    4. [Aufruf] fullyBrowser Adapter
    • ostseereiter
      ostseereiter @Issi last edited by
      @Issi sagte in [Aufruf] fullyBrowser Adapter:
      <block type="on" id="{EfUQy(n:93(-oC=/?~" x="63" y="88">
      <field name="OID">javascript.0.MeinTablet.Galaxy_Tab_A_2016.Sperrbildschirm</field>
      <block type="controls_if" id="m9C{!a.RmUjc|DY(a9(|">
      <block type="on_source" id="x~tcRc6R;$qQhB}
      ?C{">
      <block type="comment" id="1L^TU4E.@)=~Ov;Y(9@"> <field name="COMMENT">Sperrbildschirm aus</field> <next> <block type="request" id="JF~X9VqXim]s0o2iJOhy"> <mutation with_statement="false"></mutation> <field name="WITH_STATEMENT">FALSE</field> <field name="LOG"></field> <value name="URL"> <shadow type="text" id="]l4kV|5|OQ]Ks*Bxmjr{"> <field name="TEXT">text</field> </shadow> <block type="text" id="O#:nwn9P=.Cb}Ytu{+_">
      <field name="TEXT">http://xxx.xxx.xxx.xx:2323/?cmd=setBooleanSetting&key=forceScreenUnlock&value=true&password=xxxxxxxxxxxxx</field>
      <statement name="ELSE">
      <block type="comment" id="l(uLH%|uS)7]m{((.!^J">
      <field name="COMMENT">Sperrbildschirm an</field>
      <block type="request" id="oiiYZ,`J8V]jZ]Wd6k0l">
      <value name="URL">
      Bxmjr{">
      <block type="text" id="sHMIU.gbbNyK^X2!W?xr">
      <field name="TEXT">http://xxx.xxx.xxx.xx:2323/?cmd=setBooleanSetting&key=forceScreenUnlock&value=false&password=xxxxxxxxxxxxx</field>
      <block type="comment" id="rUbvx7=@8{y%9[{tfec$">
      <field name="COMMENT">Datenpunkt wird erstellt</field>
      <block type="procedures_callcustomnoreturn" id="8l2]F0|.wkI4Gq%DQD~">
      <mutation name="Datenpunkt erstellen"></mutation>
      <block type="procedures_defcustomnoreturn" id="D^4vwd-2
      I=:dUDrEhIo" x="63" y="588">
      <mutation statements="false"></mutation>
      <field name="NAME">Datenpunkt erstellen</field>
      <field name="SCRIPT">Y29uc3QgU3RhdGUgPSAnamF2YXNjcmlwdC4wLk1laW5UYWJsZXQuR2FsYXh5X1RhYl9BXzIwMTYnOw0KY3JlYXRlU3RhdGUoJ01laW5UYWJsZXQuR2FsYXh5X1RhYl9BXzIwMTYuU3BlcnJiaWxkc2NoaXJtJywgZmFsc2Use3R5cGU6ICJib29sZWFuIixuYW1lOiJTcGVycmJpbGRzY2hpcm0ifSk7</field>
      Danke erst mal
      Habe es installiert so wie du es beschrieben hast. dann habe ich mal den Datenpunkt auf true gesetzt da wurde was auf den Tablet angezeigt aber er ist nicht in den Sperrmodus gegangen.Mache ich was falsch?
      Issi 1 Reply Last reply Reply Quote 0
      • Issi
        Issi Developer @ostseereiter last edited by
        @ostseereiter hast du deine ip und dein PW eingetragen ?
        ostseereiter 1 Reply Last reply Reply Quote 0
        • ostseereiter
          @Issi ja alles so gemacht wie du beschrieben hast. irgendwas hat das Tablet ja beim ersten mal auch angezeigt dann leider nicht mehr.
          • Issi
            Issi Developer @ostseereiter last edited by Issi
            @ostseereiter ist das tablet vllt entsperrt wen es nämlich entsperrt ist passiert nichts wen man es so versucht zu umgehen also pin Password oder so rein machen
            • ostseereiter
              @Issi ja ist entsperrt.
              • Issi
                Issi Developer last edited by
                @ostseereiter im Fully Remote Admin solte Keyguard locked on sein
                • Issi
                  @ostseereiter sagte in [Aufruf] fullyBrowser Adapter:
                  das tablet muss gesperrt sein also mit pin oder password
                  • ostseereiter
                    @Issi
                    aber Keyguard locked on ist bei mir
                    • Issi
                      @Issi
                      dann sollte es funktionieren tut es bei mir jedes mal
                      versuche mal das in dein browser zu öffnen
                      http:// deine Ip:2323/?cmd=setBooleanSetting&key=forceScreenUnlock&value=false&password=dein pw
                      dann sollte er in den Sperrbildschirm gehen
                      • ostseereiter
                        @Issi
                        also du meinst mal sperrbildpasswort setzen
                        • ostseereiter
                          ostseereiter @ostseereiter last edited by
                          @ostseereiter
                          habe mal Pin gesetzt, aber leider auch nichts.Schade danke dir trotzdem
                          • Issi
                            @ostseereiter hmm das ist aber seltsam die ganzen app Berechtigungen hast du freigegeben oder?
                            • ostseereiter
                              Kann man das irgendwo einsehen?
                              • Issi
                                hmm bei mir funktioniert es auch ohne Berechtigungen und der fully meckert sowieso wen ihm Berechtigung fehlt also solltest du sie an haben
                                • ostseereiter
                                  Danke trotzdem.
                                  • Issi
                                    @ostseereiter hab jetzt mal auf einem meiner Tablet's die noch kein pin hatten pin eingerichtet und neu start gemacht dann Fully startet ja eh beim booten von selber und hab's dann probiert es geht man darf das tablet nicht entsperren.
                                    wenn nicht hilft dann weiß ich auch nicht mehr weiter wie gesagt bei mir funktioniert es hab nur Samsung Tablet's vllt hängt es mit dem Fire HD
                                    • ostseereiter
                                      @Issi
                                      Diese Fehlermeldung kommt :
                                      • ostseereiter
                                        @ostseereiter
                                        Ich denke jetzt auch das liegt am Fire Tablet
                                        • Issi
                                          @ostseereiter
                                          ja glaub ich auch da das script anschein funktionirt und er versucht zu entsperren
                                          • ostseereiter
                                            Danke dir dann werde ich es über die Helligkeit steuern ab uhr auf 0 und morgens wieder auf
                                            255
                                            31.7k
                                            79.8k
                                            fullybrowser fullybrowser adapter
                                            45
                                            289
                                            39917
