    4. [HowTo] ioBroker unter Docker auf Synology DiskStation
    • andre
      andre Developer @Negalein last edited by
      @Negalein Prozesse im Container laufen?
      • Negalein
        @andre
        Noch was zu meinem Problem.
        Mir ist gerade unter "Inspect" folgendes aufgefallen.
        Die Host-IP wird mit 0.0.0.0 angezeigt.
        Ist das normal?
        Networks
        bridge
        Aliases
        EndpointID fa65d56578df9cc51c67360869962f5c3c73b485192bbbc6cfd075f898b613fc
        Gateway 172.17.0.1
        GlobalIPv6Address
        GlobalIPv6PrefixLen 0
        IPAMConfig
        IPAddress 172.17.0.3
        IPPrefixLen 16
        IPv6Gateway
        Links
        MacAddress 02:42:ac:11:00:03
        NetworkID 1723637c0c2a8f40e46658c1e1f553adabdef300feab12ecca1a4efd5ac607b8
        Ports
        8081/tcp
        0
        HostIp 0.0.0.0
        HostPort 8850
        SandboxID b12254db70ea32df37a9d7e4204acb12e206e4336d837d72e6d16c6b1c8b1051
        SandboxKey /var/run/docker/netns/b12254db70ea
        SecondaryIPAddresses
        SecondaryIPv6Addresses
        Ja, Prozesse laufen. Mich hat Telegram auch jedesmal gleich begrüsst.
        UID PID PPID C STIME TTY TIME CMD
        root 7842 7825 0 May10 ? 00:00:00 /bin/bash /opt/scripts/iobroker_startup.sh
        root 8381 7842 0 May10 ? 00:00:00 sudo -u iobroker node node_modules/iobroker.js-controller/controller.js
        root 8382 7842 0 May10 ? 00:00:00 tail -f /dev/null
        1000 8384 8381 17 May10 ? 00:02:26 iobroker.js-controller
        1000 8473 8384 0 May10 ? 00:00:00 io.discovery.0
        1000 8544 8384 0 May10 ? 00:00:00 io.backitup.0
        1000 8565 8384 0 May10 ? 00:00:01 io.web.0
        1000 8656 8384 0 May10 ? 00:00:02 io.cloud.0
        1000 8740 8384 0 May10 ? 00:00:01 io.ping.0
        1000 9335 8384 0 May10 ? 00:00:00 io.socketio.0
        1000 9410 8384 0 May10 ? 00:00:00 io.denon.0
        1000 9427 8384 0 May10 ? 00:00:02 io.hs100.0
        1000 9502 8384 0 May10 ? 00:00:01 io.harmony.0
        1000 9583 8384 0 May10 ? 00:00:07 io.hue.0
        1000 9680 8384 0 May10 ? 00:00:01 io.fronius.0
        1000 9694 8384 0 May10 ? 00:00:01 io.alexa2.0
        1000 9770 8384 2 May10 ? 00:00:21 io.javascript.0
        1000 9783 8384 0 May10 ? 00:00:01 io.snmp.0
        1000 9866 8384 0 May10 ? 00:00:02 io.node-red.0
        1000 9986 8384 0 May10 ? 00:00:04 io.enigma2.0
        1000 10091 8384 1 May10 ? 00:00:07 io.info.0
        1000 10442 8384 0 May10 ? 00:00:05 io.synology.0
        1000 10529 8384 0 May10 ? 00:00:04 io.synology.1
        1000 10616 8384 0 May10 ? 00:00:04 io.synology.2
        1000 10796 8384 0 May10 ? 00:00:04 io.telegram.0
        1000 10870 8384 0 May10 ? 00:00:00 io.email.0
        1000 11055 8384 0 May10 ? 00:00:03 io.iot.0
        1000 11219 8384 0 May10 ? 00:00:03 io.upnp.0
        1000 11321 8384 0 May10 ? 00:00:01 io.parser.0
        1000 11415 8384 0 May10 ? 00:00:00 io.mihome.0
        1000 11503 8384 0 May10 ? 00:00:01 io.terminal.0
        1000 11593 8384 0 May10 ? 00:00:01 io.zigbee.0
        1000 11695 8384 0 May10 ? 00:00:00 io.scenes.0
        1000 11879 8384 0 May10 ? 00:00:02 io.virtualpowermeter.0
        1000 11964 8384 0 May10 ? 00:00:00 io.iqontrol.0
        • andre
          @Negalein mhh, kann ich so nicht bewerten. Bin nur noch am Smartphone online. Müsste ich sonst morgen mal schauen ob das bei ihr auch so ist... Sonst sieht es aber gut aus...
          Negalein 2 Replies Last reply Reply Quote 0
          • Negalein
            Negalein Global Moderator @andre last edited by
            @andre sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
            Danke, dann machen wir morgen weiter!
            Gute Nacht noch 🙂
            • dslraser
              @andre
              ich konnte es natürlich auch nicht lassen mich mal an Portainer zu versuchen. Leider erreiche ich nun bis auf die Portainer Oberfläche nix mehr und komme auch nicht so wirklich mit dem Netzwerk weiter.
              Docker kann ich zwar öffnen, aber ich komme nicht mehr an die Container um erstmal Portainer auszuschalten. Meine ioBroker Admin Oberfläche erreiche ich auch nicht mehr, seit Portainer gestartet ist.
              Wie kann ich Portainer deaktivieren ?
                Superdad @andre last edited by
                @andre Ich starte im Host-Mode, da der Bridge-Mode nicht funktioniert.
                Da kommt eine Fehlermeldung wegen Konflikten.
                Failure
                failed to add interface docker69ca9fd to sandbox: error setting interface "docker69ca9fd" IP to 172.17.0.3/16: cannot program address 172.17.0.3/16 in sandbox interface because it conflicts with existing route {Ifindex: 7 Dst: 172.17.0.0/16 Src: 172.17.0.1 Gw: Flags: [] Table: 254}
                Wenn ich im Host-Mode auf Start drücke kommt im Docker folgendes:
                ![alt text](Docker.png image url)
                Danach bleibt es stehen.
                Wenn ich über die Console starte, dann funktioniert es.
                • Negalein
                  Negalein Global Moderator @Superdad last edited by
                  @Superdad sagte in [HowTo][Anleitung] Installation ioBroker in Docker auf Synology DiskStation:
                  Wie hast du ihn über die Konsole gestartet?
                  Bei mir funktioniert bridged auch nicht.
                  Welche DS hast du?
                    Du kannst normal im Docker-Container auf der DS unter Terminal mit dem Befehl iobroker start den Container starten.
                    Oder im Portainer unter Container - dann ioBroker - dann steht da klein >_Console - drauf klicken - dann Connect - dann iobroker start eingeben - dann disconnect.
                    So hat es jedenfalls bei mir funktioniert.
                      Achso, ich habe die DS415+.
                        Die einzige Fehlermeldung die ich im iobroker-Log bekomme, ist:
                        paw.0 2019-05-11 12:20:21.842 info parse_data_error: TabKueche
                        Hängt dass mit dem Portainer zusammen?
                          Rufe ich dann ioBroker weiterhin über ip-adresse:8081 auf?
                          Und wie kann ich sicher sein, dass der iobroker-Container im Portainer läuft?
                          • Negalein
                            Ah, ich Dummkopf!
                            IoBroker läuft bei mir ja eh. Seh ich am Telegram.
                            Aber ich komm nicht auf die Weboberfläche vom Admin.
                            • Negalein
                              In meiner Konfiguration würde ich ihn über ip:8850 aufrufen.
                              Siehst du auf der Portainer Webseite unter Containers.
                                OK, dass mit dem Container sehe ich.
                                Das Portmapping habe ich aber nicht.
                                Kann man das nachträglich noch einrichten?
                                Ich habe ja nicht neu erstellt, sondern meine alte Installation weiter benutzt.
                                • Negalein
                                  Im Portainer geht das so.
                                  Ich hab meinen laufenden kopiert und im Portainer dann das kopierte Verzeichnis in die V3 eingebunden.
                                    Vielen Dank!
                                      Habe es jetzt mal mit der 8850 auf 8081 probiert.
                                      Docker startet auch weiterhin nur über die Konsole.
                                      Welchen Vorteil habe ich jetzt, wenn ich den Port mape von 8850 auf 8081?
                                      Negalein andre 2 Replies Last reply Reply Quote 0
                                      • Negalein
                                        Das ist komisch.
                                        Versuch doch auch mal, den bestehenden Ordner in iobroker-data (wie im Tutorial) zu kopieren.
                                        Und dann 1:1 (bis auf das MAVLAN-Dings) wie im Tutorial zu machen.
                                        Vorteil ist dann, dass du jederzeit wieder während der Testerei auf deine funktionierende Installation kannst.
                                        Vorteil, hmmmmm, ich meine du musst ein Mapping einrichten, da du sonst nicht raufkommst.
                                        Vorteil sehe ich auch noch, da ich 2 ioBroker laufen lassen kann.
                                        • Negalein
                                          Andre, es läuft!
                                          Ich hab in der Konsole ein
                                          iobroker list instances
                                          ausgeführt.
                                          Da seh ich,
                                          system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 10.0.1.22, run as: admin
                                          Dann hab ich
                                          iobroker set admin.0 --bind 0.0.0.0
                                          ausgeführt.
                                          Jetzt komm ich mit ip:8850 auf den Admin! 🙂
                                          Soll ich das bei allen Adaptern machen, die ein bind: 10.0.1.22 stehen haben?
                                          • Homer.J.
                                            Homer.J. last edited by Homer.J.
                                            Hallo Andre,
                                            Hab alles nach Anleitung installiert hab aber das im Log stehen.
                                            Hab alles nochmal gelöscht und neu installiert jetzt läuft es.
                                            tar: opt/iobroker/node_modules: Funktion mkdir fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/node_modules/performance-now/test/scripts/delayed-call.coffee: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/test/scripts/initial-value.coffee: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/test/mocha.opts: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/test/scripts.coffee: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/test/performance-now.coffee: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/lib: Funktion mkdir fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/lib/performance-now.js.map: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/lib/performance-now.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/performance-now/package.json: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/media-typer: Funktion mkdir fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/media-typer/LICENSE: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/media-typer/README.md: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/media-typer/index.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/media-typer/HISTORY.md: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/media-typer/package.json: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend: Funktion mkdir fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/.npmignore: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/test.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/.jshintrc: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/README.md: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/Makefile: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/mutable.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/LICENCE: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/immutable.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/xtend/package.json: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/strip-color: Funktion mkdir fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/strip-color/LICENSE: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/strip-color/README.md: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/strip-color/index.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/node_modules/strip-color/package.json: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/iob: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/iobroker: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/killall.sh: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/install: Funktion mkdir fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/install/windows: Funktion mkdir fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/install/windows/uninstall.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/install/windows/controller.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/install/windows/install.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/install/windows/serviceIoBroker.bat: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/log: Funktion mkdir fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/README.md: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/.npmrc: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/fix_installation.sh: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/.install_host: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/package-lock.json: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/lib: Funktion mkdir fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/lib/installCopyFiles.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/lib/tools.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/lib/installSetup.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/lib/checkVersions.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/lib/install.js: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
                                            tar: opt/iobroker/package.json: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker/reinstall.sh: Funktion open fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker: Funktion utime fehlgeschlagen: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker: Kann Datei-Eigentümer nicht zu uid 1000, gid 1000 ändern: Das Dateisystem ist nur lesbar
                                            tar: opt/iobroker: Kann Zugriffsrechte nicht zu rwxrwxr-x ändern: Das Dateisystem ist nur lesbar
                                            tar: Beende mit Fehlerstatus aufgrund vorheriger Fehler
                                            Starting ioBroker...
                                            Starting ioBroker done...
                                            buanet diskstation docker iobroker synology
                                            248
                                            2854
                                            1538036
