NBA-W10	2019-05-07 16:47:55.490	info	instance system.adapter.linkeddevices.0 started with pid 7560
        host.FP-NBA-W10	2019-05-07 16:47:52.933	info	instance system.adapter.linkeddevices.0 terminated with code null ()
        host.FP-NBA-W10	2019-05-07 16:47:52.933	warn	instance system.adapter.linkeddevices.0 terminated due to SIGTERM
        host.FP-NBA-W10	2019-05-07 16:47:52.916	info	stopInstance system.adapter.linkeddevices.0 killing pid 12892
          paul53 @Scrounger last edited by paul53
          @Scrounger sagte:
          Eine Ordnerstruktur ist kein Device. LinkedStates wäre passender.
          • Scrounger
            Scrounger Developer @paul53 last edited by
            @paul53 sagte in [Neuer Adapter] LinkedDevices:
            Log sieht gut aus. Hab des bei mir nachgestellt und funktioniert wie es soll.
            Poste mal noch bitte das parentObjekt (RAW Daten), also NEQ12xxx.AUTO_MODE.
            Musst vlt. doch auf 8.16. updaten.
              paul53 @paul53 last edited by paul53
              @paul53 sagte:
              Eine Änderung des Wertes im verlinkten Datenpunkt (Bad.HKT.Auto_Mode) wird nicht an den Original-Datenpunkt übertragen.
              Habe noch einen zweiten Datenpunkt verlinkt und jetzt werden die Werte übertragen ☺
              BBTown paul53 2 Replies Last reply Reply Quote 0
              • BBTown
                BBTown @paul53 last edited by BBTown
                @paul53 ist dieser weitere Datenpunkt auch "read = false"?
                vielleicht hängt das doch damit zusammen?
                @Scrounger oder war dein Test mit dem gleichen/gleichartigen Datenpunkt?
                  @paul53 sagte:
                  Habe noch einen dritten DP verlinkt: Auf dem erfolgt wieder keine Wertübertragung, sondern nur mit den beiden "älteren". Auch ein Neustart der Instanz ändert daran nichts, außer dass während des Neustarts eine Wertübertragung erfolgt.
                  @BBTown sagte:
                  "read = false"?
                  Nein, es funktioniert in beide Richtungen (mit 2 verlinkten Datenpunkten).
                  EDIT: Mit einem 4. verlinkten DP funktioniert es auch nicht, nur bei den beiden "ältesten".
                    Nach einem ioBroker-Neustart funktioniert die Wertübertragung mit allen 4 verlinkten Datenpunkten.
                    • Scrounger
                      Scrounger Developer @BBTown last edited by Scrounger
                      @BBTown sagte in [Neuer Adapter] LinkedDevices:
                      Ja hab mit dem gleichen getestet. Grundsätzlich ist es so, dass der Adapter die Datenpunkte 1:1 spiegelt, d.h. alles was unter 'common' im parentObject steht bekommt dann auch das linkedObject.
                      • Scrounger
                        Das ist doch ein Bug, hab es grad reproduzieren können. Fix hab ich hoch geladen, bitte aktualisierten branch von git ziehen
                          @Scrounger sagte:
                          Mal schauen, ob ich bei weiteren Tests noch etwas finde.
                          Die Eigenschaften "read" und "write" wertest Du nicht aus, was meiner Meinung nach aber sinnvoll wäre:
                          "read": false - Übertragung nur vom verlinkten DP zum Original
                          "write": false - Übertragung nur vom Original-DP zum verlinkten
                          Alle anderen Fälle: bidirektional.
                          • Scrounger
                            Scrounger Developer @paul53 last edited by Scrounger
                            @Scrounger sagte:
                            Dann funktioniert das Konzept doch nicht mehr.
                            Beispiel:
                            Du hast dein linkedObject "Auto_Mode" (was 'write' ist) z.B. mit einem Button in deinem vis verknüpft. Wenn du diesen jetzt drückst wird der 'state' des LinkedObject auf 'true' gesetzt. Jetzt muss natürlich auch das parentObject mitbekommen das da was passiert ist, also der 'state' muss hier auch auf 'true' gesetzt werden.
                            Wie gesagt alles was im 'common' eines Objektes steht wird nur gespiegelt, den rest macht der Adapter.
                            In deinem Fall würde das parentObjekt nix mit bekommen und somit auf der tatsächlichen Hardware auch nix ausgeführt werden
                              @Scrounger sagte:
                              Wirklich ? "read": false, "write": true ist dieser Fall:
                              • Scrounger
                                @Scrounger sagte:
                                Sorry aber versteh nicht was du meinst? Mach mal bitte ein Beispiel warum dieses verhalten nicht korrekt ist.
                                  @Scrounger sagte:
                                  Beispiel AUTO_MODE hat "read": false, ist also "write only". Ich habe geschrieben
                                  Somit erfolgt die Wertänderung am verlinkten DP durch Vis oder durch ein Skript auch am parentDatapoint.
                                  • Scrounger
                                    Scrounger Developer last edited by Scrounger
                                    wenn es kein linkedObject dazwischen geben würde, würde vis oder skript den 'state' des parentObject setzen (=write).
                                    Genau dieses verhalten hat man auch mit einem linkedObjekt dazwischen...
                                    vis/skript -> write -> linkedObject -> wirte -> parentObject.
                                      @Scrounger sagte:
                                      Ja, so soll es auch sein. Wenn aber jemand den Wert des parentObjektes ändert, erfolgt diese Änderung auch im linkedObjekt, wenn "read": false nicht ausgewertet wird.
                                      • Scrounger
                                        Ja und das ist genau richtig, weil das linkedObjekt ja ein Spiegelbild des parentObjects ist und immer den gleichen Zustand wie das parentObjekt abbilden muss.
                                        vis/skript -> write -> parentObject -> write -> linkedObject & Hardware.
                                          @Scrounger sagte:
                                          Das ist Ansichtssache. Wenn Du es so dokumentierst, wird es sicherlich akzeptiert und Nachfragen vermieden.
                                            @Scrounger Der Zustand eines Datenpunktes beinhaltet auch den Zeitstempel. Jetzt erfolgt die Übertragung nur bei einer Wertänderung, nicht jedoch, wenn nur der Zeitstempel aktualisiert wird - wie es bei Tasten (z.B. PRESS_SHORT) der Fall ist.
                                            adapter
                                            68
                                            464
                                            92617
