    4. Adapter: ioBroker.info
    • ldittmar
      ldittmar Developer @SBorg last edited by
      @SBorg Ahh... ok... kannst du mir bitte deine komplette Ausgabe posten, wenn du "sensors" in der Console eingibst? Da ist bestimmt ein Fehler beim Parsen... ich schaue es mir mal an. ✌
      • SBorg
        War eigentlich oben schon alles, hatte nur die Spg. gekürzt:
        coretemp-isa-0000
        Adapter: ISA adapter
        Core 0:       +44.0°C  (crit = +100.0°C)
        Core 1:       +45.0°C  (crit = +100.0°C)
        w83627uhg-isa-0290
        in0:          +1.19 V  (min =  +0.00 V, max =  +1.74 V)
        in1:          +1.02 V  (min =  +1.42 V, max =  +0.02 V)  ALARM
        AVCC:         +4.92 V  (min =  +4.49 V, max =  +5.49 V)
        +5V:          +4.93 V  (min =  +4.49 V, max =  +5.51 V)
        in4:          +1.02 V  (min =  +0.53 V, max =  +0.50 V)  ALARM
        in5:          +1.50 V  (min =  +0.24 V, max =  +0.86 V)  ALARM
        5VSB:         +4.92 V  (min =  +4.49 V, max =  +5.49 V)
        Vbat:         +3.30 V  (min =  +2.69 V, max =  +3.64 V)
        fan1:           0 RPM  (min = 10546 RPM, div = 128)  ALARM
        fan2:           0 RPM  (min = 10546 RPM, div = 128)  ALARM
        SYSTIN:       +42.0°C  (high = +37.0°C, hyst = +111.0°C)  sensor = thermal diode
        CPUTIN:       +35.5°C  (high = +80.0°C, hyst = +75.0°C)  sensor = thermal diode
        intrusion0:  ALARM
        oder RAW:
        coretemp-isa-0000
        Core 0:
        temp2_input: 44.000
        temp2_crit: 100.000
        temp2_crit_alarm: 0.000
        Core 1:
        temp3_input: 45.000
        temp3_crit: 100.000
        temp3_crit_alarm: 0.000
        w83627uhg-isa-0290
        in0:
        in0_input: 1.192
        in0_min: 0.000
        in0_max: 1.744
        in0_alarm: 0.000
        in1:
        in1_input: 1.024
        in1_min: 1.424
        in1_max: 0.016
        in1_alarm: 1.000
        AVCC:
        in2_input: 4.925
        in2_min: 4.493
        in2_max: 5.491
        in2_alarm: 0.000
        +5V:
        in3_input: 4.931
        in3_min: 4.485
        in3_max: 5.513
        in3_alarm: 0.000
        in4:
        in4_input: 1.016
        in4_min: 0.528
        in4_max: 0.504
        in4_alarm: 1.000
        in5:
        in5_input: 1.496
        in5_min: 0.240
        in5_max: 0.856
        in5_alarm: 1.000
        5VSB:
        in7_input: 4.925
        in7_min: 4.493
        in7_max: 5.491
        in7_alarm: 0.000
        Vbat:
        in8_input: 3.298
        in8_min: 2.686
        in8_max: 3.638
        in8_alarm: 0.000
        fan1:
        fan1_input: 0.000
        fan1_min: 10546.000
        fan1_alarm: 1.000
        fan1_div: 128.000
        fan2:
        fan2_input: 0.000
        fan2_min: 10546.000
        fan2_alarm: 1.000
        fan2_div: 128.000
        SYSTIN:
        temp1_input: 41.000
        temp1_max: 37.000
        temp1_max_hyst: 111.000
        temp1_alarm: 0.000
        temp1_type: 3.000
        temp1_offset: 0.000
        CPUTIN:
        temp2_input: 35.500
        temp2_max: 80.000
        temp2_max_hyst: 75.000
        temp2_alarm: 0.000
        temp2_type: 3.000
        temp2_offset: 0.000
        intrusion0:
        intrusion0_alarm: 1.000
        ldittmar 1 Reply Last reply Reply Quote 0
        • ldittmar
          @SBorg Kannst du mir noch bitte sagen, ob die Werte im Objekte-Baum angezeigt werden?
          • SBorg
            Nö, glänzt durch gänzliche Leere 🙂
            • ldittmar
              @SBorg Ahh... ja... Das Problem war, dass bei dir die Haupttemperatur nicht vom cotetemp-isa ausgegeben wird, sondern nur die Temperatur pro core. Ich bin davon ausgegangen, dass die Haupttemperatur immer dabei ist (wieder was gelernt) und geprüft ob da ein Wert drin ist. Wenn nicht habe ich dann halt nichts angezeigt. Ich habe es jetzt in der Github Version gefixt... Beim nächsten Update ist das auch dabei.
              Für die anderen Informationen aus lm-sensors existiert schon ein Issue. Es wird also daran gearbeitet und dann wird auch CPUTIN und SYSTIN berücksichtigt werden. https://github.com/sebhildebrandt/systeminformation/issues/220
              ldittmar81 created this issue in sebhildebrandt/systeminformation
              open Get more Informations from lm-sensors #220
              BBTown 1 Reply Last reply Reply Quote 1
              • SBorg
                Thx, Intel Atom Dual-Core halt...^^
                • BBTown
                  BBTown @ldittmar last edited by BBTown
                  @ldittmar puhhhh .... im Augenblick habe ich den Info-Adapter nicht mehr lieb 😞
                  Be jedem Aufruf oder refresh einer meiner ioBroker Seiten kommt eine nervige Warnung bzgl. des Z-Waves Adapters hoch.
                  Davon mal abgesehen, dass ich diesen Adapter überhaupt nicht benutze, wäre ja ein einmaliger Hinweis in Ordnung, aber bei jedem Seitenaufruf???
                  Ich habe den Adapter daher erst einmal deaktiviert - das nervt mich zu sehr 😞
                  [Nachtrag]
                  hmmm ... tue ich dem Adapter unrecht, kommen die nervigen Hinweise gar nicht vom Info-Adapter?
                  Oder muss ich den sogar entfernen, damit das aufhört?
                  ... so kann ich zumindest nicht mit ioBroker arbeiten ;-(
                  ldittmar Dutchman 2 Replies Last reply Reply Quote 0
                  • ldittmar
                    ldittmar Developer @BBTown last edited by
                    @BBTown das ist ein Bug irgendwo im System. Wir sind dran es zu beheben. Die Meldungen verschwinden nach einer Zeit automatisch. Wir werden erstmal keine neue Nachrichten hinzufügen, bis die Ursache gefunden worden ist. Sorry....
                    • Dutchman
                      Dutchman Developer Most Active Administrators @BBTown last edited by
                      @BBTown sagte in Adapter: ioBroker.info:
                      ich habe soeben die News gelöscht damit solltet ihr in 15-20 min das popup nicht mehr bekommen.
                      Eigentlich sollte das pop-up nur einmal kommen und nach bestätigen nicht mehr, da geht aber leider etwas schief.
                      Entschuldigt bitte de Unannehmlichkeiten die hierdurch entstanden sind
                      ~ Dutch
                        liv-in-sky last edited by
                        sorry für die frage, aber wo sollte den dieses popup erscheinen - ich sehe die fehlermeldung nur im infoadapter
                        ich habe die popups in chrome für iobroker blockiert - hat das damit zu tun, dass ich diese nicht sehe
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @liv-in-sky last edited by
                          @liv-in-sky sagte in Adapter: ioBroker.info:
                            liv-in-sky @bahnuhr last edited by liv-in-sky
                            @bahnuhr das habe ich nicht gemeint - da seh ich es auch so wie abgebildet - weiter oben wird aber von popups gesprochen,
                            ich würde das gut finden, wenn ein popup kommt bei einer solchen warnung - mein browser ist meist den ganzen tag offen - ich hätte die warnung garnicht gesehen, wenn ich nicht zufällig im infoadapter nachgeschaut hätte, was es für updates gibt
                            • bahnuhr
                              Also ich hab nur diese meldung.
                              Popups hab ich nicht.
                              mfg
                                @bahnuhr 🙂 ich ja auch nicht - deshalb frage ich ja
                                vor ein paaar tagen hatte die cloud ein problem - kann vorkommen - ist kein problem - aber es wäre toll gewesen, darüber auch so eine nachricht zu bekommen und/oder ein ein popup im browser.
                                • Bluemoon
                                  Bluemoon last edited by Bluemoon
                                  Hier habe ich die Meldung, sie kommt mehrmals am Tag!
                                  Man muss nicht im Info Tab sein, da würde sie gleich kommen.
                                  liv-in-sky bahnuhr 2 Replies Last reply Reply Quote 0
                                    liv-in-sky @Bluemoon last edited by
                                    @Bluemoon hast du mal die nachrichten im browser blockiert ?
                                    Bluemoon 1 Reply Last reply Reply Quote 0
                                    • Bluemoon
                                      Bluemoon @liv-in-sky last edited by
                                      @liv-in-sky
                                      nein, habe ich noch nicht
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @Bluemoon last edited by
                                        @Bluemoon sagte in Adapter: ioBroker.info:
                                        Also so ne Meldung hatte ich noch nicht.
                                        Benutze primär Chrome.
                                        Wüsste aber auch nicht, dass ich irgendein Blocker aktiviert habe.
                                          wenn man in chrome darauf klickt - kann man popups blockieren (webseite einstellung)
                                          • bahnuhr
                                            tatsächlich!
                                            Ist bei mir offensichtlich blockiert.
                                            Dann hat das aber chrome blockiert, oder?
                                            wahrscheinlich wg. dem "Nicht sicher", richtig ?
                                            mfg
                                            31.7k
                                            79.8k
                                            info adapter
                                            53
                                            350
                                            52122
