    3. Entwicklung
    4. Mieleathome Adapter
    Mieleathome Adapter
    • siggi85
      siggi85 last edited by
      Habe endlich die Daten von Miele Developer erhalten (am 12.04 angefragt), jedoch habe ich nun folgende Fehler nachdem ich die Daten eingetragen habe.
      host.ioBroker	2019-04-29 20:21:36.092	info	Restart adapter system.adapter.mieleathome.0 because enabled
      host.ioBroker	2019-04-29 20:21:36.092	error	instance system.adapter.mieleathome.0 terminated with code 0 (OK)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at emitNone (events.js:111:20)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Object.onceWrapper (events.js:313:30)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.emit (events.js:211:7)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at emitOne (events.js:116:13)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.emit (events.js:214:7)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at emitTwo (events.js:126:13)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mieleathome/utils/mieleathome.js:229:22)
      Caught	2019-04-29 20:21:36.092	error	by controller[0]: TypeError: this.NRefreshToken is not a function
      Der Datenpunkt "mieleathome.0.Authorization.Authorized" steht auf true.
      S siggi85 2 Replies Last reply Reply Quote 0
        Seb0304 @siggi85 last edited by
        @siggi85 sagte in Mieleathome Adapter:
        Gleicher Fehler bei mir auch.
        • HomeZecke
          HomeZecke last edited by
          Ja, bei mir ebenso!
          Hat Miele was verändert? Oder sind die Zugangsdaten nur temporär?
            digiklopfer last edited by
            ich habe den gleichen Fehler.
            Ich habe Miele angeschrieben, mal abwarten, was und wann sie antworten.
            siggi85 1 Reply Last reply Reply Quote 0
            • siggi85
              siggi85 @digiklopfer last edited by
              @digiklopfer sagte in Mieleathome Adapter:
              Bei mir hat es über 2 Wochen gebraucht bis ich die Daten erhalten habe, und das obwohl sofort eine automatische Mail kam, dass sie innerhalb eines Business Day antworten. Mal schauen wann und was als Antwort kommt.
                und hier die Antwort von Miele....
                Der Adapter hat aber leider immer noch den gleichen Fehler
                Dear
                We’ve checked your credentials, they’re still valid and working.
                Within the last days we’ve some unforeseen server outages, meanwhile everything is working stable again.
                Please let us know if your account is still not working
                Kind regards
                Miele 3rd party API Team
                Lenny.CB 1 Reply Last reply Reply Quote 0
                • Lenny.CB
                  Lenny.CB Most Active @digiklopfer last edited by
                  @digiklopfer
                  ich selbst nutze nicht den Adapter, ich machen das mit einem Script. Wenn ich alles lösche und neu starte bekomme ich die "err.message" --> "Error: username/password is invalid"
                  Da dies Kombination aber an der APP funktioniert, gehe ich davon aus, dass das Problem bei Miele liegt.
                  Ich mutmaße, bei den Serverproblemen bei MIele ist was mit den API-Konten schief gegangen.
                  Das scheint ja bei allen ein Problem zu geben.
                    @Lenny-CB
                    das schätz ich auch, warten wir mal ab was noch passiert.
                    Mit was für einen Skript fragst du die Daten ab?
                    • Lenny.CB
                      Lenny.CB Most Active @digiklopfer last edited by Lenny.CB
                      @digiklopfer
                      Schau mal hier...
                      https://github.com/lennycb/miele
                      • siggi85
                        siggi85 @siggi85 last edited by
                        Habe weiterhin den Fehler. Habt ihr den auch noch? Liegt das nun an Miele oder ist was mit dem Adapter?!
                          Der Fehler ist bei mir auch noch. Miele hat sich bis jetzt dazu auch nicht mehr gemeldet.
                          • HomeZecke
                            Ja, bei mir auch. Ich denke da wird sich erst einmal nichts tun, hat sicherlich keine hohe Priorität dei Miele..☹
                            • siggi85
                              Habe jetzt auch mal Miele geschrieben...
                              • siggi85
                                Kurzes Statusupdate: Mailverlauf mit Miele.
                                13.5.:
                                Dear Siggi,
                                due to a server movement we’ve problems with some of our accounts.
                                May we ask you to help us finding the issue.
                                Please be so kind:
                                •      Generate a new access token
                                •      Send a new request to the API
                                •      If the failure still exist, please tell us the time of the day of your request.
                                Thank you very much for your support.
                                Kind regards
                                15.5.:
                                I generated a new token and send a few requests some minutes ago (7:23 my time). Same error. Do you see the requests?
                                Regards
                                  bei mir läuft der Adapter wieder wie gewohnt.
                                  • siggi85
                                    siggi85 @digiklopfer last edited by siggi85
                                    Bei mir sieht es auch besser aus.
                                      Seb0304 last edited by
                                      Keine Fehler mehr im Log beim Adapter.
                                      Das script von Lenny.CB läuft auch wieder.
                                      Gruß Sebastian
                                        mameier1234 last edited by
                                        Habt Ihr alle bei Miele nachgefragt, oder geht es einfach wieder ??
                                        Beim mir läuft weder das Script noch der Adapter... immer noch Tokenrefresh is not a funktion .. oder so....
                                        • siggi85
                                          siggi85 @mameier1234 last edited by
                                          @mameier1234 sagte in Mieleathome Adapter:
                                          Lösch Mal die Datenpunkte, dann erzeugt er neue Tokens etc.
                                          Ich kann nur vermuten, dass Miele was ändert hat, eine Mail dazu habe ich nicht bekommen.
                                            mameier1234 @siggi85 last edited by
                                            @siggi85
                                            Bingo, Danke für den Tipp!
                                            miele
                                            20
                                            144
                                            19400
