    5. Stoppuhr
    Stoppuhr
      Schlagschatten last edited by
      Für Stunde
      <variables>
      <variable type="undefined" id="Intervall">Intervall</variable>
      <variable type="" id="RJX#bCFN/lLc{/ML$d(C">counter22</variable>
      </variables>
      <block type="on_ext" id="nlX!8rCV~k.;9Xm#$t0S" x="-1087" y="-1287">
      <value name="OID0">
      <shadow type="field_oid" id="ES``F{uHqW8J+/Y,X@P,">
      <field name="oid">vis.0.HansNOTAUS.Wasserzaehler2</field>
      <value name="OID1">
      <shadow type="field_oid" id="c1dm,W4lL4F/SCN/JXE[">
      <field name="oid">vis.0.HansNOTAUS.Wasserzaehler2.Stunden</field>
      <block type="controls_if" id="CjOQv-/z9yZw|+5]9~Ey">
      <block type="logic_compare" id="mbvd~(W_.g}5*}=^oO~v">
      <field name="OP">EQ</field>
      <block type="get_value" id="jMiE]hV^DT%]ElNF/Ms">
      <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2</field>
      <block type="logic_boolean" id="_zD5z^Eg?Mp/(ND7]U/1">
      <block type="timeouts_setinterval" id="@4#gh8ib?30YN]phECu"> <field name="NAME">Intervall</field> <field name="INTERVAL">60</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="math_change" id="ISrC8BYmAH[I|pL+%xZ">
      <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter22</field>
      <value name="DELTA">
      <shadow type="math_number" id="fRCT)TN8g
      |+PyckhQDs">
      <field name="NUM">1</field>
      <block type="controls_if" id="e02eDw4RhcrUIFhfdw_.">
      <block type="logic_compare" id=";GfrwfY$+9p-)fDhUb$^">
      <block type="variables_get" id="]b(I5apIK{$dp*qaHjv3">
      <block type="math_number" id="eKpd|+UN.Vum}MTuDzQ">
      <field name="NUM">60</field>
      <block type="update" id="bMO;21Gt^nL/r2CY@1
      t">
      <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Stunden</field>
      <block type="math_arithmetic" id="Vp#pAhCa-z%KT|(U:K+"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="j1N0n8@)2iYs00z3u#fB"> <field name="NUM">1</field> </shadow> <block type="get_value" id="+nhPP|Y:/v3J51YI:~1a"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Stunden</field> </block> </value> <value name="B"> <shadow type="math_number" id="(/_[7S|b%eWw1_/$Wu;m"> <field name="NUM">1</field> </shadow> </value> </block> </value> <next> <block type="timeouts_clearinterval" id="tB5ooe#rUd?S;~;+GFti"> <field name="NAME">Intervall22</field> <next> <block type="variables_set" id="Y3Rl?EUO8%)_wC#VErw">
      <block type="math_number" id="[kE?RAf~_i@=IdcO3N]Z">
      <field name="NUM">0</field>
      <block type="controls_if" id="8.VKm@=a-,I7-x^meO@"> <value name="IF0"> <block type="logic_compare" id="YdKP=*uUGT9TP9v@0nu{"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="r{?aRDWm3%:*uWXQ4A~Z"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Stunden</field> </block> </value> <value name="B"> <block type="math_number" id="kzoG5Gd8[tKgkneVQeuq"> <field name="NUM">23</field> </block> </value> </block> </value> <statement name="DO0"> <block type="update" id="M@/~6vePwX4_JkTwL?Y">
      <block type="math_number" id="Tt2P_gQaCts35x$$Wd[F">
      <block type="timeouts_clearinterval" id=";MzYTKH52#jlPrjTBqeF">
      <block type="variables_set" id="lXuk(/~;a7txQ=,2~vg"> <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter22</field> <value name="VALUE"> <block type="math_number" id="tb7yE@DsV#Hqa:oAA7|Q"> <field name="NUM">0</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </statement> <value name="IF1"> <block type="logic_compare" id="HZ*d)FAmc$T/gmUyaATz"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Bgj{aa~3Rhl-J_{J,JEj"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2</field> </block> </value> <value name="B"> <block type="logic_boolean" id="z=?N^mXE=#b:f;PI7M@c"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="variables_set" id="P2H;X!(CVbMKDLqv34hT"> <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter22</field> <value name="VALUE"> <block type="math_number" id="l3z)Gn0Uy?}=Te48Ai[">
      <block type="timeouts_clearinterval" id="TQ;:O)dZR;9m`8)[Ubq8">
        Tag
        <variables>
        <variable type="undefined" id="Intervall33">Intervall33</variable>
        <variable type="" id="RJX#bCFN/lLc{/ML$d(C">counter33</variable>
        </variables>
        <block type="on_ext" id="nlX!8rCV~k.;9Xm#$t0S" x="-1112" y="-1337">
        <value name="OID0">
        <value name="OID1">
        <field name="oid">vis.0.HansNOTAUS.Wasserzaehler2.Tag</field>
        <block type="timeouts_setinterval" id="@4#gh8ib?30YN]phECu"> <field name="NAME">Intervall33</field> <field name="INTERVAL">1</field> <field name="UNIT">min</field> <statement name="STATEMENT"> <block type="math_change" id="ISrC8BYmAH[I|pL+%xZ">
        <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter33</field>
        |+PyckhQDs">
        <block type="variables_get" id="]b(I5apIK{$dpqaHjv3">
        <field name="NUM">1440</field>
        t">
        <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Tag</field>
        <block type="math_arithmetic" id="Vp#pAhCa-z%KT|(U:K+"> <field name="OP">ADD</field> <value name="A"> <shadow type="math_number" id="j1N0n8@)2iYs00z3u#fB"> <field name="NUM">1</field> </shadow> <block type="get_value" id="+nhPP|Y:/v3J51YI:~1a"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2.Tag</field> </block> </value> <value name="B"> <shadow type="math_number" id="(/_[7S|b%eWw1_/$Wu;m"> <field name="NUM">1</field> </shadow> </value> </block> </value> <next> <block type="timeouts_clearinterval" id="tB5ooe#rUd?S;~;+GFti"> <field name="NAME">Intervall33</field> <next> <block type="variables_set" id="Y3Rl?EUO8%)_wC#VErw">
        <block type="controls_if" id="?mjZfBT8Xecb![V:#If#">
        <block type="logic_compare" id="IlY(^7|L^PL{#$Ef:0K7">
        <block type="get_value" id="XG{iq+Iq:-PioU+|NIg8">
        <block type="math_number" id="y
        #0BBv2lF3l1eRR|TB$">
        <field name="NUM">150</field>
        <block type="update" id="Ra[sDyz:[v~THw17*OB6">
        <block type="math_number" id=",W@U]?C~uk+N7:Z~H~Z"> <field name="NUM">0</field> </block> </value> <next> <block type="timeouts_clearinterval" id="+U[%E4VpEBy)9mDc,FtW"> <field name="NAME">Intervall33</field> <next> <block type="variables_set" id="2qecrhsfgE-R5[MWB5by"> <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter33</field> <value name="VALUE"> <block type="math_number" id="F8X}B-:T~5)nxFSE/69N"> <field name="NUM">0</field> </block> </value> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </next> </block> </next> </block> </statement> </block> </next> </block> </statement> </block> </statement> <value name="IF1"> <block type="logic_compare" id="HZ*d)FAmc$T/gmUyaATz"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="Bgj{aa~3Rhl-J_{J,JEj"> <field name="ATTR">val</field> <field name="OID">vis.0.HansNOTAUS.Wasserzaehler2</field> </block> </value> <value name="B"> <block type="logic_boolean" id="z=?N^mXE=#b:f;PI7M@c"> <field name="BOOL">FALSE</field> </block> </value> </block> </value> <statement name="DO1"> <block type="variables_set" id="P2H;X!(CVbMKDLqv34hT"> <field name="VAR" id="RJX#bCFN/lLc{/ML$d(C" variabletype="">counter33</field> <value name="VALUE"> <block type="math_number" id="l3z)Gn0Uy?}=Te48Ai[">
          Kann auch alles in ein Script
            liv-in-sky @rantanplan last edited by liv-in-sky
            @rantanplan
            hättest du mal lust, mein (mit datenpunkten anlegen) script zu testen - im script ist auch ein testmodus der alle paar minuten läuft und die stoppuhr immer wieder startet - bei mir geht es - du müßtest also nicht mal start ode stopp drücken, da dies schon im test script vorhanden ist - nur die datenpunkte überwachen und evt. ein paar performance sachen feststellen.
            stoppuhr-mit-daternanlegen.txt
            • rantanplan
              rantanplan @liv-in-sky last edited by
              @liv-in-sky sagte in Stoppuhr:
              ich habe nicht damit gerechnet, dass es gleich in die massenverarbeitung geht 🙂
              Wer die Geister ruft.....☺
              Hier mal ein kleines Beispiel wie ich das mit dem Initialieseren meine.
              Ich mache das z.B. bei meiner Heizungssteuerung so.
              Da ich jeden Raum einzeln steuer, hat das noch den Vorteil das ich die Scripte kopieren kann und nur an einer Stelle die Daten anpassen muss.
              Du brauchst dann noch eine Funktion, die am Ende die Werte der lokalen Variablen in die Datenpunkte schreibt.
                @rantanplan
                habe das mit dem berechnen teil so gemacht - nkannst ja mal kucken - bitte - aber ich denke, ich habe es verstanden
                  liv-in-sky @Schlagschatten last edited by
                  @Schlagschatten
                  zwischen unseren scripten, gibt es einen wichtigen unterschied
                  du zählst die sekunden oder minuten die ganze zeit und verbraucht die ganze zeit performance
                  meine scripte berechnen die sekunden alle z.b 30 sekunden - das spart die performance !!!!!!
                    Das Script ist wesentlich einfacher augebaut, es Zählt eigentlich nur und damit bibt es Problem. In deinem Script z.b. wandels du Datum in Rechenwerte um und halt wieder zurück. Wenn ich das richtig verstanden habe. Und wofür braucht du das Objekt Momentan?
                      Ein Zähler der nach 45min nicht mehr richtig zählt.
                        @Schlagschatten
                        dein problem im script - was ist bei einem ausfall oder neustart des iobrokers - dann ist vorbei mit zählen oder du speicherst alle deine sekunden und minuten plus ob script aktiv ist - sonst geht das nicht
                        da du keine sekunden brauchst, kannst du meine scripte auch minütlich ausführen
                          Können die Bausteine mit Sekunden im Script gelöscht werden?
                            liv-in-sky @Schlagschatten last edited by liv-in-sky
                            @Schlagschatten
                            macht keinen sinn, da die grundlage in millisekunden ist - die sog. linuxzeit - würde nicht wirklich was bringen - ich mach jetzt noch mal einen längeren test
                            momentan laufen schon 3 scripte von mir - ich sehe absolut keine laufzeitdifferenz von 45 minuten - manchmal habe ich eine (EINS) sekunden abweichung
                            vielleicht hast du noch eine alte version - des scripts
                            rantanplan 1 Reply Last reply Reply Quote 0
                              Zum Thema Neustart ist da keine Lösung vorhanden.
                              Die Frage die sich stellt, wie kommt der Pi mit all den Scripten und was man sonst noch läuft klar.
                                @Schlagschatten ich glaube nicht, das der pi bei 8 scripten die nur alle minute oder so rechnen ein großes problem hat -
                                  Missverständnis. Bei meinem Script läuft die Zeit nach 45min weg. Bei Deinen läuft die Zeit korrekt, die Zeit startet nur 10 sek später. Nimm eine Stopuhr und dein Script und starte es gleichzeitig. Der Punkt ist unwichtig, sind nur 10 sek. danach läuft es.
                                  • rantanplan
                                    Deshalb sollte man immer den ersten Beitrag aktualisieren. Und nicht irgendwo mittendrin.
                                      @rantanplan ich weiß
                                      ich wollte nach der richtigen funktion einen eigenen thread mit dem script machen
                                        Habe gerade mal nachgeschaut, die geplante Anzahl an Scripten geht auf die 30 zu. Und was man sonst noch angeschlossen hat. Was an Performance nötig ist, kann ich nicht sagen, habe mir gestern abend den RPI-Monitor-Adapter installiert und die Werte sehen noch gut aus.
                                        Auch wieviel Leistung das Script von liv-in-sky braucht, keine Vorstellung, es sieht halt nur sehr umfangreich aus. Kann halt auch letztlich weniger Rechenleistung nutzten.
                                        • rantanplan
                                          Guter Plan!
                                          Dein Anlegen von Datenpunkten scheint nicht richtig zu sein.
                                          Vom Script angelegt
                                            "user": "system.user.admin",
                                            "ts": 1558013055132,
                                            "common": {
                                              "name": "Reset",
                                              "desc": "Reset",
                                              "type": "boolean",
                                              "role": "state"
                                            "native": {},
                                            "acl": {
                                              "object": 1636,
                                              "owner": "system.user.admin",
                                              "state": 1636
                                            "_id": "javascript.0.STOPPUHR.Steuerung.Reset",
                                            "type": "state"
                                          Manuell angelegt
                                            "ts": 1558013264754,
                                            "common": {
                                              "name": "Test Objekt",
                                              "role": "",
                                              "type": "boolean",
                                              "desc": "Manuell erzeugt",
                                              "read": true,
                                              "write": true,
                                              "def": false
                                            "native": {},
                                            "acl": {
                                              "object": 1636,
                                              "state": 1636
                                            "_id": "javascript.0.STOPPUHR.Steuerung.Test_Objekt",
                                            "type": "state"
                                            @rantanplan
                                            ja habe ich geseh - sollte aber kein thema sein - ich werd aber noch versuchen, die restlichen werte hinzuzufügen - ich habe das von jmd anderem aus dessen script kopiert - dises script legt die punkte auch so an,und läuft schon über ein jahr bei mir
                                            vielleicht probleme lönnten kommen, wenn man mit sowas wie aufzählungen arbeitet - weil man dann die punkte im "raw-tab" ändern müßte
                                            12038
