    4. [Aufruf] iobroker.link Test
    • Negalein
      Negalein Global Moderator @Bluefox last edited by
      @Bluefox sagte in [Aufruf] iobroker.link Test:
      wir arbeiten an den Tool für Integratoren iobroker.link weiter.
      sind mein Node und NPM zu alt dafür?
      npm ERR! Linux 4.4.59+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.link" "--production" "--save" "--prefix" "/opt/iobroker"
      npm ERR! node v6.14.4
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      Bluefox 1 Reply Last reply Reply Quote 0
      • Bluefox
        Bluefox @Negalein last edited by
        @Negalein Eigentlich nicht.
        Hast du versucht manuell zu installieren?
        • Negalein
          Negalein Global Moderator @Bluefox last edited by Negalein
          Nein, über Admin!
          Hab jetzt endlich ein Update von Node, Nodejs und NPM gemacht.
          Link-Installation läuft gerade.
          Hat nicht funktioniert!
          Fertig mit Fehler: host.ioBroker Cannot install link
          $ ./iobroker add link --host ioBroker
          NPM version: 6.4.1
          npm install iobroker.link --production --save --prefix "/opt/iobroker" (System call)
          module.js:550 throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.link/lib/install'
          at Function.Module._resolveFilename (module.js:548:15)
          at Function.Module._load (module.js:475:25)
          at Function.Module.runMain (module.js:694:10)
          at startup (bootstrap_node.js:204:16)
          at bootstrap_node.js:625:3
          npm
          WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm
          ERR! code ELIFECYCLEnpm ERR! errno 1
          npm ERR! iobroker.link@0.4.0 postinstall: node lib/installnpm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the iobroker.link@0.4.0 postinstall script.
          npm
          ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-03-21T10_19_06_305Z-debug.log
          host.ioBroker install adapter link
          NPM version: 6.4.1
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          npm
          npm ERR!
          npm ERR!
          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          npm ERR!
          A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-03-21T10_19_54_033Z-debug.log
          NPM version: 6.4.1
          npm
          npm
          npm
          ERR! npm ERR! Failed at the iobroker.link@0.4.0 postinstall script.
          npm ERR!
          A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2019-03-21T10_20_52_680Z-debug.log
          ERROR: host.ioBroker Cannot install link
          ERROR: process exited with code 13
          • Negalein
            @Bluefox
            Hab jetzt die Logdatei vom letzten Versuch
            2019-03-21T15_50_37_621Z-debug.log
              markus-now @Bluefox last edited by
              @Bluefox ich weiß, dass es etwas spät kommt, aber ich mochte auch nur kurz erwähnen, dass es genau das ist, was ich suche und werde auf jeden fall für die absolute best Leistung von euch bezahlen.
              Koste es, was es soll und bestimmt viele andere auch.
              Spitze was ihr abliefert.👍
              • cvidal
                Gibt es momentan Probleme mit dem Adapter?
                Heute ist mir aufgefallen dass das Zertifikat abgelaufen sein soll, nur welche?
                Hier mal das Log:
                link.0 2019-05-27 04:34:42.142 error AccessClient: error getting connection requests: Error: certificate has expired
                link.0 2019-05-27 04:34:32.133 error AccessClient: certificate has expired
                  markus-now last edited by
                  Bei mir das gleiche seit gestern Mittag.
                  • N
                    nureintechniker last edited by
                    Ja. Das ist bekannt. Das Zertifikat auf dem Server ist abgelaufen. Ihr müsst nichts machen. Wird gefixt in den ersten freien 5 Minuten ;). Leider ist die Nutzerzahl dieses Services entspricht nicht ganz unseren Erwartungen, so dass er im Moment nicht die höchste Aufmerksamkeit geniesst.
                    Neuschwansteini 1 Reply Last reply Reply Quote 0
                    • Neuschwansteini
                      Neuschwansteini @nureintechniker last edited by
                      @nureintechniker
                      Es muss auch publiziert werden, sonst weiß es keiner 😉
                      • N
                        Ja. Das habe ich bereits bei gewissen Personnen auch angemeckert 🙂
                          Schade☹
                          Welche Möglichkeiten habe ich den sonst noch einen Server aus 100 km Entfernung zu konfigurieren und vis etc. zu programmieren.
                          cvidal 1 Reply Last reply Reply Quote 0
                          • cvidal
                            cvidal Forum Testing @markus-now last edited by
                            @markus-now Ich denke mal das die meisten Teamviewer nutzen.
                              markus-now @cvidal last edited by
                              @cvidal Danke für die Info,
                              kann ich den auf ein Raspberry mit ioBroker Server installieren?
                              Sorry aber habe iobroker noch nicht solange.
                              31.7k
                              79.8k
                              test
                              11
                              112
                              6742
