    4. hm-rpc.1 zeigt nur state no alarm an
      markus-now @paul53 last edited by
      @paul53 nach dem Eintrag in die XML Datei kommt das in der log
      hm-rpc.1 2019-05-15 20:39:18.304 info Connected
      hm-rpc.1 2019-05-15 20:39:18.245 info xmlrpc -> 344 devices
      hm-rpc.1 2019-05-15 20:39:18.109 info xmlrpc <- listDevices ["hm-rpc.1"]
      hm-rpc.1 2019-05-15 20:39:18.102 info xmlrpc <- system.listMethods ["hm-rpc.1"]
      hm-rpc.1 2019-05-15 20:39:18.077 info xmlrpc client is trying to connect to 192.168.178.28:2000/ with ["http://192.168.178.33:2000","hm-rpc.1"]
      hm-rpc.1 2019-05-15 20:39:18.076 info xmlrpc server is trying to listen on 192.168.178.33:2000
      hm-rpc.1 2019-05-15 20:39:17.820 info starting. Version 1.9.11 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.16.0
      host.ioBroker 2019-05-15 20:39:16.744 info instance system.adapter.hm-rpc.1 started with pid 15843
      host.ioBroker 2019-05-15 20:39:14.444 info instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
      hm-rpc.1 2019-05-15 20:39:14.240 info Disconnected
      hm-rpc.1 2019-05-15 20:39:14.228 info xmlrpc -> 192.168.178.28:2000/ init ["http://192.168.178.33:2000",""]
      host.ioBroker 2019-05-15 20:39:14.227 info stopInstance timeout "1000 system.adapter.hm-rpc.1 killing pid 15576
      host.ioBroker 2019-05-15 20:39:13.136 info stopInstance system.adapter.hm-rpc.1
      host.ioBroker 2019-05-15 20:39:13.136 info object change system.adapter.hm-rpc.1
      hm-rpc.1 2019-05-15 20:39:08.765 warn No image for "HBW-SD6-Multikey-v1" found.
      hm-rpc.1 2019-05-15 20:39:08.756 info xmlrpc <- newDevices 344
      hm-rpc.1 2019-05-15 20:39:07.617 info Connected
      hm-rpc.1 2019-05-15 20:39:07.550 info xmlrpc -> 0 devices
      hm-rpc.1 2019-05-15 20:39:06.595 info xmlrpc <- listDevices ["hm-rpc.1"]
      hm-rpc.1 2019-05-15 20:39:06.587 info xmlrpc <- system.listMethods ["hm-rpc.1"]
      hm-rpc.1 2019-05-15 20:39:06.556 info xmlrpc client is trying to connect to 192.168.178.28:2000/ with ["http://192.168.178.33:2000","hm-rpc.1"]
      hm-rpc.1 2019-05-15 20:39:06.555 info xmlrpc server is trying to listen on 192.168.178.33:2000
      hm-rpc.1 2019-05-15 20:39:06.281 info starting. Version 1.9.11 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v8.16.0
      host.ioBroker 2019-05-15 20:39:05.265 info instance system.adapter.hm-rpc.1 started with pid 15576
      host.ioBroker 2019-05-15 20:39:02.794 info instance system.adapter.hm-rpc.1 terminated with code 0 (OK)
      hm-rpc.1 2019-05-15 20:39:02.766 info xmlrpc -> 192.168.178.28:2000/ init ["http://192.168.178.33:2000",""]
      hm-rpc.1 2019-05-15 20:39:02.755 info Disconnected
      hm-rpc.1 2019-05-15 20:39:02.745 info xmlrpc -> 192.168.178.28:2000/ init ["http://192.168.178.33:2000",""]
      host.ioBroker 2019-05-15 20:39:02.742 info stopInstance timeout "1000 system.adapter.hm-rpc.1 killing pid 14166
      host.ioBroker 2019-05-15 20:39:01.741 info stopInstance system.adapter.hm-rpc.1
        @paul53Du bist echt spitze, danke dir es geht.
        So ein geniales Forum hier DANKE euch allen noch einmal.☺ ☺ ☺ ☺ ☺ 👌 👌 👌 👌 👍 👍 👍 👏 👏 👏 👏
            @paul53 noch eine frage, ist es normal, dass die Taster immer auf true stehen.
              paul53 @markus-now last edited by
              @markus-now sagte:
              Ja.
                @paul53 Danke👍
                  @paul53 ich hoffe das ich dich nicht so sehr belästige, aber hast du eventuell zu dem Thema noch eine Idee.
                  Link Text
                    @markus-now sagte:
                    Nein, mit Alexa habe ich nichts am Hut, beschäftige mich also auch nicht damit.
                    Du solltest den Betreiber der Webseite haus-bus.de über die fehlerhafte Datei hbw_sd6_multikey.xml informieren.
                      @paul53 Okay. Danke werde ich direkt machen.
                        @paul53 sagte in hm-rpc.1 zeigt nur state no alarm an:
                        Habe eben eine Email an haus-bus.de geschrieben, melde mich was sie antworten.
                          HausBusDe last edited by
                          Moin IO-Brokers,
                          wir haben die XML Datei in unserem aktuellen Homematic Addon gerade aktualisiert. Den Maintanance Kanal hatte wir nicht so richtig auf dem Schirm.
                          Vielen Dank auf jeden Fall fürs Melden des Fehlers.
                          Wenn ihr weitere Wünsche oder gern auch Anregungen habt, wie man unsere Komponenten besser in IO Broker integrieren kann, wären wir daran sehr interessiert.
                          Z.b. hat unser Taster mittlerweile auch Helligkeitssensoren. Hat das jemand schon ausprobieren können?
                          Gibts ansonsten Wünsche ?
                          Herm
                          Haus-Bus.de
                            sigi234 Forum Testing Most Active @markus-now last edited by sigi234
                            @markus-now
                            Zeig mal die Einstellungen von Adapter hm-rpc.1 und von der CCU!
                            Falscher Beitrag........
                              markus-now @sigi234 last edited by
                              @sigi234 bin gerade arbeiten, mach ich heute Nachmittag.
                                markus-now @HausBusDe last edited by
                                @HausBusDe
                                Super das es so schnell bearbeitet wurde 👍 . werde gleich heute Nachmittag die CCU aktualisieren.
                                Ich habe die Taster mit Helligkeitssensoren, kann ja jetzt auch mal einiges damit ausprobieren und testen.
                                Melde mich dann nochmal.
                                4564
