    4. CacheSelector findet nicht alle Datenpunkte bzw. States
    SOLVED CacheSelector findet nicht alle Datenpunkte bzw. States
      mark77 last edited by Negalein
      also:
      var dps = $('[state.id=sonoff.0.*.alive]');
      dps.each(function(id, i) {
          var val = getObject(id);
          log("Sonoff: " + id);
      Ergebinis Version 4.1.12:
      18:32:41.109	[info]	javascript.1 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-163.alive
      18:32:41.109	[info]	javascript.1 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-166.alive
      18:32:41.109	[info]	javascript.1 script.js.CacheTest: Sonoff: sonoff.0.WiFi-RPi-POE.alive
      Ergebins Version 3.6.4:
      18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.3D-Drucker.alive
      18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.DunstAbzgHaube.alive
      18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.EnergyPow1.alive
      18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.GasStrom.alive
      18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Kompressor.alive
      18:33:13.212	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Luefter-1.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Luefter-2.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.NachtlichtJohanna.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.NachtlichtPaulina.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.RGB-Controller-1.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.RGB-Controller-2.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.RGB-Controller-3.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-163.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-166.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Sonoff-167.alive
      18:33:13.213	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Bohrmaschine.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Kodi-Johanna.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Kodi-Schlafz.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Messgeraete.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Nextion.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Printserver.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-RPi-Server.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.Switch-Schleifmaschinen.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.TuerKlingel.alive
      18:33:13.214	[info]	javascript.2 script.js.CacheTest: Sonoff: sonoff.0.WiFi-RPi-POE.alive
      Meinst du so?
        Moin,
        habe gerade die Tage wieder damit experimentiert.
        Irgendwo hatte ich auch noch Probleme damit, weiß nur leider nicht mehr genau, welche Datenpunkte es genau waren.
        Sie ließen sich nur dann auslesen, wenn das Logging über History/SQL aktiviert war.
        Habe vor 5 Minuten mal die Versionen 4.1.14 und 4.3.1 probiert und da, wo ich es benötige, nichts auffälliges festgestellt.
        Für mich scheint es zu laufen.
        Am einfachsten ließ sich das testen, mit einem Slave (z.B. RPi), auf dem eine andere Version installiert ist, dann kann man immer zwischen den Instanzen wechseln.
        Gruß,
        Mark
        • AlCalzone
          AlCalzone Developer @mark77 last edited by
          @mark77 Ja sieht gut aus. Kannst du mir noch je von einem der Objekte die gefunden werden und einem, die nicht mehr gefunden werden, die Objektdefinition zeigen? (Objekte -> Bearbeiten-Pfeil -> Reiter "Raw")
            Geht:
              "_id": "sonoff.0.Sonoff-163.alive",
              "common": {
                "name": "Sonoff-163 alive",
                "type": "boolean",
                "role": "indicator.connected",
                "read": true,
                "write": true
              "type": "state",
              "from": "system.adapter.sonoff.0",
              "user": "system.user.admin",
              "ts": 1539845127231,
              "acl": {
                "object": 1636,
                "owner": "system.user.admin",
                "state": 1636
              "native": {}
            Geht nicht:
              "_id": "sonoff.0.Sonoff-167.alive",
              "common": {
                "type": "boolean",
                "read": true,
                "write": false,
                "name": "Sonoff-167 alive"
              "type": "state",
              "ts": 1539845147409,
              "acl": {
                "object": 1636,
                "state": 1636,
              "native": {}
            • AlCalzone
              @mark77 Danke. Das find ich schon sehr seltsam. Nur um sicher zu gehen, dass das kein bekannter Bug ist:
              Die Datenpunkte existieren schon vor dem Start des Skript-Adapters, und werden nicht erst während der Laufzeit durch einen anderen Adapter angelegt - richtig?
                @AlCalzone Ja, ist richtig, alles wurde vom Adapter selber angelegt.
                Hilft es, wenn ich das gleich mit dem ZigBee Adapter mache?
                Da gibt es die gleichen Probleme.
                  arteck Developer Most Active @mark77 last edited by
                  @mark77 jo mach bitte
                  • AlCalzone
                    @AlCalzone sagte in CacheSelector findet nicht alle Datenpunkte bzw. States:
                    @mark77 Das ist der entscheidende Punkt. Der Sonoff-Adapter lief, die Objekte waren da, und dann hast du den Skript-Adapter gestartet?
                      @AlCalzone ja, korrekt
                        Der geht:
                          "from": "system.adapter.zigbee.0",
                          "ts": 1557846957200,
                          "common": {
                            "name": "Battery percent",
                            "type": "number",
                            "unit": "%",
                            "role": "battery.percent",
                            "min": 0,
                            "max": 100,
                            "read": true,
                            "write": false,
                            "icon": "img/battery_p.png",
                            "custom": {
                              "history.0": {
                                "enabled": true,
                                "changesOnly": true,
                                "debounce": "10000",
                                "maxLength": "960",
                                "retention": "63072000",
                                "changesRelogInterval": 0,
                                "changesMinDelta": 0,
                                "aliasId": ""
                              "sql.1": {
                                "enabled": true,
                                "storageType": "",
                                "aliasId": ""
                          "native": {},
                          "acl": {
                            "object": 1636,
                            "state": 1636
                          "_id": "zigbee.0.HierStehtDieId.battery",
                          "type": "state",
                        Der geht nicht:
                          "type": "state",
                          "common": {
                            "type": "number",
                            "unit": "%",
                            "read": true,
                            "write": false,
                            "min": 0,
                            "max": 100,
                            "custom": {
                              "history.0": {
                                "enabled": true,
                                "maxLength": "960",
                                "retention": "31536000",
                                "aliasId": ""
                          "ts": 1557846957223,
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                          "native": {}
                          Gibt es eigentlich einen Grund, dass sich der Aufbau der Objekte, bei eigentlich gleichen Typen, unterscheidet?
                            rtamas @mark77 last edited by rtamas
                            @mark77 Hallo! Ich habe die selben Probleme mit Sonoff. Hast du es irgendwie gelöst?
                            ScriptEngine 4.1.12
                            sonoff 2.2.2
                            js-controller 1.5.14
                              paul53 @rtamas last edited by
                              @rtamas sagte:
                              ScriptEngine 4.1.12
                              Hast Du es mal mit einer neueren Version (4.3.x) versucht ?
                                Moin,
                                Gruß,
                                Mark
                                  rtamas @paul53 last edited by
                                  @paul53 Hab ich noch nicht, danke Dir fürs Tipp!
                                  @mark77 Danke für die weitere Info!
                                  Es war mein Fehler mit dem Code, läuft schon problemlos. 🙂
                                  Gruß,
                                  Tamas
                                  cacheselector javascript
                                  1270
