    4. [Aufruf] Adapter: Snips - Offline Speak2Text
      Findus last edited by
      @unltdnetworx 👍 👍 👍
      • Daniel Beiderwieden
        Daniel Beiderwieden last edited by Daniel Beiderwieden
        Moin,
        ich bin jetzt schon 2 Tage dran Snips zu installieren bzw. zum laufen zu bringen.
        IoBroker hat den Snips und den Command Adapter wie beschrieben installiert. Er wurde auch entsprechend in der Sinps Console hinzugefügt.
        Der Snips Server läuft in Proxmox in einer Debian VM.
        Das Hotword wird erkannt und per sam watch bekomme ich folgende Informationen:
        sam watch
        [17:31:25] Watching on localhost:1883 (MQTT)
        [17:31:27] [Hotword] detected on site room1, for model hey_snips
        [17:31:27] [Asr] was asked to stop listening on site room1
        [17:31:27] [Hotword] was asked to toggle itself 'off' on site room1
        [17:31:27] [Dialogue] session with id '19c5c8b4-b002-49d7-9c2e-0e6bb5453ed0' was started on site room1
        [17:31:27] [AudioServer] was asked to play a wav of 41.1 kB with id '61c42146-84bc-4820-a907-0a59dc623e5d' on site room1
        [17:31:42] [Dialogue] session with id '19c5c8b4-b002-49d7-9c2e-0e6bb5453ed0' was ended on site room1. The session was ended because one of the component didn't respond in a timely manner
        [17:31:42] [Asr] was asked to stop listening on site room1
        [17:31:42] [Hotword] was asked to toggle itself 'on' on site room1
        der Satellite wurde mit dem git Script hinzugefügt von Psychokiller..
        Sam Status gibt mir folgendes aus:
        sam status
        Connected to device localhost
        OS version ................... Debian GNU/Linux 9 (stretch)
        Installed assistant .......... MainSnips
        Language ..................... de
        Hotword ...................... hey_snips
        ASR engine ................... snips
        Status ....................... Live
        Service status:
        snips-analytics .............. (not running)
        snips-asr .................... 0.63.2 (running)
        snips-audio-server ........... 0.63.2 (running)
        snips-dialogue ............... 0.63.2 (running)
        snips-hotword ................ 0.63.2 (running)
        snips-nlu .................... 0.63.2 (running)
        snips-skill-server ........... 0.63.2 (running)
        snips-tts .................... 0.63.2 (running)
        Den Audio Server habe ich zum laufen gebracht indem ich die Soundkarte durchgeschliffen habe.
        Auf dem Satellite habe ich wie in auf dem git reposetory die entsprechen packte installiert.
        Ich verwende ein Rasb. mit ReSpeaker ohne lautsprecher derzeit.
        Daher die Frage, was läuft hier falsch? was muss ich tun, ich finde einfach keine Lösung.
        Und muss auf der VM der Skill-server laufen?
        unltdnetworx 1 Reply Last reply Reply Quote 0
        • unltdnetworx
          unltdnetworx Developer @Daniel Beiderwieden last edited by
          @Daniel-Beiderwieden
          Hi, also zum Skill-Server: Nein, der muss nicht laufen.
          Es sieht so aus, als würde er zumindest das Hotword erkennen, soweit so gut. Hast du evtl. zu früh begonnen zu sprechen? Du bekommst ja keine Feedback ohne Lautsprecher.
          Daniel Beiderwieden 1 Reply Last reply Reply Quote 0
            Daniel Beiderwieden @unltdnetworx last edited by
            @unltdnetworx habe das ganze jetzt erneut gestest und in verschiedenen Abständen gesprochen. Es kommt leider immer die selbe meldung.
            • unltdnetworx
              unltdnetworx Developer last edited by
              Ich habe das Tool noch nie verwendet, aber ich denke, dass zu viele Server auf dem Satelliten laufen. Weiter oben war schon mal das Thema. Ich glaube es müssen nur 2 auf dem Satelliten aktiv sein, auf dem Server natürlich mehr. (Skill kannst du ausmachen.)
                Bin nun noch mal die Server durch gegangen. diese wurden wohl doch mit installiert.
                Nach dem Ausschalten kommt immer noch der selbe Fehler.
                allerdings konnte ich mit dem Befehlt: sudo tail -f /var/log/syslog folgendes raus bekommen.
                May 23 17:45:14 raspberrypi snips-hotword[548]: INFO:snips_hotword_lib::audio: Audio thread for site room1 stopped.
                May 23 17:45:14 raspberrypi snips-audio-server[547]: INFO:snips_audio_portaudio      : Playing "3df58b5b-396b-4403-957b-67dd680d6818" using output "bcm2835 ALSA: IEC958/HDMI (hw:0,1)", wav spec: WavSpec { channels: 2, sample_rate: 22050, bits_per_sample: 16, sample_format: Int }
                May 23 17:45:14 raspberrypi snips-audio-server[547]: Expression 'paInvalidSampleRate' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2043
                May 23 17:45:14 raspberrypi snips-audio-server[547]: Expression 'PaAlsaStreamComponent_InitialConfigure( &self->playback, outParams, self->primeBuffers, hwParamsPlayback, &realSr )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2717
                May 23 17:45:14 raspberrypi snips-audio-server[547]: Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2838
                May 23 17:45:14 raspberrypi snips-audio-server[547]: thread 'portaudio.player' panicked at 'ERROR:snips_audio_server_hermes  : could not play "3df58b5b-396b-4403-957b-67dd680d6818"
                May 23 17:45:14 raspberrypi snips-audio-server[547]:  -> caused by: InvalidSampleRate
                May 23 17:45:14 raspberrypi snips-audio-server[547]: called `Result::unwrap()` on an `Err` value: "SendError(..)"', src/libcore/result.rs:997:5
                werde also wohl irgendwas vergessen haben zu installieren oder so. Ich werde dann mal googlen was ich vergessen habe oder hast du noch eine Idee`?
                • unltdnetworx
                  unltdnetworx Developer @Daniel Beiderwieden last edited by unltdnetworx
                  @Daniel-Beiderwieden sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                  22050
                  Sind da USB-Lautsprecher bzw. irgendwie HDMI dran? Vllt. unterstützen diese die Rate von 22050 nicht? Scheint ein Konfigurationsfehler zu sein?!
                  • Wal
                    Wal Developer last edited by
                    Auf dieser Seite steht was auf dem Server bzw. Client laufen muß. Link Text
                      Vielen Dank für die Hilfe.
                      Satellite und VM laufen nun und in IoBroker kommt auch etwas an.
                      Irgendwie scheine ich wohl undeutlich zu sprechen und bisher führt er noch keine Commands aus aber das wird noch.
                      • O
                        onlinepilot last edited by onlinepilot
                        Hallo Zusammen,
                        Auch ich hatte anfangs Schwierigkeiten mit dem Hey Snips, aber seit ich "Snips" dann mal als deutsches Wort (also nicht englisch) ausspreche, läuft die Erkennung ca. bei 80%. Ich habe eine ähnliche Konfiguration, bloß dass ich kein Proxmox, sondern vSphere verwende. Bei mir laufen die Audio-Server auf den Satelliten (RPi Zero W). Über: sudo apt install snips-hotword-model-heysnipsv4 sudo apt install snips-satellite werden sie mitinstalliert. Mit snips-watch -vvv kann man die Hotworderkennung gut nachvollziehen. Nun muss ich nur noch das mit den Befehlen über iobroker hinbekommen - ich verzweifle. Vielleicht kann mir jemand dabei einen Tipp geben, wie ich das brauchbar konfigurieren und gestalten kann. Mit dem text2command-Adapter komme ich irgendwie nicht klar.
                        Danke im Voraus
                        onlinepilot
                        unltdnetworx 2 Replies Last reply Reply Quote 0
                        • unltdnetworx
                          unltdnetworx Developer @onlinepilot last edited by
                          @onlinepilot sagte in [Aufruf] Adapter: Snips - Offline Speak2Text:
                          also nicht englisch
                          Was meinst du mit englisch? Wäre m.M.n. ja in englisch und deutsch gleich auszusprechen. Siehe auch Windows Snipping-Tool.
                          Meinst du vllt. Snipes, so wie Wesley Snipes?
                          • unltdnetworx
                            Was willst denn erreichen?
                            • unltdnetworx
                              unltdnetworx Developer @unltdnetworx last edited by unltdnetworx
                              @onlinepilot
                              Schau dir mal diesen Post an. Vllt. bringt er dich schon mal weiter.
                              • O
                                onlinepilot @unltdnetworx last edited by onlinepilot
                                @unltdnetworx said in [Aufruf] Adapter: Snips - Offline Speak2Text:
                                also nicht englisch
                                Wie man eben der englischen Aussprache mächtig ist, vielleicht ist es auch texanisches Kauderwelsch gewesen ;).
                                Das Ziel ist natürlich ein für den Alltag benutzbares System zu erhalten, vorrangig als parallele Integration zum VIS. Das bedeutet in meiner Wahrnehmung, dass ich bestehende Strukturen gern weiter nutzen würde und nicht unbedingt eine zweite, völlig anders aufzubauende Logik erarbeiten muss.
                                @onlinepilot
                                Ja, das nehme ich gern mal an. Ich schau mal, wie weit ich damit komme.
                                Danke Dir erstmal!
                                onlinepilot
                                • BluePixelHD
                                  BluePixelHD last edited by BluePixelHD
                                  Hallo Leute,
                                  ich versuch seit ein paar Wochen Snips problemlos mit dem ioBroker zum laufen zu bekommen (möchte von Googles Cloud wegkommen 😌 ), aber irgendwie klappt das nicht so gut 😕
                                  Zur Hardware:
                                  Aktuelle benutze ich für Snips einen Pi3 mit der Playstation Eye und einen zweiten Pi3 für ioBroker und etc.
                                  Jetzt zu meinen Problemen:
                                  1. Snips erkennt die gesprochenen Wörter häufig falsch (leider deutlich schlechter als Google Home und Alexa), obwohl ich viele "Geräte" über snips.0.send.inject.device hinzugefügt habe.
                                  2. Die Geräte Namen habe ich hinzugefügt: Tischlampe, Lampe eins, Lampe zwei, Lampe drei, PlayStation, Netflix, Prime Video, Spotify und YouTube.
                                    Trotzdem erkennt er alle Wörter, bis auf die Tischlampe, nicht richtig.
                                  3. Text2Command schaltet manche Geräte nicht immer in den gewünschten Zustand, obwohl es richtig eingetragen ist.
                                  4. Snips ignoriert, trotz kurzer Pause am Anfang, das erste Wort häufig und er hört oft nicht lange genug zu und weiß dann nicht, ob das Gerät ein/aus geschaltet werden soll.
                                  5. Eine Funktion, um die Mikrofone von der PS Eye lauter zu machen, gibt es glaube ich nicht, oder?
                                  Ich hoffe ihr könnt mir weiterhelfen und könnt meine Probleme nachvollziehen 😌
                                  Anbei noch ein paar Bilder, die ich gemacht habe 🤓
                                  • O
                                    Oak last edited by
                                    Moin,
                                    Ich habe zurzeit auch das Problem das Snips und Texttocommand zwar richtig erkennt, jedoch genau wie im letzten Bild trotz erkannten "false" einfach true weitergibt. Wenn Ich den Adapter neu starte tuts das das ein paar mal bis der Fehler wieder auftaucht! Gibt's dazu schon eine Lösung?
                                    unltdnetworx 1 Reply Last reply Reply Quote 1
                                    • unltdnetworx
                                      unltdnetworx Developer @BluePixelHD last edited by
                                      @BluePixelHD
                                      Hi. Es gibt meines Erachtens nach momentan zwei große Probleme. Das eine sind geeignete Mikros. Ich hab das 4-Mic-Hat und bin je nach Entfernung zum Snips-Endgerät unterschiedlich zufrieden damit. Das schwankt von Top zufrieden bis geht gar nicht.
                                      Das andere sind englische Worte. Ich habe den Eindruck, dass Snips bei eingestellter deutscher Sprache Probleme mit dem Erkennen von englischen Worten hat. Siehe z.B. bei dir YouTube, etc.
                                      Du kannst ja mal mit Sam deine Spracheingabe überwachen und sehen, was jeweils erkannt wird.
                                      Sam watch
                                      wäre der Befehl. Außerdem würde ich dir in text2command die Funktion "Steuere mit Funktion" ans Herz legen. Du musst dazu lediglich die Funktion "light" und einen Raum aus den Enums in den Objekten zuweisen.
                                      Ich werde mal versuchen eine grobe Anleitung zu schreiben, sobald ich Zeit dafür finde.
                                      • unltdnetworx
                                        da ich gebeten wurde, die Spracheingabe bei Bedarf auf die Räume zu beschränken, in denen der jeweilige Satellit steht, habe ich eine Testversion auf Github hochgeladen. Der Sinn einer solchen Funktion ist, dass z.B. bei Häusern mit vielen Zimmern die Bewohner keine fremden Räume schalten können, etwa in Hotels.
                                        Ich hatte mir das so gedacht, dass man dem Gerät über die Enumerationen (Aufzählungen) einen Raum zuweist und dann den Punkt "enforceSameRoom" auf wahr setzt.
                                        Jetzt tritt bei mir ein kurioses Phänomen auf und ich komme auf keine Lösung. Ich habe ein Testsystem, auf dem klappt das Ganze einwandfrei. Raum auf "Wohnzimmer", "enforceSameRoom" auf "true" und der Befehl "Schalte das Licht in der Küche aus" bewirkt ein "Schalte das Licht im Wohnzimmer aus".
                                        In meinem Echtsystem hingegen wird mit dem selben Satelliten der Raum auf "undefined" gesetzt und text2command meldet, dass es diesen Raum nicht gibt.
                                        Evlt. kann das mal jemand testen. Wenn das "enforceSameRoom" auf false steht, läuft der Adapter und die Befehle wieder wie gewohnt, es sollte also keine Gefahr drohen, etwas zu zerstören.
                                        Danke schon mal für eure Hilfe.
                                        • unltdnetworx
                                          unltdnetworx Developer @Oak last edited by unltdnetworx
                                          @Oak
                                          Das Problem hatte ich bisher nicht. Außer ich war zu weit weg und wurde nicht einwandfrei verstanden. Aber dann wurde der Text auch auf true statt false gesetzt. Gab es denn ein Update von text2command?
                                          Welchen Adapter startest du neu? Liefert Snips den richtigen Wert an text2command?
                                          • O
                                            Oak last edited by
                                            Guten Abend,
                                            kann mir bitte vielleicht kurz jemand erläutern wie ich Snips neue Räume beibringen kann.
                                            Die Vordefinierten Räume erkennt er ohne Problemem, wenn Ich jedoch Haustüre als Raum eingebe wird dieser nicht mehr gefunden!
                                            Vielen Dank
                                            snips
                                            43
                                            635
                                            132909
