    4. Shelly Adapter
    SOLVED Shelly Adapter
      Rocket85 last edited by Negalein
      So langsam fehlen mir die Worte. Anbei das Log der Neuinstallation. Leider immer noch auf ROT.
      $ ./iobroker add shelly  --host raspberrypi
      NPM version: 6.5.0
      npm install iobroker.shelly --production --save --prefix "/opt/iobroker" (System call)
      host.raspberrypi install adapter shelly
      got /opt/iobroker/node_modules/iobroker.shelly/admin
      upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
      upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
      upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
      host.raspberrypi object system.adapter.shelly created
      host.raspberrypi create instance shelly
      host.raspberrypi object shelly.0.info.connection created
      host.raspberrypi object shelly.0.info created
      host.raspberrypi object system.adapter.shelly.0.outputCount created
      host.raspberrypi object system.adapter.shelly.0.inputCount created
      host.raspberrypi object system.adapter.shelly.0.uptime created
      host.raspberrypi object system.adapter.shelly.0.memRss created
      host.raspberrypi object system.adapter.shelly.0.memHeapTotal created
      host.raspberrypi object system.adapter.shelly.0.memHeapUsed created
      host.raspberrypi object system.adapter.shelly.0.connected created
      host.raspberrypi object system.adapter.shelly.0.alive created
      host.raspberrypi object system.adapter.shelly.0 created
      process exited with code 0
        apollon77 last edited by
        äääähm ... alos Stündlicher restart muss das erste * eine 0 sein ... ansonsten: warum denn überhaupt? Und auch der Default ist nur * * * * * sondern "leer" weil an sich kein Restart beim Shelly Adapter nötig ist
        Stuebi H 2 Replies Last reply Reply Quote 0
          host.raspberrypi	2019-02-12 16:59:51.548	error	instance system.adapter.shelly.0 terminated with code 0 (OK)
          host.raspberrypi	2019-02-12 16:59:50.074	info	instance system.adapter.shelly.0 started with pid 10547
          host.raspberrypi	2019-02-12 16:59:50.061	info	object change system.adapter.shelly.0
          host.raspberrypi	2019-02-12 16:59:49.979	info	Restart adapter system.adapter.shelly.0 because enabled
          host.raspberrypi	2019-02-12 16:59:49.979	error	instance system.adapter.shelly.0 terminated with code 0 (OK)
          shelly.0	2019-02-12 16:59:49.918	info	Starting shelly.0 in version 2.1.0
          shelly.0	2019-02-12 16:59:49.905	info	starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.15.0
          shelly.0	2019-02-12 16:59:49.785	debug	statesDB connected
          shelly.0	2019-02-12 16:59:49.714	debug	objectDB connected
            Auch hier: https://forum.iobroker.net/topic/17306/shelly-adapter-errors-im-log/2
              Rocket85 @apollon77 last edited by
              @apollon77
              Vielen DANK, jetzt ist der Adapter auf grün. Hoffentlich kann ich dann endlich die Shelly steuern, sobald alle gefunden wurden!
                This post is deleted!
                  @apollon77
                  Was kann ich denn noch tun, habe den Adapter nun seit einem Tag auf grün, aber leider sind in den Objekten immer noch keine Shelly`s sichtbar?
                    Hat keiner eine Idee? Es werden immer noch keine Shelly`s angezeigt!?!
                      Und die Shelly Geräte sind definitiv im gleichen Netzwerk? UDP Pakete werden weitergeleitet? Keine Repeater die Sie ggf verschlucken?
                      R H 2 Replies Last reply Reply Quote 0
                        @apollon77
                        Ja im selben Netzwerk, sie wurde ja vor der Neuinstallation auch alle angezeigt, nur leider konnte ich damals ja nicht schalten
                          Home79 @apollon77 last edited by
                          @apollon77 Hi ich habe auch ein Problem mit meinem shelly Adapter
                          welcher jede min neu starte. Hab in neu aufgesetzt und bin nicht über mqtt verbunden.
                          Du hast davon gesprochen das es Probleme geben könnte wenn einem Repeater?
                          Kannst du das erklären ? befindet sich doch aber im gleichen Netz ?
                          Was kann ich tun
                          Bei den log kommt immer der error :
                          ![alt text](Bildschirmfoto 2019-06-03 um 21.30.14.png image url)
                          instance system.adapter.shelly.0 terminated with code 156 ()
                          Stuebi 1 Reply Last reply Reply Quote 0
                          • Stuebi
                            Stuebi @Home79 last edited by
                            @Home79 , kannst du bitte den Shelly Instanz deaktivieren und dann den Shelly Adapter manuell über Kommandozeile starten. Was bekommst Du jetzt angezeigt?
                            node node_modules/iobroker.shelly/main.js --force --logs
                              Home79 last edited by Negalein
                              pi@raspberrypi:~ $ node node_modules/iobroker.shelly/main.js --force --logs
                              module.js:550
                                  throw err;
                              Error: Cannot find module '/home/pi/node_modules/iobroker.shelly/main.js'
                                  at Function.Module._resolveFilename (module.js:548:15)
                                  at Function.Module._load (module.js:475:25)
                                  at Function.Module.runMain (module.js:694:10)
                                  at startup (bootstrap_node.js:204:16)
                                  at bootstrap_node.js:625:3
                                Home79 @Stuebi last edited by Negalein
                                @Stuebi
                                module.js:550
                                    throw err;
                                  @Home79 sagte in Shelly Adapter:
                                  nimm mal
                                  node node_modules/iobroker.shelly/shelly.js --force --logs
                                    @apollon77dbc14c60-4771-4906-8a7f-386b55f01437-iobroker.2019-06-04.log.pdf iobroker.2019-06-04.log.pdf
                                      Mich interessiert was an der Kommandozeile wo du das manuell gestartet hast steht wenn Du das startest und er wieder abstürzt ...
                                        @apollon77 sorry wo finde ich das was du meinst
                                          DIe Bitte war:
                                          • Stoppe den Adaspter
                                          • Öffne eine Shell/SSH und wechsle ins ioBroker Verzeichnis
                                          • führe den genannten Befehl manuell dort aus
                                          • schicke das in der Shell ausgegebene Log mit - vor allem den Schluss wenn er wieder abstürzt
                                            Home79 @apollon77 last edited by Negalein
                                            @apollon77
                                            pi@raspberrypi:/opt/iobroker $ node node_modules/iobroker.shelly/shelly.js --force --logs
                                            starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.shelly, node: v8.16.0
                                            Schedule restart: * 1,3,5-23 * * *
                                            Stating Shelly adapter in CoAP modus.
                                            Listening for Shelly packets in the network
                                            CoAP status package received: {"3332":"SHRGBW2#662476#1","3412":38400,"3420":7936,"Uri-Path":"cit/s"} / {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}
                                            Status update received for SHRGBW2#662476#1: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}
                                            CoAP device description request for SHRGBW2#662476#1 to 192.168.178.62(0)
                                            CoAP response: {"3332":"SHRGBW2#662476#1"}
                                            Device description received: {"3332":"SHRGBW2#662476#1"} / {"blk":[{"I":1,"D":"RGBW2"}],"sen":[{"I":111,"T":"Red","R":"0/255","L":0},{"I":121,"T":"Green","R":"0/255","L":0},{"I":131,"T":"Blue","R":"0/255","L":0},{"I":141,"T":"White","R":"0/255","L":0},{"I":151,"T":"Gain","R":"0/100","L":0},{"I":161,"T":"VSwitch","R":"0/1","L":0}],"act":[{"I":211,"D":"RGBW2","L":0,"P":[{"I":2011,"T":"Red","R":"0/255"},{"I":2021,"T":"Green","R":"0/255"},{"I":2031,"T":"Blue","R":"0/255"},{"I":2041,"T":"White","R":"0/255"},{"I":2051,"T":"Gain","R":"0/100"},{"I":2061,"T":"VSwitch","R":"0/1"}]}]}
                                            Shelly device 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1) with CoAP connected!
                                            CoAP Message for SHRGBW2#662476#1 : {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}
                                            Create State : SHRGBW2#662476#1.color.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            State change : SHRGBW2#662476#1.color.Switch, Value: false for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.color.red, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            State change : SHRGBW2#662476#1.color.red, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.color.green, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            State change : SHRGBW2#662476#1.color.green, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.color.blue, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            State change : SHRGBW2#662476#1.color.blue, Value: 255 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.color.white, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            State change : SHRGBW2#662476#1.color.white, Value: 97 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.color.gain, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            State change : SHRGBW2#662476#1.color.gain, Value: 4 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.white0.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Create State : SHRGBW2#662476#1.white0.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Create State : SHRGBW2#662476#1.white1.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Create State : SHRGBW2#662476#1.white1.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Create State : SHRGBW2#662476#1.white2.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Create State : SHRGBW2#662476#1.white2.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Set state SHRGBW2#662476#1.color.AutoTimerOff, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Set state SHRGBW2#662476#1.color.AutoTimerOn, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Set state SHRGBW2#662476#1.mode, Value: "color" for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Set state SHRGBW2#662476#1.version, Value: "20190531-080138/v1.5.0-hotfix2@022ec015" for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Create State : SHRGBW2#662476#1.white3.Switch, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Create State : SHRGBW2#662476#1.white3.brightness, Payload: {"G":[[0,111,0],[0,121,0],[0,131,255],[0,141,97],[0,151,4],[0,161,0]]}for SHRGBW2#662476#1
                                            Set state SHRGBW2#662476#1.color.effect, Value: 0 for 192.168.178.62 (shellyrgbw2 / shellyrgbw2-662476 / SHRGBW2#662476#1)
                                            Scheduled restart.
                                            Closing Adapter
                                            terminating
                                            Closing Adapter
                                              Home79 @Home79 last edited by
                                              @Home79
                                              passt das so ? sorry bin nicht ganz so drin im Thema sorry
                                              6423
