    4. Update VIS 1.1.10 auf 1.2.0 Error 10
    UNSOLVED Update VIS 1.1.10 auf 1.2.0 Error 10
    • Negalein
      Negalein Global Moderator @apollon77 last edited by Negalein
      @apollon77 sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
      ich frage mal frech: Genug Plattenplatz ist frei und so?
      Ja, mehrere TB 🙂
      Führe doch mal
      npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker"
      manuell an der Kommandozeile aus
      root@ioBroker:/opt/iobroker# npm install iobroker.vis@1.1.10 --production --save --prefix "/opt/iobroker"
      > iobroker.vis@1.1.10 install /opt/iobroker/node_modules/iobroker.vis
      > node main.js --install
      module.js:550
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.vis/main.js'
          at Function.Module._resolveFilename (module.js:548:15)
          at Function.Module._load (module.js:475:25)
          at Function.Module.runMain (module.js:694:10)
          at startup (bootstrap_node.js:204:16)
          at bootstrap_node.js:625:3
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darw
      in","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arc
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.vis@1.1.10 install: `node main.js --install`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.vis@1.1.10 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR!     /root/.npm/_logs/2019-05-08T21_48_42_503Z-debug.log
      Log von /root/.npm/_logs/2019-05-08T21_48_42_503Z-debug.log
      • Stabilostick
        Stabilostick last edited by Stabilostick
        Hmm, da steht auch nur drin:
        108 silly lifecycle iobroker.vis@1.1.10~install: Args: [ '-c', 'node main.js --install' ]
        112 silly lifecycle iobroker.vis@1.1.10~install: Returned: code: 1  signal: null
        113 info lifecycle iobroker.vis@1.1.10~install: Failed to exec install script
        Vielleicht im iobroker Ordner
        npm i iobroker.vis@1.1.10 --production --force
        ausführen?
          Bitte nicht mit alten Versionen dinge tun, die 1.2.0 ist aktuell.
          Also ich habe es bei mir manuell gemacht und bei mir ist alles da.
          Bei Dir scheint im Verzeichnis iobroker.is die main,js zu fehlen nach dem entpacken ... und das kann an sich nicht sein. Irgendwas st da bei dir gerade komisch. Kann da irgendwas mit Docker dazwischenfunken?
          • Negalein
            Negalein Global Moderator @Stabilostick last edited by
            @Stabilostick sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
            ausführen?
            DANKE
            Jetzt ist zumindest die 1.1.10 wieder als installiert zu sehen.
            root@ioBroker:/opt/iobroker# npm i iobroker.vis@1.1.10 --production --force
            npm WARN using --force I sure hope you know what you are doing.
            > osx-temperature-sensor@1.0.3 install /opt/iobroker/node_modules/osx-temperature-sensor
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird betreten
              SOLINK_MODULE(target) Release/obj.target/none.node
              COPY Release/none.node
            make: Verzeichnis „/opt/iobroker/node_modules/osx-temperature-sensor/build“ wird verlassen
            > xpc-connection@0.1.4 install /opt/iobroker/node_modules/xpc-connection
            > node-gyp rebuild
            make: Verzeichnis „/opt/iobroker/node_modules/xpc-connection/build“ wird betreten
              SOLINK_MODULE(target) Release/obj.target/binding.node
              COPY Release/binding.node
            make: Verzeichnis „/opt/iobroker/node_modules/xpc-connection/build“ wird verlassen
            + iobroker.vis@1.1.10
            added 3 packages from 4 contributors and audited 33920 packages in 114.152s
            found 70 vulnerabilities (43 low, 4 moderate, 23 high)
              run `npm audit fix` to fix them, or `npm audit` for details
            • Stabilostick
              Dann versuche doch gleich das Update auf die neue Version nocheinmal.
              • Negalein
                Hmmm, beim Docker hab ich aktuell nur 2 Probleme, die ich noch vernachlässigen kann.
                1. ich bekomme zB beim Update vom JS-Controller die Meldung "sudo: Hostname ioBroker kann nicht aufgelöst werden"
                2. den Javascriptadapter bekomm ich nicht auf 4.1.12
                Sonst funktionieren immer alle Adapterupdates.
                  @Negalein sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
                  und warum?
                  • Negalein
                    Wieder das selbe Problem.
                    VIS scheint unter Adapter nicht installiert auf.
                    $ ./iobroker upgrade vis
                    Update vis from @1.1.10 to @1.2.0
                    NPM version: 6.4.1
                    npm install iobroker.vis@1.2.0 --production --save --prefix "/opt/iobroker" (System call)
                    module.js:550    throw err;
                    npm
                     ERR! code ELIFECYCLEnpm ERR! errno 1
                    npm
                     ERR! iobroker.vis@1.2.0 install: `node main.js --install`npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the iobroker.vis@1.2.0 install script.
                    npm
                    ERR!     /root/.npm/_logs/2019-05-08T22_09_52_789Z-debug.log
                    ERROR: Cannot find io-package.json in null
                    ERROR: process exited with code 10
                      machs mal wieder manuell mit dem --force
                      • Negalein
                        und warum?
                        Gibt schon seit einiger Zeit ein Thema darüber. Leider ohne Lösung.
                        • Stabilostick
                          Und hast Du bei der Einrichtung des Containers z.B. auf Synology die Einstellung „dasselbe Netzwerk wie Docker Host verwenden“ ausgewählt? Das vermeidet Probleme mit dem Hostnamen.
                          • Negalein
                            Danke jungs
                            Jetzt bin ich auf 1.2.0 lt. Adapter
                            Im VIS-Edit scheint zwar noch oben links die 1.1.10 auf.
                            Stabilostick 2 Replies Last reply Reply Quote 0
                            • Stabilostick
                              Stabilostick @Negalein last edited by
                              @Negalein
                              Mache das gleiche bei JavaScript.
                              • Negalein
                                Ja, ich bin da 1:1 nach der Anleitung von Buanet vorgegangen.
                                Wenn ich in die Hosts meine IP und den Namen der Syno eintrage, verschwindet dieser Eintrag spätestens beim 1. ausgeführten Befehl.
                                Stabilostick 1 Reply Last reply Reply Quote 0
                                • Negalein
                                  Negalein Global Moderator @Stabilostick last edited by Negalein
                                  @Negalein
                                  schon dabei 🙂
                                  EDIT: Suuuuuuuper
                                  4.1.12 läuft
                                  • Stabilostick
                                    @Negalein
                                    ? In der Anleitung von B. sehe ich nichts von hosts...
                                    • Negalein
                                      @Negalein
                                      Abschnitt 3
                                      Achtung! Wie es ausschaut hat sich innerhalb des Docker Pakets von Synology etwas in Bezug auf den Hostnamen geändert. Wurde bisher der Hostname der DS verwendet, so wird ab sofort im Container der Name des Containers verwendet. Da ioBroker auf den Hostnamen „geschlüsselt“ ist, kann es sein dass nach dem Update des Containers die ioBroker Adapter nicht mehr starten. Um dies zu korrigieren reicht es folgende Schritte aus zu führen:
                                      cd /opt/iobroker
                                      pkill io
                                      iobroker host this (bei multihostsystemen: iobroker host [hostname der ds])
                                      node node_modules/iobroker.js-controller/controller.js >/opt/scripts/docker_iobroker_log.txt 2>&1 &
                                      Abschnitt 4 steht auch zB
                                      Schritt 3: ioBroker für den Start auf neuem System vorbereiten und starten
                                      An dieser Stelle ist ioBroker noch nicht lauffähig, da sich mit dem Umzug auf die DS in der Regel auch der Hostname geändert hat. Um ioBroker den neuen Hostname mit zu teilen reicht ein einfacher Befehl, ausgeführt im ioBroker-Verzeichnis über das Terminal des Docker-Containers:
                                      cd /opt/iobroker
                                      iobroker host this
                                      • Stabilostick
                                        Kenne mich da mit 1.2.0 nicht aus, aber schlimmer wird es damit nicht:
                                        iobroker upload vis.0
                                        im ioBroker-Ordner auf Verdacht ausführen.
                                        sigi234 Negalein 2 Replies Last reply Reply Quote 0
                                          sigi234 Forum Testing Most Active @Stabilostick last edited by
                                          Ja, beim starten von Vis muss dann eine Meldung kommen mit : update found........
                                          • Negalein
                                            Und da komm dann auch gleich der Fehler mit Hostname iobroker
                                            root@ioBroker:/opt/iobroker# iobroker upload vis.0
                                            module.js:550
                                                throw err;
                                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                            PS: war über die Konsole
                                            Über den Admin mach ich es gerade und scheint zu funktionieren.
                                            Yes, ist durchgelaufen.
                                            $ ./iobroker upload vis
                                            got /opt/iobroker/node_modules/iobroker.vis/admin
                                            upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                            upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                            upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                            upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                            Update "system.adapter.vis.0"
                                            Adapter "system.adapter.vis.0" restarted.
                                            got /opt/iobroker/node_modules/iobroker.vis/www
                                            upload [900] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/clockbg6.png widgets/timeandweather/img/clock/clockbg6.png image/png
                                            upload [850] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/3-2.png widgets/timeandweather/img/clock/3-2.png image/png
                                            upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
                                            upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/rgraph/img/Prev_gauge.png widgets/rgraph/img/Prev_gauge.png image/png
                                            upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/players/img/winamp/asc.gif widgets/players/img/winamp/asc.gif image/gif
                                            upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/fonts/iconFont.dev.svg widgets/metro/fonts/iconFont.dev.svg image/svg+xml
                                            upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_10.svg widgets/jqui-mfd/img/sani_valve_10.svg image/svg+xml
                                            upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_90.png widgets/jqui-mfd/img/fts_shutter_90.png image/png
                                            upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
                                            upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/google-fonts/fonts/Ubuntu/Ubuntu-Italic.ttf widgets/google-fonts/fonts/Ubuntu/Ubuntu-Italic.ttf font/ttf
                                            upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/google-fonts/fonts/Indie_Flower/IndieFlower.ttf widgets/google-fonts/fonts/Indie_Flower/IndieFlower.ttf font/ttf
                                            upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/fancyswitch/img/ibutton-slider-giva2.png widgets/fancyswitch/img/ibutton-slider-giva2.png image/png
                                            upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/js/table.js widgets/basic/js/table.js application/javascript
                                            upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars.html widgets/bars.html text/html
                                            upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
                                            upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
                                            upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
                                            upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
                                            upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
                                            upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
                                            upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
                                            upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
                                            upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
                                            upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
                                            upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
                                            upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
                                            upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                                            upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
                                            upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
                                            upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
                                            upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
                                            upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
                                            upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
                                            upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
                                            upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
                                            upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
                                            upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
                                            upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
                                            upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
                                            upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
                                            upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
                                            upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
                                            upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
                                            upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
                                            upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                            process exited with code 0
                                            Liegt es am Befehl?
                                            iobroker upload vis.0 gegen $ ./iobroker upload vis
                                            1.2k
                                            81.1k
                                            error update vis
                                            3056
