Online Version
Restart blieb hängen, musste den js-controller killen, dann hat es funktioniert.
chmod -R 777 funktioniert unter Mac, umgekehrt leider nicht.
kurz… ich bekomme meine ioBroker Mac Umgebung nicht mehr zum Laufen
Probiere bitte````
cd /Users/herwig/iobroker
./iobroker stop
npm install iobroker.js-controller --production
sudo chmod 777 * -R
./iobroker start -
Probiere bitte````
./iobroker stop
sudo chmod 777 * -R
./iobroker start```` `
habe ich gemacht:
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker stop Stopping ioBroker controller daemon... ioBroker controller daemon stopped. Michaels-MacBook-Pro-Retina-2:iobroker herwig$ npm install iobroker.js-controller --production > ws@0.5.0 install /Users/herwig/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws > (node-gyp rebuild 2> builderror.log) || (exit 0) CXX(target) Release/obj.target/bufferutil/src/bufferutil.o SOLINK_MODULE(target) Release/bufferutil.node SOLINK_MODULE(target) Release/bufferutil.node: Finished CXX(target) Release/obj.target/validation/src/validation.o SOLINK_MODULE(target) Release/validation.node SOLINK_MODULE(target) Release/validation.node: Finished > ws@0.4.31 install /Users/herwig/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws > (node-gyp rebuild 2> builderror.log) || (exit 0) CXX(target) Release/obj.target/bufferutil/src/bufferutil.o > iobroker.js-controller@0.7.2 install /Users/herwig/iobroker/node_modules/iobroker.js-controller > node lib/setup.js setup first iobroker.js-controller@0.7.2 node_modules/iobroker.js-controller ├── daemonize2@0.4.2 ├── mime@1.3.4 ├── node-schedule@0.1.13 ├── ncp@2.0.0 ├── adm-zip@0.4.7 ├── semver@4.3.6 ├── yargs@3.7.2 (decamelize@1.0.0, camelcase@1.1.0, window-size@0.1.0, wordwrap@0.0.2) ├── node.extend@1.1.5 (is@3.0.1) ├── winston@1.0.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, isstream@0.1.2, pkginfo@0.3.0, async@0.9.2, colors@1.0.3) ├── prompt@0.2.14 (revalidator@0.1.8, pkginfo@0.3.0, read@1.0.6, winston@0.8.3, utile@0.2.1) ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31) ├── request@2.55.0 (caseless@0.9.0, aws-sign2@0.5.0, forever-agent@0.6.1, stringstream@0.0.4, oauth-sign@0.6.0, tunnel-agent@0.4.0, isstream@0.1.2, json-stringify-safe@5.0.1, node-uuid@1.4.3, qs@2.4.2, combined-stream@0.0.7, form-data@0.2.0, mime-types@2.0.14, http-signature@0.10.1, bl@0.9.4, tough-cookie@2.0.0, hawk@2.3.1, har-validator@1.8.0) ├── npm@2.7.6 ├── socket.io@1.3.5 (debug@2.1.0, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.4, engine.io@1.5.1) └── socket.io-client@1.3.5 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, backo2@1.0.2, object-component@0.0.3, component-emitter@1.1.2, has-binary@0.1.6, parseuri@0.0.2, socket.io-parser@2.2.4, engine.io-client@1.5.1) Michaels-MacBook-Pro-Retina-2:iobroker herwig$ sudo chmod 777 * -R Password: chmod: -R: No such file or directory Michaels-MacBook-Pro-Retina-2:iobroker herwig$ sudo chmod -R 777 * Michaels-MacBook-Pro-Retina-2:iobroker herwig$ Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker start Starting ioBroker controller daemon... ioBroker controller daemon started. PID: 2466 Michaels-MacBook-Pro-Retina-2:iobroker herwig$Musste das
sudo chmod 777 * -Rgegen:
sudo chmod -R 777 *tauschen.
Daemon startet. Auf Admin und Vis komme ich trotzdem nicht. :?
Nunja, die Rechte unter Mac sind eigentlich gleich wie unter Linux, einmal sudo immer sudo.
Ändere mal das ganze ioBroker Verzeichnis mittels
sudo chown -R herwig:staff /Users/herwig/iobroker
Und alle io Prozesse vorher stoppen/killen und dann als User herwig iobroker Neustarten.
Du siehst alle Prozesse mittels
sudo ps -ef|grep io|egrep -v "System|Applic|usr"
Gesendet von meinem iPhone mit Tapatalk
sudo ps -ef|grep io|egrep -v "System|Applic|usr" `
Direkt durchgeführt:
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ sudo ps -ef|grep io|egrep -v "System|Applic|usr" 501 1145 1 0 8:20pm ?? 0:02.40 com.pushbullet.macapp-notifications 501 2466 1 0 8:31pm ?? 0:00.40 io.js-controller 501 2760 962 0 8:35pm ttys000 0:00.00 grep io Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker stop Stopping ioBroker controller daemon... ioBroker controller daemon stopped. Michaels-MacBook-Pro-Retina-2:iobroker herwig$ sudo ps -ef|grep io|egrep -v "System|Applic|usr" 501 1145 1 0 8:20pm ?? 0:02.49 com.pushbullet.macapp-notifications 501 2826 962 0 8:36pm ttys000 0:00.00 grep io Michaels-MacBook-Pro-Retina-2:iobroker herwig$ Michaels-MacBook-Pro-Retina-2:iobroker herwig$ Michaels-MacBook-Pro-Retina-2:iobroker herwig$ sudo chown -R herwig:staff /Users/herwig/iobroker Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ls etc iobroker-data fritz.gif log ioBroker.js-controller-master.zip node_modules iobroker Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker start Starting ioBroker controller daemon... ioBroker controller daemon started. PID: 2889 Michaels-MacBook-Pro-Retina-2:iobroker herwig$Die Webseiten lassen sich immer noch nicht öffnen
Muss ich noch etwas starten? Etwas ganz einfaches, von dem jeder ausgeht, dass das selbstverständlich ist und es deshalb nicht erwähnt?
Einmal sudo immer sudo?
Du meinst, wenn ich iobroker mit sudo installiert habe, will er das immer so und mit dem chown -R herwig wird das von "sudo" auf meinem User geändert?
Linux und Mac… na ja... der Unterbau ist identisch.. ich benutze den Mac aber in der GUI
und eher gar nicht auf CLI Ebene. Also Linux Dummy User... -
Was sagt das Logfile? Bzw. ist der Port 8081 aktiv?
netstat -na|grep 8081Muss ich noch etwas starten? Etwas ganz einfaches, von dem jeder ausgeht, dass das selbstverständlich ist und es deshalb nicht erwähnt?
Nein
Ja
Linux und Mac… na ja... der Unterbau ist identisch.. ich benutze den Mac aber in der GUI  und eher gar nicht auf CLI Ebene. Also Linux Dummy User...
Ich hab leicht reden, ich nutze Mac, Linux und Unix bereits seit Jahrzehnten.
Ich hab leicht reden, ich nutze Mac, Linux und Unix bereits seit Jahrzehnten. `
na dann bin ich doch optimistisch, dass ich das mit Deiner Unterstützung hinbekomme
` > Michaels-MacBook-Pro-Retina-2:iobroker herwig$ netstat -na|grep 8081
tcp4 0 0 172.16.130.113.52712 172.16.130.122.8081 ESTABLISHED
tcp4 0 0 172.16.130.113.52710 172.16.130.122.8081 ESTABLISHED
tcp4 0 0 172.16.130.113.52708 172.16.130.122.8081 CLOSE_WAIT
tcp4 0 0 172.16.130.113.52707 172.16.130.122.8081 CLOSE_WAIT
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ netstat -na|grep 8082
tcp4 0 0 172.16.130.113.52757 172.16.130.122.8082 ESTABLISHED
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ `
Links müsste die 8081 und die 8082 stehen?
Wenn ja, sind die Ports nicht aktiv oder?
Auf der rechten Seite ist die IP der zweiten ioBroker Installation unter Debian (VM auf dem Mac).
Nachtrag… Du fragtest noch nach dem Logfile...
2015-06-29 19:07:30.982 - warn: admin.0 Reconnection to DB. 2015-06-29 19:25:51.344 - info: admin.0 terminating http server on port 8081 2015-06-29 19:25:51.337 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 19:25:51.361 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 19:25:52.846 - info: admin.0 terminating with timeout 2015-06-29 19:34:04.918 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.6.6 js-controller starting 2015-06-29 19:34:04.920 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 19:34:04.921 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 19:34:04.921 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: fe80::aa20:66f 172.16.130.113 fe80::2acf:e 172.16.130.183 fe80::f49e:180::cbf:870 fd56:9af1: 192.168.184.1 192.168.225.1 2015-06-29 19:34:04.982 - info: inMem-states listening on port 9000 2015-06-29 19:34:04.991 - info: inMem-objects listening on port 9001 2015-06-29 19:34:04.993 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 19:34:04.995 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 19:34:04.995 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this host 2015-06-29 19:34:43.550 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 19:34:43.551 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 2015-06-29 19:34:43.551 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 not running 2015-06-29 19:34:43.551 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 2015-06-29 19:34:43.551 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 not running 2015-06-29 19:34:43.553 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 19:34:47.799 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.6.6 js-controller starting 2015-06-29 19:34:47.803 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 19:34:47.803 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 19:34:47.804 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: 172.16.130.113 172.16.130.183 f 192.168.184.1 192.168.225.1 2015-06-29 19:34:47.867 - info: inMem-states listening on port 9000 2015-06-29 19:34:47.876 - info: inMem-objects listening on port 9001 2015-06-29 19:34:47.878 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 19:34:47.881 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 19:34:47.881 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this host 2015-06-29 19:35:51.070 - info: vis.0 starting. Version 0.6.1 in /Users/herwig/iobroker/node_modules/iobroker.vis 2015-06-29 19:35:51.189 - info: vis.0 Changes in index.html detected => update cache.manifest 2015-06-29 19:35:54.479 - info: vis.0 starting. Version 0.6.1 in /Users/herwig/iobroker/node_modules/iobroker.vis 2015-06-29 19:58:46.345 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 19:58:46.348 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 2015-06-29 19:58:46.348 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 not running 2015-06-29 19:58:46.348 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 2015-06-29 19:58:46.348 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 not running 2015-06-29 19:58:46.352 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 20:06:19.172 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.7.1 js-controller starting 2015-06-29 20:06:19.175 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 20:06:19.176 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 20:06:19.176 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: 172.16.130.113 2015-06-29 20:06:19.240 - info: inMem-states listening on port 9000 2015-06-29 20:06:19.251 - info: inMem-objects listening on port 9001 2015-06-29 20:06:19.253 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 20:06:19.256 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 20:06:19.257 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this host 2015-06-29 20:14:09.261 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 20:14:09.269 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 20:14:09.752 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.7.1 js-controller starting 2015-06-29 20:14:09.756 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 20:14:09.757 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 20:14:09.757 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: 2015-06-29 20:14:09.829 - info: inMem-states listening on port 9000 2015-06-29 20:14:09.841 - info: inMem-objects listening on port 9001 2015-06-29 20:14:09.844 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 20:14:09.848 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 20:14:09.848 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this host 2015-06-29 20:15:51.694 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 20:15:51.698 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 20:25:51.707 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.7.1 js-controller starting 2015-06-29 20:25:51.710 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 20:25:51.710 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 20:25:51.710 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: 2015-06-29 20:25:51.778 - info: inMem-states listening on port 9000 2015-06-29 20:25:51.789 - info: inMem-objects listening on port 9001 2015-06-29 20:25:51.792 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 20:25:51.795 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 20:25:51.795 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this host 2015-06-29 20:30:32.740 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 20:30:32.741 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 2015-06-29 20:30:32.741 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 not running 2015-06-29 20:30:32.741 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 2015-06-29 20:30:32.742 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 not running 2015-06-29 20:30:32.743 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 20:31:36.937 - info: host.Michaels-MacBook-Pro-Retina-3.local ioBroker.js-controller version 0.7.2 js-controller starting 2015-06-29 20:31:36.940 - info: host.Michaels-MacBook-Pro-Retina-3.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 20:31:36.940 - info: host.Michaels-MacBook-Pro-Retina-3.local hostname: Michaels-MacBook-Pro-Retina-3.local 2015-06-29 20:31:36.940 - info: host.Michaels-MacBook-Pro-Retina-3.local ip addresses: 2015-06-29 20:31:37.005 - info: inMem-states listening on port 9000 2015-06-29 20:31:37.016 - info: inMem-objects listening on port 9001 2015-06-29 20:31:37.018 - info: host.Michaels-MacBook-Pro-Retina-3.local InMemoryDB connected 2015-06-29 20:31:37.021 - info: host.Michaels-MacBook-Pro-Retina-3.local 12 instances found 2015-06-29 20:31:37.021 - warn: host.Michaels-MacBook-Pro-Retina-3.local does not start any instances on this host 2015-06-29 20:36:08.148 - info: host.Michaels-MacBook-Pro-Retina-3.local received SIGTERM 2015-06-29 20:36:08.150 - info: host.Michaels-MacBook-Pro-Retina-3.local terminated 2015-06-29 20:36:57.122 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.7.2 js-controller starting 2015-06-29 20:36:57.126 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 20:36:57.126 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 20:36:57.126 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: 2015-06-29 20:36:57.191 - info: inMem-states listening on port 9000 2015-06-29 20:36:57.204 - info: inMem-objects listening on port 9001 2015-06-29 20:36:57.206 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 20:36:57.209 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 20:36:57.210 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this hostdort sehe ich nur Port 9000 und 9001…
Du hast keinen Listener auf Port 8081.
chmod -R 777 /Users/herwig/iobroker/node_modules/iobroker.js-controllerund danach iobroker neustarten und Logfile bitte vom Start.
1304_screenshot_17.png -
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker stop Stopping ioBroker controller daemon... ioBroker controller daemon stopped. Michaels-MacBook-Pro-Retina-2:iobroker herwig$ chmod -R 777 /Users/herwig/iobroker/node_modules/iobroker.js-controller Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker start Starting ioBroker controller daemon... ioBroker controller daemon started. PID: 4382 Michaels-MacBook-Pro-Retina-2:iobroker herwig$ netstat -na|grep 8081 tcp4 0 0 172.16.130.113.53452 172.16.130.122.8081 ESTABLISHED tcp4 0 0 172.16.130.113.52712 172.16.130.122.8081 ESTABLISHED Michaels-MacBook-Pro-Retina-2:iobroker herwig$gestopt, chmod, gestartet
und das Log:
2015-06-29 20:56:23.051 - info: host.Michaels-MacBook-Pro-Retina-2.local received SIGTERM 2015-06-29 20:56:23.053 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 2015-06-29 20:56:23.053 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.hm-rpc.0 not running 2015-06-29 20:56:23.053 - info: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 2015-06-29 20:56:23.053 - warn: host.Michaels-MacBook-Pro-Retina-2.local stopInstance system.adapter.fritzbox.0 not running 2015-06-29 20:56:23.055 - info: host.Michaels-MacBook-Pro-Retina-2.local terminated 2015-06-29 20:56:33.286 - info: host.Michaels-MacBook-Pro-Retina-2.local ioBroker.js-controller version 0.7.2 js-controller starting 2015-06-29 20:56:33.290 - info: host.Michaels-MacBook-Pro-Retina-2.local Copyright (c) 2014-2015 bluefox, hobbyquaker 2015-06-29 20:56:33.291 - info: host.Michaels-MacBook-Pro-Retina-2.local hostname: Michaels-MacBook-Pro-Retina-2.local 2015-06-29 20:56:33.291 - info: host.Michaels-MacBook-Pro-Retina-2.local ip addresses: fe80::aa20: 172.16.130.113 fe80::2acf:e9ff 172.16.130.183 fe80::8f7: fe80::2d7b:f56b:86e6:f792:2d7b:f56b:8 192.168.184.1 192.168.225.1 2015-06-29 20:56:33.358 - info: inMem-states listening on port 9000 2015-06-29 20:56:33.369 - info: inMem-objects listening on port 9001 2015-06-29 20:56:33.371 - info: host.Michaels-MacBook-Pro-Retina-2.local InMemoryDB connected 2015-06-29 20:56:33.374 - info: host.Michaels-MacBook-Pro-Retina-2.local 12 instances found 2015-06-29 20:56:33.375 - warn: host.Michaels-MacBook-Pro-Retina-2.local does not start any instances on this hostkeine Änderung
keine Änderung
Was siehst du bei:iobroker list instancesund
bei
iobroker object get system.adapter.admin.0 --prettyEs sieht so aus, als ob hostname geändert wurde.
keine Änderung
Was siehst du bei:iobroker list instances ```` `Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker list instances system.adapter.admin.0 : admin - disabled, port: 8081, bind: 0.0.0.0 system.adapter.example.0 : example - disabled system.adapter.ping.0 : ping - disabled system.adapter.javascript.0 : javascript - disabled system.adapter.sayit.0 : sayit - disabled system.adapter.mqtt.0 : mqtt - disabled, port: 1883 system.adapter.yr.0 : yr - enabled system.adapter.history.0 : history - enabled system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0 system.adapter.vis.0 : vis - enabled system.adapter.hm-rpc.0 : hm-rpc - disabled system.adapter.fritzbox.0 : fritzbox - disabledund
bei
iobroker object get system.adapter.admin.0 --pretty ```` `Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker object get system.adapter.admin.0 --pretty { "_id": "system.adapter.admin.0", "type": "instance", "common": { "name": "admin", "version": "0.4.8", "title": "", "desc": { "en": "Opens a webserver for the ioBroker admin UI", "de": "Stellt Webserver für 'ioBroker Admin UI' zur Verfügung", "ru": "Запускает веб сервер с 'ioBroker admin UI' для удобной настройки через веб интерфейс" }, "mode": "daemon", "platform": "Javascript/Node.js", "loglevel": "info", "icon": "admin.png", "messagebox": true, "enabled": false, "extIcon": "https://raw.githubusercontent.com/ioBroker/ioBroker.admin/master/admin/admin.png", "keywords": [ "setup", "config", "update", "upgrade", "system", "konfiguration", "administration", "einrichtung", "wartung" ], "readme": "https://github.com/ioBroker/ioBroker.admin/blob/master/README.md", "authors": [ "hobbyquaker <hq@ccu.io>", "bluefox <bluefox@ccu.io>" ], "type": "common adapters", "license": "MIT", "logTransporter": true, "wwwDontUpload": true, "installedVersion": "0.4.8", "host": "Michaels-MacBook-Pro-Retina.local", "schedule": "" }, "native": { "port": 8081, "auth": false, "secure": false, "bind": "0.0.0.0", "cache": false, "certPublic": "", "certPrivate": "" } } Michaels-MacBook-Pro-Retina-2:iobroker herwig$</bluefox@ccu.io></hq@ccu.io>Es sieht so aus, als ob hostname geändert wurde. `
mmh….
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname
vs.
das -2 scheint dazugekommen zu sein…
aber warum? :shock: :? :?:
3188_cloud.png -
Apple…
Stell das in Settings/Sharing in Mac OSX zurück
habe ich schon versucht…
und es wird verrückt:
Michaels-MacBook-Pro-Retina-2:iobroker herwig$ ./iobroker stop Stopping ioBroker controller daemon... ioBroker controller daemon stopped. Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-2.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-2.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-3.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-3.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-3.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-2.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-2.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-2.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$ hostname Michaels-MacBook-Pro-Retina-2.local Michaels-MacBook-Pro-Retina-2:iobroker herwig$Über Einstellungen/Freigeben geändert:
dann im Termial mehrmals hostname eingegeben und es ändert sich wie folgt:
und wieder zurück zu
In der Zeit habe ich nichts gemacht, als hostname im Terminal zu bestätigen… :shock:
Was ist denn das für ein ''&%&$'$§ grummel :?:
Was macht der Mac da...?
ich scheine nicht alleine zu sein mit dem Problem der selbstständig ändernden Hostnamen am Mac:
http://www.macuser.de/forum/thema/71109 … engt/page8
Dort ist der letzte Eintrag vom 17.06.2015 und das Thema scheint nicht gelöst.
DNS wird bei mir von dem Synology NAS übernommen.
Mal sehen, ob ich noch was finde. Es kann doch nicht sein, dass ich wg. so einem (Mac) Käse ioBroker dort nicht nutzen kann.
Da läuft die "Entwicklungsumgebung" drauf. Muss mir sonst anschauen, wie ich Webstorm lokal am Mac am sinnvollsten nutze, mit einer entfernten iobroker Installation. Dann verstehe ich aber mal wenigstens, wo nun was ausgeführt wird, was mir derzeit nicht ganz klar ist (wenn ich im Webstorm auf Run drücke… peinlich, peinlich,....)
Wird schon. Ein Mac ist schließlich kein Windows
[EDIT] noch zur Info, falls noch jemand das Problem bekommt. Ich bin im Betaprogramm von Yosemite angemeldet.Dort wurde mir schon ewig die Mac OS X Beta 10.10.4 angeboten. Da ich den Rechner nciht gerne neu starte
habe ich das jetzt sehr lange ausgesessen. Heute im Zuge des ioBroker Updates habe ich dann einmal durchgestartet und direkt 10.10.4 installiert. Seitdem scheinen die Hostnamen "zu spinnen". -
Hier kann wahrscheinlich Bluefox schnell helfen…?!
2015-06-29 22:05:18.904 - error: host.Michaels-MacBook-Pro-Retina.local startInstance web.0: cannot find start file!
2015-06-29 22:05:10.886 - info: inMem-states listening on port 9000 2015-06-29 22:05:10.897 - info: inMem-objects listening on port 9001 2015-06-29 22:05:10.900 - info: host.Michaels-MacBook-Pro-Retina.local InMemoryDB connected 2015-06-29 22:05:10.903 - info: host.Michaels-MacBook-Pro-Retina.local 12 instances found 2015-06-29 22:05:10.903 - info: host.Michaels-MacBook-Pro-Retina.local starting 4 instances 2015-06-29 22:05:11.332 - info: yr.0 starting. Version 0.1.6 in /Users/herwig/iobroker/node_modules/iobroker.yr 2015-06-29 22:05:11.819 - info: yr.0 got weather data from yr.no 2015-06-29 22:05:14.906 - info: host.Michaels-MacBook-Pro-Retina.local instance system.adapter.history.0 started with pid 9804 2015-06-29 22:05:15.239 - info: history.0 starting. Version 0.1.3 in /Users/herwig/iobroker/node_modules/iobroker.history 2015-06-29 22:05:16.839 - info: host.Michaels-MacBook-Pro-Retina.local instance system.adapter.yr.0 terminated with code 0 (OK) 2015-06-29 22:05:18.904 - error: host.Michaels-MacBook-Pro-Retina.local startInstance web.0: cannot find start file!Ich habe jetzt das WLAN im Macbook deaktiviert. Seitdem bleibt der Hostname noch stabil… toi, toi, toi, ...
Nun komme ich nach einem ./iobroker restart immer noch nciht auf meine Webseiten 8081 und 8082.
Die letzte error Meldung aus dem Log sagt vielleicht was aus?
so… funktioniert wieder...
was am Ende geholfen hat... da bin ich mir nicht zu 100% sicher, da ich viel hin und her probiert habe.
Leider musste ich wieder Kommandos unter sudo ausführen (ohne sudo liefen sie nicht durch).
sudo ./iobroker upgrade sudo ./iobroker add webwaren die letzten Schritte. Danach konnte ich wieder Admin und VIS benutzen.
