    4. Neue Installationsroutine (für Linux)
      denjo @Homoran last edited by
      @Homoran ohh übersehen, klasse endlich läuft alles, vielen dank
        Semenchkare last edited by Semenchkare
        ich habe, seitdem ich das script ausgeführt habe, probleme mit vcard, welches bisher nie muckte.
        vcard.0	2019-03-01 07:49:47.508	error	Error reading file: EACCES: permission denied, open '.node-xmlhttprequest-sync-10671'
        vcard.0	2019-03-01 07:49:47.459	info	starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.vcard, node: v8.15.0
        host.IoBroker-Raspi	2019-03-01 07:49:46.177	info	instance system.adapter.vcard.0 started with pid 10671
        tankerkoenig.0	2019-03-01 07:49:36.198	info	Reading data from tankerkoenig ...
        host.IoBroker-Raspi	2019-03-01 07:49:16.842	info	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
        daswetter.0	2019-03-01 07:49:16.824	debug	nothing to do
        host.IoBroker-Raspi	2019-03-01 07:49:16.154	info	Restart adapter system.adapter.vcard.0 because enabled
        host.IoBroker-Raspi	2019-03-01 07:49:16.154	error	instance system.adapter.vcard.0 terminated with code 0 (OK)
        Caught	2019-03-01 07:49:16.154	error	by controller[0]: at processImmediate [as _immediateCallback] (timers.js:745:5)
        Caught	2019-03-01 07:49:16.153	error	by controller[0]: at tryOnImmediate (timers.js:768:5)
        Caught	2019-03-01 07:49:16.153	error	by controller[0]: at runCallback (timers.js:810:20)
        Caught	2019-03-01 07:49:16.153	error	by controller[0]: at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3709:38)
        Caught	2019-03-01 07:49:16.152	error	by controller[0]: at Adapter.emit (events.js:214:7)
        Caught	2019-03-01 07:49:16.152	error	by controller[0]: at emitTwo (events.js:126:13)
        Caught	2019-03-01 07:49:16.152	error	by controller[0]: at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.vcard/vcard.js:99:17)
        Caught	2019-03-01 07:49:16.152	error	by controller[0]: at performNumberString (/opt/iobroker/node_modules/iobroker.vcard/vcard.js:323:30)
        Caught	2019-03-01 07:49:16.151	error	by controller[0]: at getNameToNumber (/opt/iobroker/node_modules/iobroker.vcard/vcard.js:401:39)
        Caught	2019-03-01 07:49:16.150	error	by controller[0]: TypeError: Cannot read property 'length' of null
        ich habe die Instanz gelöscht und nochmals neu aufgespielt, kein Erfolg....
        Beim Starten der Instanz kommt irgendwie ein Zugriffsfehler auf die Datei...
        vcard.0	2019-03-01 07:58:50.799	error	Error reading file: EACCES: permission denied, open '.node-xmlhttprequest-sync-10762'
        vcard.0	2019-03-01 07:58:50.746	info	starting. Version 0.0.9 in /opt/iobroker/node_modules/iobroker.vcard, node: v8.15.0
        klicke ich den Pfad zur vcard-Datei an, kann ich sie am PC ansehen (liegt auf einem internen Web-Server, Synology.
        Kann mir jemand sagen, woran das liegen könnte?
          Gelöst!
          Das Problem ist, dass vCard erwartet, dass die Datei iobroker.vcard im Besitz vom user iobroker ist.
          was habe ich getan: die iobroker.vcard auf den pi kopiert (ins verzeichnis opt). Dort habe ich mit chown den Besitzer per sudo chown auf "iobroker" geändert.
          Voila - nach Neustart der Instanz kein Fehler mehr!
          PS: auf dem Webserver konnte ich das nicht ändern, ich hätte dort einen User "iobroker" anlegen müssen, um den Besitz von iobroker.vcard ändern zu können....
            Alexander.G @apollon77 last edited by
            @apollon77 Wollte abschließend noch berichten. Es war tatsächlich der Rock64 für die Abstürze und zerschossenen Dateien verantwortlich. Hatte mir im Land der Sonne nochmal einen bestellt. Jetzt tut er seit 3 Tagen ohne Probleme☺
            Danke für die Hilfe!
              Super und danke für die Rückmeldung!
                peer69 Forum Testing last edited by
                Habe mein Core-Produktivsystem nun mit Hilfe des Fixer-Skripts umgestellt. Das hat ohne Zwischenfälle funktioniert. Auch die SBC-Slaves konnten ohne Probleme umgestellt werden. Sogar eher anfällige Adapter (bei mir insb. YAHKA und ZWave) kamen anschließend fehlerfrei wieder hoch.
                Gute Arbeit und vielen Dank dafür! 🙂
                  jiglitsch last edited by
                  Hallo zusammen.
                  Also irgendwas scheint dich da nicht zu stimmen. Ich habe jetzt zweimal unabhängig voneinander auf zwei Geräten iobroker installiert.
                  In beiden Fällen war iobroker nicht über den Browser erreichbar. In dem Troubleshooting Beitrag habe ich dann den Hinweis gefunden, die Admin-Instanz manuell zu installieren. Das hat auch dann funktioniert... aber das kann doch nicht sein?
                  In allen Tutorials wird nur das Installationsskript ausgeführt und alles funktioniert... nur bei mir nicht.
                  Geräte: Cubitruck
                  OS: Armbian
                  • AlCalzone
                    AlCalzone Developer @jiglitsch last edited by
                    @jiglitsch Dann poste mal einen Log der Installationen sowie den Inhalt der Datei /opt/iobroker/INSTALLER_INFO.txt.
                    Außerdem die Ausgabe der folgenden Befehle:
                    node -v
                    nodejs -v
                    npm -v
                    Ggf. sieht man da schon was schief läuft.
                      Output INSTALLER_INFO:
                      Installer version: 2019-05-14
                      Installation date 2019-05-28
                      Platform: linux
                      Installed as non-root user jigl
                      init system: systemd
                      Autostart: systemd
                      ACL enabled: true
                      Platform: linux
                      Autostart: systemd
                      ACL enabled: true
                      jigl@cubietruck:~$ node -v
                      v8.16.0
                      jigl@cubietruck:~$ nodejs -v
                      v8.16.0
                      jigl@cubietruck:~$ npm -v
                      6.4.1
                      Was genau meinst du mit "Dann poste mal einen Log der Installationen".
                      Danke schonmal
                      • AlCalzone
                        @jiglitsch sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                        Die Ausgabe auf dem Bildschirm, wenn du per Skript installierst.
                        Der Rest sieht alles gut aus
                          jiglitsch last edited by jiglitsch
                          Ich hab es jetzt gerade nochmal neu installiert.
                          Diesmal hatte ich sogar (wieso auch immer) ein paar eventuell interessante outputs.:
                          jigl@cubietruck:~$ curl -sL https://iobroker.net/install.sh | bash -
                              Welcome to the ioBroker installer!
                              You might need to enter your password a couple of times.
                              Installing prerequisites (1/4)
                              Creating ioBroker user and directory (2/4)
                          Created /etc/sudoers.d/iobroker
                          Directory /opt/iobroker created
                              Installing ioBroker (3/4)
                          ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
                          ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                             data->callback.Call(2, argv);
                          In file included from ../src/./serialport.h:6:0,
                                           from ../src/serialport.cpp:1:
                          ../../nan/nan.h:1740:3: note: declared here
                             Call(int argc, v8::Local<v8::Value> argv[]) const {
                          ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
                          ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                             data->callback.Call(1, argv);
                          ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
                          ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
                          ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
                          ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
                          ../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
                          ../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
                          ../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                          ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
                          ../src/serialport_unix.cpp:166:5: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
                           int setup(int fd, OpenBaton *data) {
                          In file included from /usr/include/stdio.h:862:0,
                                           from ../src/serialport.h:3,
                                           from ../src/serialport_unix.cpp:2:
                          /usr/include/arm-linux-gnueabihf/bits/stdio2.h:65:44: note: ‘__builtin___snprintf_chk’ output 20 or more bytes (assuming 1043) into a destination of size 1024
                                  __bos (__s), __fmt, __va_arg_pack ());
                          ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
                          ../src/serialport_unix.cpp:79:6: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
                           void EIO_Open(uv_work_t* req) {
                          /usr/include/arm-linux-gnueabihf/bits/stdio2.h:65:44: note: ‘__builtin___snprintf_chk’ output 22 or more bytes (assuming 1045) into a destination of size 1024
                          ../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
                          ../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
                             obj->callback.Call(2, argv);
                          In file included from ../src/poller.cpp:1:0:
                              Finalizing installation (4/4)
                          Enabling autostart...
                          Autostart enabled!
                          Fixing directory permissions...
                              ioBroker was installed successfully
                              Open http://192.168.178.50:8081 in a browser and start configuring!
                          You need to re-login before doing anything else on the console!
                          Was zum Teufel... jetzt hat es geklappt O_o. Ich kann iobroker instant im Browser ausfrufen.
                          Das muss ich nicht verstehen.
                          Danke trotzdem 🕵
                          • AlCalzone
                            Das ist meine Aura 👻 ... passiert mir öfter 😄
                              cruunnerr last edited by
                              die links zu den Anleitungen sind defekt 😞
                              will gerade Biobroker im Proxmox Container installieren und weiß jetzt nicht welche Anleitung nun noch nutzbar ist 😕
                                Homoran Global Moderator Administrators @cruunnerr last edited by
                                @cruunnerr
                                https://doc.iobroker.net/#de/documentation/install/linux.md
                                  cruunnerr @Homoran last edited by cruunnerr
                                  @Homoran
                                  Das ging flott. Danke.
                                  SSL Zertifikat war zwar nicht ok, aber einem Admin vertrau ich gerne 🙂
                                  Eine Frage noch...
                                  Habe momentan ioBroker auf nem Server mit node V8.12.0 und npm 4.6.1 laufen.
                                  Will dann den Backup Adapter nutzen um alles wieder auf den neuen Server zu bringen auf dem ja nun node 8.16.0 und npm 6 läuft.
                                  Könnte das Probleme bringen?
                                    @cruunnerr
                                    Nö!
                                    Warum dann nicht direkt node 10?
                                    C dslraser 2 Replies Last reply Reply Quote 0
                                      @Homoran
                                      In der Anleitung stand:
                                      "Die momentan empfohlene Version ist node 8.x; mit js-controller 1.5.7 auch node 10.x, dann in Schritt 4.1. die “8.x” gegen 10.x” austauschen."
                                      Dann hab ich einfach die 8 genommen XD
                                        Homoran Global Moderator Administrators @cruunnerr last edited by Homoran
                                        @cruunnerr
                                        Dann muss ich den text mal ändern 😂
                                        Wie foch die Zeit vergeht.
                                          @Homoran sagte in Neue Installationsroutine und neue Anleitungen (für Linux-basierte Systeme):
                                          @cruunnerr
                                          War mir irgendwie grad nicht sicher, ob ich denn jetzt auch den js-controller 1.5.7 hab.
                                          bitte nicht hauen 😄
                                          • dslraser
                                            dslraser Forum Testing Most Active @Homoran last edited by
                                            @Homoran
                                            Hierr wird auch 8.16 empfohlen. Ich hatte nach dem ich das gesehen habe zwischenzeitlich sogar deswegen ein Downgrade gemacht 🙁
                                            installation
                                            64
                                            415
                                            114214
