    4. Update VIS 1.1.10 auf 1.2.0 Error 10
    UNSOLVED Update VIS 1.1.10 auf 1.2.0 Error 10
    • Negalein
      Negalein Global Moderator @Stabilostick last edited by Negalein
      @Stabilostick sagte in Update VIS 1.1.10 auf 1.2.0 Error 10:
      iobroker upload vis.0
      Und da komm dann auch gleich der Fehler mit Hostname iobroker
      root@ioBroker:/opt/iobroker# iobroker upload vis.0
      sudo: Hostname ioBroker kann nicht aufgelöst werden
      module.js:550
          throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (module.js:548:15)
          at Function.Module._load (module.js:475:25)
          at Function.Module.runMain (module.js:694:10)
          at startup (bootstrap_node.js:204:16)
          at bootstrap_node.js:625:3
      PS: war über die Konsole
      Über den Admin mach ich es gerade und scheint zu funktionieren.
      Yes, ist durchgelaufen.
      $ ./iobroker upload vis
      got /opt/iobroker/node_modules/iobroker.vis/admin
      upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
      upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
      upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
      upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
      Update "system.adapter.vis.0"
      Adapter "system.adapter.vis.0" restarted.
      got /opt/iobroker/node_modules/iobroker.vis/www
      upload [900] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/clockbg6.png widgets/timeandweather/img/clock/clockbg6.png image/png
      upload [850] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/timeandweather/img/clock/3-2.png widgets/timeandweather/img/clock/3-2.png image/png
      upload [800] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/tabs/styles/images/rightArrow.png widgets/tabs/styles/images/rightArrow.png image/png
      upload [750] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/rgraph/img/Prev_gauge.png widgets/rgraph/img/Prev_gauge.png image/png
      upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/players/img/winamp/asc.gif widgets/players/img/winamp/asc.gif image/gif
      upload [650] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/metro/fonts/iconFont.dev.svg widgets/metro/fonts/iconFont.dev.svg image/svg+xml
      upload [600] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/sani_valve_10.svg widgets/jqui-mfd/img/sani_valve_10.svg image/svg+xml
      upload [550] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui-mfd/img/fts_shutter_90.png widgets/jqui-mfd/img/fts_shutter_90.png image/png
      upload [500] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/jqui/img/Prev_ContainerDialog.png widgets/jqui/img/Prev_ContainerDialog.png image/png
      upload [450] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/google-fonts/fonts/Ubuntu/Ubuntu-Italic.ttf widgets/google-fonts/fonts/Ubuntu/Ubuntu-Italic.ttf font/ttf
      upload [400] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/google-fonts/fonts/Indie_Flower/IndieFlower.ttf widgets/google-fonts/fonts/Indie_Flower/IndieFlower.ttf font/ttf
      upload [350] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/fancyswitch/img/ibutton-slider-giva2.png widgets/fancyswitch/img/ibutton-slider-giva2.png image/png
      upload [300] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/basic/js/table.js widgets/basic/js/table.js application/javascript
      upload [250] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/bars.html widgets/bars.html text/html
      upload [200] vis /opt/iobroker/node_modules/iobroker.vis/www/lib/js/jquery.ba-resize.min.js lib/js/jquery.ba-resize.min.js application/javascript
      upload [150] vis /opt/iobroker/node_modules/iobroker.vis/www/js/visEditInspect.js js/visEditInspect.js application/javascript
      upload [100] vis /opt/iobroker/node_modules/iobroker.vis/www/js/fm/icon/actions/delete.png js/fm/icon/actions/delete.png image/png
      upload [90] vis /opt/iobroker/node_modules/iobroker.vis/www/index.html index.html text/html
      upload [80] vis /opt/iobroker/node_modules/iobroker.vis/www/img/faviconEdit.png img/faviconEdit.png image/png
      upload [70] vis /opt/iobroker/node_modules/iobroker.vis/www/img/bulbOn.png img/bulbOn.png image/png
      upload [60] vis /opt/iobroker/node_modules/iobroker.vis/www/img/back/oblique-line-bk.png img/back/oblique-line-bk.png image/png
      upload [50] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/timestamp.png icon/timestamp.png image/png
      upload [40] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/ok.png icon/ok.png image/png
      upload [30] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/distribute-vertical-equal.png icon/distribute-vertical-equal.png image/png
      upload [20] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-width.png icon/align-width.png image/png
      upload [19] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-top-2.png icon/align-vertical-top-2.png image/png
      upload [18] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
      upload [17] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-bottom-2.png icon/align-vertical-bottom-2.png image/png
      upload [16] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-right-2.png icon/align-horizontal-right-2.png image/png
      upload [15] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-left.png icon/align-horizontal-left.png image/png
      upload [14] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-horizontal-center-2.png icon/align-horizontal-center-2.png image/png
      upload [13] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-height.png icon/align-height.png image/png
      upload [12] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/add.png icon/add.png image/png
      upload [11] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.src.html edit.src.html text/html
      upload [10] vis /opt/iobroker/node_modules/iobroker.vis/www/edit.html edit.html text/html
      upload [9] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis.css css/vis.css text/css
      upload [8] vis /opt/iobroker/node_modules/iobroker.vis/www/css/vis-editor.css css/vis-editor.css text/css
      upload [7] vis /opt/iobroker/node_modules/iobroker.vis/www/css/styles.css css/styles.css text/css
      upload [6] vis /opt/iobroker/node_modules/iobroker.vis/www/css/montserrat-regular-webfont.woff css/montserrat-regular-webfont.woff font/woff
      upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/css/doc.css css/doc.css text/css
      upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/css/backgrounds.css css/backgrounds.css text/css
      upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/css/app.css css/app.css text/css
      upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/css/add_kian.css css/add_kian.css text/css
      upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/cordova.js cordova.js application/javascript
      upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
      process exited with code 0
      Liegt es am Befehl?
      iobroker upload vis.0 gegen $ ./iobroker upload vis
      • Stabilostick
        Stabilostick last edited by Stabilostick
        Was bringt der Befehl
        hostname
        ioBroker?
        • Negalein
          hostname
          root@ioBroker:/opt/iobroker# hostname
          • Negalein
            Vis-Edit zeigt jetzt links oben 1.2.0 🙂
            • Stabilostick
              Heist der Container so? Was passiert, wenn Du in so nennst, wie deine Diskstation heißt? (Wieder auf Verdacht)
              • Negalein
                Genau.
                Der Container heißt ioBroker
                Werde ihn morgen mal umbenennen.
                • Stabilostick
                  Warte mal. Siehe z.B. https://debianforum.de/forum/viewtopic.php?t=147575
                  Kenne mich mit Docker nicht aus, aber die Zeile
                  127.0.0.1 ioBroker
                  in die /etc/hosts-Datei einfügen?
                  • Negalein
                    Die Hosts schaut bei mir so aus
                    # Any manual change will be lost if the host name is changed or system upgrades.
                    127.0.0.1       localhost
                    ::1             localhost
                    127.0.0.1       Synology_Nega_3
                    ::1             Synology_Nega_3
                    • Stabilostick
                      Mach wie oben geschrieben die zwei Zeilen mit ioBroker.
                      Und dann mal einen
                      ping ioBroker
                      • Negalein
                        Also so
                        127.0.0.1       ioBroker
                        ::1             localhost
                        127.0.0.1       ioBroker
                        ::1             Synology_Nega_3
                        • Stabilostick
                          127.0.0.1       localhost
                          ::1             localhost
                          ::1             Synology_Nega_3
                          127.0.0.1       ioBroker
                          ::1             ioBroker
                          Oder
                          127.0.0.1       localhost Synology_Nega_3 ioBroker
                          ::1             localhost Synology_Nega_3 ioBroker
                          • Negalein
                            127.0.0.1       localhost
                            ::1             localhost
                            ::1             Synology_Nega_3
                            127.0.0.1       ioBroker
                            ::1             ioBroker
                            Ok, habs so gespeichert
                            • Stabilostick
                              Jetzt den Ping, wenn ok dann zum Test nochmal den vis-Upload über die Konsole. Fehler noch da?
                              • Negalein
                                Jetzt den Ping, wenn ok dann zum Test nochmal den vis-Upload. Fehler noch da?
                                Ping geht nicht.
                                Ich werde ioBroker mal neu starten und dann nochmal testen.
                                • Stabilostick
                                  Du machst es spannend... 😎
                                  • Negalein
                                    C:\WINDOWS\system32>ping iobroker
                                    Ping-Anforderung konnte Host "iobroker" nicht finden. Überprüfen Sie den Namen, und versuchen Sie es erneut.
                                    • Stabilostick
                                      Du hast das B kleingeschrieben.
                                      • Negalein
                                        bringt auch keine Änderung
                                        C:\WINDOWS\system32>ping ioBroker
                                        Ping-Anforderung konnte Host "ioBroker" nicht finden. Überprüfen Sie den Namen, und versuchen Sie es erneut.
                                        • Stabilostick
                                          Hmm, geht der Ping auf Synology_Nega_3?
                                          • Negalein
                                            Nein, geht auch nicht.
                                            Mit IP aber schon
                                            1.2k
                                            81.1k
                                            error update vis
                                            3056
