    3. Entwicklung
    4. [Adapter] Neuer radar2-Adapter
      helfi9999 @frankjoke last edited by
      @frankjoke
      Hallo habe auf node 8.16 upgrade gemacht seitdem bekomme ich folgende Fehlermeldung und Adapter läuft nicht nicht:
      host.ioBroker-Rock 2019-05-06 19:27:08.771 info Restart adapter system.adapter.radar2.0 because enabled
      host.ioBroker-Rock 2019-05-06 19:27:08.771 error instance system.adapter.radar2.0 terminated with code 0 (OK)
      host.ioBroker-Rock 2019-05-06 19:27:08.771 error Caught by controller[0]: port: 67 }
      host.ioBroker-Rock 2019-05-06 19:27:08.771 error Caught by controller[0]: address: '0.0.0.0',
      host.ioBroker-Rock 2019-05-06 19:27:08.771 error Caught by controller[0]: syscall: 'bind',
      host.ioBroker-Rock 2019-05-06 19:27:08.770 error Caught by controller[0]: code: 'EACCES',
      host.ioBroker-Rock 2019-05-06 19:27:08.770 error Caught by controller[0]: errno: 'EACCES',
      host.ioBroker-Rock 2019-05-06 19:27:08.770 error Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
      host.ioBroker-Rock 2019-05-06 19:27:08.770 error Caught by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:142:11)
      host.ioBroker-Rock 2019-05-06 19:27:08.769 error Caught by controller[0]: at _handle.lookup (dgram.js:266:18)
      host.ioBroker-Rock 2019-05-06 19:27:08.769 error Caught by controller[0]: { Error: bind EACCES 0.0.0.0:67
      radar2.0 2019-05-06 19:27:08.686 info found '@abandonware/noble'
      radar2.0 2019-05-06 19:27:08.085 info debug: mtime of /opt/iobroker/node_modules/iobroker.radar2/lib/vendors.json is Sun May 05 2019 00:57:10 GMT+0200 (CEST) stats are 0.059027038966049376
      radar2.0 2019-05-06 19:27:08.078 info radar2 initialization started...
      radar2.0 2019-05-06 19:27:08.077 info debug: radar2 received undefined objects and 124 states, with config devices,scandelay,arp_scan_cmd,btadapterid,printerdelay,removeEnd,knownIPs,knownBTs,external,delayaway,delayuwz,numuwz,longuwz,deb
      radar2.0 2019-05-06 19:27:07.499 info starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.radar2, node: v8.16.0
      Weiß nicht weiter
      Gruß Helfi
        steimi @frankjoke last edited by
        @frankjoke sagte in [Adapter] Neuer radar2-Adapter:
        Ok, danke an alle die inzwischen einige Aufklärungsarbeit geleistet haben!
        Eine Zusammenfassung kurz:
        1. Wenn ein neues node (V8->V10) installiert wird sollten auch die node-tools (node-gyp, u.s.w) neu installiert werden
        2. Wenn ein neues node (V8.x auf V8.y oder V8 auf V10 ...) installiert wird muss müssen auch die Berechtigungen neu vergeben werden:
        sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which node`)
        1. Wenn andere updates am System vorgenommen werden die neue BT-Treiber oder utilities installieren müssen alle im Install spoiler stehenden Installationsbefehle neu ausgeführt werden. Fehler wie { Error: bind EACCES 0.0.0.0:67 deuten darauf hin dass sich was geändert hat da keine Berechtigung zum Aufbau einer dhcp-Verbindung besteht.
        War wieder im Spital (diesmal mit Notebook, habe neuen Gips aus Kunststoff und keine Fäden von der OP mehr 🙂 ) und hab etwas dazuprogrammiert aber erst heute zu Hause nach der Rückkehr testen können:
        V1.2.0 steht auf git!
        Die Änderungen in Kürze:
        1. Möglichkeit zur Verwendung von hcitool anstatt noble unter linux geschaffen (default).
        2. _LastHere wird bei Adapterrestart nicht geändert
        3. Default Abfragezyklus auf 30 Sekunden geändert
        Bei 1) ist es möglich ohne noble auszukommen, ich verwende dann ausschließlich hcitool scan und hcitool lescan! Für normales BT ist das besser da länger gescannt wird, für BT-LE sollte es egal sein da beide Module das selbe machen.
        Ich habe dies deshalb als default angegeben welche unter linux auch so verwendet werden soll. Wenn ihr umsteigt müsst ihr nun auch
        sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hcitool`)
        sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f `which hciconfig`)
        eingeben (ist in der readme/install-Liste aufgenommen worden).
        Die 2) bedeutet dass _lastHere das letzte Datum wenn das Gerät gesichtet wurde bleibt. Einziger Nachteil: Währen Adapterstart kann es vorkommen dass Geräte als abwesend gezeigt werden wenn der Adapter längere Zeit still steht.
        Die 3) wurde umgestellt da viele Nutzer den Default von 20 Sekunden beibehalten haben aber die Scanzeit zu kurz war um viele BT-Geräte zu finden. Mit dem neuen hcitool-Verfahren wird 85% der Zeit gescannt, und zwar beide BT-Methoden gleichzeitig. Allerdings darf sonst am gleichen BT-Controller kein anderes BT-Programm laufen, auch nicht auf der Kommandozeide. Erst wieder nachdem radar2 gestoppt wird! Vorteil: Einige Geräte die unter Radar1 gefunden wurden und unter radar2 nicht mehr sollten jetzt wieder gefunden werden!
        p.s.: Hab die Version noch nicht auf npm und ins repo gegeben da ich hoffe mit eurem Feedback mögliche bugs noch auszukurieren! Von git aber nicht mittels 'beliebig' installieren!
        Punkt 2 mal ausführen...
          helfi9999 @steimi last edited by
          @steimi sagte in [Adapter] Neuer radar2-Adapter:
          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+eip $(eval readlink -f which node)
          super danke das hat geholfen
          Herzlichen Dank ein Problem weniger
          P.S. Kennst du dich auch mit dem tr-064 Adapter aus
          frankjoke 1 Reply Last reply Reply Quote 0
          • frankjoke
            frankjoke @helfi9999 last edited by
            @helfi9999 , @steimi
            Danke an @steimi für die schnelle Hilfe, besser hät ichs auch nicht sagen können!
            Früher als ioBroker noch als root lief war das alles nicht notwendig, jetzt müssen solche Bewilligungen her damit ioBroker oder die Adapter & Programme ohne sudo auskommen.
            Aus Sicherheitsgründen gelten die Bewilligungen nur für das aktuelle binary, also überschreibst du es mit einer neuen Version ist sie futsch. Das soll verhindern dass schadcode eingeschleust wird aber zieht mehr administrationsaufwand mit sich.
            MathiasJ 1 Reply Last reply Reply Quote 0
            • MathiasJ
              MathiasJ @frankjoke last edited by MathiasJ
              @frankjoke
              Sag mal, dürfen wir wissen, was Du ausgefressen hast?
              Klingt ja ziemlich gefährlich 😞
              Ich wünsche Dir gute Genesung!
              Nicht um in's OT zu verfallen.......
              Radar getestet mit USB-Extender und 15m LAN-Kabel:
              Radar stürzt laufend ab, wenn man alles durchlaufen läßt.
              Radar läuft zuverlässig durch, wenn man only hci markiert.
              Egal ob mit 1200 mA oder 600 mA.
              Vielleicht braucht das ja der ein oder andere.
              ich habe diese USB-Extender genommen.
              Gruß,
              Mathias
              frankjoke SBorg 2 Replies Last reply Reply Quote 0
              • frankjoke
                frankjoke @MathiasJ last edited by
                @MathiasJ
                Danke für die Info Matthias! Kannte die Dinger noch gar nicht, ist aber gute Idee, kann man ja such verwenden um an 2 Stellen mit 2 Instanzen zu fahren!
                Ich habe einen BT-OBD im Auto stecken welches unter dem Carport stehen habe. Vom Arbeitszimmer sehe ich das nicht, im nächsten Raum schon. Mal kaufen/testen ob ich einen besseren Platz finde!
                Was stürzt mit noble wie ab?
                p.s.: Habe doppelten Knöchelbruch und bin jetzt mit 6 Schrauben und einer Platte auf der einen Seite und 2 Schrauben auf der anderen Seite zusammengeflickt. Schaut am Röntgen aus wie meine Werkzeugkiste... Noch 2 Wochen Liegegips und dann hoffentlich den ersten Gehgips. Das andere ist alles schon verheilt.
                • SBorg
                  SBorg Forum Testing Most Active @MathiasJ last edited by
                  Gute Besserung @terminator 0.6 ^^
                  OT:
                  @MathiasJ sagte in [Adapter] Neuer radar2-Adapter:
                  Dir ist aber schon bewusst, dass >=PI3 sowieso 1.2A auf den USB-Ports liefert, unabhängig von der Einstellung? Nur 1+2 liefern standardmäßig ohne "boost" 600mA 🙂
                  • MathiasJ
                    MathiasJ @SBorg last edited by
                    @SBorg
                    Nein das wußte ich jetzt nicht.
                    Weiß jemand wie es beim Rock64 ist?
                    Wie viel liefert der?
                    Mathias
                    • MathiasJ
                      @frankjoke
                      Dann wünsche ich Dir weiter gute Besserung und auf eine baldige Genesung.
                      Dieses Resultat habe ich nur mit USB-Extendern und 15m LAN-Kabel:
                      Noble läßt Radar immer wieder abstürzen, das heißt es kommt kein Scan mehr.
                      ich habe nicht im logfile geschaut.
                      Danach habe ich only hci enabled. Dann ging Radar 2 Tage ohne Probleme durch.
                      Beim erneutem disable ging Radar wieder nur für 2 Stunden, dann mußte ich wieder einen Neustart des Adapters machen.
                      Dann ließ ich only hci ein zweites mal enabled und ließ Radar wieder 2 Tage ohne Probleme durchsausen.
                      Ohne USB-Extender, also BT-Dongle direkt angeschlossen:
                      Da spielt es keine Rolle, ob only hci enabled ist oder nicht.
                      Da rennt Radar2 durch wie nichts.
                      Aber es spielt ja keine Rolle, wie es funktioniert. Hauptsache es geht.
                      ich warte jetzt noch auf eine anderes LAN-Kabel (7m) damit ich das ganze fest installieren kann.
                      • SBorg
                        Da es für radar durchaus interessant sein könnte:
                        Ich würde mal am Bluetooth-Stick messen was vom Extender überhaupt ankommt. Bei PoE wird dafür ein nicht unerheblicher Aufwand betrieben, und der passt mechanisch kaum in die kleinen Extender-Gehäuse. Ich vermute mal ganz grob, dass die ziemlich simpel den durch zwei Adern jagen...
                        z.B. USB Messgerät
                        • smile
                          smile last edited by
                          Hi zusammen,
                          bekomme den Radar Adapter nicht zum laufen - er geht kurz auf "grün" und wechselt dann wieder auf rot.
                          Ich möchte eigentlich nur meine Handys per Bluetooth erkennen.
                          Systeminfo: iobroker @ Asus MiniPC i5 CPU, Win10 Pro, Node 8.15.1, npm 6.9.0, internes Bleutooth Modul.
                          Mir ist auch leider nicht ganz klar was ich in welcher Zeile der radar2 Einstellungen reinschreiben soll? Hierzu habe ich keine erläuternde Doku gefunden. Anbei die Einstellungen des Radar Adapters:
                          Danke für Unterstützung.
                          • frankjoke
                            frankjoke @smile last edited by
                            @smile ,
                            kannst du mal die letzte Version von Git laden (im admin/adpters auf das äffchen und radar2 in die Liste eingeben)? VORHER aber die Installationsscripts vom readme (im Installationsspoiler oben auch) anwenden!
                            Dann gibt es in der konfig ein Häkchen für debug mode und den einschalten und dann starten und den log anschauen/posten damit Gründe ersichtlich werden können.
                            Ich hoffe du verwendest NICHTWindows, da dort das meiste nicht funktioniert!
                            • smile
                              @frankjoke In meiner Signatur sind wie bei dir die Daten zu meinem System...
                              Das heißt ich kann das ganze ohnehin nicht nutzen?
                              Laut dem Programm "bluetoothview" werden die Smartphones mit Bluetooth Mac Adresse jedenfalls korrekt erkannt:
                              • frankjoke
                                @smile
                                Ich sehe die Signaturen nicht auf meinem Tablet 😞
                                Ich kann auch nicht sagen ob es unkzionieren kann wenn ich kein Ino von eventuellen Fehlermeldungen bei Installation oder Start bekomme.
                                Iobroker läüft unter NodeJS und ich muss Node-Bibliotheken verwenden um auf Bluetooth zuzugreifen: Leider funktionieren die nicht alle unter Windows und ohne die Meldungen kann ich nicht mal sehen was funktioniert und was nicht.
                                Es ist leichter mit den Netzwerk-Erkennungen da ping auch auf Windows funktioniert.
                                smile 1 Reply Last reply Reply Quote 0
                                • MathiasJ
                                  MathiasJ @SBorg last edited by MathiasJ
                                  @SBorg sagte in [Adapter] Neuer radar2-Adapter:
                                  z.B. USB Messgerät
                                  USB-Testgerät ist bestellt und müßte nächste Woche eintreffen.
                                  Bin auf die Ergebnisse gespannt.
                                  Ich werde jedenfalls ohne/mit USB-Extender auf dem Teststystem messen.
                                  • smile
                                    smile @frankjoke last edited by
                                    @frankjoke Achso okay, sorry.
                                    Habe iobroker auf einem Intel i5 mit Windows 10Pro, 16GB RAM. Node 8.15.1, npm 6.9.0
                                    Hier einmal der LOG wenn ich den Radar Adapter starte:
                                    host.DJ-Server 2019-05-14 20:02:39.796 info Restart adapter system.adapter.radar2.0 because enabled
                                    host.DJ-Server 2019-05-14 20:02:39.796 error instance system.adapter.radar2.0 terminated with code 0 (OK)
                                    Caught 2019-05-14 20:02:39.796 error by controller[0]: at process._tickCallback (internal/process/next_tick.js:181:9)
                                    Caught 2019-05-14 20:02:39.796 error by controller[0]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
                                    Caught 2019-05-14 20:02:39.795 error by controller[0]: at Noble.<anonymous> (C:\ioBroker\node_modules@abandonware\noble\lib\noble.js:57:24)
                                    Caught 2019-05-14 20:02:39.795 error by controller[0]: at NobleBindings.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\bindings.js:82:13)
                                    Caught 2019-05-14 20:02:39.795 error by controller[0]: at Hci.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\hci.js:101:35)
                                    Caught 2019-05-14 20:02:39.795 error by controller[0]: at BluetoothHciSocket.bindRaw (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:43:8)
                                    Caught 2019-05-14 20:02:39.795 error by controller[0]: at BluetoothHciSocket.bindUser (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:87:11)
                                    Caught 2019-05-14 20:02:39.795 error by controller[0]: Error: No compatible USB Bluetooth 4.0 device found!
                                    radar2.0 2019-05-14 20:02:39.763 info Adapter disconnected and stopped with dostop(false) and callback(true)
                                    radar2.0 2019-05-14 20:02:39.762 error at process._tickCallback (internal/process/next_tick.js:181:9)
                                    radar2.0 2019-05-14 20:02:39.762 error at _combinedTickCallback (internal/process/next_tick.js:132:7)
                                    radar2.0 2019-05-14 20:02:39.762 error at Noble.<anonymous> (C:\ioBroker\node_modules@abandonware\noble\lib\noble.js:57:24)
                                    radar2.0 2019-05-14 20:02:39.762 error at NobleBindings.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\bindings.js:82:13)
                                    radar2.0 2019-05-14 20:02:39.762 error at Hci.init (C:\ioBroker\node_modules@abandonware\noble\lib\hci-socket\hci.js:101:35)
                                    radar2.0 2019-05-14 20:02:39.762 error at BluetoothHciSocket.bindRaw (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:43:8)
                                    radar2.0 2019-05-14 20:02:39.762 error at BluetoothHciSocket.bindUser (C:\ioBroker\node_modules@abandonware\bluetooth-hci-socket\lib\usb.js:87:11)
                                    radar2.0 2019-05-14 20:02:39.762 error Error: No compatible USB Bluetooth 4.0 device found!
                                    radar2.0 2019-05-14 20:02:39.762 error uncaught exception: No compatible USB Bluetooth 4.0 device found!
                                    radar2.0 2019-05-14 20:02:39.759 warn Promise problem unhandledRejection of Promise Promise { <rejected> TypeError: A.isLinuxApp(...).then is not a function at Network.updateMacdb.then.then (C:\ioBroker\node_modules\iobroker.radar2\radar
                                    radar2.0 2019-05-14 20:02:39.757 info radar2 set to scan every 20 seconds and printers every 720 minutes.
                                    radar2.0 2019-05-14 20:02:39.757 info arp-scan will use the following interfaces: [ 'Ethernet', 'USB Netzwerk Dongle' ]
                                    radar2.0 2019-05-14 20:02:39.757 info use known IP list: [ '1.1.1.1', '172.16.2.47' ]
                                    radar2.0 2019-05-14 20:02:39.756 info use known BT list: [ '3c:dc:bc:24:05:21', '00:00:46:00:00:01' ]
                                    radar2.0 2019-05-14 20:02:39.756 info radar2 set to flag items away if they are not seen for 2 minutes
                                    radar2.0 2019-05-14 20:02:39.756 info found 'node-bluetooth'
                                    radar2.0 2019-05-14 20:02:39.715 info found '@abandonware/noble'
                                    radar2.0 2019-05-14 20:02:39.296 info Connected with '0.0.0.0' for DHCP Scan
                                    radar2.0 2019-05-14 20:02:39.193 info radar2 initialization started...
                                    radar2.0 2019-05-14 20:02:39.160 info starting. Version 1.0.7 in C:/ioBroker/node_modules/iobroker.radar2, node: v8.15.1
                                    Danke für Deine Unterstützung.
                                      lobito last edited by
                                      Ich bekomme den Adapter auf Teufel komm raus nicht installiert. Fehlermeldung ist ```
                                      npm ERR! enoent ENOENT: no such file or directory, rename 'c:\ioBroker\node_modules\.staging\q-0da3371a' -> 'c:\ioBroker\node_modules\iobroker.radar2\node_modules\q'
                                      Irgendwelche Ideen? Das ist der einzige Adapter der rumspinnt....
                                        ChristianF last edited by ChristianF
                                        ich würde auch gern eine Frage stellen.. auf einem RPi3 mit ext. USB BT Stick funktioniert die Erkennung von Handys mittels L2PING prima:
                                        root@raspi:~# l2ping -f 60:73:BC:C8:CB:26
                                        Ping: 60:73:BC:C8:CB:26 from 00:1A:7D:DA:71:13 (data size 44) ...
                                        44 bytes from 60:73:BC:C8:CB:26 id 0 time 20.79ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 1 time 26.30ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 2 time 20.05ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 3 time 23.82ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 4 time 21.37ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 5 time 46.31ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 6 time 17.52ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 7 time 42.59ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 8 time 23.82ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 9 time 26.30ms
                                        44 bytes from 60:73:BC:C8:CB:26 id 10 time 15.11ms
                                        Ich habe das Gerät mit Namen und (ausschließlich) BT-MAC im Radar2 Adapter definiert, es bleibt aber leider auf AWAY wenn man nicht gerade BT an- und ausschaltet. Die L2PING Erreichbarkeit funktioniert allerdings dauerhaft, egal wie lange das Handy schon rumliegt (und sich inzwischen lange aus dem WLAN ausgebucht hat -> Energiesparen).
                                        Ein sudo hcitool scan findet... nichts:
                                        root@raspi:~# sudo hcitool scan
                                        Scanning ...
                                        root@raspi:~#
                                        Stellt man am Handy BT aus und wieder an, findet sich auch was:
                                        Scanning ...
                                                60:73:BC:C8:CB:26       ZTE AXON7
                                        root@raspi:~#
                                        Dann bleibt das Gerät auch für kurze Zeit im Radar2 auf TRUE, verschwindet aber ein paar Minuten später wieder.
                                        Für mich bedeutet das: Raspi und Handy können grundsätzlich miteinander reden (siehe L2PING), aber so wirklich auch nicht...
                                        Hat jemand einen Tipp für mich?
                                        Vielen Dank !
                                        Viele Grüße
                                        Christian
                                        • ostseereiter
                                          ostseereiter last edited by
                                          Hallo mir geht es genauso ichbekomme den Adapter zwar installiert aber er bleibt rot, Ich kann mir vorstellen das es an der Installition liegt denn man soll ja vorher dies tun.
                                          nstallation
                                          Before installing the adapter into ioBroker you need to install on linux arp-scan and libcap2-bin and some drivers which you can do by running below commands. On Debian (Raspi-Stretch, Ubuntu, ...) it looks like:
                                          sudo apt-get install libcap2-bin arp-scan bluetooth bluez libbluetooth-dev libudev-dev net-tools
                                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+ei p $(eval readlink -f `which arp-scan`)
                                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+ei p $(eval readlink -f `which node`)
                                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+ei p $(eval readlink -f `which arp`)
                                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+ei p $(eval readlink -f `which hcitool`)
                                          sudo setcap cap_net_admin,cap_net_raw,cap_net_bind_service=+ei p $(eval readlink -f `which hciconfig`)
                                          If you update node or some system tools the above should be executed again!
                                          aber genau da liegt der Haase im Pfeffer. Diese wird schon abgebrochen.
                                          Die folgenden Pakete werden aktualisiert (Upgrade):
                                          libudev-dev libudev1 udev
                                          3 aktualisiert, 34 neu installiert, 0 zu entfernen und 25 nicht aktualisiert.
                                          Es müssen noch 1.329 kB von 5.681 kB an Archiven heruntergeladen werden.
                                          Nach dieser Operation werden 18,2 MB Plattenplatz zusätzlich benutzt.
                                          Möchten Sie fortfahren? [J/n] j
                                          Fehl:1 http://ftp.de.debian.org/debian stretch/main amd64 libudev-dev amd64 232-25+deb9u6
                                          404 Not Found
                                          Fehl:2 http://ftp.de.debian.org/debian stretch/main amd64 udev amd64 232-25+deb9u6
                                          404 Not Found
                                          Fehl:3 http://ftp.de.debian.org/debian stretch/main amd64 libudev1 amd64 232-25+deb9u6
                                          404 Not Found
                                          E: Fehlschlag beim Holen von http://ftp.de.debian.org/debian/pool...b9u6_amd64.deb 404 Not Found
                                          E: Einige Archive konnten nicht heruntergeladen werden; vielleicht »apt-get upda
                                          • Diginix
                                            Diginix @ostseereiter last edited by
                                            @ostseereiter Die Fehlermeldungen besagen, dass dein System entweder den Server mit den Systemupdates nicht erreicht oder die Adressen nicht stimmen. Das hat nichts mit dem radar Adapter zu tun. Bei dir sind ja schon 25 Pakete veraltet, also hast du länger keine Systemupdate gemacht. Internetzugriff hat dein System?
                                            ostseereiter 1 Reply Last reply Reply Quote 0
                                            adapter radar2 adapter
                                            80
                                            840
                                            231982
