    4. Absturz iobroker.admin
      hometm last edited by
      nach dem Update von ioBroker.admin auf Version 0.5.3 (Windows 7) stürzt dieser Adapter direkt nach dem Start mit einer Exception ab.
      2015-07-01 20:21:03.669  - info: admin.0 starting. Version 0.5.3 in C:/Program Files/ioBroker/node_modules/iobroker.admin
      2015-07-01 20:21:03.695  - info: admin.0 requesting all states
      2015-07-01 20:21:03.696  - info: admin.0 requesting all objects
      2015-07-01 20:21:03.699  - info: admin.0 http server listening on port 8081
      2015-07-01 20:21:03.699  - info: admin.0 Use link "http://localhost:8081" to configure.
      2015-07-01 20:21:04.012  - info: admin.0 received all objects
      2015-07-01 20:21:04.020  - info: admin.0 received all states
      2015-07-01 20:21:19.405  - info: host.nuc ioBroker.js-controller version 0.6.6 js-controller starting
      2015-07-01 20:21:19.410  - info: host.nuc Copyright (c) 2014-2015 bluefox, hobbyquaker
      2015-07-01 20:21:19.411  - info: host.nuc hostname: nuc
      2015-07-01 20:21:19.411  - info: host.nuc ip addresses: fe80::74e5:4673:2f34:a92f 192.168.2.251
      2015-07-01 20:21:19.677  - info: inMem-states listening on port 9000
      2015-07-01 20:21:19.740  - info: inMem-objects listening on port 9001
      2015-07-01 20:21:19.818  - info: host.nuc instance system.adapter.admin.0 started with pid 4436
      2015-07-01 20:21:23.458  - info: admin.0 starting. Version 0.5.3 in C:/Program Files/ioBroker/node_modules/iobroker.admin
      2015-07-01 20:21:23.781  - info: host.nuc instance system.adapter.hm-rpc.0 started with pid 6080
      2015-07-01 20:21:23.843  - info: admin.0 received all objects
      2015-07-01 20:21:23.852  - info: admin.0 received all states
      2015-07-01 20:21:25.237  - info: hm-rpc.0 starting. Version 0.4.0 in C:/Program Files/ioBroker/node_modules/iobroker.hm-rpc
      2015-07-01 20:21:25.423  - info: hm-rpc.0 xmlrpc server is trying to listen on 192.168.2.251:2001
      2015-07-01 20:21:25.425  - info: hm-rpc.0 xmlrpc -> 192.168.2.253:2001 init ["http://192.168.2.251:2001","hm-rpc.0"]
      2015-07-01 20:21:25.446  - info: hm-rpc.0 xmlrpc <- system.listMethods ["hm-rpc.0"]
      2015-07-01 20:21:25.455  - info: hm-rpc.0 xmlrpc <- listDevices ["hm-rpc.0"]
      2015-07-01 20:21:25.462  - info: hm-rpc.0 xmlrpc -> 160 devices
      2015-07-01 20:21:25.579  - error: hm-rpc.0 Error: XML-RPC fault: type error
      2015-07-01 20:21:27.775  - info: host.nuc instance system.adapter.hm-rega.0 started with pid 5308
      2015-07-01 20:21:29.219  - info: hm-rega.0 starting. Version 0.2.2 in C:/Program Files/ioBroker/node_modules/iobroker.hm-rega
      2015-07-01 20:21:29.245  - info: hm-rega.0 subscribe hm-rpc.0.BidCoS-RF:50.PRESS_SHORT
      2015-07-01 20:21:30.501  - info: hm-rega.0 ReGaHSS 192.168.2.253 up
      2015-07-01 20:21:30.543  - info: hm-rega.0 time difference local-ccu -162s
      2015-07-01 20:21:30.589  - info: hm-rega.0 added/updated 0 favorites to enum.favorites
      2015-07-01 20:21:30.682  - info: hm-rega.0 added/updated functions to enum.functions
      2015-07-01 20:21:30.738  - info: hm-rega.0 added/updated rooms to enum.rooms
      2015-07-01 20:21:30.937  - info: hm-rega.0 got 46 programs
      2015-07-01 20:21:31.025  - info: hm-rega.0 added/updated 46 programs
      2015-07-01 20:21:31.026  - info: hm-rega.0 deleted 0 programs
      2015-07-01 20:21:31.329  - info: hm-rega.0 got 77 variables
      2015-07-01 20:21:31.544  - info: hm-rega.0 added/updated 77 variables
      2015-07-01 20:21:31.544  - info: hm-rega.0 deleted 0 variables
      2015-07-01 20:21:31.545  - info: hm-rega.0 request state values
      2015-07-01 20:21:31.766  - info: host.nuc instance system.adapter.history.0 started with pid 4644
      2015-07-01 20:21:32.065  - info: hm-rega.0 got state values
      2015-07-01 20:21:33.305  - info: history.0 starting. Version 0.1.3 in C:/Program Files/ioBroker/node_modules/iobroker.history
      2015-07-01 20:21:35.786  - info: host.nuc instance system.adapter.web.0 started with pid 2376
      2015-07-01 20:21:36.119  - error: uncaught exception: Object # <adapter>has no method 'calculatePermissions'
      2015-07-01 20:21:36.122  - error: TypeError: Object # <adapter>has no method 'calculatePermissions'
          at Namespace.initSocket (C:\Program Files\ioBroker\node_modules\iobroker.admin\admin.js:522:17)
          at Namespace.emit (events.js:95:17)
          at Namespace.emit (C:\Program Files\ioBroker\node_modules\iobroker.admin\node_modules\socket.io\lib\namespace.js:205:10)
          at C:\Program Files\ioBroker\node_modules\iobroker.admin\node_modules\socket.io\lib\namespace.js:172:14
          at process._tickCallback (node.js:442:13)</adapter></adapter>
      Ist dies ein neuer Fehler, oder gibt es hierzu bereits eine Lösung?
      Vielen Dank
      Tobias
      • Bluefox
        Bluefox last edited by
        @hometm:
        Vielen Dank
        Tobias `
        js-controller upgedated? Ich vermute nicht.
        Schreib bitte:
        cd /opt/iobroker
        ./iobroker upgrade self
        sudo reboot
          Vielen Dank Bluefox, hat funktioniert!
