    4. Test Adapter MercedesMe v0.0.x
    • BBTown
      BBTown @tombox last edited by
      @tombox sagte in [Aufruf] Mecedes me Adapter:
      Browser Cache oder iobroker neustarten
      das hat ihn beides nicht sonderlich beeindruckt
        tombox @BBTown last edited by
        @BBTown Was passiert auf der Konsole bei ./iobroker url "https://github.com/TA2k/iobroker.mercedesme"
        BBTown 2 Replies Last reply Reply Quote 0
        • BBTown
          Auf welcher Konsole?
          • BBTown
            @tombox Bitte nicht steinigen ... einmal kurz den PiHole deaktiviert und schon funktionierte das Update ... da werde ich wohl mal meine WhiteList ergänzen müssen 😕
              mrx last edited by
              Hallo
              also bei mir kommt nach dem starten
              host.raspberrypi 2019-05-10 18:28:55.492 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
              Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
              Caught 2019-05-10 18:28:55.492 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
              Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
              Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              Caught 2019-05-10 18:28:55.492 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
              Caught 2019-05-10 18:28:55.492 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
              Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
              Caught 2019-05-10 18:28:55.491 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
              Caught 2019-05-10 18:28:55.491 error by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
              Caught 2019-05-10 18:28:55.490 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
              Caught 2019-05-10 18:28:55.489 error by controller[0]: TypeError: Cannot read property 'val' of undefined
              mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
              mercedesme.0 2019-05-10 18:28:54.368 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
              mercedesme.0 2019-05-10 18:28:54.368 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
              mercedesme.0 2019-05-10 18:28:54.368 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
              mercedesme.0 2019-05-10 18:28:54.368 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
              mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
              mercedesme.0 2019-05-10 18:28:54.368 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
              mercedesme.0 2019-05-10 18:28:54.368 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
              mercedesme.0 2019-05-10 18:28:54.368 error at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4612:61)
              mercedesme.0 2019-05-10 18:28:54.368 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:205:88)
              mercedesme.0 2019-05-10 18:28:54.368 error TypeError: Cannot read property 'val' of undefined
              mercedesme.0 2019-05-10 18:28:54.367 error uncaught exception: Cannot read property 'val' of undefined
              und der adapter wird rot er hat sich aber einige daten gezogen.
              nodejs ist aktuell 1.5.8
              gruss
              stefan
              • BBTown
                BBTown @mrx last edited by BBTown
                @mrx ja, diese Fehler kommen bei mir ebenfalls
                [Nachtrag]
                und dann startet der Adapter auch neu durch
                  kannst du mal ein screenshot von den DOORLOCK_STATUS und PRECONDITIONING_DATA Objekten machen
                    SpS @tombox last edited by
                    @tombox leider nein - hab auf V0.3 umgestellt und bekomme den gleichen Fehler wie @mrx .
                      @mrx said in [Aufruf] Mecedes me Adapter:
                      205
                      Bitte den Adapter neuinstallieren und nochmal probieren
                        @tombox Auch nach Neuinstallation immer noch gleicher Fehler. Allerdings bekomme ich auch beim Login über Safari folgenden Fehler. Bei Firefox jedoch kann ich mich beim Mercedes.me Portal anmelden. Screenshot 2019-05-10 20.20.39.png
                          tombox @SpS last edited by
                          @SpS exakt der gleiche Fehler kann eigentlich nicht sein dann nochmal installiere
                            @tombox
                            host.RASPioBroker 2019-05-10 20:38:28.352 info Restart adapter system.adapter.mercedesme.0 because enabled
                            host.RASPioBroker 2019-05-10 20:38:28.352 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                            host.RASPioBroker 2019-05-10 20:38:28.352 error Caught by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                            host.RASPioBroker 2019-05-10 20:38:28.351 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                            host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240)
                            host.RASPioBroker 2019-05-10 20:38:28.350 error Caught by controller[0]: TypeError: Cannot read property 'val' of null
                            mercedesme.0 2019-05-10 20:38:27.316 error TypeError: Cannot read property 'val' of null at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:240) at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:
                            mercedesme.0 2019-05-10 20:38:27.314 error uncaught exception: Cannot read property 'val' of null
                            mercedesme.0 2019-05-10 20:38:20.838 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                            host.RASPioBroker 2019-05-10 20:38:16.310 info instance system.adapter.mercedesme.0 started with pid 813
                            host.RASPioBroker 2019-05-10 20:38:13.850 info instance system.adapter.mercedesme.0 terminated with code 0 (OK)
                            mercedesme.0 2019-05-10 20:38:13.796 info terminating
                            host.RASPioBroker 2019-05-10 20:38:13.785 info stopInstance system.adapter.mercedesme.0 killing pid 766
                              @SpS Den Fehler habe ich auch abgefangen. Nochmal installieren. Aber irgendwas anderes stimmt da nicht.
                              Wie sehen deine Objekte für den Adapter aus?
                                @tombox
                                Adapter deinstalliert, ioBroker neu gestartet, Adapter neu installiert. Instanz angelegt und konfiguriert.
                                Objekte hab ich nur die oberste Ebene mit FIN/Autonummer
                                Logfile:
                                host.RASPioBroker 2019-05-10 21:14:51.717 info Restart adapter system.adapter.mercedesme.0 because enabled
                                host.RASPioBroker 2019-05-10 21:14:51.717 error instance system.adapter.mercedesme.0 terminated with code 6 (uncaught exception)
                                Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                Caught 2019-05-10 21:14:51.716 error by controller[0]: at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                Caught 2019-05-10 21:14:51.716 error by controller[0]: at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                                Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                Caught 2019-05-10 21:14:51.715 error by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                Caught 2019-05-10 21:14:51.715 error by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                Caught 2019-05-10 21:14:51.714 error by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                Caught 2019-05-10 21:14:51.714 error by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                                Caught 2019-05-10 21:14:51.713 error by controller[0]: at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                                Caught 2019-05-10 21:14:51.712 error by controller[0]: TypeError: Cannot read property 'val' of null
                                mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
                                mercedesme.0 2019-05-10 21:14:50.660 error at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
                                mercedesme.0 2019-05-10 21:14:50.660 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4332:61
                                mercedesme.0 2019-05-10 21:14:50.660 error at getStates (/opt/iobroker/node_modules/iobroker.mercedesme/main.js:208:310)
                                mercedesme.0 2019-05-10 21:14:50.660 error TypeError: Cannot read property 'val' of null
                                mercedesme.0 2019-05-10 21:14:50.658 error uncaught exception: Cannot read property 'val' of null
                                mercedesme.0 2019-05-10 21:14:43.702 info starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.mercedesme, node: v8.11.4
                                host.RASPioBroker 2019-05-10 21:14:39.695 info instance system.adapter.mercedesme.0 started with pid 1070
                                host.RASPioBroker 2019-05-10 21:14:09.669 info Restart adapter system.adapter.mercedesme.0 because enabled
                                  bitte nochmal installieren
                                    @tombox 🙂
                                    Jetzt hab ich keine Fehler mehr im Log und DoorLock auf/zu geht. Vorklimatisierung geht nicht (Wert wird nicht bestätigt und Standheizung geht nicht an).
                                      tombox @SpS last edited by tombox
                                      @SpS kannst du mir ein screenshot von den objekten in PRECONDITIONING_DATA schicken auch als private nachricht.
                                      Wie heißt der Punkt auf der mercedes me webseite? Programmierung Ladeeinstellungen und Vorklimatisierung?
                                        SpS @tombox last edited by SpS
                                        @tombox Objekt PRECONDITIONING_DATA gibt es bei mir nicht - Vermutlich gibt es das nur bei Elektrofahrzeugen und hat nichts mit Standheizung zu tun.
                                        Vorklimatisierung ist dort die Möglichkeit das Fahrzeug beim Laden auch im Innenraum zu Kühlen/Heizen.
                                          @SpS Aber DOORLOCK_STATUS hast du schon?
                                          Dann benötige ich Zugang zu einem Account oder per Fernwartung kurzen Zugriff auf ein Account
                                          Du kannst ja über die mercedes me webseite die standheizung einschalten oder?
                                            mrx last edited by
                                            also fehlermeldung ist weg und den punkt PRECONDITIONING_DATA hab ich auch nicht,
                                            DOORLOCK_STATUS hab ich
                                            1.0k
                                            mercedes
                                            120
                                            935
                                            243170
