    3. Entwicklung
    4. Mieleathome Adapter
    Mieleathome Adapter
      digiklopfer last edited by
      @Lenny-CB
      das schätz ich auch, warten wir mal ab was noch passiert.
      Mit was für einen Skript fragst du die Daten ab?
      Lenny.CB 1 Reply Last reply Reply Quote 0
      • Lenny.CB
        Lenny.CB Most Active @digiklopfer last edited by Lenny.CB
        @digiklopfer
        Schau mal hier...
        https://github.com/lennycb/miele
        • siggi85
          siggi85 @siggi85 last edited by
          @siggi85 sagte in Mieleathome Adapter:
          Habe endlich die Daten von Miele Developer erhalten (am 12.04 angefragt), jedoch habe ich nun folgende Fehler nachdem ich die Daten eingetragen habe.
          host.ioBroker	2019-04-29 20:21:36.092	info	Restart adapter system.adapter.mieleathome.0 because enabled
          host.ioBroker	2019-04-29 20:21:36.092	error	instance system.adapter.mieleathome.0 terminated with code 0 (OK)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at emitNone (events.js:111:20)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Object.onceWrapper (events.js:313:30)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.emit (events.js:211:7)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at emitOne (events.js:116:13)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.emit (events.js:214:7)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at emitTwo (events.js:126:13)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.mieleathome/utils/mieleathome.js:229:22)
          Caught	2019-04-29 20:21:36.092	error	by controller[0]: TypeError: this.NRefreshToken is not a function
          Der Datenpunkt "mieleathome.0.Authorization.Authorized" steht auf true.
          Habe weiterhin den Fehler. Habt ihr den auch noch? Liegt das nun an Miele oder ist was mit dem Adapter?!
            Der Fehler ist bei mir auch noch. Miele hat sich bis jetzt dazu auch nicht mehr gemeldet.
            • HomeZecke
              HomeZecke last edited by
              Ja, bei mir auch. Ich denke da wird sich erst einmal nichts tun, hat sicherlich keine hohe Priorität dei Miele..☹
              • siggi85
                Habe jetzt auch mal Miele geschrieben...
                • siggi85
                  Kurzes Statusupdate: Mailverlauf mit Miele.
                  13.5.:
                  Dear Siggi,
                  due to a server movement we’ve problems with some of our accounts.
                  May we ask you to help us finding the issue.
                  Please be so kind:
                  •      Generate a new access token
                  •      Send a new request to the API
                  •      If the failure still exist, please tell us the time of the day of your request.
                  Thank you very much for your support.
                  Kind regards
                  Miele 3rd party API Team
                  15.5.:
                  I generated a new token and send a few requests some minutes ago (7:23 my time). Same error. Do you see the requests?
                  Regards
                    bei mir läuft der Adapter wieder wie gewohnt.
                    siggi85 1 Reply Last reply Reply Quote 0
                    • siggi85
                      siggi85 @digiklopfer last edited by siggi85
                      @digiklopfer sagte in Mieleathome Adapter:
                      Bei mir sieht es auch besser aus.
                        Seb0304 last edited by
                        Keine Fehler mehr im Log beim Adapter.
                        Das script von Lenny.CB läuft auch wieder.
                        Gruß Sebastian
                          mameier1234 last edited by
                          Habt Ihr alle bei Miele nachgefragt, oder geht es einfach wieder ??
                          Beim mir läuft weder das Script noch der Adapter... immer noch Tokenrefresh is not a funktion .. oder so....
                          • siggi85
                            siggi85 @mameier1234 last edited by
                            @mameier1234 sagte in Mieleathome Adapter:
                            Lösch Mal die Datenpunkte, dann erzeugt er neue Tokens etc.
                            Ich kann nur vermuten, dass Miele was ändert hat, eine Mail dazu habe ich nicht bekommen.
                              mameier1234 @siggi85 last edited by
                              @siggi85
                              Bingo, Danke für den Tipp!
                              • siggi85
                                In welchen zyklen pollt der Adapter eigentlich? Und was bedeutet eigentlich "Active API Push" in den Einstellungen der Instanz?
                                • siggi85
                                  Der Adapter pollt anscheinend alle 10 Minuten. Könnte man das ggf. in die Instanzkonfiguration aufnehmen? Und was "Active API Push" bedeutet, weiß ich immer noch nicht. 🤔
                                  • Grizzelbee
                                    Grizzelbee Developer last edited by Grizzelbee
                                    Hallo Zusammen!
                                    leider ziemlich still geworden hier ...
                                    Ist die Entwicklung eingestellt, oder lediglich wegen Zeitmanlgel vorübergehend pausiert? 😉
                                    @hash99-0 : Vielen Dank an dich für das Erstellen dieses Adapters! Tolle Arbeit schon mal bis hier hin. Ich habe ihn quasi in letzter Minute gefunden. 10 Minuten später hätte ich begonnen einen eigenen zu schreiben.
                                    Ich habe den Adapter heute mal installiert und er läuft zumindest soweit erst einmal.
                                    Leider musste ich (wie andere vor mir auch schon) feststellen das die Miele API noch deutlich Potential nach oben hat. Die Infos, die mich am Meisten interessieren würden, sind natürlich nicht verfügbar. 😞
                                    Infos über den Status von TwinDos fehlen offenbar genau wie die über Firmwareupdates.
                                    Naja. Mal sehen, ob ich mir aus den Wasch(programm)infos selber einen TwinDos-Alarm basteln kann.
                                    Ich habe auch schon die Anregung an Miele geschickt, dass es eine gute Idee wäre in der App zu informieren, wenn eine der TwinDos-Phasen leer ist/wird. Die haben sich auch artig für die Anregung bedankt und gelobt darüber nachzudenken.
                                    Aktuell gehe ich davon aus, dass es eine gute Idee ist, wenn alle denen ein Feature/Info in der App/API fehlt das per Mail an Miele schreibt. Nur so erfahren die was ihre Kunden wollen und können die Software anpassen.
                                    @siggi85 : Active API Push ist leider noch nicht möglich oder implementiert. Soll am Ende aber dafür sorgen, dass der Adapter nicht mehr alle 10 Minuten seine updates pollt, sondern eben über Statusänderungen von der API informiert wird. Ich bin allerdings nicht sicher ob Miele dieses Feature je freischalten wird.
                                    Ich freue mich auf eine rege Diskussion...
                                    viele Grüße
                                    siggi85 alealdata 2 Replies Last reply Reply Quote 1
                                    • siggi85
                                      siggi85 @Grizzelbee last edited by
                                      @Hanjo Danke für die Info bezüglich der Active Push Funktion. Sowas hatte ich schon vermutet, hat mich nur verwundert, dass Änderungen nicht auf das Verhalten ausgewirkt haben. Aber das erklärt es natürlich. 😉
                                      • siggi85
                                        siggi85 last edited by siggi85
                                        Habt ihr auch wieder Fehler bei der Abfrage? Seit ein paar Tagen schon wieder die gleichen Fehler wie vor ein paar Wochen. 😞
                                        EDIT: Löschen vom "Authorized" und "Refresh_Token" Datenpunkt scheint das Problem erst mal gelöst zu haben. Die Fehlermeldungen im Log sind auf jeden Fall weg.
                                        M S 2 Replies Last reply Reply Quote 0
                                          mameier1234 @siggi85 last edited by mameier1234
                                          @siggi85 Bei mir dasselbe.. allerdings hat das Löschen der beiden Datenpunkte nichts gebracht..
                                          Dann nochmal die komplette Unterstrukture Authorized gelöscht.. jjetzt geht es wieder...
                                            Stormbringer @siggi85 last edited by
                                            @siggi85 ja habe ich leider auch wieder
                                            miele
                                            20
                                            144
                                            18932
