[Aufruf] fullyBrowser Adapter
man sollte nix zwischendurch machen
probier mal noch mal bitte.. von GIT
host.BrokerNUC 2019-05-03 10:12:18.786 error instance system.adapter.fullybrowser.0 terminated with code 0 (OK) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at emitNone (events.js:111:20) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at Object.onceWrapper (events.js:313:30) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at Request.emit (events.js:211:7) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at emitOne (events.js:116:13) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at Request.emit (events.js:214:7) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at emitTwo (events.js:126:13) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22) host.BrokerNUC 2019-05-03 10:12:18.786 error Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24) host.BrokerNUC 2019-05-03 10:12:18.785 error Caught by controller[0]: ReferenceError: leti is not defined fullybrowser.0 2019-05-03 10:12:18.649 error ReferenceError: leti is not defined at Request._callback (/opt/iobroker/node_modules/iobroker.fullybrowser/main.js:194:24) at Request.self.callback (/opt/iobroker/node_modules/request/request. fullybrowser.0 2019-05-03 10:12:18.648 error uncaught exception: leti is not defined
@0018 ok das wird nix.... muss ich mir am system anschauen...
heute abend.. installiere die Stable bitte 0.0.16..
ich mach heute Abend ein Update
@arteck Ok, leider schaffe ich es nicht den Adapter zu deinstallieren. Die 0.17 bleibt immer sichtbar. Hast du einen Tipp?
@0018 sagte in [Aufruf] fullyBrowser Adapter:
Hat sich erledigt, downgrade auf 16 mit "npm install iobroker.fullybrowser@0.0.16 --production" hat geklappt und läuft erstmal wieder
kurze zwischeninfo: habe 0.17 installiert. wenn ich den adapter stoppe, läuft er trotzdem noch weiter (in htop)
@liv-in-sky ne das wird die 0.0.16 sein die nicht beendet wurde..
so 0.0.17 sollte laufen
jup - du hattest recht - neustart und getestet(aus/eingeschaltet) - funktioniert - danke dir
Moin,
seit zwei Tagen funktioniert der Adapter nicht mehr. Meine beiden Tabs sind leer gelaufen da die Ladeüberwachung nicht mehr funktioniert. Fully ist normal über web erreichbar. Nur der Adapter baut keine Verbindung auf. Neustart, installieren der 17er Version haben nichts gebracht. Was mir aufgefallen ist, die App auf den Tabs ist aktualisiert worden und da sind einige Neuerungen bezügliche Java drin?
@intruder7 welche Version des Fullybrowser ??
@arteck ich habe auf beiden Tabs die Version 1.31
@arteck Hab jetzt den Adapter nochmal komplet neu installiert. Er funktioniert trotzdem nicht. Was verwunderlich ist, Befehle sendet er. Also z.B. Sceen on. Nur sämtliche Infos erhält er nicht
@intruder7 muss ich mir mal anschauen.. vor WE wird das aber nix
@arteck Lass dir Zeit. Die Tabs sind im Moment am Dauerstrom. Hoffe nur du findest eine Lösung
@arteck Achso, und eins noch. Besteht die Möglichkeit in den Objekten anstatt der IP einen unter Einstellungen vergebenen Namen zu nutzen? Das wäre auch noch Klasse. ansonsten hat der Adapter von Anfang bis eben vor ein paar Tagen super funktioniert.
@arteck Hab mal geschaut bei Git. Unter Umständen hilft es schon wenn du das timeout von 2000 bei Abfrage der Infos etwas erhöhst. Die Abfrage über das REST Interface dauert ziemlich lange.
function updateDevice(ip,port,psw) {
var id = ip.replace(/[.\s]+/g, '_');
var statusURL = 'http://' + ip + ':' + port + '/?cmd=deviceInfo&type=json&password=' + psw;
var vari = '';var thisOptions = { uri: statusURL, method: "GET", timeout: 2000, followRedirect: false, maxRedirects: 0 };
@intruder7 mach die änderung lokal bei dir und schau nach obs funktioniert
also bei mir läuft alles wie es soll
und ich habe 4 Tablets die ich überwache..
ich aktualisiere alle 120000 milisec -
@arteck also ich musste auf 18000 erhöhen damit es wieder funktioniert. Aber das ist doch seltsam. Hast du die selbe Fully Version(1.31)? welche tabs hast du? Ich habe jeweils ein Samsung Tab A 2016 (SM-T580) mit allen aktuellen Updates. Und der Aufruf der Device Info Seite über den Browser dauert eben ziemlich lange. Ich versteh es echt nicht. Irgendwas muss sich verändert haben weil es ja vorher funktioniert hat.
