    5. Hue Lampe Blinken lassen
    • dslraser
      dslraser Forum Testing Most Active @SevenUp last edited by
      @SevenUp
      mit diesen Werten funktioniert es bei mir zuverlässig (ausgiebig probiert)
      Danke nochmal an @SevenUp 👍
        <variables>
          <variable type="" id="e.5!g}F+GLL#M%]7JgZa">vorherige_Lichtwerte</variable>
          <variable type="undefined" id="Alarm">Alarm</variable>
          <variable type="" id="#-mXz|12s@TMb{7:o;u`">Alarmfarbe</variable>
          <variable type="undefined" id="vorher">vorher</variable>
        </variables>
        <block type="variables_set" id="JSh#M2]R-=+=Ilabu1#W" x="-712" y="-562">
          <field name="VAR" id="e.5!g}F+GLL#M%]7JgZa" variabletype="">vorherige_Lichtwerte</field>
            <block type="text_join" id="5JMlZ5#p?K_miTW0%b/">
              <mutation items="9"></mutation>
              <value name="ADD0">
                <block type="text" id="U]|wMur8iz=]8+1tUbt)">
                  <field name="TEXT">{"level":</field>
              <value name="ADD1">
                <block type="get_value" id="wi{WaS95nx]r{v:ilOX">
                  <field name="OID">hue.0.HueBridge.Küchenlampe.level</field>
              <value name="ADD2">
                <block type="text" id="sUEIx=x{)~s(:N/q-[%5">
                  <field name="TEXT">,"hue":</field>
              <value name="ADD3">
                <block type="get_value" id="UaKZdnsBCdmF5[Wp6#@U">
                  <field name="OID">hue.0.HueBridge.Küchenlampe.hue</field>
              <value name="ADD4">
                <block type="text" id="Mxh+uSmr[%bxf{`[C3b:">
                  <field name="TEXT">,"sat":</field>
              <value name="ADD5">
                <block type="get_value" id="4H7N6?HKWvT6?(QYt,]q">
                  <field name="OID">hue.0.HueBridge.Küchenlampe.sat</field>
              <value name="ADD6">
                <block type="text" id="H@tM2t+d@D(L/@2|cP/">
                  <field name="TEXT">,"bri":</field>
              <value name="ADD7">
                <block type="get_value" id="w-Nf$ldfIha86^H6@;es">
                  <field name="OID">hue.0.HueBridge.Küchenlampe.bri</field>
              <value name="ADD8">
                <block type="text" id="0di1b!%j8COWfdC7MOm">
                  <field name="TEXT">,"alert":"none","transitiontime":100}</field>
            <block type="timeouts_settimeout" id="t5z9IGhAM2U||A=l?oE+">
              <field name="NAME">Alarm</field>
              <field name="DELAY">100</field>
              <field name="UNIT">ms</field>
                <block type="variables_set" id="eV2nz=S+o0Qh#knfX(VX">
                  <field name="VAR" id="#-mXz|12s@TMb{7:o;u`" variabletype="">Alarmfarbe</field>
                    <block type="text" id="6=Nsu~FIZ]GOWy9RW!a~">
                      <field name="TEXT">{"level":100, "hue":0, "sat":254, "alert":"lselect", "transitiontime":0}</field>
                    <block type="control" id="EtMjm5X93)jJEYLz]Nzd">
                      <field name="OID">hue.0.HueBridge.Küchenlampe.command</field>
                        <block type="variables_get" id="ngn}]},?Md%P|OSygBYc">
                <block type="timeouts_settimeout" id="Ft#CxWl=aL97Eq/1At(.">
                  <field name="NAME">vorher</field>
                  <field name="DELAY">20</field>
                    <block type="control" id="+f@3jf3-S)##iv,qIgug">
                        <block type="variables_get" id="vQc+7P~B7!YMf=0ytWKl">
        skokarl last edited by
        Ihr Glücklichen, irgendwas ist bei mir anders.
        Also, ich hab nen aktuellen IOBroker, ne Hue Bridge, nen Hue Adapter...
        In den Objekten sind dann auch die paar Hue Objekte.
        Und dann den LED Strip im Wohnzimmer.....letztes Beispiel von Euch genommen,
        Objekte natürlich geändert.... und siehe da .... das liebe LOG ..
        hue.0 2019-05-26 13:15:45.678 error SyntaxError: Unexpected token , in JSON at position 19
        dslraser S 3 Replies Last reply Reply Quote 0
        • dslraser
          dslraser Forum Testing Most Active @skokarl last edited by
          @skokarl
          welche HUE Adapter Version ?
          Welche Pollingzeit ist eingestellt ?
          Mach mal ein Bild von den Datenpunkten des LED Stripe
          poste mal Dein Blockly als Export
            SevenUp @skokarl last edited by
            @skokarl das Problem muss aber an deinem Programm liegen 😉 LED Strip wird genau so angesteuert wie eine normale Farb-LED auch. Meinen Tipp befolgst du ja nicht. Dann ist eine Hilfe nicht einfach...
            "stell erstmal sicher, dass das von dir erzeugtes Kommando richtig ist. Gib es per Debug in die Konsole aus, kopiere es und füge es in die "Command"-Eigenschaft deiner Lampe ein. Wenn die Lampe dieses Kommando nicht übernimmt, dann ist das Kommando falsch."
            --> wie sieht das erzeugte Kommando nun den aus?
              skokarl @dslraser last edited by
              @dslraser sagte in Hue Lampe Blinken lassen:
              @skokarl
              HUE Bridge ist 1.1.0
              Polling steht auf 60 sek.
                skokarl @SevenUp last edited by
                @SevenUp sagte in Hue Lampe Blinken lassen:
                sorry, ich bin nicht soweit wie ihr,....ich muss auch verstehen was Du willst ... 😬
                  ich muss jetzt erstmal gerade für meine Schwester grillen ..... melde mich später zurück
                  • dslraser
                    @skokarl
                    ich nutze den HUE Adapter 0.6.9 (stable)
                    Die Versionen danach arbeiten anders und haben zum Teil Verzögerung.
                    Die Version von @jens-maus soll aber auch funktionieren.
                    Polling habe ich auf 5 Sekunden, schon Monate lang, keine Probleme damit.
                      @dslraser
                      dann liegt es wohl am Adapter.... glaube aber der hat sich selbst auf 1.1.0 aktualisiert
                      • dslraser
                        @skokarl sagte in Hue Lampe Blinken lassen:
                        Ohne Dein dazu tun aktualisiert der sich nicht.
                        Aber Du kannst ja einen downgrade machen.
                          @dslraser
                          oder, du aktualisierst mal 😎 ..... hat ja auch nen Grund die 1.1....
                          • dslraser
                            Ja, stimmt, hat einen Grund, die 1.1 ist BETA
                            Die ist in latest und nicht in stable
                            • dslraser
                              dslraser Forum Testing Most Active @dslraser last edited by dslraser
                              @skokarl
                              ich habe jetzt mal den hier installiert, der läuft auch.
                              https://github.com/jens-maus/ioBroker.hue.git
                              Das ist die Version 1.2.3 von @jens-maus
                              • dslraser
                                dslraser Forum Testing Most Active @skokarl last edited by dslraser
                                gerade nochmal etwas ausprobiert, genau dieser Fehler kommt, wenn der Command Befehl nicht stimmt.
                                Ich hatte eben z.B. bei
                                "alert":"lselect"
                                vergessen die " " zu setzen, also ich hatte es so
                                "alert":lselect
                                dann kommt genau so ein Fehler wie bei Dir.
                                bei mir kam
                                SyntaxError: Unexpected token l in JSON at position 21
                                  @skokarl Unter "System" gibt es einen Blockly zur Debug-Ausgabe. Füge es 2x in dein Code rein.
                                  So wie hier:
                                    skokarl @dslraser last edited by skokarl
                                    @skokarl
                                    wie kommst du auf 1.2.3 ?
                                    • Daniel Schwarz
                                      Daniel Schwarz last edited by Daniel Schwarz
                                      Hi, ich hänge mich einfach mal dran.
                                      Ich habe das script genutzt um waschmaschine fertig zu signalisieren, aber leider habe ich zwei punkte, ersten ich weiß nicht wie ich die alarmfarbe anpassen kann. und zum zweiten, ändert der das licht nach dem alarm nicht wieder auf den ursprungswert zurück, sondern lässt die lampen auf rot leuchten.
                                      wieso weshalb warum weiß ich aber leider nicht.
                                      Muss ich selbst iwelche datenpunkte erstellen ?
                                        skokarl last edited by skokarl
                                        Daniel, hier bist Du gut aufgehoben, habs auch nie hingekriegt 😁
                                        • Asgothian
                                          Asgothian Developer @Daniel Schwarz last edited by
                                          @Daniel-Schwarz
                                          Hallo
                                          ein paar Punkte vorweg:
                                          • Dein Screenshot ist sehr schwer zu erkennen - das Bild ist klein und die Schrift kaum lesbar.
                                          • Du Triggerst auf "aktualisiert", das ist m.M. nach zu oft - triggern auf "geändert" ist da besser.
                                          • Du hast einen Timeout mit 100 ms zum Setzen der Alarm-Farbe. Warum ? Du kannst die Farbe doch problemlos auch direkt setzen
                                          • Der vollständige wert von "Alarmfarbe" ist in deinem Bild nicht erkennbar
                                          • Du hast an verschiedenen Stellen Befehle mit Verzögerung ausgeführt. Bei all diesen sollte zur Sicherheit noch der "löschen falls läuft" haken gesetzt werden - schutz dagegen das der Befehl doppelt kommt.
                                          • vor dem "ausführen vorher2" sollte noch ein "anhalten timeout vorher2", um auch da eine doppelte Ausführung zu verhindern.
                                          Nun zu den Fragen:
                                          • um die Farbe zu ändern musst du im String für die Alarm-Farbe den "hue" Wert anpassen.
                                          • Des weiteren würde ich versuchen , den Befehl zum Rücksitzen des Alarms doppelt zu senden, das 2. mal mit 100 ms verzögerung - für den Fall das die Hue Bridge beim abschalten des Alarm die Farb-Anweisung nicht umsetzt.
                                          Daniel Schwarz 1 Reply Last reply Reply Quote 0
                                          • Daniel Schwarz
                                            Daniel Schwarz @Asgothian last edited by
                                            @Asgothian
                                            Ja sorry, hatte den Screenshot aufm Laptop gemacht.
                                            anbei vom PC...
                                            Der vollständige wert alarmfarbe ist dieser ... {"level":100, "hue":0, "sat":254, "alert":"lselect", "transitiontime":0}
                                            Geändert habe ich bislang noch nichts, wie gesagt, es läuft soweit.
                                            Nur das Rücksetzen der Farbe, geht leider iwie gar nicht.
                                            Ich habe zB warmweiß eingestellt, dann kommt der alarm und es blinkt rot, danach bleibt das Licht an und zwar in Rosa, als würden sich beide werte vermischen oder so.
                                            haselchen dslraser 2 Replies Last reply Reply Quote 0
                                            blockly
                                            13
                                            105
                                            15382
