    4. Update js-controller fehlgeschlagen
      Marcus1807 last edited by
      im Log vom IOBROKER habe ich folgende Meldunge bekommen:
      > host-raspberrypi 03 11:51:58.129 error startInstance system.adapter.web.0Invalid version of "js-controller". Installed "0.8.2", required ">=0.9.0
      Daraufhin habe ich damit versucht den js-controller zu aktualisieren:
       sudo npm install iobroker.js-controller
      Ergebnis:
      > iobroker.js-controller@0.9.0 install /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/setup.js setup first
      fs.js:502
        return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES, permission denied '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
          at Error (native)
          at Object.fs.openSync (fs.js:502:18)
          at Object.fs.writeFileSync (fs.js:1103:15)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:490:23
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:511:11)
          at Module._compile (module.js:460:26)
          at Object.Module._extensions..js (module.js:478:10)
          at Module.load (module.js:355:32)
          at Function.Module._load (module.js:310:12)
      npm ERR! Linux 4.1.13-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "--production"
      npm ERR! node v0.11.16
      npm ERR! npm  v2.3.0
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@0.9.0 install: `node lib/setup.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.9.0 install script 'node lib/setup.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node lib/setup.js setup first
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log</anonymous>
      Kann mir bitte jemand weiterhelfen?
      Danke Marcus
        @Marcus1807:
        Kann mir bitte jemand weiterhelfen? `
        ich wünschte ich könnte 😞
        Was ich deinem log entnehme ist, dass du noch mit debian Wheezy arbeitest und einer alten nodejs Version.
        Beides ist nicht mehr up to date.
        @Marcus1807:
        npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.js-controller" "–production"
        npm ERR! npm v2.3.0
        npm ERR! code ELIFECYCLE `
        Du müsstes auf nodejs 4.xx updaten wie hier beschrieben.
        http://www.iobroker.net/?page_id=3397&l … ion_Nodejs
        Diese Anleitung gilt aber für Jessie!
        Leider hat hier ein User damit Probleme unter Wheezy gehabt und ich kann das nicht nachvollziehen. Ich müsste mir einen RasPi freischaufeln und da eine entsprechende Konfig aufbauen 😞
        Daher kann ich dich nur bitten das Update zu versuchen.
        ggf musst du auf Jessie updaten und hier fehlt mir die Info wie.
        Rainer
          checkitout last edited by
          Hallo Marcus,
          ich hatte heute das selbe Problem … und mich auch schon ein paar Stunden damit gequält...
          durch Zufall habe ich im IoBroker- HOST das hier auf der Admin Seite gefunden..
          Ich betreibe zwar den IOBROKER auf Windows aber ich denke das Problem ist das Selbe. 1208_unbenannt.jpg
          das aktualisieren ist zwar "NOCH" fehlgeschlagen - System wehrt sich noch ;-))
          aber ich denke zumindest das es der Weg ist.
          … melde mich wenn ich es geschafft hab..
          LG Chris
            Neustart
            aktualisieren
            hat geklappt
            WIN 32 halt
            • derAuge
              derAuge last edited by
              Wenn Markus das auch hin bekommt bitte das Thema als [gelöst] kennzeichnen. (Edit erste Post)
              Jürgen
